Currently PLL1_SYSCLK3 clock is being configured to 88MHz but the latest
OMAP-L138 data sheet (http://www.ti.com/lit/ds/symlink/omap-l138.pdf)
restricts this frequency to maximum of 75MHz. This patch modifies the
PLL divider and configures PLL1_SYSCLK3 to 66MHz.
Signed-off-by: Rajashekhara, Sudhakar <sudhakar.raj@ti.com>
add a entry for NAND configuration in boards.cfg.
This config can directly be used to build for NAND boot mode.
Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com>
Signed-off-by: Manjunathappa, Prakash <prakash.pm@ti.com>
This patch adds support for direct NOR boot mode on
da850/omap-l138. Added da850evm_direct_nor entry in
boards.cfg to allow to build targets.
Signed-off-by: Hadli, Manjunath <manjunath.hadli@ti.com>
This patch adds configuration required for NAND SP
on DA850/OMAP-L138.
DA850/OMAP-L138 does not support strict MMC/SD boot mode. SPL will
be in SPI flash and U-Boot image will be in MMC/SD card. SPL will
do the low level initialization and then loads the u-boot image
from MMC/SD card.
Define CONFIG_SPL_MMC_LOAD macro in the DA850/OMAP-L138
configuration file to enable this feature.
define SPI specific configs for SPL only when CONFIG_USE_SPIFLASH
config is defined
On Logic PD Rev.3 DA850/OMAP-L138 EVM, NOR and MMC/SD cannot
work together. This patch enables the MMC/SD support only
when NOR support is disabled. NOR Flash identification works
even without this patch, but erase and write will have issues.
This patch adds support for MMC/SD on DA850/OMAP-L138.
Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
When calling board_late_init, we need to define CONFIG_BOARD_LATE_INIT.
The latest ecovec config defines BOARD_LATE_INIT, board_late_init is not called.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
* 'master' of git://git.denx.de/u-boot-arm:
ARM926EJS: Fix cache.c to comply with checkpatch.pl
ARM926EJS: Make asm routines volatile in cache ops
MX35: mx35pdk: wrong board revision
ARM1136: MX35: Make asm routines volatile in cache ops
ARM: add u-boot.imx as target for i.MX SOCs
M28: Pull out CONFIG_APBH_DMA so it's always enabled
DMA: Split the APBH DMA init into block and channel init
imx: Return gpio_set_value in gpio_direction_output
imx: Use GPIO_TO_PORT macro in the gpio driver instead of (gpio >> 5)
imx: Add GPIO_TO_PORT macro in the mxc_gpio driver
imx: Remove unneeded/repititive definitions from imx headers
i.MX28: Allow coexistence of PIO and DMA mode for SD/MMC
MX31: mx31pdk: drop enable_caches from board file
i.MX28: Fix initial stack pointer position
mx35: mx35pdk: fix when cache functions are linked
mx35: flea3: fix when cache functions are linked
ARM: 926ejs: use debug() for misaligned addresses
ARM1136: add cache flush and invalidate operations
mx6qsabrelite: Fix the serial console port
mx6qsabrelite: Add boot switch setting information into the README
i.MX6: mx6qsabrelite: add cache commands if cache is enabled
i.MX6: implement enable_caches()
i.MX6: define CACHELINE_SIZE
MX53: DDR: Fix ZQHWCTRL field TZQ_CS
mx28evk: Add a README file
mx28: Split the README into a common part and a m28 specific part
tricorder: Load kernel from ubifs
tricorder: Add UBIFS
cm-t35: fix Ethernet reset timing
hawkboard: Add CONFIG_SPL_LIBGENERIC_SUPPORT
BeagleBoard: Remove userbutton command and use gpio command instead
OMAP: Move omap1510inn to Unmaintained / Orphaned
The board revision is detected accessing to the pmic,
that is not available before relocation (I2C).
This generates the following error:
CPU: Freescale i.MX35 rev 2.0 at 532 MHz.
