path: root/include/configs
2011-07-04arm/km: fix u-boot.kwb build breakageHolger Brunck
commit 010a958b (arm/km: remove CONFIG_SYS_KWD_CONFIG from keymile-common.h) breaks building keymile arm targets, when u-boot.kwb tries to generate the binary with mkimage. A simple make <board> or MAKEALL succeeded because it don't try to build the kirwood binary at the end. Due this commit we use the CONFIG_SYS_KWD_CONFIG from the arch-kirkwood/config.h and it was removed from the board config. But it was forgotten to include the header. Now the header is included in km_arm.h. Some other defines were obsolete due to this include, these are also removed in this commit. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Heiko Schocher <hs@denx.de>
2011-07-04atstk100x: switch to common cfi driverAndreas Bießmann
This patch removes the board implemenatation for flash driver which can now safely switched to the common cfi driver. Compile tested for all atstk100x boards, runtime tested on atstk1002. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-07-04cpuat91: use atmel_usartAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Eric Bénard <eric@eukrea.com>
2011-07-04eb_cpux9k2: use atmel_usartAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Jens Scharsig <js_at_ng@scharsoft.de> Acked-by: Jens Scharsig<js_at_ng@scharsoft.de> Tested-by: Jens Scharsig<js_at_ng@scharsoft.de> (for eb_cpux9k2 board)
2011-07-04at91rm9200ek: use atmel_usartAndreas Bießmann
2011-07-04arm920t/at91: use new clock.c featuresAndreas Bießmann
This patch enables the new clock features from arm920t/at91/clock.c. This is an required step to get at91rm9200_usart replaced by atmel_usart driver. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Jens Scharsig <js_at_ng@scharsoft.de> Cc: Eric Bénard <eric@eukrea.com>
2011-07-04MX53: Add initial support for MX53ARDFabio Estevam
2011-07-04arm: Update jadecpu boardMatthias Weisser
Enable dcache and arch memset/memcpy for speed reasons Remove of config.mk and some environment overwrites Some generic cleanup Signed-off-by: Matthias Weisser <weisserm@arcor.de>
2011-07-04arm: omap2: apollon: fix broken buildIgor Grinberg
Define CONFIG_SYS_SDRAM_BASE to physical SDRAM address and CONFIG_SYS_INIT_SP_ADDR to physical SRAM address Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Kyungmin Park <kyungmin.park@samsung.com>
2011-07-04arm: Tegra2: GPIO: enable GPIO for Tegra2 boardsTom Warren
Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-07-04VCMA9: various cleanups/code style fixesDavid Müller (ELSOFT AG)
Signed-off-by: David Müller <d.mueller@elsoft.ch>
2011-07-04VCMA9: use CFI driver (and remove the old one)David Müller (ELSOFT AG)
2011-07-04VCMA9: remove unneeded config.mkDavid Müller (ELSOFT AG)
2011-07-04armv7: adapt omap4 to the new cache maintenance frameworkAneesh V
adapt omap4 to the new layered cache maintenance framework Signed-off-by: Aneesh V <aneesh@ti.com>
2011-07-04armv7: rename cache related CONFIG flagsAneesh V
Replace the cache related CONFIG flags with more meaningful names. Following are the changes: CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF CONFIG_SYS_NO_ICACHE -> CONFIG_SYS_ICACHE_OFF CONFIG_SYS_NO_DCACHE -> CONFIG_SYS_DCACHE_OFF Signed-off-by: Aneesh V <aneesh@ti.com> V2: * Changed CONFIG_L2_OFF -> CONFIG_SYS_NO_L2CACHE V4: * Changed all three flags to the final names suggested as above and accordingly changed the commit message
2011-06-27Minor coding style fixes.Wolfgang Denk
2011-06-23Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: run arm_pci_init after relocation IXP42x PCI rewrite update/fix PDNB3 board update/fix IXDP425 / IXDPG425 boards add dvlhost (dLAN 200 AV Wireless G) board IXP NPE: add support for fixed-speed MII ports update/fix AcTux4 board update/fix AcTux3 board update/fix AcTux2 board update/fix AcTux1 board use -ffunction-sections / --gc-sections on IXP42x support CONFIG_SYS_LDSCRIPT on ARM fix "depend" target in npe directory Fix IXP code to work after relocation was added trigger hardware watchdog in IXP42x serial driver add support for IXP42x Rev. B1 and newer add XScale sub architecture (IXP/PXA) to maintainer list Conflicts: arch/arm/lib/board.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-06-23update/fix PDNB3 boardMichael Schwingen
Signed-off-by: Michael Schwingen <michael@schwingen.org>
2011-06-23update/fix IXDP425 / IXDPG425 boardsMichael Schwingen
2011-06-23add dvlhost (dLAN 200 AV Wireless G) boardMichael Schwingen
2011-06-23update/fix AcTux4 boardMichael Schwingen
2011-06-23update/fix AcTux3 boardMichael Schwingen
2011-06-23update/fix AcTux2 boardMichael Schwingen
2011-06-23update/fix AcTux1 boardMichael Schwingen
2011-06-22ARM: drop unsupported 'trab' boardWolfgang Denk
