(common/cmd_ide.c, common/cmd_reiser.c, common/cmd_scsi.c).
* Enable USB and IDE support for INKA4x0 board
* Patch by Andrew Dyer, 28 February 2005:
fix ext2load passing an incorrect pointer to get_partition_info()
resulting in load failure for devices other than 0
* Add reset code for Coral-P on INKA4x0 board
* Patch by Martin Krause, 28 Jun 2004:
Update for TRAB board.
* Fix some missing "volatile"s in MPC5xxx FEC driver
makes 'ld' to overlook binary objects compatibility.
* Moved $(PLATFORM_LIBS) from the library group (--start-group ...
--end-group) outside of the group. This will make 'ld' to do
_multiple_ search in the library group when resolving symbol
references and do only a _single_ seach in libgcc.a after the group
search.
* Fix stability problems on CPC45 board again.
* Make image detection for diskboot / usbboot / scsiboot more robust
(also check header checksum)
* Add USB and PCI support for INKA4x0 board
Add standalone application to change SMC91C111 MAC addresses,
see examples/README.smc91111_eeprom
* Patch by Xiaogeng (Shawn) Jin, 12 Oct 2004:
Fix Flash support for ARM Integrator CP.
* Patch by Richard Woodruff, 10 Jan 2005:
Update support for OMAP2420 (ARM11) and H4 board:
o clean up and add new types to H4 memory probe code.
o fix to work with internal boot.
o added PRCM config III operation.
o fix marginal flash timings.
o add revison ATAG usage.
o enable voltage scaling at power chip.
o fix compile error for i2c.
* Fix network problem (error when receiving multiple ARP packets)
Add support for Wind River sbc405 board
* Patch by Rainer Brestan, 12 Oct 2004:
Make examples/Makefile more robust
- Add RESET/PREBOOT/AUTOBOOT support for RPXlite_DW board
- Adjust CPU:BUS frequency ratio 1:1 when core frequency
less than 50MHz
* Patch by Sam Song, 10 Oct 2004:
Fix a parameter error in run_command() in main.c
add support for the TI OMAP2420 processor and its H4 reference
board
* Patch by Christian Pellegrin, 24 Sep 2004:
Added support for NE2000 compatible (DP8390, DP83902) NICs.
add support for the AMD db1550 board
* Patch by Travis Sawyer, 15 Sep 2004:
Add CONFIG_SERIAL_MULTI support for ppc4xx,
update README.serial_multi
- add u-boot.hex target in the top level Makefile
- add support for the UNSW/NICTA PLEB 2 board (pleb2)
- use -mtune=xscale and -march=armv5 options for PXA
Add support for SenTec-COBRA5272-board (Coldfire).
Add Xilinx Spartan2E family FPGA support
* Patch by Jeff Angielski, 02 Sep 2004:
Add Added support for H2 revision of the EP8260 board.
Fixed formatting for some of the EP8260 related source files.
Reset monitor size back to 256 so environment can be written
to flash on MPC85xx ADS and CDS releases.
* Patch by Paolo Broggini, 02 Sep 2004:
Make BSS clearing on ARM systems more robust
* Patch by Yue Hu and Joe, 01 Sep 2004:
- add PCI support for ixp425;
- add EEPRO100 suppor tfor ixdp425 board.
* Fix problem with protected sector detection in driver/cfi_flash.c
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to
pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for
additional ethernet addresses.
* Cleanup drivers/i82365.c - avoid duplication of code
* Fix bogus "cannot span across banks" flash error message
* Add support for CompactFlash for the CPC45 Board.
* Adjust INKA 4x0 default settings
- add support for "STK52xx" board (including PS/2 multiplexer)
- add hardware detection for TQM5200
* Enable long help on CMC PU2 board;
fix reset issue;
increase CPU speed from 179 to 207 MHz.
- Enable booting directly from flash
- fix CMC_PU2 flash driver
* Fix mkimage usage message
- add support for MPC8220 CPU
- Add support for Alaska and Yukon boards
* Adjust MIPS compiler options at run-time depending on tools version
("-march=4kc -mtune=4kc -Wa,-mips_allow_branch_to_undefined" for new,
"-mcpu=4kc" for old tools)
kernel on xaeniax board.
* Patch by Thomas Lange 07 Oct 2004:
Updated README for DBAu1x00 boards to match current status
Fix Flash support for Versatile.
* Patch by Roger Blofeld, 16 Sep 2004:
Fix timeout for DHCP command retry
[Remember: CFG_HZ should be 1000 on ALL systems!]
- Add support to revA version of PQ27 and PQ27E.
- Reverted MPC8260ADS baudrate back to original 115200
* Patch by Hojin, 17 Sep 2004:
Fix typo in cfi_flash.c
* Patch by Mark Jonas, 09 September 2004:
mtest's data line test (with CFG_ALT_MEMTEST set) returned a wrong
error message
* Patch by Mark Jonas, 31 August 2004:
Added option CFG_XLB_PIPELINING to enable XLB pipelining. This
improves FTP performance for MPC5200 systems. Enabled for IceCube
by default.
- Improve platform.S code for omap1510inn that detects whether code
is running from SDRAM or not. Patch allows SDRAM to be configured
if code is running out of SRAM at 0x20000000.
* Patch by Frederick Klatt, 30 Aug 2004:
Add support for the Wind River SBC8540/SBC8560 boards
* Patches by Michael Bendzick, 30 Aug 2004:
- Configure omap1510inn board to use drivers/cfi_flash.c
- Make drivers/cfi_flash.c protect environment and redundant
environment.
* Patch by Steven Scholz, 23 Jun 2004:
- Add script (tools/img2brec.sh) to programm U-Boot into
(Synch)Flash using the Bootstrap Mode of the MC9328MX1/L
- Add support for Altera Nios-II processors.
- Add support for Psyent PCI-5441 board.
- Add support for Psyent PK1C20 board.
- Add support for the MPC8541 and MPC8555 CDS boards
- Cleanup eth?addr handling: make dependent on CONFIG_ETH?ADDR
- Fix PCI window on MPC85xx; remove unneeded PCI initialization
from board_early_init_f()
- Provide SW workaround for PCI initialization on 85xx CDS
- Convert MPC85xxADS to use common CFI flash driver
* Cleanup: avoid compiler warnings
* Add CMC PU2 board to MAKEALL script
- Enable ramdisk/initrd tagged param support for omap1610h2_config
- Remove static network setup defaults from mx1ads_config
- add support for CMC PU2 board
- add support for I2C on at91rm9200
* Patch by Gary Jennejohn, 28 Sep 2004:
fix baudrate handling on at91rm9200
