- add support for MPC8220 CPU
- Add support for Alaska and Yukon boards
* Adjust MIPS compiler options at run-time depending on tools version
("-march=4kc -mtune=4kc -Wa,-mips_allow_branch_to_undefined" for new,
"-mcpu=4kc" for old tools)
kernel on xaeniax board.
* Patch by Thomas Lange 07 Oct 2004:
Updated README for DBAu1x00 boards to match current status
Fix Flash support for Versatile.
* Patch by Roger Blofeld, 16 Sep 2004:
Fix timeout for DHCP command retry
[Remember: CFG_HZ should be 1000 on ALL systems!]
- Add support to revA version of PQ27 and PQ27E.
- Reverted MPC8260ADS baudrate back to original 115200
* Patch by Hojin, 17 Sep 2004:
Fix typo in cfi_flash.c
* Patch by Mark Jonas, 09 September 2004:
mtest's data line test (with CFG_ALT_MEMTEST set) returned a wrong
error message
* Patch by Mark Jonas, 31 August 2004:
Added option CFG_XLB_PIPELINING to enable XLB pipelining. This
improves FTP performance for MPC5200 systems. Enabled for IceCube
by default.
- Improve platform.S code for omap1510inn that detects whether code
is running from SDRAM or not. Patch allows SDRAM to be configured
if code is running out of SRAM at 0x20000000.
* Patch by Frederick Klatt, 30 Aug 2004:
Add support for the Wind River SBC8540/SBC8560 boards
* Patches by Michael Bendzick, 30 Aug 2004:
- Configure omap1510inn board to use drivers/cfi_flash.c
- Make drivers/cfi_flash.c protect environment and redundant
environment.
* Patch by Steven Scholz, 23 Jun 2004:
- Add script (tools/img2brec.sh) to programm U-Boot into
(Synch)Flash using the Bootstrap Mode of the MC9328MX1/L
- Add support for Altera Nios-II processors.
- Add support for Psyent PCI-5441 board.
- Add support for Psyent PK1C20 board.
- Add support for the MPC8541 and MPC8555 CDS boards
- Cleanup eth?addr handling: make dependent on CONFIG_ETH?ADDR
- Fix PCI window on MPC85xx; remove unneeded PCI initialization
from board_early_init_f()
- Provide SW workaround for PCI initialization on 85xx CDS
- Convert MPC85xxADS to use common CFI flash driver
* Cleanup: avoid compiler warnings
* Add CMC PU2 board to MAKEALL script
- Enable ramdisk/initrd tagged param support for omap1610h2_config
- Remove static network setup defaults from mx1ads_config
- add support for CMC PU2 board
- add support for I2C on at91rm9200
* Patch by Gary Jennejohn, 28 Sep 2004:
fix baudrate handling on at91rm9200
- remove ZPC.1900 board-specific flash driver;
switch the port to generic CFI driver;
- port clean-up
- Fix a typo in README
- Align "(RO)" output for "flinfo" after "protect on"
- Add RESET support for RPXlite_DW board; adjust CPU:BUS frequency
ratio 1:1 when core frequency less than 50MHz
- fix some "use of label at end of compound statement" warnings
- Define type of LCD panel on lubbock board if CONFIG_LCD is used
- Added support for both 8 and 16 bit mode access to System ACE CF
through MPU.
- Fixed missing System ACE CF device during get FAT partition info
in fat_register_device function.
- Enabled System ACE CF support on ML300.
* Patch by Sean Chang, 09 Aug 2004:
Synch defines for saveenv and do_saveenv functions so they get
compiled under the same statement.
- Added I2C support for ML300.
- Added support for ML300 to read out its environment information
stored on the EEPROM.
- Added support to use board specific parameters as part of
U-Boot's environment information.
- Updated MLD files to support configuration for new features
above.
* Patches by Travis Sawyer, 5 Aug 2004:
- Remove incorrect bridge settings for eth group 6
- Add call to setup bridge in ppc_440x_eth_initialize
- Fix ppc_440x_eth_init to reset the phy only if its the
first time through, otherwise, just check the phy for the
autonegotiated speed/duplex. This allows the use of netconsole
- only print the speed/duplex the first time the phy is reset.
