path: root/include/configs
2008-04-13Add apollon board MAINTAINERS entryKyungmin Park
2008-04-13Support for LinkStation / KuroBox HD and HG PPC modelsGuennadi Liakhovetski
This patch is based on the port by Mihai Georgian (see linkstation.c for Copyright information) and implements support for LinkStation / KuroBox HD and HG PPC models from Buffalo Technology, whereby HD is deactivated at the moment, pending network driver fixing. Notice to users: this is pretty much a barebone port. Support for network on HG models is already in the U-Boot mainline, but you might also want patches to switch fan / phy modes depending on the negotiated ethernet parameters. This patch also doesn't support console switching, booting EM mode, Buffalo specific ext2 magic number. So, if you want to use any of those, you need additional patches. Otherwise this patche provides a fully functional u-boot with a network console on your system. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-13Add CONFIG_MII_INIT support to related boardsTsiChung Liew
Replace CONFIG_8xx and CONFIG_MCF532x to CONFIG_MII_INIT in cmd_init.c. Add CONFIG_MII_INIT to board configuration files that use mii_init() in cmd_init.c. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: Ben Warren <biggerbadderben@gmail.com>
2008-04-13Update CONFIG_PCIAUTO_SKIP_HOST_BRIDGE to related boardsTsiChung Liew
Remove test for CONFIG_MPC5200 in drivers/pci/pci_auto.c and define CONFIG_PCIAUTO_SKIP_HOST_BRIDGE in related board configuration files. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-04-13Phytec Phycore-i.MX31 supportSascha Hauer
This patch adds support for the Phytec Phycore-i.MX31 board Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-13mx31 litekit supportSascha Hauer
This patch adds support for the mx31 litekit board Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-13ppc: Get rid of unused machine type definitionsWolfgang Denk
2008-04-13Coding Style cleanup; update CHANGELOGWolfgang Denk
2008-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-mpc83xxWolfgang Denk
2008-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxWolfgang Denk
2008-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-microblazeWolfgang Denk
2008-04-13Merge branch 'master' of git://www.denx.de/git/u-boot-sparcWolfgang Denk
2008-04-11mpc83xx: Fix the SATA clock setting of 837x targetsDave Liu
Currently the SATA controller clock is configured as CSB clock, usually the CSB clock is 400/333/266MHz. However, The SATA IP block is only guaranteed to operate up to 200 MHz as stated in the HW spec. The bug is reported by Joe D'Abbraccio <ljd015@freescale.com> This patch makes the SATA clock as half of CSB clock. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-04-11Revert merge of git://www.denx.de/git/u-boot-arm, commit 62479b18:Wolfgang Denk
Reverting became necessary after it turned out that the patches in the u-boot-arm repo were modified, and in some cases corrupted. This reverts the following commits: 066bebd6353e33af3adefc3404560871699e9961 7a837b7310166ae8fc8b8d66d7ef01b60a80f9d6 c88ae20580b2b01487b4cdcc8b2a113f551aee36 a147e56f03871bba4f05058d5e04ce7deb010b04 d6674e0e2a6a1f033945f78838566210d3f28c95 8c8463cce44d849e37744749b32d38e1dfb12e50 c98b47ad24b2d91f41c09a3d62d7f70ad84f4b7d 8bf69d81782619187933a605f1a95ee1d069478d 8c16cb0d3b971f46fbe77c072664c0f2dcd4471d a574a73852a527779234e73e17e7597fd8128882 1377b5583a48021d983e1fd565f7d40c89e84d63 1704dc20917b4f71e373e2c888497ee666d40380 Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-11ppc4xx: Update Kilauea defconfig to use device-tree booting as defaultStefan Roese
This patch reworks the default environment on Kilauea/Haleakala. Now "net_nfs" for exmaple uses the device-tree style booting formerly know as "net_nfs_fdt". Also the addresses in RAM were changed because of the new image booting support, which check for image overwriting. So the addresses needed togeet adjusted. Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-09ppc4xx: Fix Canyonlands default environment to work with new image supportStefan Roese
Since the new image support checks for image overwriting, the default environment needs to get adjusted to use correct addresses. Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-08microblaze: xupv2p fix config file for supporting FDTMichal Simek
2008-04-08microblaze: ml401 fix config file for supporting FDTMichal Simek
2008-04-08microblaze: ml401 - add ifdef for GPIOMichal Simek
2008-04-08microblaze: clean uart16550 and uartlite handlingMichal Simek
2008-04-08microblaze: ML401 and XUPV2P remove emac and emaclite referenceMichal Simek
2008-04-08SPARC/LEON2: added support for Gaisler simulator GRSIM/TSIM for SPARC/LEON2 ↵Daniel Hellstrom
targets. See www.gaisler.com for information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-04-08SPARC/LEON3: added support for GR-CPCI-AX2000 FPGA AX board. The FPGA is ↵Daniel Hellstrom
