2006-03-08 | Enable simple (non-redundant) NAND environment on delta board. | Markus Klotzbücher | |
2006-03-06 | Merge with /home/wd/git/u-boot/master | Wolfgang Denk | |
Code cleanup. | |||
2006-03-06 | Turned on SDRAM scrubbing. | Markus Klotzbücher | |
2006-03-06 | Cleanup of NAND support of delta board using the Monahans Data Flash | Markus Klotzbücher | |
Controller. | |||
2006-03-06 | NAND finally working. Two bugs fixed: | Markus Klotzbücher | |
* For READ_STATUS and READID commands always 8 bytes need to be read from NDDB. Otherwise they stay there and get send to flash as the first data word when writing. * In nand_base.c the oob variable is not reset so this->oob_buf is overwritten what eventually screws up the bad block descriptor table. | |||
2006-03-06 | Minor code cleanup | Wolfgang Denk | |
2006-03-06 | Merge the new NAND code (testing-NAND brach); see doc/README.nand | Wolfgang Denk | |
Rewrite of NAND code based on what is in 2.6.12 Linux kernel Patch by Ladislav Michl, 29 Jun 2005 [Merge with /home/tur/nand/u-boot] | |||
2006-03-05 | Re-factoring the legacy NAND code (legacy NAND now only in board-specific | Bartlomiej Sieka | |
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards. | |||
2006-03-04 | Lots of new stuff: | Markus Klotzbücher | |
* Debug message can be turned on and off. * Waiting for events now times out. * Implemented RESET command. * Added appropriate nand_bbt_descriptor and nand_oobinfo. Remaining Problems: * Read Status still behaves weird an returns invalid stuff sometimes. * ECC Placement does not respect our scheme in nand_oobinfo. | |||
2006-02-28 | Added GPIO initialization of DF signal. Still not working. | Markus Klotzbücher | |
2006-02-28 | Update mcc200 config: Disable PCI and DoC, use 133 MHz IPB clock, | Wolfgang Denk | |
use hush shell. | |||
2006-02-28 | First steps implementing NAND support. Not working, fails to read ID. | Markus Klotzbücher | |
2006-02-28 | Merge with Stefan Roese's branch with CFI driver fixes | Wolfgang Denk | |
2006-02-28 | Merge with /home/wd/git/u-boot/master | Wolfgang Denk | |
2006-02-28 | Convert mcc200 to use common CFI flash driver | Stefan Roese | |
Patch by Stefan Roese, 28 Feb 2006 | |||
2006-02-24 | Merge /home/tur/nand/u-boot/ | Markus Klotzbücher | |
This is a first version of the testing-NAND branch merged back to main. | |||
2006-02-24 | Merge branch 'master' of http://www.denx.de/git/u-boot | Markus Klotzbücher | |
2006-02-24 | Merge with /home/wd/git/u-boot/testing-NAND/ to add new NAND handling. | Bartlomiej Sieka | |
2006-02-22 | SDRAM now working. | Markus Klotzbücher | |
2006-02-22 | SDRAM now working for delta board, but there are still aliasing problems, | Markus Klotzbücher | |
we only see 64MB. | |||
2006-02-22 | Rename SMMACO4 board into smmaco4 for consistency with Linux. | Wolfgang Denk | |
2006-02-22 | Disable CMD_BSP for SMMACO4 board. | Wolfgang Denk | |
2006-02-22 | Merge with /home/hs/PanDacom/u-boot-dev | Wolfgang Denk | |
2006-02-22 | Initial port to MCC200 board (work in progress) | Wolfgang Denk | |
Minimally modified patch by Bluetechnix, Vienna | |||
2006-02-21 | Merge with /home/sr/git/u-boot | Wolfgang Denk | |
2006-02-20 | [Patch] Add basic support for the SMMACO4 Board from PanDaCom. | Heiko Schocher | |
Signed-off-by: Heiko Schocher <hs@denx.de> | |||
2006-02-20 | New board directory and config for the benq delta board (copied from | Markus Klotzbücher | |
zylonite). Minor pxa-regs.h update. | |||
2006-02-20 | Merged and added more pxa-regs.h stuff, especially the GPIO Control | Markus Klotzbücher | |
Register Definitions. | |||
2006-02-19 | Merged sufficient changes to pxa-regs.h in order to make u-boot compile. | Markus Klotzbücher | |
