path: root/include/configs
2011-10-01sbc82xx: delete support for obsolete SBC8240/SBC8260Paul Gortmaker
The EST SBC8260 is over 10 years old, and the SBC8240 older than that. With the tiny amount of RAM (by today's standards), there really isn't anyone interested in running the latest U-boot on these EOL products anymore. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> CC: jon.diekema@smiths-aerospace.com
2011-10-01Merge branch 'post' of git://git.denx.de/u-boot-blackfinWolfgang Denk
* 'post' of git://git.denx.de/u-boot-blackfin: Blackfin: uart: implement loop callback for post Blackfin: bf537-stamp/bf548-ezkit: update POST flash block range Blackfin: post: generalize led/button tests with GPIOs Blackfin: bf537-stamp: drop uart/flash post tests Blackfin: post: drop custom test list Blackfin: bf537-stamp: convert to gpio post hotkey
2011-09-30EfikaSB: Add preliminary EfikaSB supportMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de>
2011-09-30vision2: Place machine ID into board configFabio Estevam
Let common code set the machine ID. Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-09-30zmx25: Place machine ID into board configFabio Estevam
Let common code set the machine ID. Cc: Matthias Weisser <weisserm@arcor.de> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-30mx53evk: Place machine ID into board configFabio Estevam
Let common code set the machine ID. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Jason Liu <jason.hui@linaro.org>
2011-09-30mx53ard: Place machine ID into board configFabio Estevam
2011-09-30mx53smd: Place machine ID into board configFabio Estevam
2011-09-30mx53loco: Place machine ID into board configFabio Estevam
Let common code set the machine ID. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Jason Liu <jason.hui@linaro.org>
2011-09-30mx51evk: Place machine ID into board configFabio Estevam
2011-09-30imx31_litekit: Place machine ID into board configFabio Estevam
2011-09-30mx31ads: Place machine ID into board configFabio Estevam
2011-09-30mx25pdk: Place machine ID into board configFabio Estevam
2011-09-30mx31pdk: Place machine ID into board configFabio Estevam
2011-09-30imx31_litekit: Remove dram_init_banksize()Fabio Estevam
As only one RAM bank is used we can rely on the code from arch/arm/lib/board.c Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-30EfikaMX: Adjust undocumented magic constant in config fileMarek Vasut
This magic constant with zero documentation, when it's last 8 bits are set to 0x45, configures correctly the PERCLK dividers. Therefore the I2C operates correctly when divider computed from PERCLK. Note: This constant is written to CBCDR register in arch/arm/cpu/armv7/mx5/lowlevel_init.S, but it's written only once. The register is accessed three more times in the file, with different values written to it each time. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2011-09-30MX25: Add initial support for MX25PDKFabio Estevam
Add the initial support for MX25PDK booting from SD card via internal boot. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-30mx31pdk: Change the prompt as per other i.MX boardsFabio Estevam
Change the prompt as done in other i.MX boards. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-30Devkit8000: Change console from ttyS2 to ttyO2Thomas Weber
The omap serial names have changed from ttySx to ttyOx, so the console should be also changed to support this. Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-30omap3evm: env: Fix default consoleSanjeev Premi
Change the default console from ttyS2 to ttyO0 to match the Linux default for the EVM. Signed-off-by: Sanjeev Premi <premi@ti.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-30mmc: omap: config VMMC, MMC1_PBIASBalaji T K
Config VMMC voltage to 3V for MMC/SD card slot and PBIAS settings needed for OMAP4 Fixes MMC/SD detection on boot from eMMC. Signed-off-by: Balaji T K <balajitk@ti.com> Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-30devkit8000: Add nand-spl support for new SPLSimon Schwarz
Add NAND SPL support to the devkit8000 config Signed-off-by: Simon Schwarz <simonschwarzcor@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-30Armada100: Enable 88E3015 PHY support for GplugDAjay Bhargav
This patch adds support for 88E3015 PHY for Marvell GplugD board. This patch depends on series of patch which adds support for Marvell GuruPlug-Display. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-09-30Armada100: Enable Ethernet support for GplugDAjay Bhargav
This patch enables ethernet support for Marvell GplugD board. Network related commands works. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-09-29Blackfin: bf537-stamp/bf548-ezkit: update POST flash block rangeMike Frysinger
Update the define names for the new common code, and improve the range used on the bf548-ezkit. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-29Blackfin: post: generalize led/button tests with GPIOsMike Frysinger
Make it easy for any Blackfin board to enable led/push button tests. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-29Blackfin: post: drop custom test listMike Frysinger
The few tests that are Blackfin-specific have been migrated to common code or been rewritten with the existing "bsp-specific" defines. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-29Blackfin: bf537-stamp: convert to gpio post hotkeyMike Frysinger
No need for our custom implementations now that common code supports the generic gpio layer. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-27ARM: remove broken "ixdp425" and "ixpdg425" boardsAlbert ARIBAUD
