The LS1046AQDS processor has three integrated USB 3.0 controllers
(USB1, USB2, and USB3) that allow direct connection to the USB
ports with appropriate protection circuitry and power supplies.
USB1 and USB2 ports are powered by a NX5P2190UK device, which
supplies 5v power at up to 1.2 A. The power enable and
power-fault-detect pins are connected to the LS1046A processor
via CPLD for individual port management.
Signed-off-by: Tang Yuantian <yuantian.tang@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
CONFIG_ARCH_MISC_INIT
CONFIG_BOARD_EARLY_INIT_F
CONFIG_ARCH_EARLY_INIT_R
This patch enables the MMC support for the SDHCI controller on the
Armada 7k db-88f7040 and the Armada 8k db-88f8040 board.
Cc: Nadav Haklai <nadavh@marvell.com>
Cc: Kostya Porotchkin <kostap@marvell.com>
Cc: Wilson Ding <dingwei@marvell.com>
Cc: Victor Gu <xigu@marvell.com>
Cc: Hua Jing <jinghua@marvell.com>
Cc: Terry Zhou <bjzhou@marvell.com>
Cc: Hanna Hawa <hannah@marvell.com>
Cc: Haim Boot <hayim@marvell.com>
Armada 3700 db-88f3720 board.
The module is continuously rebooting with the following message:
Net: data abort
pc : [<fff77f42>] lr : [<fff6e32b>]
reloc pc : [<80816f42>] lr : [<8080d32b>]
sp : fdf5ce48 ip : fdf5d79c fp : 00000017
r10: 8083cd58 r9 : fdf5cef0 r8 : fdf5d5d0
r7 : 48485000 r6 : 400000ff r5 : fdf5d6e0 r4 : fdf5d618
r3 : fdf5d5b4 r2 : fdf5d5d0 r1 : 643a3631 r0 : fdf5d6e0
Flags: nzCv IRQs off FIQs off Mode SVC_32
Resetting CPU ...
Modifications:
* Enable Ethernet configuration in the SPL.
* Update PINMUX of PHY enable GPIO.
Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il>
Rename CONFIG_IMX31_PHYCORE_EET to CONFIG_TARGET_IMX31_PHYCORE_EET and
make this a distinct config target.
We may want to run different firmware before running U-Boot. For
example, ARM Trusted Firmware runs before U-Boot, making U-Boot
a non-secure world boot loader. In this case, the SoC might be
initialized there, which enables us to skip SPL entirely.
This commit removes "select SPL" to make it configurable. This
also enables the Multi SoC support for the UniPhier ARMv8 SoCs.
(CONFIG_ARCH_UNIPHIER_V8_MULTI) Thanks to the driver model and
Device Tree, the U-Boot proper part is now written in a generic way.
The board/SoC parameters reside in DT. The Multi SoC support
increases the memory footprint a bit, but the U-Boot proper does
not have strict memory constraint. This will mitigate the per-SoC
(sometimes per-board) defconfig burden.
Move all of the status LED feature to drivers/led/Kconfig.
The LED status definitions were moved from the board configuration
files to the defconfig files.
TBD: Move all of the definitions in the include/status_led.h to the
relevant board's defconfig files.
Tested boards: CL-SOM-AM57x, CM-T335
Signed-off-by: Jagan Teki <jagan@openedev.com>
When falcon mode support was added, it was right around when SPL_OS_BOOT
was migrated to Kconfig. So first we must move the enablement to the
defconfig file. Next, it turned off EXT support rather than add the
information to allow for falcon mode from EXT. Add this information so
that the board compiles after 5d28b930f237.
Fixes: d96796ca23b2 ("mx6sabresd: Add Falcon mode support")
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Use the generic "distro" boot framework to enable automatic DHCP boot.
MMC and USB are not yet implemented, so this is the only boot option.
The fdt and kernel addresses are adopted from downstream; ramdisk and
scriptaddr addresses were chosen arbitrarily.
Signed-off-by: Andreas Färber <afaerber@suse.de>
Reviewed-by: Alexander Graf <agraf@suse.de>
Move it from meson-gxbb-common.h to odroid-c2.h to allow new boards not
to implement it.
Some scripts are calling the same functions, so these changes consolidate
common scripts together to reduce redundancy and shrink size a bit. This
also keeps the 'bootargs' variable from growing if manually called more
than one time. This also adds NAND booting scripts based on newly consolidated
scripts.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
[York S: clean up scripts/config_whitelist.txt]
Add the chip power supply voltage initialization on LS1046ARDB.
Add function power_init_board(), and it will initialize the
PMIC and call the chip power initialization function.
Add secure boot validation of MC, DPC images using
esbc_validate command.
Signed-off-by: Sumit Garg <sumit.garg@nxp.com>
Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com>
This patch binds the sys_info->freq_systembus to Platform PLL, and
implements the IPs' clock function individually.