It doesn't run yet. | |||
2006-02-10 | Config updated for compiling the SMC911111 network driver | Markus Klotzbücher | |
2006-02-09 | basic u-boot is working, boots into the command shell. | Markus Klotzbücher | |
2006-02-08 | Convert CPCI750 to use common CFI flash driver | Stefan Roese | |
Patch by Reinhard Arlt, 8 Feb 2006 | |||
2006-02-07 | Forgot to add files to zylonite branch. | Markus Klotzbücher | |
2006-02-07 | Various changes to esd HH405 board specific files | Stefan Roese | |
Patch by Matthias Fuchs, 07 Feb 2006 | |||
2006-02-07 | Update default environment for INKA4x00 board. | Wolfgang Denk | |
2006-01-18 | Add VGA support (CT69000) to CPCI750 board. | Stefan Roese | |
Insert missing __le32_to_cpu() for filesize in ext2fs_read_file(). Patch by Reinhard Arlt, 30 Dec 2005 | |||
2006-01-18 | PMC405 and CPCI405: Moved configuration of pci resources into config file. | Stefan Roese | |
PMC405 and CPCI2DP: Added firmware download and booting via pci. Patch by Matthias Fuchs, 20 Dec 2005 | |||
2006-01-13 | Fix 28F256J3A support on PM520 board | Wolfgang Denk | |
(without bank-switching only 32 MB can be accessed) | |||
2005-12-29 | Add support for 28F256J3A flah (=> 64 MB) on PM520 board | Wolfgang Denk | |
2005-12-06 | Change port configuration for O2DNT (CODEC1 on PSC1) | Marian Balakowicz | |
2005-12-04 | Code cleanup, especially MIPS for GCC 4.x | Wolfgang Denk | |
2005-12-01 | Merge with /home/sr/git/u-boot | Wolfgang Denk | |
2005-12-01 | Adjust TQM834x PHY addresses for latest hardware revision. | Wolfgang Denk | |
2005-12-01 | Increase malloc arena on TQM5200 board to 256 kB. | Wolfgang Denk | |
With 64 kb uniform flash sector size the old value of 128 kB was too small. | |||
2005-11-30 | Add support for TQM8541/8555 boards, TQM85xx support reworked: | Stefan Roese | |
- Support for TQM8541/8555 boards added. - Complete rework of TQM8540/8560 support. - Common TQM85xx code now supports all current TQM85xx platforms (TQM8540/8541/8555/8560). - DDR SDRAM size detection added. - CAS latency default values can be overwritten by setting "serial#" to e.g. "ABC0001 casl=25" -> CAS latency 2.5 will be used. If problems are detected with this non default CAS latency, the defualt values will be used instead. - FLASH size detection added. - Moved FCC ethernet driver initialization behind TSEC driver init -> TSEC is first device. Patch by Stefan Roese, 30 Nov 2005 | |||
2005-11-29 | Add support for AMCC 440SP, add support for AMCC Luan 440SP eval board. | Stefan Roese | |
Patch by John Otken, 23 Nov 2005 | |||
2005-11-27 | Increase IPB and PCI clocks for O2DNT board. | Marian Balakowicz | |
2005-11-27 | Changed PPC44x startup message (cpu info, speed...) to common style: | Stefan Roese | |
On PPC44x platforms, the startup message generated in "cpu.c" only comprised the ppc type and revision but not additional informations like speed etc. Those speed infos where printed in the board specific code. This new implementation now prints all CPU infos in the common cpu specific code. No board specific code is needed anymore and therefore removed from all current 44x implementations. Patch by Stefan Roese, 27 Nov 2005 | |||
2005-11-22 | Add support for Prodrive P3P440 board: | Stefan Roese | |
- Added onboard PPC440 DDR autodetection in cpu/ppc/sdram.c - CFG_FLASH_QUIET_TEST added to use the common CFI driver for bank autodetection Patch by Stefan Roese, 22 Nov 2005 | |||
2005-11-20 | Change all '$(...)' variable references into '${...}' | Wolfgang Denk | |
which makes the environment compatible with the hush shell. WARNING: Support for the old '$(...)' syntax will be discontinued in a later version. |
