path: root/include/configs
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-23xilinx-ppc.h: DropTom Rini
With PowerPC 4xx support removed, we have removed xilinx-ppc support as well, remove this file now. Fixes 98f705c9cefd ("powerpc: remove 4xx support") Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-22powerpc: Remove unneccessary #ifdefs in reginfoChristophe Leroy
reginfo command is calling mpc8xx_reginfo(), mpc85xx_reginfo() or mpc86xx_reginfo() based on CONFIG_ symbol. As those 3 functions can't me defined at the same time, let's rename them print_reginfo() to avoid the #ifdefs The name is kept generic as it is not at all dependent on powerpc arch and any other arch could want to also print such information. In addition, as the Makefile compiles cmd/reginfo.c only when CONFIG_CMD_REGINFO is set, there is no need to enclose the U_BOOT_CMD definition inside a #ifdef CONFIG_CMD_REGINFO Lets all remove the #ifdefs around the U_BOOT_CMD as this file is only compiled when CONFIG_CMD_REGINFO is defined Finally, this is a PowerPC-only command, disable it on a number of non-PowerPC platforms. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-22meson-gx: reserved memory regionsxypron.glpk@gmx.de
The Odroid C2 has two GiB of memory with two reserved regions. reg = <0x0 0x0 0x0 0x1000000>; reg = <0x0 0x10000000 0x0 0x200000>; Patch bfcef28ae4cf (arm: add initial support for Amlogic Meson and ODROID-C2) provided function dram_init_banksize to reserve the first 16 MiB of RAM for firmware in function dram_init_banksize in arch/arm/mach-meson/board.c and defined CONFIG_NR_DRAM_BANKS = 1. With this patch dram_init_banksize is changed to additionally reserve the 2MiB region for the ARM Trusted Firmware (BL31). CONFIG_NR_DRAM_BANKS is set to 2. Cc: Andreas Färber <afaerber@suse.de> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-07-18Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2017-07-14mx6cuboxi: Move CONFIG_CMD_SATA to KconfigFabio Estevam
Move CONFIG_CMD_SATA option to Kconfig to fix the following build error: In file included from include/configs/mx6cuboxi.h:137:0, from include/config.h:7, from include/common.h:21, from common/env_common.c:11: include/config_distro_bootcmd.h:161:2: error: expected '}' before 'BOOT_TARGET_DEVICES_references_SATA_without_CONFIG_SATA' BOOT_TARGET_DEVICES_references_SATA_without_CONFIG_SATA Reported-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-07-12Merge git://www.denx.de/git/u-boot-marvellTom Rini
2017-07-12imx: cx9020: try pxe boot, if no vmlinuz on mmcPatrick Bruenn
If no vmlinuz is found on mmc, try to boot from pxe. Signed-off-by: Patrick Bruenn <p.bruenn@beckhoff.com>
2017-07-12imx: cx9020: use fdt_addr_r and ramdisk_addr_rPatrick Bruenn
Replace fdtaddr and rdaddr variable names with u-boot standard names fdt_addr_r and ramdisk_addr_r. This will make the use of pxe boot more easy. Signed-off-by: Patrick Bruenn <p.bruenn@beckhoff.com>
2017-07-12mx6sabreauto: Add Falcon mode supportDiego Dorta
Add support for Falcon mode and explain in the README the steps to boot the kernel directly without loading the full U-Boot. Signed-off-by: Diego Dorta <diego.dorta@nxp.com> Acked-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-07-12warp: Use PARTUUID to specify the rootfs locationFabio Estevam
warp can run different kernel versions, such as NXP 4.1 or mainline. Currently the rootfs location is passed via mmcblk number and the problem with this approach is that the mmcblk number for the eMMC changes depending on the kernel version. In order to avoid such issue, use UUID method to specify the rootfs location. Succesfully tested booting a NXP 4.1 and also a mainline 4.12 kernel. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Otavio Salvador <otavio@ossystems.com.br>
2017-07-12embestmx6boards: Use PARTUUID to specify the rootfs locationFabio Berton
