Unfortunately, that missing M makes the current downstream NXP BSP
4.14.98_2.0.0_ga crash early during Linux kernel boot. Fix this.
Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Tested-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Switch to the generic compressed Kernel image type (zImage) instead of
the U-Boot specific uImage format.
1. This fixes linking issues when building with DM_VIDEO enabled mxsfb
driver.
2. Provide proper defines for both VIDEO=y and DM_VIDEO=y.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Added default environment for hdp loading.
Added hdp loading as default for iMX8QM MEK board.
Signed-off-by: Oliver Brown <oliver.brown@nxp.com>
(cherry picked from downstream commit 432e5b4347841095c3b5a8a0d106f35deadd006e)
(cherry picked from downstream commit cb78a32fa8eb8c37932be003ebe4fa1f8c46c1d5)
Fix booting for wandboard
One of the SD-CARD slots on the Wandboard Quad B1 is MMC 2. Enable it as a
boot device.
Reviewed-by: Fabio Estevam <festevam@gmail.com>
- fix complation error for CONFIG_USB
- update RPi3 DTBs to v5.1-rc6 state
- add defconfig for RPi3 B+
- Fix BCM2835_MBOX_TAG_TEST_PIXEL_ORDER define
The raw u-boot.bin for tinker board has been about 450KB without
debug option, and 550KB with all debug on, and the default value is 200KB,
which is not enough for run raw u-boot.bin.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
Fixes for 2019.07
- menlo board
- allow SDB on Sabre
- HAB for mx6sl
- apalis board
Default value (4000ms) of PHY_ANEG_TIMEOUT for Micrel KSZ9031 contoller
isn't sufficient to finish auto-negotiation, which sometimes leads to
timeout errors:
Apalis iMX6 # dhcp
FEC Waiting for PHY auto negotiation to complete......... TIMEOUT !
Increase the auto-negotiation time-out to 15000ms.
Reviewed-by: Philippe Schenker <philippe.schenker@toradex.com>
Enable DM Video support on iMX53 M53Menlo and fix minor details
to restore previous behavior of the system.
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Since the pico-pi uses the distroboot,
this commit remove the 'script' variable (cf boot_scripts).
Signed-off-by: Pierre-Jean Texier <pjtexier@koncepto.io>
Fix set_emmcargs wrapper, which prepares proper bootargs for booting
from eMMC.
Add SPL support for rk3328, default with of-platdata enabled.
[cherry picked from https://github.com/rockchip-linux/u-boot/commit/cb2b7a1bc75ebb116b1eb9b0ae0223e84d86fc4b with minor modifications]
Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Extra "not DM" controllers support is disabled.
u-boot BSP still good enough to upgrade and run images.
Signed-off-by: Oleksandr Zhadan <oleks@arcturusnetworks.com>
Signed-off-by: Michael Durrant <mdurrant@arcturusnetworks.com>
- PCIe driver change to support DM model
- T2080QDS migrated to use PCIe DM model
Disable legacy PCIe driver and unused PCIe macros when DM_PCI enabled.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Use the Kconfig option to select the PCIe reset errata.
- LS1046AFRWY support
- USB errata fix and secure boot defconfig support for LS1028A
- Enabled SDHC and SATA for LX2160
- LS1046A serdes fixes
- other minor fixes
LS1046AFRWY board supports LS1046A family SoCs. This patch
add base support for this board.
Board support's 4GB ddr memory, i2c, micro-click module,microSD card,
serial console,qspi nor flash,ifc nand flash,qsgmii network interface,
usb 3.0 and serdes interface to support two x1gen3 pcie interface.
Signed-off-by: Camelia Groza <camelia.groza@nxp.com>
Signed-off-by: Madalin Bucur <madalin.bucur@nxp.com>
Signed-off-by: Pankit Garg <pankit.garg@nxp.com>
Signed-off-by: Pramod Kumar <pramod.kumar_1@nxp.com>
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Signed-off-by: Vabhav Sharma <vabhav.sharma@nxp.com>
During SD boot, MC firmware and DPC are copied from SD card to DDR.
Size reserved between MC and DPC firmware on DDR is 1MB.
If the size of MC firmware(load address 0x80000000) is more than 1 MB
then part of MC firmware will be overwritten by DPC firmware (load
address 0x80100000).
Fix: Update the MC/DPL/DPC firmware's DDR address as per their
respective addresses in SD card.
Signed-off-by: Wasim Khan <wasim.khan@nxp.com>
Add bootcmd for IFC NOR boot and SD boot.