The 'trab' board configuration is broken, and there is nobody who is interested and willing to fix it. Drop it. This includes support for VFD displays which have always been used by this board only. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-06-21Build fix/update of AFEB9260Sergey Lapin
Make AFEB9260 build again. Based on fix for AT91SAM9260EK. Signed-off-by: Sergey Lapin <slapin@ossfans.org>
2011-06-21cpu9260/9G20: fix board supportEric Benard
Signed-off-by: Eric Bénard <eric@eukrea.com>
2011-06-21AT91 rework: fix TOP9000 files to build againReinhard Meyer
Fix EMK TOP9000 board to build again: - changes required due to ATMEL rework Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-06-21AT91 rework: fix at91sam(9260/9g20/9xe)ek board port to build again:Reinhard Meyer
Make ATMEL's at91sam9260/9g20/9xe-ek boards build again Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-06-21Add support for Bluewater Systems Snapper 9260/9G20 modulesRyan Mallon
Add support for Bluewater Systems AT91 based Snapper 9260 and 9G20 single board computer modules. Includes NAND flash and Ethernet support. Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
2011-06-21update arm/at91rm9200 work with rework rework110202Jens Scharsig
* convert at91rm9200ek and eb_cpux9k2 board to ATMEL_xxx name scheme * Fix: timer.c compile error io.h not found with arm/at91rm9200 * update arm920t/at91 to ATMEL_xxx name scheme * update arm920t/at91 soc lib * update at91_emac driver Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de> Tested-by: Andreas Bießmann <andreas.devel@gmail.com>
2011-06-21mx31pdk: Add DHCP commandFabio Estevam
2011-06-21imx31_phycore: Fix build by using new relocation schemeFabio Estevam
2011-06-21mx1ads: Fix build by using new relocation schemeFabio Estevam
2011-06-21MX31: QONG: drop config.mkStefano Babic
Remove obsolete config.mk from QONG board. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-06-21omap730p2: fix build breaksAneesh V
Provide SDRAM base address and use SRAM for initial stack Signed-off-by: Aneesh V <aneesh@ti.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2011-06-21omap2420h4: fix build breaksAneesh V
2011-06-21omap1610inn: fix build breaksAneesh V
2011-06-21omap1510inn: fix build breaksAneesh V
2011-06-21omap5912osk: fix build breaksAneesh V
2011-06-21omap1610h2: fix build breaksAneesh V
2011-06-08Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: SMDK6400: fix the compiler error imx27lite: Remove local config.mk mx31ads: Fix environment location on flash imx31_litekit: Remove local config.mk mx31litekit: Fix boot with the new relocation scheme. mx31ads: Use the new relocation scheme
2011-06-07imx27lite: Remove local config.mkFabio Estevam
Local board config.mk should be avoided. Place CONFIG_SYS_TEXT_BASE definition into the board config file instead. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-06-07mx31ads: Fix environment location on flashFelix Radensky
At the moment u-boot and u-boot environment on flash have overlapping addresses, so each u-boot update erases the environment. Fix this by placing evironment right after u-boot. Also, remove confusing comment about environment location. Signed-off-by: Felix Radensky <felix@embedded-sol.com>
2011-06-07imx31_litekit: Remove local config.mkFabio Estevam
Local board config.mk should be avoided. Place CONFIG_SYS_TEXT_BASE definition into the board config file instead. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-06-06mx31litekit: Fix boot with the new relocation scheme.Fabio Estevam
imx31_litekit has been converted to the new relocation scheme, but it does not boot. Make the boot functional by using board_early_init_f . Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Magnus Lilja <lilja.magnus@gmail.com>
2011-06-06mx31ads: Use the new relocation schemeFabio Estevam
This fixes the MX31ADS build by using the new relocation scheme. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Felix Radensky <felix@embedded-sol.com>
2011-06-03Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: update embedded env settingsHarald Krapfenbauer
The recent commit ea882baf9c1 broke embedding environments in the middle of a sector, so relocate it to the start of the 2nd sector. Signed-off-by: Harald Krapfenbauer <harald.krapfenbauer@bluetechnix.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-06-03Blackfin: bf548-ezkit/bf561-ezkit: update env locationMike Frysinger
Relocate the env to one of the small end sectors to avoid issues with embedding it, such as support being broken (by recent commit ea882baf9c1), and for taking a while to save updates. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-06-01armv7: Add support for ST-Ericsson U8500 href platformJohn Rigby
Minimal platform support to boot linux from SD. Supported devices/hw limited to external MMC/SD slot, GPIO, I2C and minimal PRCMU. Signed-off-by: John Rigby <john.rigby@linaro.org> CC: Albert Aribaud <albert.aribaud@free.fr>