Reset cause: WDOG
<reg num> = 7 is invalid. Should be less than 0
Board: MX35 PDK 1.0
The revision number is wrong, as a default value is printed
(tested on a mx35pdk Rev. 2.0).
Move the output in the board_late_init(), when
pmic can be accessed.
The ABPH DMA is now used also by the SD card. Therefore it has to be enabled
even if NAND is disabled.
Cc: Detlev Zundel <dzu@denx.de>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
The patch:
m28evk: Use GENERATED_GBL_DATA_SIZE
commit 1084606c972ea5f1d89f69bdbd978b867d0ee521
introduced usage of GENERATED_GBL_DATA_SIZE and calculation of initial stack
pointer position defived from that. Due to a small typo, the SP position moved
to 0x21f80, which is past the SRAM area. This didn't manifest on the real
hardware as the SRAM repeats there (address bits in the CPU being ignored).
Though this was caught in QEMU, where it crashed the emulator.
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
On mx6qsabrelite the console is ttymxc1.
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
disabled by default until drivers are fixed
Signed-off-by: Bernhard Walle <walle@corscience.de>
Since kernel should be in a ubifs partition, we need UBIFS.
The greater malloc size is needed for UBIFS.
Squashed two commits (UBIFS enabled and malloc size increased) into one.
Signed-off-by: Thomas Weber <weber@corscience.de>
With older toolchains we need CONFIG_SPL_LIBGENERIC_SUPPORT in order for
CONFIG_SPL_NAND_SUPPORT to link.
Remove userbutton command and do the detection in board config file using the gpio command
Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com>
Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
Fix typo on CONFIG_SYS_HUSH_PARSER and also add CONFIG_SYS_PROMPT_HUSH_PS2
to avoid build error.
* 'marek.vasut@gmail.com' of git://git.denx.de/u-boot-staging:
LMB: Fix undefined lmb_reserve() on non-lmb platforms
MIPS: fix endianess handling
MIPS: fix inconsistency in config option for cache operation mode
MIPS: board.c: fix init of flash data in bd_info
* 'master' of git://git.denx.de/u-boot-net:
net/designware: Change timeout loop implementation
net/designware: Set ANAR to 0x1e1
net/designware: Program phy registers when auto-negotiation is ON
net/designware: Try configuring phy on each dw_eth_init
net/designware: Consecutive writes must have delay
net/designware: Phy address fix
net/designware: Fix the max frame length size
net/designware: Fix to restore hw mac address
microblaze: Wire up LL_TEMAC driver initialization
microblaze: Add faked LL_TEMAC driver configuration
microblaze: Enable several ethernet driver compilation
net: ll_temac: Add LL TEMAC driver to u-boot
Update net subsystem maintainer in doc/git-mailrc
net/eth.c: fix eth_write_hwaddr() to use dev->enetaddr as fall back
mvgbe: remove warning for unused methods
* 'master' of git://git.denx.de/u-boot-onenand:
onenand: samsung: Enable OneNAND support at Samsung's Exynos4210
onenand: Replace ONENAND_IS_MLC() with ONENAND_HAS_4KB()
onenand:samsung OneNAND chip probe functions added for GONI and Exynos4210
onenand:samsung Target dependent OneNAND chip probe function
* 'master' of git://git.denx.de/u-boot-nios:
nios2 - adjust gbl data off to account for bd_info
nios2: implement get_ticks and get_tbclk
nios2: add flush_dcache_range function
Enable OneNAND support for Exynos4210 (C210 universal).
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
U-Boot's multipple network supports enables to use
several ethernet drivers but microblaze-generic
platform config file select only one driver.
Reported-by: Michal Simek <monstr@monstr.eu>
Signed-off-by: Stephan Linz <linz@li-pro.net>
Make endianess of target CPU configurable. Use the new config
option for dbau1550_el and pb1000 boards.
Adapt linking of standalone applications to pass through
endianess options to LD.
