Use of PCIe on SABRE Lite and Nitrogen6x boards
is atypical and requires the use of custom daughter
boards.
Use in U-Boot is even rarer, so this patch removes it from
the standard configuration.
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
CONFIG_BOOT_INTERNAL is not used anywhere, so let's remove it.
Add yet another OCOTP driver for this i.MX family. This time, it's a driver for
the OCOTP variant found in the i.MX23 and i.MX28. This version of OCOTP is too
different from the i.MX6 one that I could not use the mxc_ocotp.c driver without
making it into a big pile of #ifdef . This driver implements the regular fuse
command interface, but due to the IP blocks' limitation, we support only READ
and PROG functions.
When using HAB, there are additional special requirements on the placement of
U-Boot and the U-Boot SPL in memory. To fullfill these, this patch moves the
U-Boot binary a little further from the begining of the DRAM, so the HAB CST
and IVT can be placed in front of the U-Boot binary. This is necessary, since
both the U-Boot and the IVT must be contained in single CST signature. To
make things worse, the IVT must be concatenated with one more entry at it's
end, that is the length of the entire CST signature, IVT and U-Boot binary
in memory. By placing the blocks in this order -- CST, IVT, U-Boot, we can
easily align them all and then produce the length field as needed.
As for the SPL, on i.MX23/i.MX28, the SPL size is limited to 32 KiB, thus
we place the IVT at 0x8000 offset, CST right past IVT and claim the size
is correct. The HAB library accepts this setup.
Finally, to make sure the vectoring in SPL still works even after moving
the SPL from 0x0 to 0x1000, we add a small function which copies the
vectoring code and tables to 0x0. This is fine, since the vectoring code
is position independent.
Allow the boot of a device tree mainline kernel by aligning the environment
variables with other FSL boards.
Tested NFS boot of a dt 3.14-rc5 kernel.
Acked-by: Otavio Salvador <otavio@ossystems.com.br>
Gateworks Ventana is a product family based on the i.MX6. This
patch adds support for all boards in the Ventana family. Where
possible, data from the boards EEPROM is used to determine various
details about the board at runtime.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
Since the switch may be re-configured for VLAN usage in Linux (or any
other OS), lets reset the switch to its default register values upon
power-up. Otherwise network might not be available in U-Boot.
Cc: Roger Meier <r.meier@siemens.com>
Cc: Lukas Stockmann <lukas.stockmann@siemens.com>
Cc: Tom Rini <trini@ti.com>
Add Ethernet Boot support to SPL
Acked-by: Tom Rini <trini@ti.com>
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Adding support for reading cpsw 2nd mac address from efuse and pass it
to kernel via dtb which will be used in dual emac mode of cpsw.
Also adding mii command support to am335x common config.
Adding support for CPSW to AM43xx EPOS nad GP EVM which is connected
to RMII and RGMII phy respectively and enable cpsw in config.
Reviewed-by: Felipe Balbi <balbi@ti.com>
Some platforms like AM437x have different EVMs with different phy addresses,
so this patch adds support for passing phy address via cpsw plaform data.
Also renamed phy_id to phy_addr so better understanding of the code.
[trini: Update BuR am335x_igep0033 pcm051_rev3 pcm051_rev1 cm_t335
pengwyn boards]
arch/arm/cpu/armv7/config.mk
board/ti/am43xx/mux.c
include/configs/am43xx_evm.h
With this, fixup a trivial build error of get_effective_memsize needing
to be updated in the new board/freescale/p1010rdb/spl.c
Same as the previous commit.
Move sanity check to prepare1 target to avoid nasty troubles.
Before this commit, LDSCRIPT existence was not checked
when it was specified by CONFIG_SYS_LDSCRIPT.
Now LDSCRIPT existence is checked for all boards.
$(wildcard $(LDSCRIPT)) must point to the linker scripts
with absolute path.
Otherwise, make will terminate with a false error
on out-of-tree build.
u-boot binary size for Freescale mpc8536DS platforms is 512KB.
This has been reached to upper limit of the platforms and causig
linker error. So increase the u-boot binary size to 768KB.
Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
In the previous patches, we introduced the SPL/TPL fraamework.
For SD/SPI flash booting way, we introduce the SPL to enable a loader stub. The
SPL was loaded by the code from the internal on-chip ROM. The SPL initializes
the DDR according to the SPD and loads the final uboot image into DDR, then
jump to the DDR to begin execution.
For NAND booting way, the nand SPL has size limitation on some board(e.g.
