path: root/include/configs
2015-11-21ns16550: zap CONFIG_NS16550_SERIALThomas Chou
Zap CONFIG_NS16550_SERIAL, as the unification of ns16550 drivers is completed. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-21ns16550: unify serial_omapThomas Chou
Unify serial_omap, and use the generic binding. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-21ns16550: unify serial_tegraThomas Chou
Unify serial_tegra, and use the generic binding. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-21ns16550: unify serial_dwThomas Chou
Unify serial_dw, and use the generic binding. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-21ns16550: unify serial_keystoneThomas Chou
Unify serial_keystone, and use the generic binding. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-19sandbox: Enable USB keyboardSimon Glass
Enable the USB keyboard on sandbox, now that we have a suitable emulation driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-19sandbox: Enable console recording and silent consoleSimon Glass
Allow console recording so that tests can use it. Also allow the console output to be suppressed, to reduce test output 'noise'. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-19x86: qemu: Convert to use driver model keyboardBin Meng
Convert to use driver model keyboard on QEMU. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-19x86: crownbay: Convert to use driver model keyboardBin Meng
Convert to use driver model keyboard on Intel Crown Bay. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-11-19Drop CONFIG_ISA_KEYBOARDSimon Glass
This option is mentioned but does not do anything. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-19x86: Add an i8042 device for boards that have itSimon Glass
Some boards have an i8042 device. Enable the driver for all x86 boards, and add a device tree node for those which may have this keyboard. Also adjust the configuration so that i8042 is always separate from the VGA, and rename the stdin driver accordingly. With this commit the keyboard will not work, but it is fixed in the next commit. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-19sandbox: add a sandbox timer and basic testThomas Chou
Add a sandbox timer which get time from host os and a basic test. Signed-off-by: Thomas Chou <thomas@wytron.com.tw> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-11-19video: Drop unused console functionsSimon Glass
CONFIG_CONSOLE_CURSOR, CONFIG_SYS_CONSOLE_BLINK_COUNT and CONFIG_CONSOLE_TIME are not used by any board. The implementation is not great and stands in the way of a refactor of i8042. Drop these for now. They can be re-introduced quite easily later, perhaps with driver-model real-time-clock (RTC) support. When reintroducing, it might be useful to make a few changes: - Blink time would be more useful than blink count - The confusing #ifdefs should be avoided - The time functions should support driver model - It would be best keyed off console_tstc() or some similar idle loop rather than a particular input driver (i8042 in this case) Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-19Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
2015-11-19zynq: sdhci: Define max clock by macroMichal Simek
zc1571 with silicon can operate on 200MHz maximum frequency. Setup this frequency by default and fix setting for ep108. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-11-19ARM64: zynqmp: Enable TI phy by defaultMichal Simek
Enable TI phy for Xilinx ZynqMP platform. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-11-19ARM: zynq: Choose boot image based on OF_SEPARATE macroMichal Simek
OF_CONTROL is enabled by default for all Zynq boards. The difference between two boot images is done by OF_SEPARATE or OF_EMBED macros. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-18powerpc/83xx: add support for kmtegr1 boardValentin Longchamp
This board uses the same CPU (8309) as VECT1. The memory however is different since it has NAND Flash, the NOR Flash partitioning is different and of course the FPGAs as well. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Christoph Dietrich <christoph.dietrich@keymile.com>
2015-11-18km8309: change the default QE_FW addressValentin Longchamp
It should be after the u-boot reserved sectors and before the env sectors, since the solution used for kmvect1 (tell the linker to put the firmware into the u-boot produced binary, at the end of the area) should be the exception. The #define is only "conditional" so that we can still support kmvect1. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18km83xx: use CONFIG_ENV_ADDR for the newenv env commandValentin Longchamp
The hardcoded value are bad, since the address could change between different boards. Furthermore, the relevant #defines are set only if #undefined here, so that they can be changed by some boards if required. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18powerpc/km8360: fix the ODT parameters for CS0Valentin Longchamp
The ODT parameters for km8360 set the ODT_WR_ACS bit in u-boot KM-2011.09 that is used in the release bootpackage for kmcoge5ne. During the transition from the kmeter1 to km8360 this was changed to ODT_RD_ONLY_CURRENT, which is uncorrect and causes faulty RAM accesses at low temperatures. This is now changed to ODT_WR_ONLY_CURRENT which is the equivalent of ODT_WR_ACS. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18powerpc/km8309: define CONFIG_SYS_DDRCDRValentin Longchamp
