Add the required config.mk logic for this SoC as well as the BOOT_DEVICE
define. Finally, enable the options on the am335x_evm.
Add video support to the board with the display
focaltech etm070003dh6.
Some GPIOs differ in the new revision board.
Previous revision are considered obsolete and
they will not anymore supported.
The mcx board was slightly modified and the pinmux must be updated.
There is no need to support the old board, that becomes obsolete.
Neither cm-t35, nor cm-t3730 is using OneNAND or flash.
Remove the related defines from config file.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Fix usage of 'mmc rescan' by many configs. Proper use is
'mmc dev ${mmcdev}; mmc rescan' to set the mmc device and then rescan
the device. 'mmc rescan' itself does not take any arguments.
Signed-off-by: Andrew Bradford <andrew@bradfordembedded.com>
This patch provides a support to use buffered writes on flash
for versatile and vexpress boards.
This will certainly increase the flash writes.
Signed-off-by: Jagannadha Sutradharudu Teki <402jagan@gmail.com>
Cc: David Müller <d.mueller@elsoft.ch>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: U-Boot DM <u-boot-dm@lists.denx.de>
Cc: Oliver Brown <obrown@adventnetworks.com>
Add basic support for HP iPAQ h2200 palmtop. h2200 palmtop was targeted
to general consumers. It has 64 MB of RAM, 32 MB flash. No intergrated
Wi-Fi nor Ethernet. Based on Intel PXA255 processor. It was shipped with
Windows CE 4.2 operating system.
Signed-off-by: Lukasz Dalek <luk0104@gmail.com>
Since commit 50d4a707f0 (mx5/6: Define default SoC input clock frequencies)
we can use the default clock values.
The CSI PODF bit-field used by the previous code for the i.MX31 CCM PDR0
register is actually composed of two bit-fields: one pre-divider and one
post-divider. This patch fixes the CCM access macros and the code using them
accordingly.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
The mx6qsabreauto console is different than mx6qsabresd so the console
configuration is now set in the board file.
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Define default SoC input clock frequencies for i.MX5/6 in order to get rid of
duplicated definitions.
Cc: Jason Liu <r64343@freescale.com>
Cc: Matt Sealey <matt@genesi-usa.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
mx6qsabreauto is a board based on mx6q SoC with the following features:
- 2GB of DDR3
- 2 USB ports
- 1 HDMI output port
- SPI NOR
- 2 LVDS LCD ports
- Gigabit Ethernet
- Camera
- eMMC and SD card slot
- Multichannel Audio
- CAN
- SATA
- NAND
- PCIE
- Video Input
Add very basic support for it.
Add a common mx6 config file that can be shared between some mx6 boards.
mx6qsabresd has a AR8031 Gigabit PHY.
Add support for it.
Also increase CONFIG_SYS_MALLOC_LEN so that FEC buffer allocation does not fail.
Tested on 1Gbp and 100Mbps networks.
Suggested-by: Kim Phillips <kim.phillips@freescale.com>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
mx6qsabresd is a board based on mx6q SoC with the following features:
- 1GB of DDR3
- 1 USB OTG port
- SPI NOR
- LVDS panel
- Gigabit Ethernet
- Camera Connector
- Audio
This is extremely likely to be used from the boot.scr that Tegra's default
bootcmd locates and executes.
Signed-off-by: Tom Warren <twarren@nvidia.com>
The move is pretty straight-forward. ap20.h and tegra20.h were renamed to ap.h and tegra.h.
Some files remain in arch-tegra20 but 'include' a file in 'arch-tegra' with #defines & structs
that will be common between T20 and T30 HW. HW-specific #defines, etc. stay in the 'arch-tegra20'
'root' file.
All boards build OK w/MAKEALL -s tegra20. Checkpatch.pl runs clean. Seaboard works OK.
Medcom is the marketing name for an older, PXA-based version of the same
device. In order to avoid confusion, rename the Tegra-based version to
the new marketing name.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
As the board seems to be unmaintained for some time, lets remove
the support in mainline completely.
Cc: James MacAulay <james.macaulay@amirix.com>
Cc: Peter De Schrijver <p2@mind.be>
Since the IOP480 (PPC401/3 variant from PLX) is only used on 2
boards that are not actively maintained, lets remove support
for it completely. This way the ppc4xx code will get a bit cleaner.
Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
Remove any notion of CONFIG_SERIAL_MULTI from board config files.
Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless
to specify this config option in the board config files. Therefore
remove it.
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Rework the emulation of serial console via JTAG from simple ad-hoc
implementation of serial port routines to CONFIG_SERIAL_MULTI and
enable CONFIG_SERIAL_MULTI unconditionally for blackfin.
In order for the JTAG serial console to take precedence over all
other serial ports available in system, implement override for
default_serial_console call returning this JTAG serial console.
This brings in a bit of a growth of size, but eventually will allow
us to unconditionally enable CONFIG_SERIAL_MULTI throughout the whole
U-Boot and maintain only one serial subsystem.
