The patch adds support for setting gpios to the
MX51 processor and change name to the corresponding
functions for MX31. In this way, it is possible to get rid
of nasty #ifdef switches related to the processor type.
include/ppc4xx.h
continuation of commit 39da1ba923d55f316f9f1bb3a960e4ed91dc17ac:
"e300: increase CONFIG_SYS_BOOTMAPSZ to allow booting large kernels"
This patch provides support for MPC8308 P1M board with the following
set of features:
Dual UART is supported
NOR flash is supported
Both TSEC Ethernet controllers are supported
PCI Express initialization is supported
Both I2C controllers are supported
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
This patch cleans up the Freescale MPC8308RDB Development board support.
Things fixed:
- Removed unused PCIE2 definitions from configuration
- SICR{L,H} defines used for System I/O Configuration Registers values
instead of hardcoding
- CONFIG_SYS_SCCR_PCIEXP1CM used to enable PCIE clock instead of
writing to SCCR from the board code
- sleep mode stuff removed as MPC8308 has no support for deep sleep and
PMCCR1 register. board_early_init_f() removed.
- MPC8308 has no ERRATA for DDR controller so workaround removed
- 'assignment in if statement' issues solved
- use LBLAWAR_* defines instead of hardcoding
Newer Linux kernels can overrun the initial memory window used for
booting with their BSS area. When this happens, they overwrite the FDT
and silently fail to boot.
On e300 CPUs, the Linux kernel uses an initial BAT covering the first
256MB of RAM. See arch/powerpc/kernel/head_32.S for details. Increase
the value of CONFIG_SYS_BOOTMAPSZ to accommodate the maximum value
allowed by Linux. This will allow very large kernels to boot.
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
The default partition table matches the .dts files for these boards in
Linux. This allows these partitions to be used by name with U-Boot's
"nand" command.
Remove some unused functionality to make U-Boot build again.
Especially PCI is not used on the board.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO
feature from U-Boot. It has only been implemented for PPC4xx and was not
used at all. So let's remove it and make the code smaller and cleaner.
Acked-by: Detlev Zundel <dzu@denx.de>
This patch removes the PPC4xx UART driver. Instead the common NS16550
driver is used, since all PPC4xx SoC's use this peripheral device.
The file 4xx_uart.c now only implements the UART clock calculation
function which also sets the SoC internal UART divisors.
All PPC4xx board config headers are changed to use this common NS16550
driver now.
Tested on these boards:
acadia, canyonlands, katmai, kilauea, sequoia, zeus
This cleanup is done by creating header files for all SoC versions and
moving the SoC specific defines into these special headers. This way the
common header ppc405.h and ppc440.h can be cleaned up finally.
As a part from this cleanup, the GPIO definitions for PPC405EP are
corrected. The high and low parts of the registers (for example
CONFIG_SYS_GPIO0_OSRL vs. CONFIG_SYS_GPIO0_OSRH) have been defined in
the wrong order. This patch now fixes this issue by switching these
xxxH and xxxL values. This brings the GPIO 405EP port in sync with all
other PPC4xx ports.
This patch starts a bit PPC4xx header cleanup. First patch mostly
touches PPC440 files. A later patch will touch the PPC405 files as well.
This patch changes the behaviour of the fdt_fixup_nor_flash_node()
function. Now it doesn't patch the size of the "reg" property with the
chip-select size, but with the size returned from the new function
flash_get_bank_size(). This function will return per weak default the
flash size of the bank (bank = chip-select numer) detected by the flash
driver. If this does not fit your needs, this function may be overridden
by a board specific one.
For this the parameters needed to be changed. So I intentionally squashed
the PPC4xx stuff using this routine into this patch. Otherwise it would
not be git-bisectable anymore.
The board specific function for the AMCC/APM Ebony eval board is now
included in this patch version.
Tested-by: Detlev Zundel <dzu@denx.de>
Cc: Gerald Van Baren <vanbaren@cideas.com>
features
The Freescale MPC8610 and MPC5121 DIU code had re-implement two features that already
existed in U-Boot: bitmap drawing and top-of-screen logo (CONFIG_VIDEO_LOGO).
So delete the 8610-specific code and use the built-in features instead.
This patch modifies jadecpu board so that it is usable
with the relocation patches by Heiko Schocher
Signed-off-by: Matthias Weisser <weisserm@arcor.de>
- Revives POST for blackfin arch;
- Removes redundant code:
arch/blackfin/lib/post.c
arch/powerpc/cpu/ppc4xx/commproc.c
arch/powerpc/cpu/mpc512x/common.c
- fixes up the post_word_{load|store} usage.
Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com>
Tested-by: Anatolij Gustschin <agust@denx.de>
List of the maintainers of the affected by patch boards:
Cc: Stephan Linz <linz@li-pro.net>
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Niklaus Giger <niklaus.giger@netstal.com>
Cc: Larry Johnson <lrj@acm.org>
Cc: Feng Kan <fkan@amcc.com>
This patch simplifies the use of CONFIG_SYS_MAX_FLASH_BANKS_DETECT. By
moving these optional variables and defines into the common code, board
specific code is minimized. Currently only the following board use
this feature:
APC405, IDS8247, TQM834x
And IDS8247 doesn't seem to really need this feature, since its not
updating the bank number variable at all. So this patch removes the
definition of CONFIG_SYS_MAX_FLASH_BANKS_DETECT from this board port.
This new framework will be used by the upcoming lwmon5 update as well.
Acked-by: Heiko Schocher <hs@denx.de>
Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
Recent changes caused that the smmaco4 board now is included in the
boards built by MAKEALL, which revealed that compilation for this
board has been broken for a long time:
mpc5xxx_fec.c:899:2: error: #error fec->xcv_type not initialized.
The board is orphaned. Drop support for it.
Recent changes caused that the HMI10 board now is included in the
ps2ser.c: In function 'ps2ser_init':
ps2ser.c:155: error: 'UART_LCR' undeclared (first use in this function)
ps2ser.c:155: error: (Each undeclared identifier is reported only once
ps2ser.c:155: error: for each function it appears in.)
ps2ser.c:156: error: 'UART_DLL' undeclared (first use in this function)
ps2ser.c:157: error: 'UART_DLM' undeclared (first use in this function)
ps2ser.c:159: error: 'UART_IER' undeclared (first use in this function)
ps2ser.c:160: error: 'UART_MCR' undeclared (first use in this function)
ps2ser.c:161: error: 'UART_FCR' undeclared (first use in this function)
ps2ser.c:162: error: 'UART_FCR_ENABLE_FIFO' undeclared (first use in this function)
ps2ser.c:166: error: 'UART_LSR' undeclared (first use in this function)
ps2ser.c: In function 'ps2ser_putc':
ps2ser.c:198: error: 'UART_LSR' undeclared (first use in this function)
ps2ser.c:200: error: 'UART_TX' undeclared (first use in this function)
ps2ser.c: In function 'ps2ser_getc_hw':
ps2ser.c:224: error: 'UART_LSR' undeclared (first use in this function)
ps2ser.c:225: error: 'UART_RX' undeclared (first use in this function)
ps2ser.c: In function 'ps2ser_interrupt':
ps2ser.c:293: error: 'UART_IIR' undeclared (first use in this function)
The board is orphaned, and AFAICT has reached EOL.
Recent changes caused thatthe aev board now is included in the boards
built by MAKEALL, which revealed that compilation for this board has
Fix it.
Split the existing dram_init for da8xx when ARM reloc is enabled, like the
changes to arch/arm/cpu/arm926ejs/orion5x/dram.c in
0f234d263b17ccf1b8fd776eb8c15b7cdb27a887 by Heiko Schocher <hs@denx.de>.
Without these changes gd->ram_size is '0' which leads to incorrect relocation
when CONFIG_SYS_ARM_WITHOUT_RELOC is defined and the board does not boot.
We use get_ram_size to dynamically calculate the available RAM because it runs
on different board version with different ram, as suggested by Heiko in private
communication.
Tested on a da850evm with 128M of DDR2 installed; with both
CONFIG_SYS_ARM_WITHOUT_RELOC defined and undefined.
Signed-off-by: Ben Gardiner <bengardiner@nanometrics.ca>
Reviewed-by: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
CC: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
CC: Heiko Schocher <hs@denx.de>
Change the implementation for arm926 to relocate the code to
an arbitrary address in RAM.
Adapt the TX25 (i.MX25), magnesium board to test the changes.
On the tx25 board TEXT_BASE is set to the final relocation
address to prevent one more copying of u-boot code
when relocating. More info see:
doc/README.arm-relocation
da850 board:
Tested-by: Ben Gardiner <bengardiner@nanometrics.ca>
Portions of this work were supported by funding from
the CE Linux Forum.
Cc: Ben Gardiner <bengardiner@nanometrics.ca>
Change the implementation for ARM V7 to relocate the code to an
Adapt the Beagle board (Cortex A8) to test the changes.
the CE Linux Forum.