For consistency with all the other km83xx plaforms, this should also be defined for km8309. The same settings as for km8321 are taken. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18powerpc/km8321: define CONFIG_SYS_DDRCDRValentin Longchamp
On the km8321 boards is CONFIG_SYS_DDRCDR not defined, which leads to the DDRCDR not being configured at startup and still containing the reset value. The required settings for our km8321 hardware designs are different than the reset value and must be set with CONFIG_SYS_DDRCDR, that is used by mpc83xx's cpu_init_f function at early CPU initialization. The important settings are the DDR2 internal voltage level and the half-strength "drivers". In our case where the DRAM chips are soldered on board and the routing for these signals under control, half-strength is sufficient as a few measurements done in the lasts have shown. Since all the hardware qualification tests have been performed with half strength, the nominal strength settings are removed in favor of the default reset half strength settings. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18km/powerpc: move open firmware defines to km-powerpc.hHolger Brunck
We use the same settings for open firmware defines on all our powerpc targets, so move them from the CPU specific headers to the common powerpc header. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18km/powerpc: increase space for kernel imange and FDT blobHolger Brunck
128kByte and 3,986MB may be in the future too little for kernel the fdt blob respectively the kernel image. So increase the reserved areas here, we have the space for this. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18powerpc/83xx: add support for kmtepr2 boardChristoph Dietrich
This board is similar to TUXX1, but it has differend FPGAs. Signed-off-by: Christoph Dietrich <christoph.dietrich@keymile.com> Signed-off-by: Andreas Huber <andreas.huber@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18km: update the boot script to check for a DTBValentin Longchamp
If a DTB is found with cramfsls, the bootscript continues as expected. If none is found, the cramfsloadfdt and boot subbootcmds are updated to not load the DTB from cramfs and not pass it to the kernel. The kernel thus must have an appended DTB otherwise the boot will fail. This is required for the km_kirkwood boards that must support .esw where the DTB sometimes is appended (for backwards compatibility) and sometimes is passed correctly (as we do now for all newer boards). Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-11-18km/common: stop u-boot only if someone press <SPACE>Holger Brunck
To prevent u-boot to stop accidently e.g. due to line noise on the serial line, we now use the option CONFIG_AUTOBOOT_KEYED. We choose the <SPACE> key for this. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-11-18arm/km_kirkwood: remove KM_ENV_BUS and use CONFIG_I2C_ENV_EEPROM_BUSValentin Longchamp
KM_ENV_BUS was used for nothing else than an direct assignment to CONFIG_I2C_ENV_EEPROM_BUS. To avoid this, directly use CONFIG_I2C_ENV_EEPROM_BUS instead. Patchwork: http://patchwork.ozlabs.org/patch/399411/ Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2015-11-18board/ti/am335x: add support for BeagleBone Greenrobertcnelson@gmail.com
SeeedStudio BeagleBone Green (BBG) is clone of the BeagleBone Black (BBB) minus the HDMI port and addition of two Grove connectors (i2c2 and usart2). This board can be identified by the 1A value after A335BNLT (BBB) in the at24 eeprom: 1A: [aa 55 33 ee 41 33 33 35 42 4e 4c 54 1a 00 00 00 |.U3.A335BNLT....|] http://beagleboard.org/green http://www.seeedstudio.com/wiki/Beaglebone_green In Mainline Kernel as of: https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit/?id=79a4e64c679d8a0b1037da174e4aea578c80c4e6 Patch tested on BeagleBone Black (rev C) and BeagleBone Green (production model) Signed-off-by: Robert Nelson <robertcnelson@gmail.com> CC: Tom Rini <trini@konsulko.com> CC: Jason Kridner <jkridner@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-11-18arm: mx6: cm-fx6: define fallback boot devices for splNikita Kiryanov
Use spl alternate boot device feature to define fallback to the main boot device as it is defined by hardware. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Stefano Babic <sbabic@denx.de>
2015-11-18board: ti: beagle_x15: Rename to indicate support for TI am57xx evmsKipisz, Steven
