2006-02-24 | Merge with /home/wd/git/u-boot/testing-NAND/ to add new NAND handling. | Bartlomiej Sieka | |
2006-02-07 | Update default environment for INKA4x00 board. | Wolfgang Denk | |
2006-01-18 | Add VGA support (CT69000) to CPCI750 board. | Stefan Roese | |
Insert missing __le32_to_cpu() for filesize in ext2fs_read_file(). Patch by Reinhard Arlt, 30 Dec 2005 | |||
2006-01-18 | PMC405 and CPCI405: Moved configuration of pci resources into config file. | Stefan Roese | |
PMC405 and CPCI2DP: Added firmware download and booting via pci. Patch by Matthias Fuchs, 20 Dec 2005 | |||
2006-01-13 | Fix 28F256J3A support on PM520 board | Wolfgang Denk | |
(without bank-switching only 32 MB can be accessed) | |||
2005-12-29 | Add support for 28F256J3A flah (=> 64 MB) on PM520 board | Wolfgang Denk | |
2005-12-06 | Change port configuration for O2DNT (CODEC1 on PSC1) | Marian Balakowicz | |
2005-12-04 | Code cleanup, especially MIPS for GCC 4.x | Wolfgang Denk | |
2005-12-01 | Merge with /home/sr/git/u-boot | Wolfgang Denk | |
2005-12-01 | Adjust TQM834x PHY addresses for latest hardware revision. | Wolfgang Denk | |
2005-12-01 | Increase malloc arena on TQM5200 board to 256 kB. | Wolfgang Denk | |
With 64 kb uniform flash sector size the old value of 128 kB was too small. | |||
2005-11-30 | Add support for TQM8541/8555 boards, TQM85xx support reworked: | Stefan Roese | |
- Support for TQM8541/8555 boards added. - Complete rework of TQM8540/8560 support. - Common TQM85xx code now supports all current TQM85xx platforms (TQM8540/8541/8555/8560). - DDR SDRAM size detection added. - CAS latency default values can be overwritten by setting "serial#" to e.g. "ABC0001 casl=25" -> CAS latency 2.5 will be used. If problems are detected with this non default CAS latency, the defualt values will be used instead. - FLASH size detection added. - Moved FCC ethernet driver initialization behind TSEC driver init -> TSEC is first device. Patch by Stefan Roese, 30 Nov 2005 | |||
2005-11-29 | Add support for AMCC 440SP, add support for AMCC Luan 440SP eval board. | Stefan Roese | |
Patch by John Otken, 23 Nov 2005 | |||
2005-11-27 | Increase IPB and PCI clocks for O2DNT board. | Marian Balakowicz | |
2005-11-27 | Changed PPC44x startup message (cpu info, speed...) to common style: | Stefan Roese | |
On PPC44x platforms, the startup message generated in "cpu.c" only comprised the ppc type and revision but not additional informations like speed etc. Those speed infos where printed in the board specific code. This new implementation now prints all CPU infos in the common cpu specific code. No board specific code is needed anymore and therefore removed from all current 44x implementations. Patch by Stefan Roese, 27 Nov 2005 | |||
2005-11-22 | Add support for Prodrive P3P440 board: | Stefan Roese | |
- Added onboard PPC440 DDR autodetection in cpu/ppc/sdram.c - CFG_FLASH_QUIET_TEST added to use the common CFI driver for bank autodetection Patch by Stefan Roese, 22 Nov 2005 | |||
2005-11-20 | Change all '$(...)' variable references into '${...}' | Wolfgang Denk | |
which makes the environment compatible with the hush shell. WARNING: Support for the old '$(...)' syntax will be discontinued in a later version. | |||
2005-11-15 | Merge with /server/home/stefan/git/u-boot/bamboo-sdram | Stefan Roese | |
2005-11-15 | Fix Bamboo DDR SDRAM initialization (problem with onboard SDRAM) | Stefan Roese | |