Build tested with:
- ELDK 4 mips_4KC- and mips4KCle
- Sourcery CodeBench Lite 2011.03-93
With this patch all 26 MIPS boards can be compiled now in one step by
running "MAKEALL -a mips".
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Fix:
drivers/mmc/libmmc.o: In function `mxsmmc_send_cmd':
/home/ag/git/u-boot/drivers/mmc/mxsmmc.c:210: undefined reference to `mxs_dma_desc_append'
/home/ag/git/u-boot/drivers/mmc/mxsmmc.c:211: undefined reference to `mxs_dma_go'
drivers/mmc/libmmc.o: In function `mxsmmc_initialize':
/home/ag/git/u-boot/drivers/mmc/mxsmmc.c:306: undefined reference to `mxs_dma_desc_alloc'
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
* 'agust@denx.de' of git://git.denx.de/u-boot-staging:
lzma: fix printf warnings
Remove CONFIG_SYS_EXTBDINFO from snapper9260.h
cmd_pxe.c: fix strict-aliasing warnings
net: smc91111: use mdelay()
doc: Fix some typos in different files
disk/part.c: Fix device enumeration through API
mkenvimage: Really set the redundant byte when applicable
mkenvimage: Don't try to detect comments in the input file
mkenvimage: Use mmap() when reading from a regular file
mkenvimage: Read/Write from/to stdin/out by default or if the filename is "-"
mkenvimage: More error handling
mkenvimage: Correct an include and add a missing one
mkenvimage: correct and clarify comments and error messages
MAKEALL: display SPL size if present
ARMV7/Vexpress: add missing get_ticks() and get_tbclk()
mkenvimage: fix usage message
cmd_fat: add FAT write command
fs/fat/fat_write.c: Fix GCC 4.6 warnings
FAT write: Fix compile errors
* 'master' of git://git.denx.de/u-boot-arm: (146 commits)
arm: Use common .lds file where possible
arm: add a common .lds link script
arm: Remove unneeded setting of LDCSRIPT
Define CPUDIR for the .lds link script
arm: Remove zipitz2 link script
Allow arch directory to contain .lds without requiring Makefile
OMAP: Remove omap1610inn-based boards
arch/arm/cpu/armv7/omap-common/clocks-common.c: Fix build warnings
board/ti/beagle/beagle.c: Fix build warnings
sdrc.c: Fix typo in do_sdrc_init() for SPL
tegra: i2c: Add I2C driver
tegra: fdt: i2c: Add extra I2C bindings for U-Boot
tegra: i2c: Select I2C ordering for Seaboard
tegra: i2c: Enable I2C on Seaboard
tegra: i2c: Select number of controllers for Tegra2 boards
tegra: i2c: Initialise I2C on Nvidia boards
tegra: Enhance clock support to handle 16-bit clock divisors
fdt: Add function to allow aliases to refer to multiple nodes
tegra: Rename NV_PA_PMC_BASE to TEGRA2_PMC_BASE
tegra: fdt: Enable FDT support for Ventana
tegra: fdt: Enable FDT support for Seaboard
tegra: usb: Enable USB on Seaboard
tegra: usb: Add common USB defines for tegra2 boards
tegra: usb: Add USB support to nvidia boards
arm: Check for valid FDT after console is up
fdt: Avoid early panic() when there is no FDT present
tegra: usb: Add support for Tegra USB peripheral
tegra: fdt: Add function to return peripheral/clock ID
usb: Add support for txfifo threshold
tegra: usb: fdt: Add USB definitions for Tegra2 Seaboard
tegra: usb: fdt: Add additional device tree definitions for USB ports
tegra: fdt: Add clock bindings for Tegra2 Seaboard
tegra: fdt: Add additional USB binding
fdt: Add tegra-usb bindings file from linux
fdt: Add staging area for device tree binding documentation
tegra: fdt: Add device tree file for Tegra2 Seaboard from kernel
tegra: fdt: Add Tegra2x device tree file from kernel
arm: fdt: Add skeleton device tree file from kernel
fdt: Add basic support for decoding GPIO definitions
fdt: Add functions to access phandles, arrays and bools
fdt: Tidy up a few fdtdec problems
fdt: Add tests for fdtdec
fdt: Add fdtdec_find_aliases() to deal with alias nodes
arm: Tegra2: Fix ELDK42 gcc failure with inline asm stack pointer load
