Add support for distro boot. This is especially helpful for external
devices. There is a global boot command which scans a predefined
list of boot targets:
run distro_bootcmd
As well as direct boot commands such as:
run bootcmd_mmc1
run bootcmd_mmc2
run bootcmd_usb
run bootcmd_dhcp
Refer to doc/README.distro fo details.
While at it, remove the CONFIG_DRIVE_TYPES define which has not
been used and was meant to be used for multi device boot support
which is now provided by distroboot.
Add environment variables for default framebuffer support using a
default VGA mode. Also remove memargs, since we use memory size to
reserve the framebuffer which does not get overwritten by the
Linux kernel.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Fix the framebuffer location to the very end of the available memory.
This allows to remove the area from available memory for the kernel,
which in turn allows to display the splash screen through the while
Linux kernel boot process.
Ideas has been taken from the sunxi display driver, e.g.
20779ec3a5 ("sunxi: video: Dynamically reserve framebuffer memory")
The Vybrid SoC family has the same display controller unit (DCU)
like the LS1021A SoC. This patch adds platform data, pinmux defines
and clock control to enable the driver for Vybrid based boards too.
Synchronize initramfs related configuration options and improve
memory layout. The memory layout with an offset of 16MiB allows
to boot bigger kernels. With AUTO_ZRELADDR, which is pretty much
the standard nowadays, the kernel relacates itself to PC masked
with 0xf8000000 plus a text offset of 0x8000 (hence 0x80008000 for
Vybrid). With a 16MiB offset from the start of memory and a 16MiB
distance to the device-tree, we allow kernel up to ~16MiB.
u-boot allows modifying a device tree after it is loaded into
memory. Add fdt_fixup hook in u-boot environment which can
facilitate such modifications.
(cherry picked from commit faf1e62bf04b01dc7110a459f558aaf414bfcac0)
Introduce Ethernet update capability via setethupdate which is
automatically tried by setupdate as well should SD and USB update
fail (e.g. neither an SD card nor an USB memory stick with our
flash_blk.img script and accompanying artefacts is inserted.
Our update scripts write the kernel and device tree in seperate
UBI volumes. This allows to use a lot less UBI/UBIFS support in
U-Boot, which should lower the risk of hitting bugs in this area.
Boot times are also slightly faster (measurements showed an
improvement of ~150ms).
Code mostly ported from imx-kobs-5.3.
MTD partitioning is set accordingly.
writebcb: Write Boot Control Block (FCB and DBBT)
[ported to U-Boot 2016.11]
Add writebcb command which creates a NAND Boot Configuration Block
(BCB) at the beginning of the active flash device. The BCB stores
the information for the SoC internal boot ROM where the application
with a valid IVT header can be found on the NAND device. The first
two argument of the command need an offset of the NAND device where
the primary and secondary application can be found.
Typically, U-Boot is the application which gets loaded by the boot
ROM. Hence, the offset address need to be the address where U-Boot
(u-boot.imx along with a 0x400 long prefix) is stored on the device.
At least one location is mandatory.
Currently only the FCB (Firmware Configuration Block) is written to
the device. The DBBT (Discovered Bad Block Table) is optional and
not created by writebcb currently.
Use two separate partitions for the two firmware instances. Also
resize them to be of the same size which also makes the start of
the UBI partition nicely aligned to 0x400000.
In order to detect the new MTD layout and whether we run a U-Boot
with the new BCB format or not, introduce a variable called
"updlevel" which we can use in update/upgrade scripts.
Limit memory used for relocation of FDT or initrd. This is
required to make sure that relocated artifacts are within lowmem.
If fdt_high or initrd_high are not set, U-Boot automatically
relocates artifacts to the end of memory. But this area won't
be part of lowmem and hence will not be accessible by the kernel
during early boot.
With VM split set to 2G/2G (i.MX default), only the 2GB Apalis
iMX6 is affected by that issue. With VM split set to 3G/1G (ARM
default) also modules with 1GB of memory are affected. With the
latter the amount of lowmem will be 760MiB.
The value must also not exceed available memory! Use a safe value
of 512MiB for Apalis and 256MiB for Colibri.
The DFU Kconfig menu entries should be part of the SPL
Kconfig file. Also avoid using the top level Makefile by
moving the config dependent build artifacts to the driver/
and driver/usb/gadget/ Makfiles.
With that, DFU can be built again in SPL if
CONFIG_SPL_DFU_SUPPORT is enabled.