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Stefan Roese <sr@denx.de>
2011-09-22Minor Coding Style CleanupWolfgang Denk
2011-09-20Drop bogus BOOTFLAG_* definitionsWolfgang Denk
There is no code anywhere that references BOOTFLAG_* so remove these defines. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Valentin Longchamp <valentin.longchamp@keymile.com> Cc: Peter Tyser <ptyser@xes-inc.com>
2011-09-13DA830: Fix Build WarningSandeep Paulraj
This commit fixes a build warning in the DA830 EVM build Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-13omap4: factor out common part from board config headersAneesh V
Factor out common parts from omap4_sdp4430.h and omap4_panda.h into a new file omap4_common.h Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12OMAP3 Beagle: Minor config cleanupSandeep Paulraj
This patch removes a hardcoded MAC address Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12da830: modify the MEMTEST start and end addressNagabhushana Netagunte
Modify the MEMTEST start and end address. The memtest range was overlapping the CONFIG_SYS_LOAD_ADDR which causes the uImage to be corrupt.Also, modify the size for which mtest is run to 32MB from 16MB. Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12da830: enable SPI flash boot modeNagabhushana Netagunte
Enable SPI flash boot mode in configuration file as default. With the introduction of 456MHz part, SPI operating frequency will increase and at this frequency SPI does not work correctly. Hence reduce the default SPI speed to 30MHz from 50MHz. Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12da830: modify the U-Boot prompt stringNagabhushana Netagunte
Modify U-boot promt string from 'DA830-evm >' to 'U-Boot >' as there are many variants of da830 based boards which have diffrent names such as L137, AM1707 etc. Signed-off-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Signed-off-by: Nagabhushana Netagunte <nagabhushana.netagunte@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-09-12MX25: tx25: Cleanup tx25.h configFabio Estevam
Cleanup tx25.h by removing unnecessary defines and by removing unneeded "1"'s. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-09-12MX25: tx25: Fix build by making use of GPIO frameworkFabio Estevam
Make use of GPIO framework and avoid the following build error: tx25.c: In function 'tx25_fec_init': tx25.c:73: error: dereferencing pointer to incomplete type tx25.c:74: error: dereferencing pointer to incomplete type tx25.c:75: error: dereferencing pointer to incomplete type tx25.c:76: error: dereferencing pointer to incomplete type tx25.c:83: error: dereferencing pointer to incomplete type tx25.c:84: error: dereferencing pointer to incomplete type tx25.c:114: error: dereferencing pointer to incomplete type tx25.c:115: error: dereferencing pointer to incomplete type tx25.c:116: error: dereferencing pointer to incomplete type tx25.c:117: error: dereferencing pointer to incomplete type tx25.c:124: error: dereferencing pointer to incomplete type tx25.c:125: error: dereferencing pointer to incomplete type tx25.c:126: error: dereferencing pointer to incomplete type Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-09-12omap3: beagle: Fix build warningSanjeev Premi
This patch fixes the warning dure to recent changes to the board configuration: cmd_i2c.o cmd_i2c.c -c cmd_i2c.c:109:1: warning: missing braces around initializer cmd_i2c.c:109:1: warning: (near initialization for 'i2c_no_probes[0]') Signed-off-by: Sanjeev Premi <premi@ti.com> Cc: Jason Kridner <jkridner@beagleboard.org> Acked-by: Jason Kridner <jdk@ti.com>
2011-09-10KS8695: convert KS8695 eth driver to CONFIG_MULTI_ETHGreg Ungerer
Trivial conversion of the ks8695eth driver to a CONFIG_MULTI_ETH type driver. Signed-off-by: Greg Ungerer <greg.ungerer@opengear.com>
2011-09-10CM4000: fix missing RAM definitions for OpenGear boardsGreg Ungerer
The OpenGear boards CM4008, CM4116 and CM4148 need their DRAM base and RAM stack base addresses defined. Fixes: board.c: In function ‘__dram_init_banksize’: board.c:227: error: ‘CONFIG_SYS_SDRAM_BASE’ undeclared (first use in this function) board.c:227: error: (Each undeclared identifier is reported only once board.c:227: error: for each function it appears in.) board.c: In function ‘board_init_f’: board.c:270: error: ‘CONFIG_SYS_INIT_SP_ADDR’ undeclared (first use in this function) board.c:303: error: ‘CONFIG_SYS_SDRAM_BASE’ undeclared (first use in this function) Signed-off-by: Greg Ungerer <greg.ungerer@opengear.com>
2011-09-07MX31: mx31pdk: make use of GPIO frameworkStefano Babic
2011-09-07ARM: PXA: remove broken "zylonite" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Marek Vasut <marek.vasut@gmail.com> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-09-07ARM: remove broken "shannon" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Rolf Offermanns <rof@sysgo.de>
2011-09-07ARM: remove broken "modnet50" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Thomas Elste <info@elste.org>
2011-09-07ARM: remove broken "lpc2292sodimm" board.Wolfgang Denk
2011-09-07ARM: remove broken "lart" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Alex Züpke <azu@sysgo.de>
2011-09-07ARM: remove broken "impa7" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Marius Gröger <mag@sysgo.de>
2011-09-07ARM: remove broken "gcplus" board.Wolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: George G. Davis <gdavis@mvista.com>