BeagleBoard X15 (http://beagleboard.org/x15) support in u-boot does actually support two different platform configuration offered by TI. In addition to BeagleBoard X15, it also supports the TMDXEVM5728 (or more commonly known as AM5728-evm). Information about the TI AM57xx EVM can be found here http://www.ti.com/tool/tmdxevm5728 The EVM configuration is 1-1 compatible with BeagleBoard X15 with the additional support for mPCIe, mSATA, LCD, touchscreen, Camera, push button and TI's wlink8 offering. Hence, we rename the beagle_x15 directory to am57xx to support TI EVMs that use the AM57xx processor. By doing this we have common code reuse. This sets the stage to have a common u-boot image solution for multiple TI EVMs such as that already done for am335x and am437x. This sets the stage for upcoming multiple TI EVMs that share the same code base. NOTE: Commit eae7ae185335 ("am437x: Add am57xx_evm_defconfig using CONFIG_DM") introduced DT support for beagle_x15 under am57xx_evm platform name. However, this ignored the potential confusion arising for users as a result. To prevent this, existing beagle_x15_defconfig is renamed as am57xx_evm_nodt_defconfig to denote that this is the "non device tree" configuration for the same platform. We still retain am57xx-beagle-x15.dts at this point, since we just require the common minimum dts. As a result of this change, users should expect changes in build procedures('make am57xx_evm_nodt_defconfig' instead of 'make beagle_x15_defconfig'). Hopefully, this would be a one-time change. Signed-off-by: Steve Kipisz <s-kipisz2@ti.com> Signed-off-by: Schuyler Patton <spatton@ti.com> Acked-by: Nishanth Menon <nm@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-11-17Merge git://git.denx.de/u-boot-marvellTom Rini
2015-11-17arm: kirkwood: ib62x0: drop duplicate defines from CONFIG_SYS_MVFSLuka Perkov
These options were already defined in mv-common.h file. Signed-off-by: Luka Perkov <luka.perkov@sartura.hr>
2015-11-17arm: kirkwood: ib62x0: drop dev CONFIG_OF_LIBFDTLuka Perkov
It is already defined in included mv-common.h file. Signed-off-by: Luka Perkov <luka.perkov@sartura.hr>
2015-11-17arm: kirkwood: ib62x0: make use of defconfigLuka Perkov
2015-11-17arm: kirkwood: ib62x0: drop CONFIG_CMD_ENV defineLuka Perkov
The CONFIG_CMD_ENV is enabled by default so we can safely remove it. Signed-off-by: Luka Perkov <luka.perkov@sartura.hr>
2015-11-17arm: kirkwood: ib62x0: build u-boot.kwbLuka Perkov
Avoid double typing in the shell and build u-boot.kwb when running "make" only. Signed-off-by: Luka Perkov <luka.perkov@sartura.hr>
2015-11-17arm: kirkwood: ib62x0: drop CONFIG_MACH_TYPELuka Perkov
Mainline kernel for this device has only support for device tree. We can safely drop this legacy code. Signed-off-by: Luka Perkov <luka.perkov@sartura.hr>
2015-11-17arm: kirkwood: Move common definitions into common fileQuentin Armitage
Create include/configs/mv-plug-common.h for common definitions for Sheevaplug, Guruplug and Dreamplug. This will make it easier to ensure the built u-boots stay in track with each other Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-11-17arm: kirkwood: Remove duplicate definition from dreamplug.hQuentin Armitage
CONFIG_DISPLAY_CPUINFO is already defined in mv-common.h Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-11-17arm: kirkwood: Align configuration filesQuentin Armitage
Cosmetic: CONFIG_OF_LIBFDT was in a different position in the config file for the Dreamplug, compared to the Sheevaplug and Guruplug. Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-11-17arm: kirkwood: Use common definition for filesystemsQuentin Armitage
include/configs/mv-common.h brings in the required filesystems if CONFIG_SYS_MVFS is defined, so use it for Sheevaplug and Guruplug. Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-11-17arm: kirkwood: Move configuration of some commands to _defconfig filesQuentin Armitage
For Marvell plugs, move the configuration of DHCP, NAND/SF, PING and USB commands, and HUSH_PARSER into the _defconfig file, rather than the include/configs/*plug.h files. This avoids compiler warnings of duplicate definitions if the option is selected in the .config, but also defined in the include/configs/*plug.h file. Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-11-17arm: kirkwood: Remove duplicate definition of CONFIG_CMD_FATQuentin Armitage
include/configs/guruplug.h defined CONFIG_CMD_FAT twice. Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-11-17arm: kirkwood: standardise the configurationQuentin Armitage
The Marvell plugs are very similar systems, and so it makes sense for their u-boots to have the same commands/configuration. Add EXT4 and MII to Dreamplug, DATE to Guruplug and Sheevaplug. Add CONFIG_SYS_ALT_MEMTEST to Sheevaplug. There are still command differences around NAND, SPI/NOR. Also default to building u-boot.kwb for Sheevaplug and Guruplug. Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-11-18board: axs10x switch serial port and Ethernet to driver modelAlexey Brodkin
With this change Synopsys DesignWare SDP board is switched to driver model for both serial port (serial_dw) and Ethernet (Designware GMAC). This simplifies include/configs/axs101.h and allows for reuse of Linux's Device Tree description. For simplicity Linux's .dts files are not blindly copied but only very few extracts of them are really used (those that are supported in U-Boot at the moment). Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Reviewed-by: Simon Glass <sjg@chromium.org> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-11-17ARM: am43xx: Enable QUAD read and EDMA support for ti_qspiVignesh R
Enable TI_EDMA3 and QUAD read support for ti_qspi on am43xx, this increases read performance to 4 MB/s. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-11-16Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
