path: root/include/configs
2015-06-01sparc: fix build error on gr_ep2s60 boardMasahiro Yamada
Commit 92ac52082140 (net: Remove all references to CONFIG_ETHADDR and friends) accidentally dropped #endif. Since then, gr_ep2s60 could not build. scripts/kconfig/conf --silentoldconfig Kconfig CHK include/config.h GEN include/autoconf.mk In file included from include/config.h:5:0, from ./include/common.h:18: include/configs/gr_ep2s60.h:15:0: error: unterminated #ifndef #ifndef __CONFIG_H__ ^ make[1]: *** [include/autoconf.mk] Error 1 Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-05-28ARM: bcm283x: Switch to generic timerMarek Vasut
Switch to generic timer implementation from lib/time.c . This also fixes a signed overflow which was in __udelay() implementation. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Tyler Baker <tyler.baker@linaro.org> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2015-05-28vexpress64: use uncompressed kernel by defaultLinus Walleij
The foundation model (FVP) emulator nominally boots using a clean, uncompressed kernel and the "booti" command. Augment the default U-Boot script to do this. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-05-28vexpress64: let Juno wait for root deviceLinus Walleij
The Juno reference design typically plugs the root FS on a USB stick. We need to wait a bit for the root to appear so tell this on the default command line. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-05-28ppc: xilinx-ppc: Move to generic board supportRicardo Ribalda
Generic board support seems to work just fine. Tested on ml507 with bitstream generated on the latest ISE software. Tested-by: Georg Schardt <schardt@team-ctech.de> Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
2015-05-27vexpress64: fix various memory issuesLinus Walleij
The ARM Trusted Firmware or other security solutions are eating memory from the top of the physical SDRAM1 space, moving backward from 0xffffffff, currently occupying e.g. 0xfe000000-0xffffffff with Trusted Firmware. This solution to reserving memory for secure world is not optimal, so we need to think of how the secure world and earlier boot stages should communicate to U-Boot what memory they are eating up. For now let's just put 16MB aside. Also enable the memory test command and define start and end of the test range so we can check that we actually have all that memory available and working. Suggested-by: Axel Haslam <ahaslam@baylibre.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-05-27vexpress64: specify CONFIG_SYS_FLASH_CFI_WIDTHRyan Harkin
Testing on the ARM Versatile Express Juno board showed intermittent CFI flash detection problems. Debug output in exception cases showed that the NOR flash was returning incorrect values to a query command: fwc addr 0000000008000000 cmd f0 f0f0f0f0 32bit x 8 bit fwc addr 0000000008000000 cmd ff ffffffff 32bit x 8 bit fwc addr 0000000008000154 cmd 98 98989898 32bit x 8 bit is= cmd 51(Q) addr 0000000008000040 is= 00800051 51515151 fwc addr 0000000008001554 cmd 98 98989898 32bit x 8 bit is= cmd 51(Q) addr 0000000008000040 is= 00800051 51515151 fwc addr 0000000008000000 cmd f0 00f000f0 32bit x 16 bit fwc addr 0000000008000000 cmd ff 00ff00ff 32bit x 16 bit fwc addr 0000000008000154 cmd 98 00980098 32bit x 16 bit is= cmd 51(Q) addr 0000000008000040 is= 00800051 00510051 fwc addr 0000000008001554 cmd 98 00980098 32bit x 16 bit is= cmd 51(Q) addr 0000000008000040 is= 00800051 00510051 Debugging showed that the problem could be solved by preventing u-boot from scanning different flash widths by specifying CONFIG_SYS_FLASH_CFI_WIDTH so that only using the 'correct' width was used. Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2015-05-26Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-05-26Merge branch 'zynq' of git://www.denx.de/git/u-boot-microblazeTom Rini
2015-05-26mx6: standardise CONFIG_CMD_CACHEPeter Robinson
Move CONFIG_CMD_CACHE to mx6_common and standardise the way it's defined. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: generic MMC config options to mx6_commonPeter Robinson
Move all standard mx6 MMC configs to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: standardise filesystem and boot optionsPeter Robinson
Move all standard filesystem, partition and fdt options to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move generic miscellaneous and overwrite optionsPeter Robinson
Move generic miscellaneous options that are standard across most, if not all, mx6 boards to central mx6_common define to ensure consistent features. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: centralise common boot options in mx6_common.hPeter Robinson