Fixes: 6ad6102246d8 ("usb:gadget: Disallow DFU in SPL for now")
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
(cherry picked from commit 5991703e88f320767d9390d64a6a9bd62560696b)
Specify standard padding for payload to 68KB. This is derived from
the maximum header size plus maximum SPL size. It matches the
already defined offset for SD/eMMC devices (69KB) too. This allows
to use the u-boot-with-spl.imx build target to generate a directly
flashable image which can be flashed using:
dd if=u-boot-with-spl.imx of=/dev/mmcblk0 bs=512 skip=2
While the patch has been created with SD/eMMC in mind, this also
works with other boot media. The board file needs to configure the
media specific (absolute) payload offset accordingly. Especially
the IVT offset is boot media specific and can be retrieved from the
reference manual (Table 8-25. Image Vector Table Offset and Initial
Load Region Size). For NAND boot a define like this should do the
job:
#define CONFIG_SYS_NAND_U_BOOT_OFFS (SPL_PAD_TO + 0x400)
(cherry picked from commit 0405092bd21a44f5af22f17aeb0b82a0a11e1252)
Basically running the following script:
tools/moveconfig.py CONFIG_TEGRA_MMC
Note that I left the SPL specific handling in
include/configs/tegra-common-post.h unchanged.
This patch adds board support for the Toradex Apalis TK1 a computer on
module which can be used on different carrier boards.
The module consists of a Tegra TK1 SoC, a PMIC solution, 2 GB of DDR3L
RAM, a bunch of level shifters, an eMMC, a TMP451 temperature sensor
chip, an I210 gigabit Ethernet controller and a SGTL5000 audio codec.
Furthermore, there is a Kinetis MK20DN512 companion micro controller for
analogue, CAN and resistive touch functionality.
For the sake of ease of use we do not distinguish between different
carrier boards for now as the base module features are deemed
sufficient enough for regular booting.
The following functionality is working so far:
- eMMC boot, environment storage and Toradex factory config block
- Gigabit Ethernet
- MMC/SD cards (both MMC1 as well as SD1 slot)
- USB client/host (dual role OTG port as client e.g. for DFU/UMS or host,
other two ports as host)
This adds board support for the Toradex module family Colibri iMX6.
The familiy consists of a module with i.MX6 DualLite, i.MX6 Solo, both
with a version for commercial and industrial temperature range.
(cherry picked from commit a02d517b0182f83771565eba1329fb323674ec58)
This adds board support for the Toradex module family Apalis iMX6.
The familiy consists of a module with i.MX6 Dual, i.MX6 Quad with
(cherry picked from commit 592f4aed6db765172e21f228800b49f9a27ff201)
Add serial platform data to board file.
Enable driver model for PXA serial driver.
(cherry picked from commit 136179bec19f4bc84227cba138214ea392a723ea)
With em humble DM and Kconfig migraters U-Boot binary size keeps
increasing. Drop a bunch of less needed stuff to save another precious
20+ KB.
(cherry picked from commit fc127d184aea293ec415dd66e3282dba0b66c5f3)
Migrate the PXA serial driver to be configured via Kconfig.
(cherry picked from commit d804a5e1c369e59f23723cd21e1e422b7702a0ac)
remove now unused CONFIG_TRDX_PID_XXX
(cherry picked from commit 877ea607a8e07a9ed308e44a58e8e2b9028f01f2)
Now with the config block handling in place move the U-Boot environment
location before the config block at the end of 1st "boot sector" as
deployed during production using our downstream BSP.
(cherry picked from commit 74b19ad1c180fe32a01bccc35b0be1425132d927)
With our common code in place actually make use of it across all our
modules.
(cherry picked from commit b891d01038abcc8b25f12e1b91ff889b06eb07a2)
As the upcoming driver model integration takes up some more precious flash
space first make sure to drop expensive LZMA support.
Not all networks have a DHCP server configured properly, so these
scripts make it easier to boot in that scenario.
The LCD isn't supported in U-Boot and the LCD is now configured in
the device tree, so this code is pointless.
V2: Eliminiate erroneous newline.
Unify the partitions of each chip then it will be more easy for us to
write scripts, tools or guides for rockchip chips.
Those extra partitions mostly are used to be compatible with our
internal loaders (such as miniloader which was same as spl, or
android loader then we can support dual boot)
Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
rk3399 has two mmc dev controller:
mmc 0: SD card;
mmc 1: EMMC
U-Boot will scan the mmc boot device configured by CONFIG_SYS_MMC_ENV_DEV,
since evb has emmc on board, let's set the EMMC as default.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
I am not sure why this limit is changing. But my kernel
doesn't load when it's above 256. This was testing on the
rock2 board.
Signed-off-by: Sandy Patterson <apatterson@sightlogix.com>
Updated commit subject:
Mostly by adding MACH_SUN50I to some existing #ifdefs enable support
for the the HCI0 USB host controller on the A64.
Fix up some minor 64-bit hiccups on the way.
Add the bare minimum DT bits to the A64 .dtsi and enable the controllers
and the PHY on the Pine64.