Currently the rootfs location is passed via mmcblk number and the problem with this approach is that the mmcblk number for the eMMC changes depending on the kernel version. In order to avoid such issue, use UUID method to specify the rootfs location. Also add CONFIG_BOOTCOMMAND to run finduuid function and distro_bootcmd. This change was made based on U-Boot commit: - ca4f338e2efece5196eb2178e5f7d07be828da6e Signed-off-by: Fabio Berton <fabio.berton@ossystems.com.br> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-07-12mx6cuboxi: Use PARTUUID to specify the rootfs locationFabio Berton
Currently the rootfs location is passed via mmcblk number and the problem with this approach is that the mmcblk number for the eMMC changes depending on the kernel version. In order to avoid such issue, use UUID method to specify the rootfs location. This change was made based on U-Boot commit: - ca4f338e2efece5196eb2178e5f7d07be828da6e Signed-off-by: Fabio Berton <fabio.berton@ossystems.com.br> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-07-12wandboard: Use PARTUUID to specify the rootfs locationFabio Berton
2017-07-12mx6sabre: Use PARTUUID to specify the rootfs locationFabio Estevam
mx6sabre boards can run different kernel versions, such as NXP 4.1 or mainline. Currently the rootfs location is passed via mmcblk number and the problem with this approach is that the mmcblk number for the eMMC changes depending on the kernel version. In order to avoid such issue, use UUID method to specify the rootfs location. Succesfully tested booting a NXP 4.1 and also a mainline kernel on a mx6qsabresd and mx6dlsabreauto. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-07-12mx6sabreauto: Do not enable WEIM by defaultFabio Estevam
WEIM cannot be used when I2C3 is enabled due to pin conflict, so keep WEIM disabled by default. I2C3 controls GPIO I2C expander (USB host and OTG have VBUS controlled by the GPIO I2C expander), magnetometer, accelerometer. Not disabling WEIM in U-Boot causes I2C3 to behave badly when booting a NXP 4.1 kernel, which leads to probe failure on several devices, including the lack of USB: imx_usb 2184000.usb: Can't register ci_hdrc platform device, err=-517 By keeping WEIM disabled in U-Boot these kernel issues are gone. Reported-by: Takashi Matsuzawa <tmatsuzawa@xevo.com> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-07-12mmc: fsl_esdhc: drop CONFIG_SYS_FSL_ESDHC_FORCE_VSELECTPeng Fan
CONFIG_SYS_FSL_ESDHC_FORCE_VSELECT is not the correct method to set I/O to 1.8. To boards that does not support vqmmc-supply, use vs18_enable in fsl_esdhc_cfg. If regulator is supported, use fixed 1.8V regulator for vqmmc-supply. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: York Sun <york.sun@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
2017-07-12imx6_spl: Add u-boot-dtb.img for SPL payloadJagan Teki
Add u-boot-dtb.img for SPL_FS_LOAD_PAYLOAD_NAME when OF_CONTROL used. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-07-12mx6sabreauto: Update to SPL only modeVanessa Maegima
As mx6sabreauto supports SPL now, all variants can boot using the same defconfig. This patch: - Removes non-SPL targets. - Renames target to mx6sabreauto_defconfig. - Renames folder and board files to mx6sabreauto. - Updates MAINTAINERS, Makefile and Kconfig accordingly. - Removes .cfg files. - Adds a README with instructions to build and flash SPL and u-boot.img. Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2017-07-12mx6qsabreauto: Add SPL supportVanessa Maegima
Add support for mx6q, mx6dl and mx6qp sabreauto boards in SPL. Retrieved the mx6q DCD table from: board/freescale/mx6qsabreauto/imximage.cfg Retrieved the mx6dl DCD table from: board/freescale/mx6qsabreauto/mx6dl.cfg Retrieved the mx6qp DCD table from: board/freescale/mx6qsabreauto/mx6qp.cfg Flashed SPL and u-boot.img to an SD card and could successfully boot it on mx6q, mx6qp and mx6dl sabreauto boards. Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2017-07-12mx6cuboxi: Add support for sataPeter Robinson
The Cubox-i and Hummingboard series of devices have an option of SATA on board, and depending on how the fuses are blown even the option to boot SPL from SATA. So enable support for it so it can be used to boot the OS from if people desire. Cc: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Acked-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-07-12ot1200: enable CONFIG_IMX_THERMAL for detailed thermal informationChristian Gmeiner