net: fec_mxc: allow use with cache enabled
net: force PKTALIGN to ARCH_DMA_MINALIGN
i.MX28: Enable caches by default
i.MX28: Make use of the bounce buffer
i.MX28: Do data transfers via DMA in MMC driver
MMC: Implement generic bounce buffer
i.MX28: Add cache support to MXS NAND driver
i.MX28: Add cache support into the APBH DMA driver
ARM926EJS: Implement cache operations
board/vpac270/onenand.c: Fix build errors
nhk8815: fix build errors
atmel-boards: add missing atmel_mci.h
ARM: highbank: setup env from boot source register
ARM: highbank: change env config to use nvram
ARM: highbank: add reset support
ARM: highbank: Add boot counter support
ARM: highbank: change TEXT_BASE to 0x8000
ARM: highbank: fix us_to_tick calculation
ARM: highbank: add missing get_tbclk
ARM: highbank: fix warning for calxedaxgmac_initialize
net: calxedaxgmac: fix build due to missing __aligned definition
EXYNOS: Add structure for Exynos4 DMC
EXYNOS: SMDK5250: Support all 4 UARTs
ARM: fix s3c2410 timer code
ARM: davinci: fixes for cam_enc_4xx board
omap3_spi: receive transmit mode
calimain, enbw_cmc: Fix typo in comments
Davinci: ea20: use gpio framework to access gpios
OMAP3: mt_ventoux: sets its own mtdparts
OMAP3: mt_ventoux: updated timing for FPGA
twl4030: fix potential power supply handling issues
NAND: TI: fix warnings in omap_gpmc.c
cam_enc_4xx: Rename 'images' to 'imgs'
arm: Add Prep subcommand support to bootm
OMAP3: twister: add support to boot Linux from SPL
SPL: call cleanup_before_linux() before booting Linux
OMAP3: SPL: do not call I2C init if no I2C is set.
Add cache functions to SPL for armv7
devkit8000: Implement and activate direct OS boot
omap/spl: change output of spl_parse_image_header
omap-common/spl: Add linux boot to SPL
devkit8000/spl: init GPMC for dm9000 in SPL
omap-common: Add NAND SPL linux booting
devkit8000: add config for spl command
Add cmd_spl command
mx53ard: Initialize return code with error
mx53: Make PLL2 to be the parent of UART clock
configs: imx: Use CONFIG_SF_DEFAULT_CS
mx28evk: Provide default values for SPI bus and chip select
USB: ehci-mx6: Add proper IO accessors
mx6: Read silicon revision from register
i.MX28: Drop __naked function from spl_mem_init
mxs_spi: Return proper timeout error
i.MX28: Make the stabilization delays shorter
pmic_i2c: Return error in case of invalid pmic_i2c_tx_num
mx6: Remove duplicate definition of ANATOP_BASE_ADDR
mx6: Fix reset cause for Power On Reset case
i.MX6: mx6qsabrelite: add MACH_TYPE_MX6Q_SABRELITE
i.MX6: mx6q_sabrelite: add CONFIG_REVISION_TAG
i.MX28: Enable additional DRAM address bits
mx6q: mx6qsabrelite: setup_spi() should be called in board_init to allow use for environment
mx31: add "ARM11P power gating" to get_reset_cause
mx31pdk: Fix CONFIG_SYS_MEMTEST_END
efikamx: Fix CONFIG_SYS_MEMTEST_END
mx53smd: Fix CONFIG_SYS_MEMTEST_END
mx53evk: Fix CONFIG_SYS_MEMTEST_END
mx51evk: Fix CONFIG_SYS_MEMTEST_END
i.MX6: mx6qsabrelite: add ext2 support
imximage: Remove overwriting of flash_offset
IXP: Fix GPIO_INT_ACT_LOW_SET()
IXP: Fix NAND build warning on PDNB3 and SCPU
IXP: Move PDNB3 and SCPU from Makefile to boards.cfg
IXP: Squash warnings in IXP NPE
IXP: Fix missing MACH_TYPE_{ACTUX?,PNB3,DVLHOST}
IXP: Make IXP buildable with arm-linux- toolchains
Examples: Properly append LDFLAGS to LD command
SPL: Enable YMODEM support on BeagleBone and AM335x EVM
SPL: Add YMODEM over UART load support
SPL: Add README.omap3
README: document more SPL config options
spl.c: Use __noreturn decorator
config.mk: Check for -fstack-usage support
config.mk: Make cc-option create a file under include/generated
* 'master' of git://git.denx.de/u-boot-microblaze:
microblaze: Enable phylib and mii support
The CS_AUTOBOOT configurations have been broken for a long time.