This is limited to the first USB controller at the moment, which is
connected to the lower USB socket on the Pine64 board.
[Andre: remove unneeded defines, enable OHCI, add commit message]
Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
ARCH_SUNXI selects DM_USB, where CONFIG_USB_MAX_CONTROLLER_COUNT
is not used.
CONFIG_SUNXI -> CONFIG_ARCH_SUNXI
and removed CONFIG_SUNIX from config_whitelist.txt
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: Jagan Teki <jteki@openedev.com>
Enable an early debug UART to debug problems when an ICE or other
debug mechanism is not available.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
If 'ethaddr' is not set, we will get the ethernet address from AT24MAC,
and set it to 'ethaddr' variable.
Signed-off-by: Songjun Wu <songjun.wu@microchip.com>
Reviewed-by: Andreas Bießmann <biessmann@corscience.de>
Move the config options from the include/configs/sama5d2_xplained.h
to configs/sama5d2_xplained_*_defconfig.
Reviewed-by: Andreas Bießmann <andreas@biessmann.org>
common/Kconfig
configs/dms-ba16_defconfig
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig
to use that.
[trini: Re-generate configs and include/configs/ changes]
Add 'PCI' as a menu option and migrate all existing users.
icorem6qdl> mtdparts
device nand0 <nand>, # parts = 6
0: spl 0x00200000 0x00000000 0
1: uboot 0x00200000 0x00200000 0
2: env 0x00100000 0x00400000 0
3: kernel 0x00400000 0x00500000 0
4: dtb 0x00100000 0x00900000 0
5: rootfs 0x1f600000 0x00a00000 0
Cc: Peng Fan <peng.fan@nxp.com>
Cc: Matteo Lisi <matteo.lisi@engicam.com>
Cc: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Enable MTD device, partition and command support.
Add NAND support for Engicam i.CoreM6 qdl board.
Boot Log:
U-Boot SPL 2016.09-rc2-30755-gd3dc581-dirty (Sep 28 2016 - 23:00:43)
Trying to boot from NAND
NAND : 512 MiB
U-Boot 2016.09-rc2-30755-gd3dc581-dirty (Sep 28 2016 - 23:00:43 +0530)
CPU: Freescale i.MX6SOLO rev1.3 at 792MHz
CPU: Industrial temperature grade (-40C to 105C) at 55C
Reset cause: WDOG
Model: Engicam i.CoreM6 DualLite/Solo Starter Kit
DRAM: 256 MiB
NAND: 512 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Hit any key to stop autoboot: 0
icorem6qdl>
Cc: Scott Wood <oss@buserror.net>
Add DM_GPIO, DM_MMC support for u-boot and disable for SPL.
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Add enet support for engicam icorem6 qdl starter kit.
- Add pinmux settings
- Add board_eth_init
TFTP log:
Net: FEC [PRIME]
icorem6qdl> tftpboot {fdt_addr} imx6dl-icore.dtb
Using FEC device
TFTP from server 192.168.2.96; our IP address is 192.168.2.75
Filename 'imx6dl-icore.dtb'.
Load address: 0x0
Loading: ######
1.3 MiB/s
done
Bytes transferred = 28976 (7130 hex)
CACHE: Misaligned operation at range [00000000, 00007130]
icorem6qdl>
Boot Log for i.CoreM6 DualLite/Solo Starter Kit:
U-Boot SPL 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46)
Trying to boot from MMC1
U-Boot 2016.09-rc2-30739-gd1fa290 (Sep 17 2016 - 00:37:46 +0530)
CPU: Industrial temperature grade (-40C to 105C) at 31C
Reset cause: POR
DRAM: 256 MiB
MMC: FSL_SDHC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: CPU Net Initialization Failed
No ethernet found.
switch to partitions #0, OK
mmc0 is current device
reading boot.scr
** Unable to read file boot.scr **
reading zImage
6741808 bytes read in 341 ms (18.9 MiB/s)
Booting from mmc ...
reading imx6dl-icore.dtb
30600 bytes read in 19 ms (1.5 MiB/s)
Booting using the fdt blob at 0x18000000
Using Device Tree in place at 18000000, end 1800a787
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
Boot Log for i.CoreM6 Quad/Dual Starter Kit:
CPU: Freescale i.MX6Q rev1.2 at 792MHz
CPU: Industrial temperature grade (-40C to 105C) at 28C
Reset cause: POR
DRAM: 512 MiB
MMC: FSL_SDHC: 0
In: serial
Out: serial
Err: serial
No ethernet found.
icorem6qdl>
Acked-by: Peng Fan <peng.fan@nxp.com>
- Add DEFAULT_FDT_FILE kconfig entry
- Move CONFIG_DEFAULT_FDT_FILE from include/configs to defconfigs
