Copy the kernel image double-word-wise rather than byte-wise.
The last 64 byte of each DDR channel of PH1-LD20 is periodically
used as a scratch area for the DDR PHY training.
This is the first ARMv8 SoC from Socionext Inc.
configs/bcm28155_ap_defconfig
configs/dra72_evm_defconfig
configs/dra74_evm_defconfig
configs/ma5d4evk_defconfig
And also reformat defconfigs using "make savedefconfig" rule.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Description was borrowed from kernel dwc3 Kconfig.
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some
config headers. This is also probably fixes am335x_baltos board.
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and
make all UDC controllers select USB_GADGET_DUALSPEED:
- add next options to Kconfig selecting USB_GADGET_DUALSPEED:
- USB_GADGET_ATMEL_USBA
- USB_GADGET_DWC2_OTG
- USB_DWC3
- CI_UDC
- make USB_MUSB_GADGET select USB_GADGET_DUALSPEED
While at it, make some related fixes:
- remove DUALSPEED from configs that don't enable gadget support:
- kwb.h
- tseries.h
- add missing USB_GADGET option to next configs:
- novena_defconfig
- pcm051_rev*_defconfig
- xfi3_defconfig
The description was borrowed from kernel. Definitions were added to
defconfig files in a way that "make savedefconfig" generates exactly
the same file as used defconfig.
Boards using 0 mA as CONFIG_USB_GADGET_VBUS_DRAW value were moved to use
2 mA (as minimal allowed by Kconfig).
Add support for Technexion's PICO-IMX6UL-EMMC board.
For information about this board, please visit:
http://www.technexion.com/products/pico/pico-som/pico-imx6-emmc
Signed-off-by: Richard Hu <richard.hu@technexion.com>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Setup the LCD backlight brightness control pin to use PWM
Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com>
As of commit 69e173eb57d1f4848f070c83456096ba5d2ba1b4, CONFIG_OF_LIBFDT
needs to be selected in defconfig instead of board specific header file.
Hence enable CONFIG_OF_LIBFDT in defconfig.
Some variables for the distro boot commands were missing, using some
custom name instead. Rename them.
Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
Signed-off-by: Andreas Färber <afaerber@suse.de>
NAND is not yet enabled on all Keystone2 platforms. So enabled
CMD_NAND in the respective defconfigs only if available.
Reported-by: Nishanth Menon <nm@ti.com>
Not all Keystone2 devices has AEMIF NAND controller. So adding Kconfig
entry for CONFIG_TI_AEMIF and enabling it in respective defconfigs on
platforms with AEMIF controller.
Add missing define to board header file.
Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
Reviewed-by: Andreas Färber <afaerber@suse.de>
Create CMD_FDT Kconfig entry to have an option to disable fdt command
which is not required for small configuration which requires libfdt
only.
Enable it by default for all targets which enables OF_LIBFDT.
[trini: Fixup flea3/sandbox/id8313/siemens-am33xx/smartweb]
This patch follows work done by:
"Move CONFIG_OF_LIBFDT to Kconfig"
(sha1: 69e173eb57d1f4848f070c83456096ba5d2ba1b4)
[trini: Add xpress* to the patch]
Enable saving ENV to MMC for the bcm281xx boards.
Signed-off-by: Steve Rae <srae@broadcom.com>
The Pi firmware has changed the default "kernel" load address for 64-bit
mode. The authors have confirmed that this is a deliberate and long-term
change. Adapt U-Boot to the new value.
Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
Use i2c cadence DM driver for all zynqmp targets except ZCU102
because I2C muxes and PCA953x are not supported in the tree yet.
zcu102 has two pca953x on i2c bus 0. Chips 0x20 and 0x21.
Enable option to work with these two chips.
Enable DM GPIO and ZYNQ GPIO using kconfig instead of the board
config file.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Moving stuff to Kconfig by script is keep some empty lines
or comment in the file. Remove them.
Support ZynqMP zc1751 with DC cards.
Add new board support.