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-07-12mx6sabresd: Fix guard file symbolFabio Estevam
Remove the "Q" from the file guard symbol, so that it matches the file name. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-07-12marvell: armada385: Add the Turris Omnia boardMarek Behún
The Turris Omnia is a open-source router created by CZ.NIC. The code is based on the Marvell/db-88f6820-gp by Stefan Roese with modifications from Tomas Hlavacek in the CZ.NIC turris-omnia-uboot repository, which can be found at https://gitlab.labs.nic.cz/turris/turris-omnia-uboot By default, the Turris Omnia uses btrfs as the main and only filesystem, and also loads kernel and device tree from this filesystem. Since U-Boot does not yet support btrfs, you should not flash your Turris Omnia board with this unless you know what you are doing. Signed-off-by: Tomas Hlavacek <tomas.hlavacek@nic.cz> Signed-off-by: Marek Behun <marek.behun@nic.cz> create mode 100644 board/CZ.NIC/turris_omnia/Makefile create mode 100644 board/CZ.NIC/turris_omnia/kwbimage.cfg create mode 100644 board/CZ.NIC/turris_omnia/turris_omnia.c create mode 100644 configs/turris_omnia_defconfig create mode 100644 include/configs/turris_omnia.h Signed-off-by: Stefan Roese <sr@denx.de>
2017-07-11configs: am335x_evm: Enable FASTBOOT based on kconfigAlexandru Gagniuc
When CONFIG_CMD_FASTBOOT or CONFIG_USB_FUNCTION_FASTBOOT are defined in am335x_evm.h, a dependency on g_dnl.c is created. This in turn creates a dependency on having USB gadget enabled. As a result we can't create configs with USB gadget disabled. Since these CONFIG_ variables are now part of kconfig, move them to the board defconfigs, and out of am335x_evm.h. This both preserves current defaults, and allows creating configs with USB gadget off. Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-11Merge git://git.denx.de/u-boot-dmTom Rini
2017-07-11Merge branch 'master' of git://git.denx.de/u-boot-rockchipTom Rini
2017-07-11sandbox: Enable more console optionsSimon Glass
Enable the pre-console buffer, displaying the model and post-relocation console announce on sandbox. Also add a model name to the device tree. This allows testing of these features. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2017-07-11Convert CONFIG_CMD_SATA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SATA Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11Convert CONFIG_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SCSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-07-11rockchip: Add basic support for phyCORE-RK3288 SoM based carrier boardWadim Egorov
The phyCORE-RK3288 is a SoM (System on Module) containing a RK3288 SoC. The module can be connected to different carrier boards. It can be also equipped with different RAM, SPI flash and eMMC variants. The Rapid Development Kit option is using the following setup: - 1 GB DDR3 RAM (2 Banks) - 1x 4 KB EEPROM - DP83867 Gigabit Ethernet PHY - 16 MB SPI Flash - 4 GB eMMC Flash Add basic support for the PCM-947 carrier board, a RK3288 based development board made by PHYTEC. This board works in a combination with the phyCORE-RK3288 System on Module. Signed-off-by: Wadim Egorov <w.egorov@phytec.de> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11usb: Kconfig: migrate USB_DWC2 to KconfigPhilipp Tomsich
This change migrates the USB_DWC2 configuration item to Kconfig and runs moveconfig to adjust header files and defconfig. Signed-off-by: Meng Dongyang <daniel.meng@rock-chips.com> Split off into a separate patch: Ran moveconfig to migrate other boards: Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11rockchip: add evb_rk3229 boardKever Yang
evb_rk3229 is a RK3229 based board, with: - 8GB eMMC; - 1GB DDR SDRAM; - 2 USB2.0 HOST port; - 1 MAC port; - 1 HDMI port; - IR; - WiFi; Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11rockchip: rk322x: add basic soc supportKever Yang
Enable soc support for SPL and U-boot skeleton. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-07-11rockchip: add sdram_common for common functionsKever Yang
