path: root/include/configs
2010-01-17Blackfin: add a netconsole helperRobin Getz
Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: add support for BF527-EZKIT v2.1Michael Hennerich
The new board revision has a different LCD. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: convert bfin_sdh to generic mmcCliff Cai
Signed-off-by: Cliff Cai <cliff.cai@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: bf527-ezkit: auto-select NAND settingsMike Frysinger
2010-01-17Blackfin: bf561-acvilon: new board portValentin Yakovenkov
Signed-off-by: Valentin Yakovenkov <yakovenkov@niistt.ru> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: ADI settings: enable silent console supportMike Frysinger
Very little additional code overhead, and only works when the user sets an env var ahead of time, so default to on makes sense. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: bf537-stamp: rename SPI/MMC defineMike Frysinger
2010-01-17Blackfin: update tiny board settings (voltage/default env)Harald Krapfenbauer
The tinyboards like to run at a little lower voltage than the default, and they prefer to boot over the network. For the latter, extend the common code a little to make this easier. Also fix the cm-bf527 env sector size while we're in here to reflect the flash that is actually in use. Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-17Blackfin: tweak embedded LDR env config optionMike Frysinger
Use the common config option for extracting the environment for embedding into LDR files and clarify the LDR-specific option. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-01-12Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-01-12Merge branch 'master' of git://git.denx.de/u-boot-usbWolfgang Denk
2010-01-12Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
2010-01-09Adds EHCI definitions to sequoia board configuration file.Chris Zhang
Adds required definitions for EHCI support in sequoia configuration file. But still keeps the OHCI as default driver. Signed-off-by: Chris Zhang <chris@seamicro.com>
2010-01-09DA830: Add usb configAjay Kumar Gupta
Adding USB configuration. Default is set for USB MSC host. Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com> Signed-off-by: Swaminathan S <swami.iyer@ti.com>
2010-01-07mpc83xx: add support configure bus parkingHeiko Schocher
Add support to configure bus parking mode and master in bus arbitration configuration (ACR). Add this for the kmeter1 port: Configure bus arbiter with recommended values from Freescale to improve bus latency/throughput for application with intensive QuiccEngine activity. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-01-07mpc83xx: Add support for MPC8349 esd caddy2Reinhard Arlt
The caddy2 is a variant of the already supported vme8349. So we just add the differences to this board port. To better support those two boards we switched from fixed SDRAM configuration to usage of spd_sdram(). This is done by providing a board specific SPD EEPROM routine with different values for both boards. Signed-off-by: Reinhard Arlt <reinhard.arlt@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de> changed to use mkconfig -t option instead, plus misc codingstyle fixes. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-01-07mpc83xx: Add NAND boot support for MPC8315E-RDB boardsAnton Vorontsov
The core support for NAND booting is there already, so this patch is pretty straightforward. There is one trick though: top level Makefile expects nand_spl to be in nand_spl/board/$(BOARDDIR), but we can fully reuse the code from mpc8313erdb boards, and so to not duplicate the code we just symlink nand_spl/board/freescale/mpc8315erdb to mpc8313erdb. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> o silence make during ln echo o update documentation o and avoid: $ ./MAKEALL MPC8315ERDB_NAND Configuring for MPC8315ERDB board... sdram.o: In function `fixed_sdram': /home/r1aaha/git/u-boot/nand_spl/board/freescale/mpc8313erdb/sdram.c:72: undefined reference to `udelay' by renaming udelay -> __udelay in the spirit of commit 3eb90bad651fab39cffba750ec4421a9c01d60e7 "Generic udelay() with watchdog support". Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-01-05mpc85xx: Add 4-bits eSDHC support for MPC8569E-MDS boardsAnton Vorontsov
Thanks to "Errata to MPC8569E PowerQUICC III Integrated Host Processor Family Reference Manual, Rev. 0" document, which describes all eSDHC pins, we can add 4-bits eSDHC support for MPC8569E-MDS boards. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-01-05ppc/85xx: Remove CONFIG_SYS_DDR_TLB_STARTKumar Gala
Now that we dynamically determine TLB CAM entries to use we dont need CONFIG_SYS_DDR_TLB_START anymore. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-01-05ppc/85xx: Clean up ATUM8548 PCI setup codeKumar Gala
Use new fsl_pci_init_port() that reduces amount of duplicated code in the board ports, use IO accessors and clean up printing of status info. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-01-04Davinci: Configurable NAND chip selectsNick Thompson
Davinci: Configurable NAND chip selects Add a CONFIG_SYS_NAND_CS setting to all davinci configs and use it to setup the NAND controller in the davinci_nand mtd driver. Signed-off-by: Nick Thompson <nick.thompson@gefanuc.com>
2010-01-04Remove superfluous uses of V_PROMPT macro.Robert P. J. Day
A number of config files define the V_PROMPT macro for the command-line prompt, only to immediately use that macro to define CONFIG_SYS_PROMPT, making V_PROMPT entirely superfluous. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca>
2010-01-03Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2009-12-22ppc4xx: alpr: Remove some not needed commands to make image fit againStefan Roese
The latest changes increased the size of the alpr image a bit more. Now it doesn't fit into the 256k reserved for it. This patch now removes the commands "ping" and "diag" which are not needed in the production systems. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Pieter Voorthuijsen <pieter.voorthuijsen@prodrive.nl>
2009-12-21Merge branch 'master' of git://git.denx.de/u-boot-usbWolfgang Denk