Up to now, there are 3 kind of SoCs under Layerscape Chassis 2,
like LS1043A, LS1046A and LS1012A. But the clocks tree has a
lot of differences, for instance, the IP modules have different
dividers to derive its clock from Platform PLL. And the core
cluster PLL and platform PLL maybe have different reference
clocks, such as LS1012A. Another problem is which clock/PLL
should be described by sys_info->freq_systembus, it is confused
in Layerscape Chissis 2.
This patch is to bind the sys_info->freq_systembus to the Platform
PLL, and handle the different divider of IP modules separately
between different SoCs, and separate reference clocks of core
cluster PLL and platform PLL.
Enable UUID and GPT partition support for NXP's ARM based SoCs
i.e. LS1012A, LS1021A, LS1043A, LS1046A and LS2080A.
Also enable DOS partition for LS1012AFRDM boards.
Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
The patch enables PCIe in ls2080a defconfigs and
removes unused PCIe related macro defines.
Signed-off-by: Minghuan Lian <Minghuan.Lian@nxp.com>
The patch enables PCIe and E1000 in ls1043a defconfigs and
The patch enables PCIe and E1000 in ls1012a defconfigs and
The patch enables PCIe in ls1021a defconfigs and
Enable usb feature for ls1046ardb
Signed-off-by: Changming Huang <jerry.huang@nxp.com>
Once upon a time u-boot didn't support building with two usb host
controller types, these days it does. Enable XHCI in addition to the
existing EHCI support so user can plug usb devices in all available
ports regardless of the controller type.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Add usb support for mx6sllevk board.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Move symbol to Kconfig to cleanup configuration file.
Small clean-up.
Signed-off-by: Fabien Parent <fparent@baylibre.com>
Set CONFIG_SYS_MMC_MAX_DEVICE to 2 for am335x SoC.
This define is needed in the API code.
Signed-off-by: Emmanuel Vadot <manu@bidouilliste.com>
Since we're including ti_armv7_common, let's pull in DEFAULT_LINUX_BOOT_ENV
and remove unnecessary duplicative definitions. This patch also renames a
few environmental variables to match what is inside ti_armv7_common. This
should help future-proof any subsequent memory or memory location changes.
CONFIG_SPL_RAM_DEVICE
This allows us to specify a FIT configuration that will automatically
use the correct images from the FIT blob.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Before we can sync with the latest mach-types.h file from the Linux
Kernel we need to remove some instances of MACH_TYPE_xxx from our
sources. As these values have been removed from the canonical upstream
source we should not be using them either, so drop.
Cc: Tom Warren <twarren@nvidia.com>
Cc: Lucas Stach <dev@lynxeye.de>
Cc: Luka Perkov <luka@openwrt.org>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Thomas Weber <weber@corscience.de>
Cc: Lucile Quirion <lucile.quirion@savoirfairelinux.com>
Cc: Matthias Weisser <weisserm@arcor.de>
Cc: Suriyan Ramasami <suriyan.r@gmail.com>
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Cc: Bo Shen <voice.shen@atmel.com>
Cc: Nick Thompson <nick.thompson@gefanuc.com>
Cc: Erik van Luijk <evanluijk@interact.nl>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
The MACH_TYPE for IGEP0032 was never officially used and has been
removed from upstream, so we must not use it. In order to remove this
we need to rework the status LED logic.
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Acked-by: Enric Balletbo i Serra <eballetbo@gmail.com>
Dropped becuase
- driver and related configs not used any board.
- no dm conversion.
Cc: Sergey Kostanbaev <sergey.kostanbaev@gmail.com>
Now that at least on the firefly board we have network support, enable
PXE and DHCP boot targets by default.
To make rockchip soc keep the same partition map
Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com>
CONFIG_ROCKCHIP_SPL_BACK_TO_BROM
With CONFIG_ROCKCHIP_SPL_BACK_TO_BROM enabled,
the environment is inside u-boot.
So solve it by moving environment after u-boot.
RK3288 using the dwc2 USB host controller, enable it and other usb host
funtion like storage and ether.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Added rockchip: tag:
Xilinx changes for v2017.03
- ATF handoff
- DT syncups
- gem: Use wait_for_bit(), add simple clk support
- Simple clk driver for ZynqMP
- Other small changes
Move (and rename) the following CONFIG options to Kconfig:
CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI)
CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS)
CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC)
CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS)
CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA)
CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI)
They are the same option names as used in Linux.
This commit was created as follows:
[1] Rename the options with the following command:
find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \
-type f -print | xargs sed -i -e '
s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g
s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g
s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g
s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g
s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g
s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g
[2] Commit the changes
[3] Create entries in driver/mmc/Kconfig.
(copied from Linux)
[4] Move the options with the following command
tools/moveconfig.py -y -r HEAD \
MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI
[5] Sort and align drivers/mmc/Makefile for readability
This CONFIG is not referenced from anywhere.