Move kernel and fdt offsets and sizes to board config file
as the flash size varies across boards
Setup reset off for lthor.
This is example how to change u-boot to support more memory banks read
from DT.
Remove hardcoded memory sizes. Use information from DT memory node.
Add missing DT nodes and enable USB.
Reviewed-by: Nathan Rossi <nathan@nathanrossi.com>
Sometimes the PCIe link for the PEX-switch will not come-up. In this case,
the board is not in a usable state. This patch makes sure that in this
case a soft-reset is issued. If this soft-reset does not result in the
PEX-switch being detected after some soft-reset cycles, an I2C message
is sent to the uC to issue a complete power-cycle of the board.
This patch enables the 2nd I2C controller on the Armada XP theadorable
board.
This patch adds bootcount support to the MVEBU theadorable board. Since
no reset-safe registers seem to be available, it uses the last 4KiB
of SDRAM for the bootcounter location.
Now that rpi_*defconfig and Kconfig (rather than the config header file)
provide the identity of the build, we don't need to separate config
headers and board directories for each RPi variant. Set CONFIG_SYS_BOARD
and CONFIG_SYS_CONFIG_NAME so that we can get rid of the duplication. This
requires a tiny number of extra ifdefs in the config header.
The only disadvantage of this approach is that the $board/$board_name
environment variables aren't as descriptive as they used to be. This isn't
really an issue because those only exist to allow scripts to create DTB
filenames at runtime. However, the RPi board code already sets $fdtfile to
something more accurate based on FW-reported board ID anyway.
While at it, unify some Kconfig select options, and add a MAINTAINERS
entry for bcm283x too.
Partially-suggested-by: Tom Rini <trini@konsulko.com>
On all Pis so far, the VC FW provides a short stub to set up the ARM CPU
before entering the kernel (a/k/a U-Boot for us). This feature is not
currently supported by the VC FW when booting in 64-bit mode. However,
this feature will likely appear in the near future, and this U-Boot port
assumes that such a feature is in place. Without that feature, or a
temporary workaround described below, U-Boot will not boot.
Once the VC FW does provide the ARM stub, u-boot.bin built for rpi_3 can
be used drectly as kernel7.img, in the same way as any other RPi port. The
following config.txt is required:
# Fix mini UART input frequency, and setup/enable up the UART.
# Without this option, U-Boot will not boot, even if you don't care
# about the serial console. This option will always be required for
# all RPi3 use-cases, unless the PL011 UART is used, which is not
# yet supported by rpi_3* builds of U-Boot.
enable_uart=1
# Boot in AArch64 (64-bit) mode.
# It is possible that a future VC FW will remove the need for this
# option, instead auto-setting 32-/64-bit mode based on the "kernel"
# filename present on the SD card.
arm_control=0x200
Prior to the VC FW providing the ARM boot stub, you can use the following
steps to build an equivalent stub into the U-Boot binary:
git clone https://github.com/swarren/rpi-3-aarch64-demo.git \
../rpi-3-aarch64-demo
(cd ../rpi-3-aarch64-demo && ./build.sh)
Build U-Boot for rpi_3 in the usual way
cat ../rpi-3-aarch64-demo/armstub64.bin u-boot.bin > u-boot.bin.stubbed
Use u-boot.bin.stubbed as kernel7.img on the Pi SD card.
In this case, the following additional entries are required in config.txt:
# Tell the FW to load the kernel image at address 0, the reset vector.
kernel_old=1
There is an incorrect space after loadaddr= in the extra environment,
so drop it.
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Chin Liang See <clsee@altera.com>
CONFIG_SPI_FLASH_BAR was deleted from socfpga_common.h
and placed in socfpga_*_defconfig because it is Kconfig symbol.
Signed-off-by: Denis Bakhvalov <dendibakh@gmail.com>
Reported-by: Denis Bakhvalov <dendibakh@gmail.com>
Enable MUSB host and USB storage support for Microchip
PIC32MZ[DA] Starter Kit.
Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com>