Patch by Stefan Roese, 15 Nov 2005 | |||
2005-11-15 | New PPC 405EP board added: CMS700 | Stefan Roese | |
Added CONFIG_NET_MULTI for VOM405 board. Added reset_phy() for VOM405 board. Patch by Matthias Fuchs, 09 Nov 2005 | |||
2005-11-08 | Updated PCI mapping for esd CPCI2DP board. | Stefan Roese | |
Add support for error LED. Patch by Matthias Fuchs, 07 Nov 2005 | |||
2005-11-03 | Adjust TQM85x PHY addresses for latest hardware revision. | Wolfgang Denk | |
2005-10-29 | Merge with /home/m8/git/u-boot | Wolfgang Denk | |
2005-10-28 | Add support for multiple PHYs. | Marian Balakowicz | |
2005-10-21 | Merge with /home/wd/git/u-boot/master | Wolfgang Denk | |
2005-10-20 | Add NetConsole Support for AMCC eval boards | Stefan Roese | |
Patch by Stefan Roese, 20 Oct 2005 | |||
2005-10-17 | Add PCI support for the TQM834x board. | Rafal Jaworowski | |
2005-10-17 | Merge with /home/sr/git/u-boot | Wolfgang Denk | |
2005-10-15 | Merge with /home/m8/git/u-boot | Wolfgang Denk | |
2005-10-14 | Add fat & ext2 support to AMCC 440EP boards Yosemite & Bamboo | Stefan Roese | |
Patch by Stefan Roese, 14 Oct 2005 | |||
2005-10-13 | Merge with /home/sr/git/u-boot | Wolfgang Denk | |
2005-10-13 | Add support for OF flat tree for the STXtc board. | Wolfgang Denk | |
Patch by Pantelis Antoniou, 04 Sep 2005 | |||
2005-10-13 | Support passing of OF flat trees to the kernel. | Wolfgang Denk | |
2005-10-12 | Fix TQM834x config file, set correct value for CFG_IMMRBAR. | Marian Balakowicz | |
2005-10-11 | Added support for TQM834x boards. | Marian Balakowicz | |
2005-10-09 | Add support for NetSilicon NS7520 processor. | Wolfgang Denk | |
Patch by Art Shipkowski, 12 May 2005 Cleanup. | |||
2005-10-09 | Add support for AP1000 board. | Wolfgang Denk | |
Patch by James MacAulay, 07 Oct 2005 | |||
2005-10-08 | Fix gzip bmp support (test if malloc fails, warning when truncated). | Stefan Roese | |
Increase CFG_VIDEO_LOGO_MAX_SIZE on HH405 board. Patch by Stefan Roese, 08 Oct 2005 | |||
2005-10-06 | Add JFFS2 support for TRAB board | Wolfgang Denk | |
Patch by Martin Krause, 25 Aug 2005 | |||
2005-10-06 | Fix the machine-id of the Cogent csb637 board | Wolfgang Denk | |
Patch by Anders Larsen, 05 Oct 2005 | |||
2005-10-06 | Complete support for the KwikByte KB920x boards | Wolfgang Denk | |
2005-10-05 | Add support for Cogent csb637 | Wolfgang Denk | |
Patch by Anders Larsen, 29 Apr 2005 | |||
2005-10-05 | Fix device partition intialization for SystemACE disks. | Wolfgang Denk | |
Patch by Stephen Williams, 28 Apr 2005 | |||
2005-10-05 | Added support for KwikByte KB920x boards (based on AT91RM9200) | Wolfgang Denk | |
Patch by Matt ?? <kb9200_dev@kwikbyte.com>, 27 Apr 2005 | |||
2005-10-04 | Update ARM Integrator boards: | Wolfgang Denk | |
Correct addessing errors in platform files. Split off common core module data from Integrator header files to include/armcoremodule.h. Patch by Peter Pearse, 04 Oct 2005 | |||
2005-09-30 | Fix problem with SM501 init on HH405 board. | Stefan Roese | |
Patch by Stefan Roese, 30 Sep 2005 | |||
2005-09-29 | Fix FEC PHY addresses for TQM85xx boards | Wolfgang Denk | |
2005-09-26 | Undo change of f6e20fc6ca... to include/configs/trab.h | Wolfgang Denk | |
(Must have been an accident?) | |||
2005-09-26 | Add support for AT91RM9200 OHCI Controller. | Wolfgang Denk | |
Patch by Eric Benard, 07 Apr 2005 | |||
2005-09-26 | Add support for MP2USB board. | Wolfgang Denk | |