exchangeable but a standard LEON3 design is assumed. See www.gaisler.com for information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-04-08SPARC/LEON3: added support for Altera NIOS Development kit (STRATIX II ↵Daniel Hellstrom
Edition) with GRLIB template design. See www.gaisler.com for information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-04-08SPARC/LEON3: added support for Gaisler GRSIM/TSIM2 SPARC/LEON3 simulatorn. ↵Daniel Hellstrom
2008-04-08SPARC/LEON3: added support for GR-XC3S-1500 board with GRLIB template ↵Daniel Hellstrom
design. See www.gaisler.com for board information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-at91Wolfgang Denk
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-coldfireWolfgang Denk
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-blackfinWolfgang Denk
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-armWolfgang Denk
2008-04-08Merge branch 'master' of git://www.denx.de/git/u-boot-shWolfgang Denk
2008-04-07Merge branch 'master' of git://www.denx.de/git/u-boot-mpc83xxWolfgang Denk
Conflicts: lib_ppc/board.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-01Add support for AT91SAM9260EKStelian Pop
Support for booting from internal DataFlash, external DataFlash card or NAND flash is available. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-04-01Port AT91CAP9 to the new headersStelian Pop
Adapt the existing AT91CAP9 code to the new headers and APIs. Signed-off-by: Stelian Pop <stelian@popies.net>
2008-03-31ColdFire: Add dspi and serial flash support for MCF5445xTsiChung Liew
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-03-31ColdFire: Remove R5200 boardTsiChung Liew
This board never went into production Signed-off-by: Zachary P. Landau <zachary.landau@labxtechnologies.com> Acked-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-03-31ColdFire: Added M5275EVB support.Matthew Fettke
Signed-off-by: Matthew Fettke <mfettke@videon-central.com> Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-03-31ColdFire: Define bootdelay in configuration file for M52277EVBTsiChung Liew
Signed-off-by: Matt Wadel <Matt.Waddel@freescale.com> Acked-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com> Acked-by: John Rigby <jrigby@freescale.com>
2008-03-31ppc4xx: Small whitespace fix of esd patchesStefan Roese
2008-03-31ppc4xx: Minor updates for DU440 boardsMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-03-30Blackfin: unify cpu and boot modesMike Frysinger
All of the duplicated code for Blackfin processors and boot modes have been unified. After all, the core is the same for all processors, just the peripheral set differs (which gets handled in the drivers). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-03-30use correct at91rm9200 register nameDavid Brownell
This fixes a naming bug for at91rm9200 lowlevel init code: NOR boot flash is on chipselect 0, not chipselect 2. This makes code use the register name from chip datasheets. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2008-03-30Support for the MX31ADS evaluation board from FreescaleGuennadi Liakhovetski
This patch adds support for the MX31ADS evaluation board from Freescale, initialization code is copied from RedBoot sources, also provided by Freescale. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-03-30Phytec Phycore-i.MX31 supportSascha Hauer
2008-03-30mx31 litekit supportSascha Hauer
2008-03-30Adds support for the Prodrive PMDRA board, based on a DM6441Pieter Voorthuijsen
Signed-off-by: Pieter Voorthuijsen <pv@prodrive.nl>
2008-03-30Removes all board specific code from the arch. part for DM644x (DaVinci) boardsPieter Voorthuijsen
2008-03-28mpc8323erdb: fix EEPROM page size and get MAC from EEPROMMichael Barkowski
This patch fixes eeprom page size so that you can now write more than 64 bytes at a time. It also makes the board take MAC addresses, if found, from EEPROM. User should place up to 4 addresses at offset 0x7f00, for eth{,1,2,3}addr. Any unused addresses should be zero. This group of four six-byte values should have it's CRC at the end. crc32 and eeprom commands can be used to accomplish this. If CRC fails, MAC addresses come from the environment. If CRC succeeds, the environment is overwritten at startup. Signed-off-by: Michael Barkowski <michael.barkowski@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-28mpc8323erdb: define CONFIG_PCI_SKIP_HOST_BRIDGEMichael Barkowski
Commit 55774b512fdf63c0516d441cc5da7c54bbffb7f2 broke the onboard USB controller on the PCI bus in Linux on the MPC8323ERDB. This fixes it by defining CONFIG_PCI_SKIP_HOST_BRIDGE in the board's config file. Signed-off-by: Michael Barkowski <michael.barkowski@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-28mpc83xx: enable the SATA interface on mpc8315 rdb and mpc837x rdb boardsKim Phillips
