path: root/include/configs
2017-09-01Kconfig: Migrate all of cmd/fastboot/Kconfig to defconfigsTom Rini
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's not strictly part of fastboot. - Add some defaults for the fastboot buffer location and size - Migrate all options listed in cmd/fastboot/Kconfig - Cleanup the README Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-01Merge git://git.denx.de/u-boot-sunxiTom Rini
2017-09-01sunxi: Fix CONFIG_SUNXI_GMAC referencesDave Prue
SUNXI_GMAC was still used to configure the code where as the same has been renamed and moved to Kconfig in below commit "sunxi: Move SUNXI_GMAC to Kconfig" (sha1: 4d43d065db3262f9a9918ba72457bf36dfb8e0bb) Signed-off-by: Dave Prue <dave@prue.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Mark Kettenis <kettenis@openbsd.org> Tested-by: Mark Kettenis <kettenis@openbsd.org> [Tweek commit message, config_whitelist.txt, build-whitelist.sh] Signed-off-by: Jagan Teki <jagan@openedev.com>
2017-09-01Merge git://git.denx.de/u-boot-imxTom Rini
Signed-off-by: Tom Rini <trini@konsulko.com> Conflicts: configs/imx6qdl_icore_mmc_defconfig configs/imx6qdl_icore_rqs_defconfig
2017-08-30i.MX6Q: icorem6: Add falcon modeJagan Teki
Add Falcon mode support in Engicam i.CoreM6 board. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-08-30ARM: uniphier: remove unneeded NAND config optionsMasahiro Yamada
CONFIG_NAND_DENALI select's CONFIG_SYS_NAND_SELF_INIT, so the NAND initialization process is driven by the driver itself. CONFIG_SYS_NAND_MAX_CHIPS and CONFIG_SYS_NAND_BASE are unused. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-08-26igep00x0: merge igep0020 and igep0030 defconfigs to igep00x0_defconfigPau Pajuelo
Update igep00x0 code with the following features: - Add board and revision detection for the boards: - IGEP0020-RF - IGEP0020-RC - IGEP0030-RG - IGEP0030-RE - Merge IGEP0020 and IGEP0030 mux tables - Add suport to use GPIO_126, GPIO_127 and GPIO_129 - board_name and board_rev environment variables display board and revision informations - Move dtb name selection from code to boot script Signed-off-by: Pau Pajuelo <ppajuel@gmail.com> Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Tested-by: Pau Pajuelo <ppajuel@gmail.com>
2017-08-21Merge git://git.denx.de/u-boot-usbTom Rini
2017-08-21usb: ehci: Convert CONFIG_USB_EHCI_PCI to KconfigBin Meng
This converts CONFIG_USB_EHCI_PCI to a Kconfig option, and updates all boards that use it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-20ARM: uniphier: remove sLD3 SoC supportMasahiro Yamada
This SoC is too old. It is difficult to maintain any longer. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-08-18Merge branch 'master' of git://git.denx.de/u-boot-mmcTom Rini
2017-08-18m68k: add board stmark2, mcf5441x basedAngelo Dureghello
Sysam stmark2 board is a generic and fully (hw and sw) open board, with a mcf54415 Coldfire CPU, 128MB of DDR2, 16MB of SPI flash and SD card as non volatile memories, and a wifi module included on-board. The board is actually used mainly for Coldfire custodian testing activity related to the mcf5441x Coldfire family. For further information please see: http://sysam.it/cff_stmark2.html Signed-off-by: Angelo Dureghello <angelo@sysam.it> --- Changes in v2: - remove CMD_REGINFO - add board information in commit message
2017-08-18m68k: mcf5445x: move early ddr init as board-specificAngelo Dureghello
For certain boot types and sbf, for V4 cpu's, an early ddr/sdram init is required. This patch moves this ddr/sdram early initalization away from start.S (to be board related). Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2017-08-17dm: mmc: Drop CONFIG_DM_MMC_OPSSimon Glass
All boards which use DM_MMC have now been converted to use DM_MMC_OPS. Drop the option and good riddance. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-08-16Merge git://www.denx.de/git/u-boot-imxTom Rini
Update pfla02 for setenv changes and PHYLIB/etc migration to Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Convert CONFIG_ENV_IS_IN... to a choiceSimon Glass
At present we support multiple environment drivers but there is not way to select between them at run time. Also settings related to the position and size of the environment area are global (i.e. apply to all locations). Until these limitations are removed we cannot really support more than one environment location. Adjust the location to be a choice so that only one can be selected. By default the environment is 'nowhere', meaning that the environment exists only in memory and cannot be saved. Also expand the help for the 'nowhere' option and move it to the top since it is the default. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Move all of the imply logic to default X if Y so it works again] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-15Move environment files from common/ to env/Simon Glass
About a quarter of the files in common/ relate to the environment. It seems better to put these into their own subdirectory and remove the prefix. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-14ARM: rockchip: rock: Correct test to use CONFIG_IS_ENABLED not definedTom Rini
While it is likely that this entire case is superfluous and can be removed, correct the test now to match what is in rockchip-common.h and makes sense based on context of the code. Otherwise we get a large number of warnings. Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-14Merge branch 'master' of git://git.denx.de/u-boot-rockchipTom Rini
2017-08-13Convert CONFIG_OMAP3_SPI to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_OMAP3_SPI Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Minor comment tweaks] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-13spl: moveconfig: remove SPL_LDSCRIPT definitions for header-filesPhilipp Tomsich
With the hierarchical defaults set up, we remove these from the header files. To do so, I've run moveconfig on SPL_LDSCRIPT and this commits the changes. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13moveconfig: migrate TPL_STACK, TPL_TEXT_BASE and TPL_MAX_SIZEPhilipp Tomsich
We can finally drop TPL_STACK, TPL_TEXT_BASE and TPL_MAX_SIZE off the whitelist (this time it's really happening!) and migrate the setting (only used on the RK3368-uQ7 so far) into Kconfig. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: Kconfig: preset TPL_LDSCRIPT via Kconfig for the RK3368Philipp Tomsich