There are some functions like sdram_size_mb can be re-used for different rockchip SoCs, just put them into common file. Add board_get_usable_ram_top() for ram_top init base on SDRAM_MAX_SIZE. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Added SDRAM_MAX_SIZE definition for RK3036: Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> fixup: 3036 fix for sdram_common
2017-07-10ARM64: poplar: hi3798cv200: u-boot support for Poplar 96BoardsJorge Ramirez-Ortiz
This port adds support for: 1) Serial 2) eMMC 3) USB It has been tested with ARM TRUSTED FIRMWARE running u-boot as the BL33 executable [see board's README] eMMC has been tested for reading and booting the loader and linux kernels as well as saving the u-boot environment. USB has been tested with ASIX networking adapter and SanDisk 7.4GB drive. PSCI has been tested via the reset call (PSCI executes from DDR) The firwmare upgrade process has been tested via TFTP and USB FAT filesystem containing the fastboot.bin image in one of the partitions. Signed-off-by: Jorge Ramirez-Ortiz <jorge.ramirez-ortiz@linaro.org>
2017-07-10ARM: k2g: Update board_name u-boot env variable at runtimeCooper Jr., Franklin
Enable CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG to allow "board_name" to be set depending on the board it is being ran on. Update findfdt to use this new dynamic board_name value to determine which dtb should be used. Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-08powerpc, 8xx: Add support for MCR3000 board from CSSIChristophe Leroy
CS Systemes d'Information (CSSI) manufactures two boards, named MCR3000 and CMPC885 which are respectively based on MPC866 and MPC885 processors. This patch adds support for the first board. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2017-07-07board/BuR/brppt1: fix MMC bootHannes Schmelzer
since commit 'd5abcf94c7123167725fc22ace342f0d455093c1' - ti: boot: Register the MMC controllers in SPL in the same way as in u-boot MMC boot on brppt1 board is broken, with this commit we make our board working again. Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2017-07-07wdt: Unify option of timeout valueAndy Shevchenko
There is no need to duplicate same option with different name. Kill HW_WATCHDOG_TIMEOUT_MS in favor of WATCHDOG_TIMEOUT_MSECS. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2017-07-06avr32: Retire AVR32 for goodAndy Shevchenko
AVR32 is gone. It's already more than two years for no support in Buildroot, even longer there is no support in GCC (last version is heavily patched 4.2.4). Linux kernel v4.12 got rid of it (and v4.11 didn't build successfully). There is no good point to keep this support in U-Boot either. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2017-07-03powerpc: remove 4xx supportHeiko Schocher
There was for long time no activity in the 4xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 4xx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-29Merge git://git.denx.de/u-boot-arcTom Rini
2017-06-29ARM: at91: ma5d4: Support both SF and eMMC SoMsMarek Vasut
Discern the SoMs based on the presence of SPI flash to support both variants of the SoM, one booting from SPI NOR and one booting from eMMC. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Switch environment start to eMMCMarek Vasut
The redesigned version of the SoM which was released onto the market does no longer contain SPI flash, but boots from the eMMC. Move the environment storage to the eMMC. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Enable support for booting from eMMCMarek Vasut
The SoM has been redesigned to work around bug in the SoC and is now capable of booting from the eMMC. Add support for booting from eMMC. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2017-06-29ARM: at91: ma5d4: Swap SD/MMC controller orderMarek Vasut
The SDHCI1 is the primary boot controller on rev. 2.1 SoM, which is the version available on the market. Swap the controller order to match this and future versions of the SoM. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
