This patch is essentially an update of u-boot MTD subsystem to
the state of Linux-3.7.1 with exclusion of some bits:
- the update is concentrated on NAND, no onenand or CFI/NOR/SPI
flashes interfaces are updated EXCEPT for API changes.
- new large NAND chips support is there, though some updates
have got in Linux-3.8.-rc1, (which will follow on top of this patch).
To produce this update I used tag v3.7.1 of linux-stable repository.
The update was made using application of relevant patches,
with changes relevant to U-Boot-only stuff sticked together
to keep bisectability. Then all changes were grouped together
to this patch.
Signed-off-by: Sergey Lapin <slapin@ossfans.org>
[scottwood@freescale.com: some eccstrength and build fixes]
The Freescale MPC8220 Power Architecture processors have long reached
EOL; Freescale does not even list these any more on their web site.
Remove the code to avoid wasting maitaining efforts on dead stuff.
Cc: Andy Fleming <afleming@gmail.com>
Use QSGMII card PHY address as default SGMII card PHY address, QSGMII card
PHY address is variable depends on different slot.
Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
1, Implemented board_ft_fman_fixup_port() to fix port for kernel.
2, Implemented fdt_fixup_board_enet() to fix node status of different
slots and interfaces.
3, Adding detection of slot present for XGMII interface.
4, There is no PHY for XFI, so removed related phy address settings.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
T4160QDS shares the same platform as T4240QDS. T4160 is a low power
version of T4240, with eight e6500 cores, two DDR3 controllers, and
slightly different SerDes protocols.
Signed-off-by: York Sun <yorksun@freescale.com>
Separate CONFIG_PPC_T4240 from board config file. Prepare to add more SoC
variants supported on the same board.
T4240 has voltage ID fuse. Read the fuse and configure the voltage
correctly. Core voltage has higher tolerance on over side than below.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
T4240QDS uses a SST instead of SPANSION SPI flash.
powerpc-eldk53-warning-fixes
We don't use zlib and gzip but do use lzo, so enable this.
This is a convenient way of finding out where boottime is going. Enable
it for coreboot.
While we don't want PCAT timers for timing, we want timer 2 so that we can
still make a beep. Re-purpose the PCAT driver for this, and enable it in
coreboot.
This timer runs at a rate that can be calculated, well over 100MHz. It is
ideal for accurate timing and does not need interrupt servicing.
Tidy up some old broken and unneeded implementations at the same time.
To provide a consistent view of boot time, we use the same time
base as coreboot. Use the base timestamp supplied by coreboot
as U-Boot's base time.
Signed-off-by: Simon Glass <sjg@chromium.org>base
The gpio spec for bf54x and bf60x differ a lot from the old gpio driver for bf5xx.
A lot of machine macros are used to accomodate both code in one gpio driver.
This patch split the old gpio driver and move new gpio2 support to the generic
gpio driver folder.
- To enable gpio2 driver, macro CONFIG_ADI_GPIO2 should be defined in the board's
config header file.
- The gpio2 driver supports bf54x, bf60x and future ADI processors, while the
older gpio driver supports bf50x, bf51x, bf52x, bf53x and bf561.
- All blackfin specific gpio function names are replaced by the generic gpio APIs.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
- Move blackfin serial driver to the generic driver folder.
- Move blackfin serial headers to blackfin arch head folder.
- Update the include path to blackfin serial header in start up code.
- Enable hw_watchdog_init() in watchdog.h if CONFIG_HW_WATCHDOG is defined.
- Move blackfin hw watchdog driver to the generic driver folder.
- Call hw_watchdog_init() from blackfin board init code.
- Reuse macro CONFIG_WATCHDOG_TIMEOUT_MSECS
- Update README.watchdog accordingly
Remove blackfin specific implementation of the generic serial API when
early print macro is defined.
In BFIN_BOOT_BYPASS mode, don't call generic serial_puts, because
early print in bypass mode is running before code binary is relocated
to the link address.
- Disable NAND driver on bf537-stamp.
- Make MMC_SPI optional.
- Disable LCD driver on bf527-ezkit.
- Enlarge BF609 nor flash reserved size from 256k to 512k bytes.
Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
Add softswitch_output command for bf609-ezkit to enable softswitches.
Signed-off-by: Bob Liu <lliubbo@gmail.com>
Define core 1 L1 code sram start address.
Add function to enable core 1 for BF609 and BF561.
Add config macro to allow customer to run core 1 in uboot init code on core 0.
Enable VIDEO and NAND supports only when the config options is defined.
Microblaze uses gpio which is connected to the system reset.