Kshitij Gupta is no longer at TI making these broken and orphaned
boards, so remove.
This enables I2C on Seaboard.
Acked-by: Heiko Schocher <hs@denx.de>
Signed-off-by: Tom Warren <twarren@nvidia.com>
The Tegra 2x SOC has four ports, so define TEGRA_I2C_NUM_CONTROLLERS
in the shared config file.
This switches Ventana over to use FDT for run-time config instead of
CONFIG options.
At present Ventana does not have its own device tree file - it just uses
the Seaboard one.
This switches Seaboard over to use FDT for run-time config instead of
CONFIG options. USB is the only user at present.
Seaboard has a top port which is USB host or device, and a side port which
is host only.
All Tegra2 boards should include tegra2-common. This adds the required
USB config to that file.
This allows i.MX28 MMC host to fully utilize DMA transfers and caches, greatly
improving speed.
Cc: Fabio Estevam <festevam@gmail.com>
Update the highbank config to use env from NVRAM. Also remove extra env
settings as they are not used unless the default env is used.
Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com>
Add boot counter support using an sysreg which is persistent across reset.
Make some space at the beginning of RAM so the FDT can be loaded to a
known fixed address at 0x1000.
- change CONFIG_ENV_RANGE to contain 2 nand erase blocks,
one for bad block reserve.
- remove from the envvariable "img_writeramdisk" the
ubifsmount command, as it is not needed.
- erase the hole mtd partition containing u-boot
- save environment variable "dvn_app_vers" and "dvn_boot_vers"
only after installing the new image.
changes requested from Marek Vasut:
- arm, davinci: fix eldk-4.2 warnings for cam_enc_4xx board
- get rid of run_command2 usage
needed since patch:
commit 009dde1955583e306cf904c864068f3acb0db499
Author: Simon Glass <sjg@chromium.org>
Date: Tue Feb 14 19:59:20 2012 +0000
Rename run_command2() to run_command()
is now in mainline.
- add CONFIG_SPL_LIBGENERIC_SUPPORT support
- remove CONFIG_CMD_PXE support
- fix warning:
cam_enc_4xx.c: In function 'menu_handle':
cam_enc_4xx.c:609: warning: dereferencing type-punned pointer
will break strict-aliasing rules
- fix error:
arm-linux-ld: u-boot-spl: Not enough room for program headers,
try linking with -N
Cc: Tom Rini <tom.rini@gmail.com>
Cc: Fletzer Martin <Martin.Fletzer@ait.ac.at>
Drop direct access to SOC's registers and use
the function of the GPIO driver for da8xx.
[Tom: Remove gpio[68]_base as it's now unused]
CC: Bastian Ruppert <Bastian.Ruppert@Sewerin.de>
CC: dzu@denx.de
CC: Sandeep Paulraj <s-paulraj@ti.com>
