The default value of the SRS, VS18 and VS30 and ADMAS fields in the host
controller capabilities register (HOSTCAPBLT) are incorrect. The default
of these bits should be zero instead of one.
Clear these bits out when we read HOSTCAPBLT.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Do not issue a manual asynchronous CMD12. Instead, use a (software)
synchronous CMD12 or AUTOCMD12 to abort data transfer.
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
The P2020 has 2 SRIO ports and they are useable on the P2020 DS board.
Enable them using the common SRIO init code.
Signed-off-by: Li Yang <leoli@freescale.com>
Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com>
Moved the SRIO init out of corenet_ds and into common code for
8xxx/QorIQ processors that have SRIO. We mimic what we do with PCIe
controllers for SRIO.
We utilize the fact that SRIO is over serdes to determine if its
configured or not and thus can setup the LAWs needed for it dynamically.
We additionally update the device tree (to remove the SRIO nodes) if the
board doesn't have SRIO enabled.
Introduced the following standard defines for board config.h:
CONFIG_SYS_SRIO - Chip has SRIO or not
CONFIG_SRIO1 - Board has SRIO 1 port available
CONFIG_SRIO2 - Board has SRIO 2 port available
(where 'n' is the port #)
CONFIG_SYS_SRIOn_MEM_VIRT - virtual address in u-boot
CONFIG_SYS_SRIOn_MEM_PHYS - physical address (for law setup)
CONFIG_SYS_SRIOn_MEM_SIZE - size of window (for law setup)
[ These mimic what we have for PCI and PCIe controllers ]
Acked-by: Wolfgang Denk <wd@denx.de>
Remove duplicated code in MPC8610HPCD board and utilize the common
fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI
controllers based on which PCIe controllers are enabled.
Remove duplicated code in P1_P2_RDB boards and utilize the common
Remove duplicated code in MPC8569MDS board and utilize the common
Remove duplicated code in MPC8568MDS board and utilize the common
Remove duplicated code in MPC8548CDS board and utilize the common
Remove duplicated code in MPC8641HPCN board and utilize the common
Remove duplicated code in MPC8536DS board and utilize the common
Remove duplicated code in MPC8544DS board and utilize the common
fsl_pcie_init_ctrl(). We also now dynamically setup the LAWs for PCI
We don't use the full fsl_pcie_init_ctrl() since we have to handle PCIE3
specially to setup the additional memory map region and we utilize a
single LAW to cover the controller.
Remove duplicated code in P2020DS board and utilize the common
Remove duplicated code in MPC8572DS board and utilize the common
Signed-off-by: Chenhui Zhao <b26998@freescale.com>
This config option is for an erratum workaround; rename it to be more
clear. Also, drop it from config files don't need it and were
undefining it.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Correct initdram to use phys_size_t to represent the size of
dram; instead of changing this all over the place, and correcting
all the other random errors I've noticed, create a
common initdram that is used by all non-corenet 85xx parts. Most
of the initdram() functions were identical, with 2 common differences:
1) DDR tlbs for the fixed_sdram case were set up in initdram() on
some boards, and were part of the tlb_table on others. I have
changed them all over to the initdram() method - we shouldn't
be accessing dram before this point so they don't need to be
done sooner, and this seems cleaner.
2) Parts that require the DDR11 erratum workaround had different
implementations - I have adopted the version from the Freescale
errata document. It also looks like some of the versions were
buggy, and, depending on timing, could have resulted in the
DDR controller being disabled. This seems bad.
The xpedite boards had a common/fsl_8xxx_ddr.c; with this
change only the 517 board uses this so I have moved the ddr code
into that board's directory in xpedite517x.c
Some new platform's esdhc pins don't share with other function.
The eSDHC shouldn't be disabled, even if "esdhc" isn't defined
in hwconfig env variable.
Use CONFIG_FSL_ESDHC_PIN_MUX to fix this problem.
Instead of a #define use a null weak function for fsl_serdes_init
Mimic support that exists on MPC8536DS on the MPC8572DS to allow booting
from NAND.
Signed-off-by: Jin Qing <b24347@freescale.com>
Neither of these parts should have the erratum this is meant to
work around. Delete it.
This isn't used - delete it.
The PM854/PM856 boards are no longer maintained and thus we are removing
support for them.
The MPC8540EVAL board is no longer maintained and thus we are removing
support for it.
The ATUM8548 board is no longer maintained and thus we are removing
support for it.
PCI is not used at all on lwmon5. So lets remove it. It saves space and
reduces boot time a bit (approx. 50ms).
Patch "Replace CONFIG_SYS_GBL_DATA_SIZE by auto-generated value"
(sha1: 25ddd1fb0a2281b182529afbc8fda5de2dc16d96)
introduce GENERATED_GBL_DATA_SIZE which is sizeof aligned gd_t
(currently 0x40).
Microblaze configs used 0x40(128) because this place also contained
board info structure which lies on the top of ram.
U-Boot is placed to the top of the ram (for example 0xd7ffffff)
and bd structure was moved out of ram.
This patch is fixing this scheme with GENERATED_BD_INFO_SIZE
which swap global data and board info structures.
For example:
Current: gd 0xd7ffffc0, bd 0xd8000000
Fixed: gd 0xd7ffffc0, bd 0xd7ffff90
This patch supports T-SH7706LSR board.
This is constitution almost same as shmin (T-SH7706LAN).
Therefore, most functions work by a change of the setting of config.
http://web.kyoto-inet.or.jp/people/takagaki/T-SH7706/T-SH7706LSR.htm
This adds support for the SHMIN SH7706 board(T-SH7706LAN).
The CPU of this board is SH7706.
There are SDRAM of 32M byte, Flash memory of 512K byte, Serial,
10Base Ether and MMC.
http://web.kyoto-inet.or.jp/people/takagaki/T-SH7706/T-SH7706.htm
Add reginfo as a default command for p1022ds boards
Signed-off-by: Matthew McClintock <msm@freescale.com>
New default partitions on nor flash:
640k (firmware)
1408k (kernel)
2m (initrd)
4m (small-fs)
24320k (big-fs)
256k (dts)
Add ARM Relocation Support
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Some DaVinci boards are using flags that are no longer valid
So remove them.