Add support for MKS Instruments "Quantum" board
* Fix build problem with Cogent boards;
avoid using <asm/byteorder.h> when using the host compiler
Set the PCI class code for JSE board as part of PCI interface setup
* Patch by Michael Bendzick, 15 Jul 2004:
Fix problem with writes with odd sizes in drivers/cfi_flash.c when
CFG_FLASH_USE_BUFFER_WRITE is set
Allow clock setting on MPC866/MPC885 series chips according to
environment variable `cpuclk'
* Patch by Yuli Barcohen, 20 Apr 2004:
Remove unnecessary redefine of CPM_DATAONLY_SIZE for MPC826x
Add support for xaeniax board
COPYING file
* Fix FEC ethernet problem on NSCU board.
allow to use USART1 as console port on at91rm9200dk boards
Update etags build target
* Improve NetConsole support: add support for broadcast destination
address and buffered input.
* Cleanup compiler warnings for GCC 3.3.x and later
* Fix problem in cmd_jffs2.c introduced by CFG_JFFS_SINGLE_PART patch
* Enable MSDOS/VFAT filesystem support for LWMON board
* Clear Block Lock-Bits when erasing flash on LWMON board.
* Fix return code of "fatload" command
* Disable debugging for TQM5200 board
change timing for SM501 graphics controller on TQM5200 module
* Patch by Mark Jonas, 13 July 2004:
- Total5200 LCD now run in little endian mode. Endianess conversion
is done in hardware.
- Removed last reference to "console" environment variable.
Replaced hardcoded PL011 clock frequency with config variable.
Fixed wrong CONFIG_CMD_DFL doc.
* Patch by Thomas Viehweger, 09 Jun 2004:
make it possible to remove chpart when there is only one partition
netconsole patch under Linux)
- support larger DDR memories up to 2G on the PC8540/8560ADS and
STXGP3 boards
- Made MPC8540/8560ADS be 33Mhz PCI by default.
- Removed moldy CONFIG_RAM_AS_FLASH, CFG_FLASH_PORT_WIDTH_16
and CONFIG_L2_INIT_RAM options.
- Refactor Local Bus initialization out of SDRAM setup.
- Re-implement new version of LBC11/DDR11 errata workarounds.
- Moved board specific PCI init parts out of CPU directory.
- Added TLB entry for PCI-1 IO Memory
- Updated README.mpc85xxads
* Patch by Sascha Hauer, 28 Jun:
- add generic support for Motorola i.MX architecture
- add support for mx1ads, mx1fs2 and scb9328 boards
* Patches by Marc Leeman, 23 Jul 2004:
- Add define for the PCI/Memory Buffer Configuration Register
- corrected comments in cpu/mpc824x/cpu_init.c
* Add support for multiple serial interfaces
(for example to allow modem dial-in / dial-out)
* Add link for preloader for Motorola Coldfire to RAEDME.m68k
- update mach-types.h to latest arm.linux.org.uk master list
- Set correct OMAP1610 bi_arch_number for build target
* Patch by Curt Brune, 06 Jul 2004:
evb4510: add support for timer interrupt; cleanup
Fix sbc8260 environment variables
* Cleanup redundand "console" environment variable
* Patch by Mark Jonas, 05 Jul 2004:
add support for the Total5100's and Total5200's LCD screen
* Patches by Dan Eisenhut, 01 Jul 2004:
- README fixes.
- Move doc2000.h include to prevent compiler warning on some boards
Added support for Total5100 and Total5200 (Rev.1 and Rev.2)
MGT5100 and MPC5200 based Freescale platforms.
Add support for TQM5200 board
* Patch by Martin Krause, 29 Jun 2004:
Add loopw command: infinite write loop on address range
- add empty include/asm-microblaze/processor.h
- add to CREDITS and MAINTAINERS
- add gd initialization
- add MicroBlaze and SUZAKU board to MAKEALL script
- add reset support for SUZAKU
- add flush_cache() for MicroBlaze
- add CFG_FLASH_SIZE to include/configs/suzaku.h since we have fixed
size flash memory on SUZAKU
Add support for the PXA250 based Intrinsyc Cerf board.
* Patch by Yasushi Shoji, 27 Jun 2004:
fix comment in include/common.h
* Patch by Daniel Poirot, 24 Jun 2004:
Add support for Wind River's sbc8240 board
* Patches by Yasushi Shoji, 26 Jun 2004:
- drivers/serial_xuartlite.c: fix "return 0" in void function
- add microblaze support to mkimage tool