Cc: Tom Rini <trini@ti.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Remove the prototypes for zoom2_serial_deviceN from serial.h . This
can't be done right away, as they are referenced from the zoom2
config file. Therefore, adjust the code so the config file only
specifies number of the port. Then, replace the simple return in
default_serial_console() with a switch across possible values, which
returns the zoom2_serial_deviceN . With such adjustment in place,
the exported prototypes in serial.h can be safely removed.
Some of the boards using the mpc512x serial driver didn't properly
define which PSC console to use. This caused breakage when building
with CONFIG_SERIAL_MULTI enabled. Fix this by defining the default
PSC console.
Make use of the newly implemented weak default_serial_console in
the serial_pxa driver. This removes all reimplementations of this
function from board files.
Fix up the rest of implementations of __stringify().
Kill multiple occurances and redeclaration of MK_STR
in favor of __stringify().
Kill multiple occurances and redeclaration of xstr in favor of __stringify().
After taking with the former maintainer, delete this platform. The
patch is from the former maintainer.
The SPI flash is not properly detected by plain "sf probe" due to
it being located on different bus and different chipselect. Fix
this problem.
The default configuration for ml507 will generate a hang() in the
Xilinx uartlite driver.
userial_ports[] in drivers/serial/serial_xuartlite.c does not get
initialized properly. CONFIG_SERIAL_BASE is unused.
XILINX_UARTLITE_BASEADDR is used instead.
Signed-off-by: Rommel Custodio <sessyargc+uboot@gmail.com>
Due to grown code sizes the TQM85xx boards don't build any more with
some older tool chains (like ELDK 4.2). As these boards have long
reached EOL it seems a waste of effort trying to fix them. The vendor
has agreed to drop support for them, too. So let's get rid of them.
cc: Kim Phillips <kim.phillips@freescale.com>
Add minimal support for Altera's SOCFPGA Cyclone 5 hardware.
Signed-off-by: Dinh Nguyen <dinguyen@altera.com>
Signed-off-by: Chin Liang See <clsee@altera.com>
Signed-off-by: Pavel Machek <pavel@denx.de>
Acked-by: Tom Trini <trini@ti.com>
Cc: Wolfgang Denx <wd@denx.de>
v8: Remove no_return attribute for reset_cpu
Based on v2012.10-rc2
Add support for Xilinx Zynq board.
CC: Joe Hershberger <joe.hershberger@gmail.com>
This patch adds support for the X600 SPEAr600 based board. Its also
the first SPEAr600 board that uses the newly introduced SPEAr600
SPL support. Xloader is not necessary any more. By using the new
"u-boot.spr" make target, one image will generated containing both,
U-Boot SPL (with mkimage header as needed by the SPEAr BootROM, and
the main U-Boot with mkimage header.
Cc: Amit Virdi <amit.virdi@st.com>
Cc: Vipin Kumar <vipin.kumar@st.com>
This is required to configure the external 88e6352 switch on nusa.
Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Holger Brunck <holger.brunck@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
Acked-by: Prafulla Wadaskar <Prafulla@marvell.com>
Malloc len of 128K caused a warning from
ehci_hcd asking for more.
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
Add support for new board iConnect from Iomega.
More information about the device can be found here:
http://go.iomega.com/en/products/network-storage-desktop/wireless-data-station/network-hard-drive-iconnect/?partner=4735
Signed-off-by: Luka Perkov <uboot@lukaperkov.net>
Tested-by: Wojciech Dubowik <wojciech.dubowik@neratec.com>
Tested-by: Tim Fletcher <tim@night-shade.org.uk>
This patch adds support for the LaCie board d2 Network v2 which share
a lot of hardware caracteristics with the 2Big Network v2.
- CPU: Marvell 88F6281 1200Mhz
- SDRAM memory: 256MB DDR2 400Mhz
- 2 SATA ports: internal and eSATA
- Gigabit ethernet: PHY Marvell 88E1116R
- Flash memory: SPI NOR 512KB (Macronix MX25L4005A)
- i2c EEPROM: 512 bytes (24C04 type)
- 2 USB2 ports: host and host/device
- 1 push button
- 1 power switch
- 1 SATA LED (bi-color, blue and red)
Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
This patch adds support for the LaCie boards Network Space v2 (Lite and
Mini). This two boards are derived from the Network Space v2 and a lot
of hardware caracteristics are shared.
- CPU: Marvell 88F6192 800Mhz
- SDRAM memory: 128MB DDR2 200Mhz
- 1 SATA port: internal
- Gigabit ethernet: PHY Marvell 88E1318
- 2 USB2 ports (Lite only): host and host/device
- 1 push button
Defines CONFIG_EFI_PARTITION for LaCie boards.
Additionally this patch defines CONFIG_DOS_PARTITION. Note that this
definition is implicit in mv_common.h when CONFIG_CMD_USB is enabled.
Support of the MINI2440 board from FriendlyARM from
an old version of u-boot :
http://repo.or.cz/r/u-boot-openmoko/mini2440.git
Currently, supporting only boot from NOR.
Signed-off-by: Gabriel Huau <contact@huau-gabriel.fr>
armadillo-800eva needs this config.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