Define common LOADADDR and BOOTDELAY to ensure a consistent experience across mx6 boards Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move MXC_GPIO define to mx6_common.hPeter Robinson
Define CONFIG_MXC_GPIO and CONFIG_CMD_GPIO by default in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move standard ATAG configs to mx6_common.hPeter Robinson
Define the standard ATAG consfigs in mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move generic imx6 options to mx6_common.hPeter Robinson
All boards define CONFIG_MX6, CONFIG_DISPLAY_BOARDINFO, CONFIG_DISPLAY_CPUINFO and CONFIG_SYS_GENERIC_BOARD so define them in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move all standard includes to mx6_common.hPeter Robinson
The linux/sizes.h, asm/arch/imx-regs.h, asm/imx-common/gpio.h, config_cmd_default.h includes are used fairly universally across imx6 boards so include them in mx6_common.h by default. We define CONFIG_SYS_NO_FLASH before config_cmd_default.h so that we don't have to undef CONFIG_CMD_FLASH / CONFIG_CMD_IMLS everywhere. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26novena: standardise mx6_common.h includePeter Robinson
Standardise mx6_common.h to the same as other mx6 boards Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx: ventana: update MMC env configurationTim Harvey
We will use the same env size and redundancy used for NAND env for MMC. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-26arm, imx6: add support for aristainetos2 boardHeiko Schocher
add support for imx6dl based aristainetos2 board U-Boot 2015.04-rc5-00066-g60f6ed4 (Apr 10 2015 - 08:46:27) CPU: Freescale i.MX6DL rev1.1 at 792 MHz Reset cause: WDOG Board: aristaitenos2 Watchdog enabled I2C: ready DRAM: 1 GiB NAND: 1024 MiB MMC: FSL_SDHC: 0 SF: Detected N25Q128A with page size 256 Bytes, erase size 64 KiB, total 16 MiB Display: lg4573 (480x800) In: serial Out: serial Err: serial Net: FEC [PRIME] Hit any key to stop autoboot: 0 => Signed-off-by: Heiko Schocher <hs@denx.de>
2015-05-25zynq: Use system timer implementation instead of ourMichal Simek
Don't use error-prone arch timer code and instead use system timer implementation to simplify our code. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-05-24Merge git://git.denx.de/u-boot-nand-flashTom Rini
2015-05-24mtd: vf610_nfc: enable ONFI detectionStefan Agner
This changes enable ONFI detection. The Read ID command now allows one address byte which is needed for ONFI detection. To read the ONFI parameter page, the NAND_CMD_PARAM need to be supported. The CMD code enables one command and one address byte along with reading data from flash using R/B#, as specified by ONFI. Signed-off-by: Stefan Agner <stefan@agner.ch>
2015-05-24mtd: vf610_nfc: add Freescale NFC controller configs to KconfigStefan Agner
This commit allows users to enable/disable the Freescale NFC controller found in systems like Vybrid (VF610), MPC5125, MCF54418 or Kinetis K70 via Kconfig with more detailed help docs. Signed-off-by: Stefan Agner <stefan@agner.ch> Acked-by: Stefano Babic <sbabic@denx.de> [scottwood: updated vf610twr_nand_defconfig] Signed-off-by: Scott Wood <scottwood@freescale.com>
2015-05-22Merge branch 'master' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
2015-05-21imx: ventana: config: enable Falcon modeTim Harvey
Falcon mode entails the SPL booting the OS directly instead of U-Boot. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-21wandboard: Switch to SPL supportFabio Estevam
Currently we need to build one U-boot image for each of the wandboard variants: quad, dual-lite and solo. By switching to SPL we can support all these variants with a single binary, which is very convenient. Based on the work from Richard Hu. Tested kernel booting on the three boards. Signed-off-by: Richard Hu <hakahu@gmail.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Tested-by: Vagrant Cascadian <vagrant@aikidev.net> Reviewed-by: Stefano Babic <sbabic@denx.de>
2015-05-21sandbox: Enable some ENV commandsJoe Hershberger
Enable some additional ENV commands in sandbox to aid in build testing and run testing. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-05-20Merge git://git.denx.de/u-boot-netTom Rini
2015-05-20arm/ls1021a: Remove ccsr_ddr from immap_ls102xa.hYork Sun
ccsr_ddr structure is already defined in fsl_immap.h. Remove this duplicated define. Move fixed timing into ls1021atwr.h. Signed-off-by: York Sun <yorksun@freescale.com> CC: Alison Wang <alison.wang@freescale.com> Acked-by: Alison Wang <alison.wang@freescale.com>
2015-05-20arm: ls102xa: Adjust the load address of U-Boot for NOR bootAlison Wang