P1010RDB), it can not be more than 8KB, we can call it "minimal SPL", So the
dynamic DDR driver doesn't fit into this minimum SPL. We added the TPL that is
loaded by the the minimal SPL. The TPL initializes the DDR according to the SPD
and loads the final uboot image into DDR,then jump to the DDR to begin execution.
This patch enabled SPL/TPL for P1010RDB to support starting from NAND/SD/SPI
flash with SPL framework and initializing the DDR according to SPD in the SPL/TPL.
Because the minimal SPL load the TPL to L2 SRAM and the jump to the L2 SRAM to
execute, so the section .resetvec is no longer needed.
Signed-off-by: Ying Zhang <b40530@freescale.com>
There was no enough memory for malloc in SPL booting from spi flash, so
relayout the memory in SPL: reduce the memory for global data from 16K
Bytes to 4K Bytes, save the space for malloc.
There was no enough stack in SPL, so the buffer needed in SPL is to malloc
from memory pool and to repalce the temporary variable.
1. The SPL's length of SDCARD boot has not enough,expand the SPL's
length to 128K.
2. deleted unused symbol: CONFIG_SYS_RUN_INDDR
T2081 QDS is a high-performance computing evaluation, development and
test platform supporting the T2081 QorIQ Power Architecture processor.
T2081QDS board Overview
- T2081 SoC integrating four 64-bit dual-threads e6500 cores up to 1.8GHz
- 2MB shared L2 and 512KB L3 CoreNet platform cache (CPC)
- CoreNet fabric supporting coherent and noncoherent transactions with
prioritization and bandwidth allocation
- 32-/64-bit DDR3/DDR3LP SDRAM memory controller with ECC and interleaving
- Ethernet interfaces:
- Two on-board 10M/100M/1G bps RGMII ports
- Two 10Gbps XFI with on-board SFP+ cage
- 1Gbps/2.5Gbps SGMII Riser card
- 10Gbps XAUI Riser card
- Accelerator:
- DPAA components consist of FMan, BMan, QMan, PME, DCE and SEC
- SerDes:
- 8 lanes up to 10.3125GHz
- Supports SGMII, HiGig, XFI, XAUI and Aurora debug,
- IFC:
- 512MB NOR Flash, 2GB NAND Flash, PromJet debug port and Qixis FPGA
- eSPI:
- Three SPI flash (16MB N25Q128A + 16MB EN25S64 + 512KB SST25WF040)
- USB:
- Two USB2.0 ports with internal PHY (one Type-A + one micro Type mini-AB)
- PCIe:
- Four PCI Express controllers (two PCIe 2.0 and two PCIe 3.0 with SR-IOV)
- eSDHC:
- Supports various SD/SDHC/SDXC/eMMC devices with adapter cards and
voltage translators
- I2C:
- Four I2C controllers.
- UART:
- Dual 4-pins UART serial ports
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Rajeshwari Birje <rajeshwari.s@samsung.com>
Cc: Inderpal Singh <inderpal.singh@linaro.org>
Add support for the bcm28155_ap reference board.
Signed-off-by: Darwin Rambo <drambo@broadcom.com>
Reviewed-by: Steve Rae <srae@broadcom.com>
Reviewed-by: Tim Kryger <tkryger@linaro.org>
Rework rpi_b's bootcmd (and sub-commands) to match Tegra's bootcmd as
much as possible. This will aid in a future patch which will create a
common header e.g. config_distro_bootcmd.h.
While at it, enable booting from extlinux.conf using the sysboot command.
The iteration and componentization currently makes a little more sense
for Tegra than RPi, but I'd still like to keep the two as similar as
possible. USB and networking support is coming to the RPi in due course,
and it'll all make more sense then anyway.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Commit 6789e84ecaa8f45d053084e08c381284a04abff7 (i2c, omap24xx:
convert driver to new mutlibus/mutliadapter framework) intended to
make I2C driver compatible with latest changes. It unfortunately has
had a impact on size on SPL as well. For example on SDP4430,
32032 bytes before/MLO
35416 bytes after/MLO
With this mentioned commit, MLO stops booting on SDP4430 as only 32K
is accessible for non-secure (bootloader) s/w on GP devices and the size
increase to 56K fails boot.
On the latest u-boot commit e7be18225fbea76d1f0034b224f0d1e60f07cfcf,
MLO is now at size 35592 bytes, However, I2C is not necessary for SPL
to function as we use SR_I2C for controlling the PMIC.
Disabling I2C reduces MLO to 32224 bytes which allows
OMAP4 GP platform to boot up.
Since this is common for all OMAP4 platforms, remove the need for I2C
for SPL builds in the common config.