Set TPL_LDSCRIPT in Kconfig, so we don't have to pollute our header file. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-13rockchip: board: lion-rk3368: add support for the RK3368-uQ7Philipp Tomsich
The RK3368-uQ7 (codenamed 'Lion') is a micro-Qseven (40mm x 70mm, MXM-230 edge connector compatible with the Qseven specification) form-factor system-on-module based on the octo-core Rockchip RK3368. It is designed, supported and manufactured by Theobroma Systems. It provides the following features: - 8x Cortex-A53 (in 2 clusters of 4 cores each) - (on-module) up to 4GB of DDR3 memory - (on-module) SPI-NOR flash - (on-module) eMMC - Gigabit Ethernet (with an on-module KSZ9031 PHY) - USB - HDMI - MIPI-DSI/single-channel LVDS (muxed on the 'LVDS-A' pin-group) - various 'slow' interfaces (e.g. UART, SPI, I2C, I2S, ...) Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: rk3368: spl: enable SPL_FRAMEWORK in rk3368_common.hPhilipp Tomsich
To build TPL and SPL stages for the RK3368, we will also need to enable the SPL_FRAMEWORK. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: rk3368: spl: add memory layout for TPL and SPLPhilipp Tomsich
For the RK3368, we use a multi-stage boot-process consisting of the following: 1. TPL: initalises DRAM, returns to boot-ROM (which then loads the next stage and transfers control to it) 2. SPL: a full-features SPL stage including OF_CONTROL and FIT image loading, which fetches the ATF, DTB and full U-Boot and then transfers control to the ATF (using the BL31 parameter block to indicate the location of BL33/U-Boot) 3. ATF: sets up the secure world and exits to BL33 (i.e. a full U-Boot) in the normal world 4. full U-Boot TPL/SPL and the full U-Boot are built from this tree and need to run from distinct text addresses and with distinct initial stack pointer addresses. This commit sets up the configuration to run: - TPL from the SRAM at 0xff8c0000 (note that the first 0x1000 are reserved for use by the boot-ROM and contain the SP when the TPL is entered) - SPL from DRAM at 0x0 - U-Boot from DRAM at 0x200000 Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: rk3368: spl: define COUNTER_FREQUENCY to 24MHzPhilipp Tomsich
The BootROM of the RK3368 Boot ROM does not initialise cntfrq_el0. This change defines COUNTER_FREQUENCY, which is used by the AArch64 init code in arch/arm/cpu/armv8/start.S to set up cntfrq_el0. If the counter-frequency is not correctly set up, the calculation of delays using the ARMv8 generic timer can not work correctly. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-13rockchip: back-to-bootrom: split BACK_TO_BOOTROM for TPL/SPLPhilipp Tomsich
The back-to-bootrom option is rather unfortunately named CONFIG_ROCKCHIP_SPL_BACK_TO_BOOTROM instead of CONFIG_SPL_ROCKCHIP_BACK_TO_BOOTROM To make is selectable through CONFIG_IS_ENABLED(ROCKCHIP_BACK_TO_BOOTROM), we need to rename it. At the same time, we introduce a TPL_ variant of the option to give us finer-grained control over when it should be used. This change is motivated by our RK3368 boot process, which returns to the boot ROM only from the TPL stage, but not from the SPL stage. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> [added fix-up for evb-rk3229_defconfig and phycore-rk3288_defconfig:] [fixed inverted CONFIG_IS_ENABLED test for rk3288:] Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> include/configs/rock.h: undef
2017-08-12Convert CONFIG_NAND to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Sync up a few more, add imply's] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11omap3: evm: Update board, defconfig, and maintainer fileDerald D. Woods
This patch brings the OMAP3 EVM to a bootable state, on master, as of v2017.09-rc1. Signed-off-by: Derald D. Woods <woods.technical@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-08-11Convert CONFIG_CMD_ZBOOT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ZBOOT Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Convert CONFIG_CMD_TSI148 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_TSI148 Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Convert CONFIG_CMD_TRACE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_TRACE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Convert CONFIG_CMD_THOR_DOWNLOAD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_THOR_DOWNLOAD Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Kconfig: Drop CONFIG_CMD_TFTPSimon Glass
This is not a valid CONFIG option. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Convert CONFIG_CMD_TERMINAL to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_TERMINAL Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Convert CONFIG_CMD_TCA642X to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_TCA642X Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Convert CONFIG_CMD_STRINGS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_STRINGS Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Convert CONFIG_CMD_SPL_WRITE_SIZE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SPL_WRITE_SIZE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Convert CONFIG_CMD_SPL_NAND_OFS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SPL_NAND_OFS Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Convert CONFIG_CMD_SPL to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SPL Note that trats does not actually use SPL, so this option can no-longer be set. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Convert CONFIG_CMD_SH_ZIMAGEBOOT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SH_ZIMAGEBOOT Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Convert CONFIG_CMD_SF_TEST to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SF_TEST Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Convert CONFIG_CMD_SDRAM to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SDRAM Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Convert CONFIG_CMD_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SCSI Also update the Makefile to use CONFIG_CMD_SCSI instead of CONFIG_SCSI to enable the command, fixing an earlier error. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> [trini: Rework to default y if SCSI, drop cl-som-am57x which did not use CMD_SCSI for real] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11Convert CONFIG_CMD_SAVES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_SAVES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-08-11Kconfig: sandbox: Drop CONFIG_CMD_SANDBOX optionSimon Glass
This is no-longer used. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