The original load address of U-Boot is 0x67f80000. The address space of NOR flash is 0x60000000 to 0x67ffffff. It will cause the size of u-boot couldn't be larger than 512K. As more features are supported in u-boot, the size of u-boot is larger than 512K. To fix this issue, the load address of U-Boot for NOR boot is adjusted to 0x60100000. In RCW, the PBI command needs to change as follows: .pbi -write 0xee0200, 0x67f80000 +write 0xee0200, 0x60100000 .end Signed-off-by: Alison Wang <alison.wang@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-05-20net: Remove all calls to net_random_ethaddr()Joe Hershberger
Remove the calls to net_random_ethaddr() that some boards and some drivers are calling. This is now implemented inside of net/eth.c Enable the feature for all boards that previously enabled it. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-By: Michael Walle <michael@walle.cc> (for the lsxl board part) Series-changes: 2 -Fixed bfin build errors
2015-05-19net: Remove all references to CONFIG_ETHADDR and friendsJoe Hershberger
We really don't want boards defining fixed MAC addresses in their config so we just remove the option to set it in a fixed way. If you must have a MAC address that was not provisioned, then use the random MAC address functionality. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-05-19sunxi: Cache line size definitionPaul Kocialkowski
Sunxi platforms use ARM Cortex A8, A7 and A15 (unsupported yet) CPU cores, which all have 64 bytes cache line size. This is required to e.g. enable USB gadget. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-05-19sunxi: add support for UART2 on A23/A33Laurent Itti
Add support for UART2 (2-pin version but note that RTS/CTS pins are available pn that port for possible future use), can be selected in config by using CONFIG_CONS_INDEX=3 Signed-off-by: Laurent Itti <laurentitti@gmail.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-05-19console: Fix pre-console flushing via cfb_console being very slowHans de Goede
On my A10 OlinuxIno Lime I noticed a huge (5+ seconds) delay coming from console_init_r. This turns out to be caused by the preconsole buffer flushing to the cfb_console. The Lime only has a 16 bit memory bus and that is already heavy used to scan out the 1920x1080 framebuffer. The problem is that print_pre_console_buffer() was printing the buffer once character at a time and the cfb_console code then ends up doing a cache-flush for touched display lines for each character. This commit fixes this by first building a 0 terminated buffer and then printing it in one puts() call, avoiding unnecessary cache flushes. This changes the time for the flush from 5+ seconds to not noticable. The downside of this approach is that the pre-console buffer needs to fit on the stack, this is not that much to ask since we are talking about plain text here. This commit also adjusts the sunxi CONFIG_PRE_CON_BUF_SZ to actually fit on the stack. Sunxi currently is the only user of the pre-console code so no other boards need to be adjusted. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-05-19sunxi: Pass serial number through ATAGPaul Kocialkowski
Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-05-19imx: riotboard, marsboard: Enable thermal supportNikolay Dimitrov
Signed-off-by: Nikolay Dimitrov <picmaster@mail.bg>
2015-05-19imx: ventana: add pmic_setup to SPLTim Harvey
We need to do any PMIC setup in the SPL if we are to bypass U-Boot for falcon mode. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-19imx: ventana: (cosmetic) clean up size defines for improved readabilityTim Harvey
Use the SZ_1M and SZ_1K macros from linuz/sizes.h for improved readability Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-19imx: ventana: config: use MMC SPL RAW supportTim Harvey
Switch to MMC RAW support for SPL. We will place the uboot.img at 69KB. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15imx: ventana: config: enable Thermal supportTim Harvey
2015-05-15imx: ventana: enable DM_SERIALTim Harvey
mxc_serial supports DM so lets use it. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15imx: ventana: config: enable driver modelTim Harvey
Enable U-Boot Driver Model (DM). Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15imx: ventana: config: enable gpio commandTim Harvey
2015-05-15imx: ventana: display SPL boot deviceTim Harvey
Display what device the SPL will fetch uboot.img from Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15imx: ventana: set dtype env var to boot mediaTim Harvey
Bootscripts for some distro's such as Android can benefit from knowing what boot media its script was loaded from. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15tbs2910: add CONFIG_SUPPORT_EMMC_BOOTSoeren Moch
Add emmc boot partition commands to be able to select the boot partition. Signed-off-by: Soeren Moch <smoch@web.de>
