The ethernet hang is caused by receiving buffer in DRAM is not
yet ready due to access cycles require longer time in DRAM.
Relocate DMA buffer descriptors from DRAM to internal SRAM.
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
All the 85xx and 86xx UM describe the register as timing_cfg_3
not as ext_refrec.
LWMON5 DSPIC POST uses the watch-dog scratch register. So, make
the CFG_DSPIC_TEST_ADDR definition more readable.
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Arithmetic expressions do not get evaluated under stringification. Remove
default network configuration, add DHCP command support. Thanks to Felix
Radensky for reporting.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Since we didn't want to remove features from the configuration, we
decided to increase the U-Boot image size (add one flash sector).
Also changed the default environment definition to make it
independent of such changes.
This patch enables SPI and MC13783/RTC support for the Litekit board.
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
This patch removes the unknown flash message information:
'## Unknown FLASH on Bank 1 - Size = 0xdeadbeef = -286261248 MB'
This unknown flash message is caused by PromJet.
Some of the board user is unhappy with this information.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
this seems as a good compromise between human memory, typing,
and last but not least, to accommodate for current and future kernel bloat.
Acked-by: Dave Liu <daveliu@freescale.com>
introduced with latest lwmon5/POST merge
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Use the GPT0_MASKx registers as the temporary storage for watch-dog
timer POST test instead of GPT0_COMPx. The latter
(GPT0_COMP1..GPT0_COMP5) are used for the log-buffer header.
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
common/cmd_bootm.c
common/cmd_log.c
include/common.h
post/board/lwmon5/Makefile
post/board/lwmon5/dsp.c
post/board/lwmon5/dspic.c
post/board/lwmon5/fpga.c
post/board/lwmon5/gdc.c
post/board/lwmon5/sysmon.c
post/board/lwmon5/watchdog.c
Signed-off-by: Detlev Zundel <dzu@denx.de>
CONFIG_ENV_OVERWRITE is also added.
This patch is originally created by Jean-Christophe PLAGNIOL-VILLARD.
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
No functional change.
This patch was originally submitted by Jean-Christophe PLAGNIOL-VILLARD.
Then I re-created from scratch, and changed more lines than the original.
Use symbolic names instead of hard coded addresses for Litekit membases.
Update MX31ADS default environment to better match the flash layout and
the memory map, support SPI and RTC.
Limit the rate of h/w watch-dog triggering on the LWMON5 board by
the CONFIG_WD_MAX_RATE value.
Note that an earlier version of this patch which used microseconds
instead of ticks dis not work. The problem was that we used
usec2ticks() to convert microseconds into ticks. usec2ticks() uses
get_tbclk(), which in turn calls get_sys_info(). It turns out that
this function does a lot of prolonged operations (like divisions)
which take too much time so we do not trigger the watchdog in time,
and it resets the system.
This patch fixes the Canyonlands and Glacier default environment to better
fit to the arch/powerpc device-tree kernels. The variables dealing with
arch/ppc booting are removed, since these boards are supported only in
arch/powerpc. Glacier uses the same config file as Canyonlands.
Also, the Glacier now uses non-FPU rootpath, since 460GT has no FPU.
- enable esd's auto_update mechanism
- support alternative flash layout on rev. 1.8 boards
- update default environment
- use common CFI flash driver
- coding style cleanup
This patch allows U-Boot to use buffered writes to the Spansion NOR
flash installed on this board, and eliminates long delays in network
transfers after the board startup.
Also modify flash layout to embed main and redundant environment
blocks in the U-Boot image.
This patch adds support for the MX31ADS evaluation board from Freescale,
initialization code is copied from RedBoot sources, also provided by
Freescale.
Correct the name of the i.MX31 Litekit and phyCORE boards in config files.
The latter name with 13 users is already established, so we will use
that.
Signed-off-by: Sascha Laue <sascha.laue@liebherr.com>
Replace direct register address derefencing with accessor functions.
Restrict explicitly 32-bit bus-width, extend affected configurations
respectively.
This patch is based on the port by Mihai Georgian (see linkstation.c for
Copyright information) and implements support for LinkStation / KuroBox HD
and HG PPC models from Buffalo Technology, whereby HD is deactivated at
the moment, pending network driver fixing.
Notice to users: this is pretty much a barebone port. Support for network
on HG models is already in the U-Boot mainline, but you might also want
patches to switch fan / phy modes depending on the negotiated ethernet
parameters. This patch also doesn't support console switching, booting EM
mode, Buffalo specific ext2 magic number. So, if you want to use any of
those, you need additional patches. Otherwise this patche provides a fully
functional u-boot with a network console on your system.
Replace CONFIG_8xx and CONFIG_MCF532x to CONFIG_MII_INIT in
cmd_init.c. Add CONFIG_MII_INIT to board configuration files
that use mii_init() in cmd_init.c.
Acked-by: Ben Warren <biggerbadderben@gmail.com>
Remove test for CONFIG_MPC5200 in drivers/pci/pci_auto.c and define
CONFIG_PCIAUTO_SKIP_HOST_BRIDGE in related board configuration files.
This patch adds support for the Phytec Phycore-i.MX31 board
This patch adds support for the mx31 litekit board
Currently the SATA controller clock is configured as CSB clock,
usually the CSB clock is 400/333/266MHz.
However, The SATA IP block is only guaranteed to operate up to
200 MHz as stated in the HW spec.
The bug is reported by Joe D'Abbraccio <ljd015@freescale.com>
This patch makes the SATA clock as half of CSB clock.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Reverting became necessary after it turned out that the patches in
the u-boot-arm repo were modified, and in some cases corrupted.
This reverts the following commits:
066bebd6353e33af3adefc3404560871699e9961
7a837b7310166ae8fc8b8d66d7ef01b60a80f9d6
c88ae20580b2b01487b4cdcc8b2a113f551aee36
a147e56f03871bba4f05058d5e04ce7deb010b04
d6674e0e2a6a1f033945f78838566210d3f28c95
8c8463cce44d849e37744749b32d38e1dfb12e50
c98b47ad24b2d91f41c09a3d62d7f70ad84f4b7d
8bf69d81782619187933a605f1a95ee1d069478d
8c16cb0d3b971f46fbe77c072664c0f2dcd4471d
a574a73852a527779234e73e17e7597fd8128882
1377b5583a48021d983e1fd565f7d40c89e84d63
1704dc20917b4f71e373e2c888497ee666d40380
