CONFIG_SYS_CONSOLE_ENV_OVERWRITE
CONFIG_CONSOLE_SCROLL_LINES
This is not used in U-Boot. Drop it.
CONFIG_CONSOLE_EXTRA_INFO
CONFIG_VIDEO_SW_CURSOR
[trini: Re-convert, find all the cases where this is off]
CONFIG_VGA_AS_SINGLE_DEVICE
Once we migrate to driver model for video, we should be able to drop this
option.
CONFIG_SYS_CONSOLE_BG_COL
CONFIG_SYS_CONSOLE_FG_COL
CONFIG_VIDEO_CT69000
CONFIG_CFB_CONSOLE_ANSI
CONFIG_CFB_CONSOLE
This is not really a config. Rename it to avoid confusion.
Reviewed-by: Jagan Teki <jteki@openedev.com>
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
CONFIG_LCD
CONFIG_VIDEO
Move these option to Kconfig and tidy up existing uses.
The Power PC boards don't have a suitable common element: the common header
files don't appear to line up with the Kconfig files as far as I can tell.
This results in a lot of defconfig changes.
[trini: Re-migrate, update common/console.c logic]
ARCH_UNIPHIER selects DM_USB, where CONFIG_USB_MAX_CONTROLLER_COUNT
is not used.
Move FDT_FIXUP_PARTITIONS to Kconfig and cleanup existing
uses.
Move SYS_OS_BASE to Kconfig and cleanup existing
uses.
[trini: Also migrate a4m2k]
Move SPL_OS_BOOT to Kconfig and cleanup existing
uses.
T series boards use unified RCW for sd, spi and nand boot.
Now split txxx_rcw.cfg to txxx_sd_rcw.cfg, txxx_spi_rcw.cfg
and txxx_nand_rcw.cfg for SPI/NAND/SD boot.
And modify RCW[PBI_SRC] for them:
PBI_SRC=5 for SPI 24-bit addressing
PBI_SRC=6 for SD boot
PBI_SRC=14 for IFC NAND boot
Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
In AM335x GP EVM, Atheros 8031 phy is used, enable the driver as
AM335x SoC RGMII delay mode has to be enabled in phy as mentioned
in the silicon errata Advisory 1.0.10
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
include/configs/ls1021aqds.h
include/configs/ls1021atwr.h
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
Legacy video driver macros are not needed. Clean them up.
This converts coreboot to use DM framebuffer driver.
At present only chromebook boards are converted to DM video. Other
x86 boards are still using the legacy cfb_console driver. This
switches to use DM version drivers.
Update the common configuration so that it works correctly when
CONFIG_DM_VIDEO is enabled. This involves dropping the legacy CONFIG_VIDEO
option and changing the stdio device from "vga" to "vidconsole".
The Tegra 2 aka T20 is not host PC capable. Therefore gate the define
CONFIG_CI_UDC_HAS_HOSTPC in tegra-common-usb-gadget.h in case of
CONFIG_TEGRA20.
Signed-off-by: Tom Warren <twarren@nvidia.com>
This is an on-board Ethernet device. It has no point if the Micro
Support Card is not available.
NOR flash devices are seldom used on UniPhier platforms these days.
The only use case I see is the Micro Support Card is connected.
Otherwise, define CONFIG_SYS_NO_FLASH to disable NOR FLASH.
Synology DS109 is based on MV88F6281. The code
is based on Dreamplug code with modificatons
from Synologys open source repository.
Signed-off-by: Walter Schweizer <swwa@users.sourceforge.net>
The SPL size for dra7x platform increased beyond 64K,
increasing the size to 256K to cater for future enhancement.
Signed-off-by: Ravi Babu <ravibabu@ti.com>
removing CONFIG_SPL_ENV_SUPPORT defined in header files
due to moved to kconfig option for CONFIG_SPL_ENV_SUPPORT
The KeyStone platform has its own clk_get_rate() but its prototype
is different from that of the common-clk (clk-uclass) framework.
Prefix the KeyStone specific implementation with ks_ in order to
avoid name-space conflict.
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
LS1012AFRDM has 512MB of DDR. So update kernel load address to
0x96000000.
Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@nxp.com>
[York Sun: Reformatted commit message]
Remove ramdisk_addr, ramdisk_size and update UART baud-rate.
Due to clock source restrictions on i.MX6, certain pixel clock rates can
not be supported. Hence default the resolution/frame rate during boot to a
supported value by passing video bootargs 1024x768@60 for
HDMI (Display Port1) and LVDS (Display Port2) on B850v3.
Signed-off-by: Ken Lin <ken.lin@advantech.com.tw>
Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com>
Now that fastboot options are available in Kconfig, we can migrate them
from DRA7 header to corresponding DRA7 defconfigs.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Remove legancy I2C config and code in favor of upcomming DM/DT
enable I2C support.
Drop a few that are not used in U-Boot.
