The ml300 board has a number of issues, but nobody cares about this
long-orphaned board any more. Remove it.
Acked-by: Michal Simek <monstr@monstr.eu>
The soft-i2c code for AT91 defines I2C_SOFT_DECLARATIONS
for direct access by dereferencing a pio pointer.
The OTC570 platform uses the AT91 gpio API so it does not
need the pio variable.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
I executed 'find . -name "*.[chS]" -perm 755 -exec chmod 644 {} \;'
Signed-off-by: Thomas Weber <swirl@gmx.li>
Add some more: neither Makefile nor config.mk need execute permissions.
Coding style cleanup, update CHANGELOG.
This code has compile problems and the company does not even exist any
more. So we take the liberty to drop support for it.
Signed-off-by: Detlev Zundel <dzu@denx.de>
CC: Wolfgang Denk <wd@denx.de>
CC: Ben Warren <biggerbadderben@gmail.com>
The 36-bit build exceeds the 512k size we have. Removing FIT type image
support allows us to fit and we dont really use it.
Also enable support for CONFIG_HWCONFIG because we use this for
configuring if this hardware has a FEC or not.
syntax:
hwconfig=fec:on if hardware has an fec
hwconfig=fec:off if hardware has no fec
* convert otc570 board to use c stucture SoC access
* change gpio access to at91_gpio syntax
Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
Add support for the ARM part of the mgcoge2, named suen3.
This board is based on the Marvell Kirkwood (88F6281) SoC.
As there come more board variants, common config options
are collected in include/configs/km_arm.h. Also, this board
use common code for all keymile boards, which is stored in
board/keymile/common/common.c
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
This is an i.MX25 base board with only NAND
so it uses nand_spl to boot.
Signed-off-by: John Rigby <jcrigby@gmail.com>
Tune configuration, add support for (redundant) environment in NAND.
Acked-by: Wolfgang Denk <wd@denx.de>
CC: Fred Fan <fanyefeng@gmail.com>
CC: Tom <Tom.Rix@windriver.com>
The patch adds initial support for the Freescale mx51evk board.
Network (FEC) and SD controller (fsl_esdhc) are supported.
Signed-off-by: Fred Fan <fanyefeng@gmail.com>
Configuration defines should be preceeded with CONFIG_SYS_. Renamed
some at91 specific defines to conform to this naming convention:
AT91_CPU_NAME to CONFIG_SYS_AT91_CPU_NAME
AT91_MAIN_CLOCK to CONFIG_SYS_AT91_MAIN_CLOCK
Signed-off-by: Achim Ehrlich <aehrlich@taskit.de>
Reindent configuration header to limit line lenght to 80 characters by
removing obvious and sometimes misleading comments.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Limit line length to 80 characters mostly by removing obvious and sometimes
misleading comments. Fix indentation, too.
Adds support for ethernet networking on the da830evm platform.
This platform uses an SoC EMAC interface and a 3 port ethernet
switch as a PHY with an RMII interface. The PHY also has a i2c
interface for configuring the switch functions.
Signed-off-by: Nick Thompson <nick.thompson@ge.com>
Recent kernels are using generic NAND and NOR drivers. Change
default mtdparts to reflect it.
Correct switching partitions after upgrade and make it more readable.
commit 98d92d8c9f4021629a45261ad5ec3f3595f3a27a "sbc8349: fix incorrect
comment" missed this one.
and avoid e.g., two identical boards from causing random networking
conflicts when hooked up to the same network.
* new board (eb_cpux9k2)
* support for EB+CPUx9K2 board by BuS Elektronik GmbH & Co. KG
* select via make eb_cpux9k2_config
* this also demonstrates, how to use boards with AT91RM9200 cpu
in at91 arch tree
Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
* convert at91sam9263ek board to use c stucture SoC access
* add a real AT91 GPIO driver instead of header inline code
* resolve the mixing of port and pins
* change board config files to use new driver
* add macros to gpio to realize backward compatibility
* add's the new temporary CONFIG_AT91_LEGACY to all board configs
This will need for backward compatiblity, while change the SoC access
to c structures. If CONFIG_AT91_LEGACY is defined, the deprecated
SoC is used.
The EVM UI extender card has a NAND device. This change will enable
saveenv to work with NAND and Linux to be booted using:
mtdparts default
nboot kernel
bootm
Added support for the following EDB93xx boards:
EDB9301
EDB9302
EDB9302A
EDB9307
EDB9307A
EDB93012
EDB9315
EDB9315A
Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
This patch removes "CONFIG_CMD_JFFS" from the board config
Every omap3 board config file declared the global variable gpmc_cfg.
This changes moves the declaration to a better location in the
arch dependent header file cpu.h.
Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
This patch adds support for esd gmbh OTC570 board.
The OTC570 is based on an Atmel AT91SAM9263 SoC.
Add support for musb host on DM365 EVM.
Signed-off-by: Prathap Srinivas <msprathap@ti.com>
This patch fixes building for AR405 boards by remove an unused feature.
Remove some unused features and default environment variable
to shrink the PMC440 u-boot.
* add's at91_emac (AT91RM9200) network driver (NET_MULTI api)
* enable driver with CONFIG_DRIVER_AT91EMAC
* generic PHY initialization
* modify AT91RM9200 boards to use NET_MULTI driver
* the drivers has been tested with LXT971 Phy and DM9161 Phy at
MII and RMII interface
There's no sensible reason to unite speed and interface type into
one variable. So split this variable enet_interface into two
vars: enet_interface_type, which hold the interface type and speed.
Also: add the possibility for switching between 10 and 100 MBit
interfaces on the fly, when running in FAST_ETH mode.
This patch add nand boot support for MPC8569mds board.
Signed-off-by: Liu Yu <yu.liu@freescale.com>
- delete double MTDIDS_DEFAULT and MTDPARTS_DEFAULT
defines in board config file.
- add mising CONFIG_KM_UBI_PARTITION_NAME define
Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com>
Normally the processor clock has a divisor of 2.
In some cases this this needs to be set to 4.
Check the user has set environment mdiv to 4 to change the divisor.
SPEAr320 SoC support contains basic spear320 support along with the
usage of following drivers
- serial driver(UART)
- i2c driver
- smi driver
- nand driver(FSMC)
- usbd driver
- emi driver(cfi support)
Signed-off-by: Vipin <vipin.kumar@st.com>
SPEAr310 SoC support contains basic spear310 support along with the
- i2c driver
- smi driver
- nand driver(FSMC)
- usbd driver
SPEAr300 SoC support contains basic spear300 support along with the
- i2c driver
- smi driver
- nand driver(FSMC)
- usbd driver
SPEAr600 SoC support contains basic spear600 support along with the
- i2c driver
- smi driver
- nand driver(FSMC)
- usbd driver
Because of v7_flush_dcache_all is moved to omap3/cache.S
and s5pc110 needs cache routines, update s5pc1xx cache routines.
l2_cache_enable and l2_caceh_disable are moved from cache.c to cache.S
and invalidate_dcache is modified for SoC specific.
A newer CPLD version on the 405EX evaluation board requires a different
EBC controller setup for the CPLD register access. This patch adds a CPLD
version detection for Kilauea and code to reconfigure the EBC controller
(chip select 2) for the old CPLD if no new version is found.
Additionally the CPLD version is printed upon bootup:
Board: Kilauea - AMCC PPC405EX Evaluation Board (CPLD rev. 0)
Cc: Zhang Bao Quan <bqzhang@udtech.com.cn>
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
