Patch by Sangmoon Kim, 18 Aug 2005
- make highboot configurations use environment at high end, too,
to avoid flash fragmentation
- always use redundand environment
- don't enable video code for modules without graphics controller
- provide useful (though different) mtdparts settings
- get rid of CONFIG_CS_AUTOCONF which was always set anyway
* Extend mkconfig tool to print more useful target name
Hint: the CPLD on the TQM5200 must be programmed with a software
version supporting the high boot option! The new TQM5200S is
already supporting this option. On the TQM5200 this option will be
supported in configurations with MPC5200 rev B processors.
To actually "high boot", set jumper X30 on the STK52xx.
Patch by Martin Krause, 12 Jul 2006
- Support for TQM5200S (short version without graphic controller)
- Support for modules with 'N' type S29GL128N Spansion flashes
(requires changes to flash layout)
- Support for MPC5200B cpu (mostly support for second SDRAM bank)
The PS/2 keyobard driver for the TQM85xx modules only supports the
internal DUART of the MPC85xx CPU. Since the MPC8560 doesn't
include a DUART, the TQM8560 modules can't be used with the PS/2
keyboard controller on the STK85xx board.
The PS/2 keyboard driver should work with the modules TQM8540,
TQM8541 and TQM8555, but it only has been tested on a TQM8540, yet.
Make sure the PS/2 controller on the STK85xx is programmed. Jumper
settings: X66 1-2, 9-10; X61 2-3
Patch by Martin Krause, 21 Jun 2006
Patch by Martin Krause, 12 Jun 2006
- increase CFG_FLASH_ERASE_TOUT from 2 to 15 seconds
- use CFG_FLASH_WRITE_TOUT for programming instead of CFG_FLASH_ERASE_TOUT
- remove "Unlock Bypass" mode, because macronix flashes do not support
this mode officially
- fix flash reset command from 0x00FF to 0x00F0. 0x00FF is only specified
for Intel compatible flashes, not for AMD compatible.
Patch by Martin Krause, 15 Feb 2006
The TB5200 ("Tinybox") is a small baseboard for the TQM5200 module
integrated in a little aluminium case.
Patch by Martin Krause, 8 Jun 2006
Some code cleanup
Patch by Martin Krause, 20 Mar 2006
Signed-off-by: Martin Krause <martin.krause@tqs.de>
Patch by Markus Klotzbuecher, 12 Jul 2006
Set Timer Clock Select to use CPU clock as a timer input source.
Enabled it for Yucca board.
Patch from Richard Danter, 12 Aug 2005
Patch by Thomas Lange, Aug 11 2005
Patch by Martin Krause, 17 Nov 2005
Patch by Martin Krause, 07 Nov 2005
Tested on a STK85XX baseboard. Make sure the PS/2 controller
has been programmed. Jumper Settings: X66 1-2, 9-10; X61 2-3
Make the automatic CS configuration the default.
The dedicated configurations CONFIG_TQM5200_AA, CONFIG_TQM5200_AB
and CONFIG_TQM5200_AC are removed.
"TQM5200_config" is now the default for STK52XX.200 base boards.
On a STK52XX.100 base board "TQM5200_STK100_config" must be used.
Patch by Martin Krause, 27 Oct 2005
Patch by Stefan Roese, 13 Jun 2006
Patch by Scott McNutt, 08 Jun 2006
-Update base addresses for standard configuration
-Eliminate use of CACHE_BYPASS in board code
Patch by Stefan Roese, 06 Jun 2006
Patch by Stefan Roese, 02 Jun 2006
- Add IXP4xx NPE ethernet MAC support
- Add support for Intel IXDPG425 board
- Add support for Prodrive PDNB3 board
- Add IRQ support
Patch by Stefan Roese, 23 May 2006
[This patch does not include cpu/ixp/npe/IxNpeMicrocode.c which still
sufferes from licensing issues. Blame Intel.]
Patch by Stefan Roese, 15 May 2006
(needed because of differences in the PCMCIA hardware).
Patch by Stefan Roese, 10 May 2006
- Fix OMAP support that omap5912osk compiles in current source tree
- Update with code from "http://omap.spectrumdigital.com/osk5912"
to fix problems with DDR initialization
- Fix timer setup
- Use CFI flash driver and support complete 32MB of onboard flash
- Add "print_cpuinfo()" and "checkboard()" functions to display
CPU (with frequency) and Board infos