2009-12-20omap3evm: musb: add USB configAjay Kumar Gupta
Added USB host and device config for host (MSC, Keyboard) and device (ACM) functionalities. Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com>
2009-12-20OMAP3 zoom2 Use usbtty if the debug board is not connected.Tom Rix
The preferred serial output comes from the debug board. When the debug board is disconnected, fall back on using usbtty from the usb connector on the Zoom2 board. This shows up as /dev/ttyACM0 in a linux host. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-12-20OMAP3 beagle Add usbtty configurationTom Rix
The primary console of beagle is the serial header. A secondary console is to use the usbtty. The user can set this manually by doing setenv stdout usbtty; setenv stdin usbtty; setenv stderr usbtty saveenv usbtty will be usable by accessing the /dev/ttyACM0 on a linux host. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-12-20OMAP3 zoom1 Add usbtty configurationTom Rix
The primary console of zoom1 is the serial out from the jumpers accessed by removing the back panel. A secondary console is to use the usbtty. The user can set this manually by doing setenv stdout usbtty; setenv stdin usbtty; setenv stderr usbtty saveenv usbtty will be usable by accessing the /dev/ttyACM0 on a linux host. Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-12-17Merge branch 'next' of git://git.denx.de/u-boot-netWolfgang Denk
2009-12-15Merge branch 'next' of ../nextWolfgang Denk
2009-12-14Net: Clean up LAN91C96 SupportBen Warren
A previous Commit converted the LAN91C96 Ethernet driver to using the CONFIG_NET_MULTI API, but did not include full board support. This patch finishes the job. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-12-14MVBLUE: Remove CONFIG_CMD_IRQPeter Tyser
Neither the MVBLUE nor its underlying architecture implement the do_irqinfo() function which is required when CONFIG_CMD_IRQ is defined. This change fixes the following MVBLUE compiler error: -> ./MAKEALL MVBLUE Configuring for MVBLUE board... common/libcommon.a(cmd_irq.o):(.u_boot_cmd+0x24): undefined reference to `do_irqinfo' make: *** [u-boot] Error 1 Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
2009-12-14imx27lite: Reenable MTD support on NOR flash.Detlev Zundel
The support for this was silently dropped by a configuration split during the merge of the imx27lite board support in commit 864aa034f3a0e10ce710e8bbda171df3cab59414 (cmd_mtdparts: Move to common handling of FLASH devices via MTD layer). Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-12-13LAN91C96: Enable NET_MULTI LAN driverNishanth Menon
This modification is NOT tested on any of the platforms modified as I dont have them. please help by testing+building+fixing Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-12-13TI OMAP3: SDP3430 FIX NET_MULTI WarningNishanth Menon
Enable the NET MULTI option and remove build warning Tested: SDP3430 Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-12-08microblaze: Stop stack clobbering in microblaze-generic.Graeme Smecher
A typo caused the stack and malloc regions to overlap, which prevented mem_malloc_init() from returning. This commit makes the memory layout match the example described in include/configs/microblaze-generic.h Signed-off-by: Graeme Smecher <graeme.smecher@mail.mcgill.ca> Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-12-07mpc52xx, manroland: add some commandsHeiko Schocher
add the following commands for the manroland boards: CONFIG_CMDLINE_EDITING CONFIG_COMMAND_HISTORY CONFIG_AUTO_COMPLETE Signed-off-by: Heiko Schocher <hs@denx.de>
2009-12-05Merge branch 'master' into nextWolfgang Denk
Conflicts: board/esd/plu405/plu405.c drivers/rtc/ftrtc010.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-12-05i386: Final RelocationGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-12-05i386: Fix global label in inline asm compile errorGraeme Russ
2009-12-05i386: Fix malloc initializationGraeme Russ
2009-12-0285xx: Remove unused CONFIG_ASSUME_AMD_FLASH from config filesBecky Bruce
A bunch of the 85xx boards have this cruft in them - it's not used anywhere. Delete it. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-12-01Merge branch 'next-sync' of git://git.denx.de/u-boot-arm into nextWolfgang Denk
2009-11-27NAND: Add config option for imx27liteSandeep Paulraj
We will get compilation warnings without "CONFIG_SYS_64BIT_VSPRINTF" being defined in the board config. Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-11-27arm: A320: Add support for Faraday A320 evaluation boardPo-Yu Chuang
This patch adds support for A320 evaluation board from Faraday. This board uses FA526 processor by default and has 512kB and 32MB NOR flash, 64M RAM. FA526 is an ARMv4 processor and uses the ARM920T source in this patch. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2009-11-27OMAP3:SDRC: introduce DDR typesNishanth Menon
Micron DDR timings based on: http://www.sakoman.net/cgi-bin/gitweb.cgi?p=x-load-omap3.git;a=blob;f=include/asm/arch-omap3/mem.h;h=e6fbfe3947f5d0d85fea776e30821d4017316d86;hb=HEAD Introduce Micron DDR timings and provide CONFIG_OMAP3_INFINEON_DDR and CONFIG_OMAP3_MICRON_DDR config options to allow for platform files to setup their timings as per the type of DDR selected Reported-by: Steve Sakoman in http://www.nabble.com/forum/Permalink.jtp?root=25779518&post=25959734&page=y Signed-off-by: Nishanth Menon <nm@ti.com>
2009-11-27TI DA8xx: Integrate DA830 EVM support into U-BootSekhar Nori
Integrate DA830 EVM support into U-Boot. Provides initial support for TI OMAP-L137/DA830 SoC devices on a Spectrum Digital EVM board. See http://www.spectrumdigital.com/ Signed-off-by: Nick Thompson <nick.thompson@gefanuc.com>
2009-11-27Add a unified s3c24x0 header filekevin.morfitt@fearnside-systems.co.uk
This patch adds a unified s3c24x0 cpu header file that selects the header file for the specific s3c24x0 cpu from the SOC and CPU configs defined in board config file. This removes the current chain of s3c24-type #ifdef's from the s3c24x0 code. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