Change the implementation for ARM11 to relocate the code to an
Tested on the qong board.
the CE Linux Forum.
Add data cache support for arm1136 systems.
Enable "cache" command on Qong board and test performance.
Test 1: Loading 127 MB of data from NAND flash into RAM:
Instr. Cache off on on
Data Cache off off on
QONG (ARM11) 177s 95s 43s = x 4.1
Test 2: uncompressing a gzipped image from RAM to RAM
(size compressed: 6.5 MiB, uncompressed: 35 MiB):
QONG (ARM11) 1.54s 0.95s 0.18s = x 8.6
the CE Linux Forum.
Add data cache support for ARM V7 systems. Used cache flush
functions from linux:arch/arm/mm/cache-v7.S developed from
Catalin Marinas.
Enable "cache" command on Beagle board and test performance.
Beagle (Cortex A8) 116s 106s 30.3s = x 3.8
Beagle (Cortex A8) 1.84s 1.64s 0.12s = x 15.3
the CE Linux Forum.
Reviewed-by: Ben Gardiner<bengardiner@nanometrics.ca>
Enable "cache" command on tx25 and magnesium board and test performance.
magnesium 32,6s 22,5s 30s = x 1,09
tx25 (29MB only) 9,69s 5,05s 8,16s = x 1,19
magnesium 4,25s 2,08s 1,72s = x 2,47
tx25 4,82s 2,04s 1,84s = x 2,62
the CE Linux Forum.
Signed-off-by: Alessandro Rubini <rubini@gnudd.com>
Cc: Alessandro Rubini <rubini@gnudd.com>
cleanup for the uc101 and the mucmc52 board.
This (undocumented) concept was only in use for the MVSMR and
davinci_schmoogie Sergey Kubushyn <ksi@koi8.net> boards.
Drop it for now. If really needed, it should be reimplemented
later in the context of the new environment command set.
Cc: Andre Schwarz <andre.schwarz@matrix-vision.de>
Cc: Sergey Kubushyn <ksi@koi8.net>
Acked-by: Sergey Kubushyn <ksi@koi8.net>
Increase malloc size,
enable command line editing and history,
enable hush shell.
Traditionally many boards used local definitions for SRAM base address
and size (like SRAM_BASE, SRAM_LEN and/or SRAM_SIZE), while the (now)
"official" names are CONFIG_SYS_SRAM_BASE and CONFIG_SYS_SRAM_SIZE.
The corresponding code in arch/powerpc/lib/board.c was board specific,
and has never actually been maintained well. Replace this by feature-
specific code and adapt the boards that actually use this.
NOTE: there is still a ton of boards using the old #defines, which
therefor contain incorrect values in bi_sramstart and bi_sramsize.
All respective board maintainers are requested to clean up their
respective configurations. Thanks.
Cc: Josef Wagner <Wagner@Microsys.de>
A number of boards define CONFIG_SYS_SRAM_BASE but fail to define
CONFIG_SYS_SRAM_SIZE which is needed when cleaning up the code that
prints this information with the bdinfo command.
Add the missing deinitions.
The SC520 CDP boards originally implemented by Daniel Engström are now
very broken. Attempts to contact Daniel via the email address on the
copyright notice have failed. Remove these boards from mainline
Coding style cleanup.
Future versions of these boards have options for POP memory with no NAND.
This option prevents display of error messages when no NAND is detected.
Signed-off-by: Steve Sakoman <steve@sakoman.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Allows one to set the processor clock rate via "setenv mpurate 720" for example
Default is set to a "safe" 500 Mhz.
Use the MMU hardware to set up 1:1 mappings between physical and virtual
addresses. This allows us to bypass the cache when accessing the flash
without having to do any physical-to-virtual address mapping in the CFI
driver.
The virtual memory mappings are defined at compile time through a sorted
array of virtual memory range objects. When a TLB miss exception
happens, the exception handler does a binary search through the array
until it finds a matching entry and loads it into the TLB. The u-boot
image itself is covered by a fixed TLB entry which is never replaced.
This makes the 'saveenv' command work again on ATNGW100 and other boards
using the CFI driver, hopefully without breaking any rules.
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Opps, after a long time I tested recent u-boot on our
APC405 board. This simple fix makes networking work again.
Signed-off-by: Albert Aribaud <albert.aribaud@free.fr>
Acked-by: Prafulla Wadaskar<prafulla@marvell.com>
Acked-by: Heiko Schocher<hs@denx.de>
These are not used on this board, which uses soft I2C instead.
Use the same configuration around S5P SoCs.
(s5pc100, s5pc110, s5pc210 and so on)