Currently gpio subsystem wasn't used for it.
Add gpio driver and change Microblaze reset logic to be done
via gpio subsystem.
There are various configurations which Microblaze can have
that's why gpio_alloc/gpio_alloc_dual(for dual channel)
function has been introduced and gpio can be allocated
dynamically.
Adding several gpios IP is also possible and supported.
For listing gpio configuration please use "gpio status" command
This patch also remove one compilation warning:
microblaze-generic.c: In function 'do_reset':
microblaze-generic.c:38:47: warning: operation on '*1073741824u'
may be undefined [-Wsequence-point]
With the u-boot-with-spl.bin rule calling $(OBJCOPY) with
CONFIG_SPL_PAD_TO, and CONFIG_SPL_PAD_TO defaulting to
CONFIG_SPL_MAX_SIZE we cannot use math here, so set it to 4096 rather
than 4 * 1024.
The Hydra and Superhydra (P3041DS, P5020DS, and P5040DS) boards have a
second USB port that can be configured in either host, peripheral (aka
device), or OTG (on-the-go) mode. When configured in host mode, if
the port is connected to another USB host, damage to the board can
occur.
To avoid this, we change the default setting to peripheral mode. Ideally,
we'd set it to OTG mode, but currently there is no OTG support for
these boards.
Setting the hwconfig variable will also update the device tree, and so
Linux will configure the port for peripheral mode as well.
Signed-off-by: Timur Tabi <timur@tabi.org>
Add defines needed to access NAND, remove second flash bank that is
actually connected to NAND.
Add nand booting support for P1022DS with hardcoded DDR config using
SPL framework from 2011
Signed-off-by: Matthew McClintock <msm@freescale.com>
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Signed-off-by: Jiang Yutang <b14898@freescale.com>
The changes to a3m071/a4m2k in summary are:
- Enable CAN1 on I2C in GPS Port Configuration
- Enable SPI on PSC2
- Activate network console
- New flash partitioning
- Fix some typos
- Pass host name to Linux
- Change rootfs to squashfs,jffs2
- Enable UBI/UBIFS support
- Enable FIT support
The v2013.04 release has this patch set included:
5cb48582 "Add architecture-specific global data"
With this, the global_data struct is now common and new variables
have been added. Resulting in a bigger struct. Unfortunately the
currently allocated 128 bytes are just a bit too small for this
new struct.
This patch now uses the automatically generated struct size instead to
not run into this problem again.
Please note that this problem might hit some other platforms which
currently reserve a tight space of 128 bytes for the global_data
struct!
Cc: Sricharan R <r.sricharan@ti.com>
The redundancy related defines are only correct for NAND, so guard all
of that area with CONFIG_ENV_IS_IN_NAND
Cc: Fabio Estevam <fabio.estevam@freescale.com>
In order to use the generic hang() later on pull libgeneric in SPL.
This has no impact on the SPL size.
Align some comments.
include/configs/m28evk.h
Change all "#define<TAB>" sequences into "#define<SPACE>"
Enable these options to use FITs on sandbox.
With sandbox it is tricky to add an FDT to the image at build time (or
later) since we build an ELF file, not a plain binary, and the address
space of the whole U-Boot is not accessible in the emulated memory map
of sandbox.
Sandbox can read files directly from the host, though, so add an option
to read an FDT from a host file on start-up.
Add generic board support for sandbox. and remove the old board init code.
Select CONFIG_SYS_GENERIC_BOARD for sandbox now that this is supported.
Reviewed-by: Tom Rini <trini@ti.com>
Watchdog can be used on Microblaze, PPC and Zynq hw designs.
Setup environment and enable netconsole.
This patch adds the fast booting LWMON5 derivat "lcd4_lwmon5".
Its a stripped down version of the full blown lwmon5 support,
without ECC, USB, POST and some other stuff. It used the newly
introduced SPL infrastrucure for SPL from NOR flash booting
on the PPC4xx.
By setting the environment variable "boot_os" to "yes", Linux
will be started from the SPL version. If not, the "normal"
U-Boot will be started.
Quick manual fixup to merge the USB boot related defines and TPM related
defines.
include/configs/exynos5250-dt.h
Exynos5250 supports secondary USB device boot mode. If the iROM fails
to download u-boot from the primary boot device (such as SD or eMMC),
it will try to retrieve from the secondary boot device (such as USB).
Signed-off-by: Naveen Krishna Ch <ch.naveen@samsung.com>
Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com>
Since the ICH SPI controller uses PCI, we must ensure that PCI is available
before it is inited.
This fixes the current "ICH SPI: Cannot find device" message on boot.