Signed-off-by: Nishanth Menon <nm@ti.com>
Reviewed-by: Sricharan R <r.sricharan@ti.com>
With CONFIG_SYS_BOOTMAPSZ defined, recent Linux kernel booting
results in this error:
Booting using the fdt blob at 0x81f00000
Loading Kernel Image ... OK
ERROR: Failed to allocate 0x1189d bytes below 0x80004000.
device tree - allocation error
FDT creation failed! hanging...### ERROR ### Please RESET the board ###
Removing this define solves this issue.
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Patch allows to load a script at the startup from MMC.
Patch contains the same fixes as commit
4b9b2c300a23ca4a85811918dc92e822a9571a87
(missing CONFIG_OMAP3_GPIO_2) and commit
f9095aac793aa8917ab9b915c5d449e6dc8d3d30 (missing CONFIG_SPL_NAND_SOFTECC).
Same issues are relevant for the mcx board, too.
Patch f33b9bd3
[arm: omap3: Enable clocks for peripherals only if they are used]
breaks SPL booting on tao3530. Since some gpio input's are
read to detect the board revision. But with this patch above, the
clocks to the GPIO subsystems are not enabled per default any more.
The GPIO banks need to be configured specifically now.
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Adds support for Bernecker & Rainer Industrieelektronik GmbH KWB
Motherboard, using TI's AM3352 SoC.
Most of code is derived from TI's AM335x_EVM
Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
Cc: trini@ti.com
Adds support for Bernecker & Rainer Industrieelektronik GmbH T-Series
This patch add support for the Silica Pengwyn board [1]
The board is based on a TI AM3354 CPU [2]
All jumpers removed it will boot from the SDcard, the console is on
UART1 accessible via the FDTI -> USB. The on board NAND flash is
supported and can act as boot medium, depending on jumper settings.
USB Host, USB Device and Ethernet are also provided but untested.
[1]
http://www.silica.com/product/silica-pengwyn-board.html
[2]
http://www.ti.com/product/am3354
Signed-off-by: Lothar Felten <lothar.felten@gmail.com>
[trini: Move CONFIG_BOARD_LATE_INIT into am335x_evm.h, drop unused
spi0_pin_mux from Pengwyn support]
The Pi has no flash to store an environment in the usual fashion. However,
the user may wish to customize the environment. We know that the SD card
must be present, since that's where the boot ROM has loaded U-Boot from.
So, load uEnv.txt from there early during boot. This allows the user to
e.g. customize boot_targets, in order to automatically select network
boot.
Modify the rpi_b board to include the "distro defaults" header, so that
all the config options distros expect are enabled. Remove any #defines
that enable the same options from the rpi_b.h.
Proper spelling of the boad marketing name is with upper case.
So changing it from lower case to upper case here.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Makefile
drivers/net/npe/Makefile
These two conflicts arise from commit 0b2d3f20
("ARM: NET: Remove the IXP NPE ethernet driver") and are
resolved by deleting the drivers/net/npe/Makefile file
and removing the CONFIG_IXP4XX_NPE line from Makefile.
Having CONFIG_SYS_I2C_BASE requires DW I2C driver to explicitly include
<arch/hardware.h> which other platforms may not have at all.
It's always good to have a driver platform-independent.
Cc: Stefan Roese <sr@denx.de>
Cc: Vipin Kumar <vipin.kumar@st.com>
Cc: Armando Visconti <armando.visconti@st.com>
Initialize the second i2c controller.
Signed-off-by: Michael Burr <michael.burr@logicpd.com>
CONFIG_SYS_GBL_DATA_SIZE is not used any more.
The size of struct "global_data" is automatically calculated
by asm-offsets. (See lib/asm-offsets.c)
GENERATED_GBL_DATA_SIZE should be used instead of
CONFIG_SYS_GBL_DATA_SIZE.
This commit removes platform CONFIG_SYS_HZ definition for the
remainders of part1 (commit cdb23792) and part2 (commit f232950f).
Cc: Rob Herring <rob.herring@calxeda.com>
Commit af5b9b1f removed mini2440 board support,
but missed to delete include/configs/mini2440.h.
Since the generic ls command no longer segfaults sandbox, enable it.
SPL is using ps7_init.c/h files which are generated
from design tools which have to be copied to
boards/xilinx/zynq folder before compilation.
BSS section is moved to SDRAM because fat support
requires more space than SRAM size.
Added:
- MMC and QSPI support
- Boot OS directly from SPL
- Enable SPL command
Reviewed-by: Tom Rini <trini@ti.com>