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com>
Add secure boot defconfig for ls1028aqds and ls1028ardb boards.
Signed-off-by: Yuantian Tang <andy.tang@nxp.com>
Default environment variable is more complete. Also scans for efi
binaries for example.
Signed-off-by: Mian Yousaf Kaukab <ykaukab@suse.de>
- Drop zipitz2 board (Tom)
- Add DEPRECATED option (Tom)
- Mark legacy or non-dm drivers as DEPRECATED (Jagan)
- More board removal
In order to migrate this symbol to Kconfig introduce a new symbol to
guard it, CONFIG_SYS_CUSTOM_LDSCRIPT. When that is set we can then
provide the exact final location o the script.
A number of boards set CONFIG_SYS_LDSCRIPT and then end up using one of
the default searched LDSCRIPT paths. Remove these customizations.
The non-CONFIG_SPL_FRAMEWORK SPL used on some PowerPC platforms have a
choice between CONFIG_SPL_NAND_BOOT, CONFIG_SPL_MMC_BOOT and
CONFIG_SPL_SPI_BOOT. Migrate this to Kconfig
Convert CONFIG_TFTP_BLOCKSIZE to Kconfig, update defconfigs,
headers and whitelist.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Convert CONFIG_IP_DEFRAG to Kconfig, update defconfigs, headers
and whitelist. This patch is a follow-up on a patch by Christian
Gmeiner with the added config/header/whitelist updates.
Reported-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Last change to this board was done in 2016, has no prospects of
ever being converted to DM, drop it.
Cc: Chris Brandt <chris.brandt@renesas.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Cc: Vladimir Zapolskiy <vz@mleia.com>
Cc: Yoshihiro Shimoda <shimoda.yoshihiro.uh@renesas.com>
Now that various SPI related options depend on CONFIG_DEPRECATED, in
order for platforms to build out of the box they need to disable various
other options.
Cc: Albert ARIBAUD <albert.aribaud@3adev.fr>
Reviewed-by: Marek Vasut <marek.vasut@gmail.com>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Per discussion on the list, drop this board again.
Cc: Vasily Khoruzhick <anarsoul@gmail.com>
Acked-by: Vasily Khoruzhick <anarsoul@gmail.com>
This patch is to fix the following compilation error when
disabling CONFIG_USB for Rpi3:
include/config_distro_bootcmd.h:242:2: error: expected ‘}’
before ‘BOOT_TARGET_DEVICES_references_USB_without_CONFIG_CMD_USB’
Signed-off-by: Ajay Kaher <akaher@vmware.com>
Signed-off-by: Matthias Brugger <mbrugger@suse.com>
- Add Ethernet support for STM32MP1
- Add saveenv support for STM32MP1
- Add STM32MP1 Avenger96 board support
- Add SPI driver suport for STM32MP1
- Add watchdog support for STM32MP1
- Update power supply check via USB TYPE-C for STM32MP1 discovery board
u-boot-imx-20190612
- Board fixes:
- imx6logic
- wandboard
- mx6sabre boots again
- imx8qm_mek
- pico-* boards
- Toradex apalis / colibri
- engicam imx6 (environment)
- KP MX53
- opos6ul
- Switch to DM:
- vining2000
- dh MX6
- Toradex colibri i.MX7
- Novena
- Security : fix CSF size for HAB
- Other:
- imx: fix building for i.mx8 without spl
- pcie and switch to DM
mx6sabreauto: Enable SPL SDP support
Enable DM Serial support on iMX6SX VINING|2000.
Cc: Silvio Fricke <silvio.fricke@softing.com>
Remove such unneeded custom config options because the
provided default values are good enough.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Acked-by: Peng Fan <peng.fan@nxp.com>
Extend PHYTEC phyBOARD-i.MX6UL for phyCORE-i.MX6UL SoM (PCL063)
with eMMC on SoM.
CPU: Freescale i.MX6ULL rev1.0 792 MHz (running at 396 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 38C
Reset cause: POR
Model: Phytec phyBOARD-i.MX6ULL-Segin SBC
Board: PHYTEC phyCORE-i.MX6ULL
DRAM: 256 MiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
In: serial@02020000
Out: serial@02020000
Err: serial@02020000
Net: FEC0
Working:
- Eth0
- i2C
- MMC/SD
- eMMC
- UART (1 & 5)
- USB (host & otg)
Signed-off-by: Parthiban Nallathambi <parthitce@gmail.com>
