enable SNTP support in some boards.
Fix flash erase timeout on CMC_PU2
add SNTP support and expand time server and time offset fields of
DHCP support. See doc/README.SNTP
* Patch by Steven Scholz, 13 Dec 2004:
Fix bug in at91rm920 ethernet driver
Remove duplicated code by merging memsetup.S files for
at91rm9200 boards into one cpu/at91rm9200/lowlevel.S
Cleanup duplicate definition of overwrite_console()
* Update TQM5200 configuration;
prepare for Rev. 200 starter kit boards
Add support for Nios-II EPCS Controller core.
* Patch by Scott McNutt, 20 Oct 2004:
Nios-II cleanups:
- Add sysid command (Nios-II only).
- Locate default exception trampoline at proper offset.
- Implement I/O routines (readb, writeb, etc)
- Implement do_bootm_linux
- use TQM5200_auto as MAKEALL target for TQM5200 systems
- add support for SM501 graphics controller
- add support for graphic console on TQM5200
- add support for TQM5200 Rev 200
- cleanup, fix typo in include/configs/TQM5200.h
* Cleanup, fix typo in include/configs/TQM5200.h
- Change the name of the Ethernet driver: MOTO ENET -> ENET
- Reformat boot messages
- Enable redundant environment
- Replace the -O2 optimization flag with -mno-string
Restore copyright statements in OHCI drivers.
* Add support for TQM8540 board
NC650: changed NAND flash addressing to using UPMB
"brightness" environment variable.
(common/cmd_ide.c, common/cmd_reiser.c, common/cmd_scsi.c).
* Enable USB and IDE support for INKA4x0 board
* Patch by Andrew Dyer, 28 February 2005:
fix ext2load passing an incorrect pointer to get_partition_info()
resulting in load failure for devices other than 0
* Add reset code for Coral-P on INKA4x0 board
* Patch by Martin Krause, 28 Jun 2004:
Update for TRAB board.
* Fix some missing "volatile"s in MPC5xxx FEC driver
makes 'ld' to overlook binary objects compatibility.
* Moved $(PLATFORM_LIBS) from the library group (--start-group ...
--end-group) outside of the group. This will make 'ld' to do
_multiple_ search in the library group when resolving symbol
references and do only a _single_ seach in libgcc.a after the group
search.
* Fix stability problems on CPC45 board again.
* Make image detection for diskboot / usbboot / scsiboot more robust
(also check header checksum)
* Add USB and PCI support for INKA4x0 board
Add standalone application to change SMC91C111 MAC addresses,
see examples/README.smc91111_eeprom
* Patch by Xiaogeng (Shawn) Jin, 12 Oct 2004:
Fix Flash support for ARM Integrator CP.
* Patch by Richard Woodruff, 10 Jan 2005:
Update support for OMAP2420 (ARM11) and H4 board:
o clean up and add new types to H4 memory probe code.
o fix to work with internal boot.
o added PRCM config III operation.
o fix marginal flash timings.
o add revison ATAG usage.
o enable voltage scaling at power chip.
o fix compile error for i2c.
* Fix network problem (error when receiving multiple ARP packets)
Add support for Wind River sbc405 board
* Patch by Rainer Brestan, 12 Oct 2004:
Make examples/Makefile more robust
- Add RESET/PREBOOT/AUTOBOOT support for RPXlite_DW board
- Adjust CPU:BUS frequency ratio 1:1 when core frequency
less than 50MHz
* Patch by Sam Song, 10 Oct 2004:
Fix a parameter error in run_command() in main.c
add support for the TI OMAP2420 processor and its H4 reference
board
* Patch by Christian Pellegrin, 24 Sep 2004:
Added support for NE2000 compatible (DP8390, DP83902) NICs.
add support for the AMD db1550 board
* Patch by Travis Sawyer, 15 Sep 2004:
Add CONFIG_SERIAL_MULTI support for ppc4xx,
update README.serial_multi
- add u-boot.hex target in the top level Makefile
- add support for the UNSW/NICTA PLEB 2 board (pleb2)
- use -mtune=xscale and -march=armv5 options for PXA
Add support for SenTec-COBRA5272-board (Coldfire).
Add Xilinx Spartan2E family FPGA support
* Patch by Jeff Angielski, 02 Sep 2004:
Add Added support for H2 revision of the EP8260 board.
Fixed formatting for some of the EP8260 related source files.
Reset monitor size back to 256 so environment can be written
to flash on MPC85xx ADS and CDS releases.
* Patch by Paolo Broggini, 02 Sep 2004:
Make BSS clearing on ARM systems more robust
* Patch by Yue Hu and Joe, 01 Sep 2004:
- add PCI support for ixp425;
- add EEPRO100 suppor tfor ixdp425 board.
* Fix problem with protected sector detection in driver/cfi_flash.c
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to
pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for
additional ethernet addresses.
* Cleanup drivers/i82365.c - avoid duplication of code
* Fix bogus "cannot span across banks" flash error message
* Add support for CompactFlash for the CPC45 Board.
* Adjust INKA 4x0 default settings
- add support for "STK52xx" board (including PS/2 multiplexer)
- add hardware detection for TQM5200
* Enable long help on CMC PU2 board;
fix reset issue;
increase CPU speed from 179 to 207 MHz.
- Enable booting directly from flash
- fix CMC_PU2 flash driver
* Fix mkimage usage message
- add support for MPC8220 CPU
- Add support for Alaska and Yukon boards
* Adjust MIPS compiler options at run-time depending on tools version
("-march=4kc -mtune=4kc -Wa,-mips_allow_branch_to_undefined" for new,
"-mcpu=4kc" for old tools)
