Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
$ git grep CONFIG_COMMAND_HISTORY
CHANGELOG: CONFIG_COMMAND_HISTORY
include/configs/AP1000.h:#define CONFIG_COMMAND_HISTORY 1
include/configs/keymile-common.h:#define CONFIG_COMMAND_HISTORY 1
include/configs/manroland/common.h:#define CONFIG_COMMAND_HISTORY 1
Acked-by: Heiko Schocher <hs@denx.de>
Signed-off-by: Asen Dimov <dimov@ronetix.at>
The UBI/UBIFS support is added to the QONG module.
The NAND device is connected to the FPGA of the QONG board
and not to the NFC controller. For this reason, the FPGA must
be set and initialized before accessing to the NAND itself.
moved CONFIG_CMD_FAT to filesystem section
swapped CONFIG_CMD_NAND and CONFIG_CMD_MII so they are alpha correct
Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com>
This patch includes a few additional commands in the sheevaplug
version of u-boot:
- support for LONGHELP so you can get help messages
- auto completion and command editing
- ubi and mii support
- ext2 filesystem (convenient if you have an ext2 from which you want to boot)
- jffs2 and ubifs filesystems (if you want to use these in NAND)
This also makes it more similar to openrd client.
Side effect of this patch is that the code now needs 3 sectors i.s.o. 2
so an existing env is overwritten
GuruPlug Standard: 1 Gb Ethernet, 2 USB 2.0
GuruPlug Plus: 2 Gb Ethernet, 2 USB 2.0, 1 eSATA, 1 uSD slot
References:
http://www.globalscaletechnologies.com/t-guruplugdetails.aspx
http://plugcomputer.org
This patch is for GuruPlug Plus, but it supports Standard version
as well.
Signed-off-by: Siddarth Gore <gores@marvell.com>
The lowlevel_init file contained some hard-coded values
to setup the RAM. These board related values are moved into
the board configuration file.
This patch adds support for the magnesium board from
projectiondesign. This board uses i.MX27 SoC and has
8MB NOR flash, 128MB NAND flash, FEC ethernet controller
integrated into i.MX27. As this port is based on
the imx27lite port, common config options are collected
in include/configs/imx27lite-common.h
This patch fixes APC405 build, by defining CONFIG_PPC4XX_I2C. This is
needed since the move of the PPC4xx I2C driver into the drivers/i2c
directory.
Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
This patch adds support for the Mosaix Technologies, Inc. ICON board,
based on the AppliedMicro (AMCC) PPC440SPe. It's equipped with an SODIMM
(512MB standard) and 64MByte of NOR FLASH.
Support for the onboard SM502 will be added later.
Also enable HUSH shell.
Added support for LCD and splash image to the QONG module.
The supported display is VBEST-VGG322403.
This fixes an overflow during the link phase.
Signed-off-by: Detlev Zundel <dzu@denx.de>
This is a generic approach to port u-boot for nios2 boards.
You may find the usage of this approach on the nioswiki,
http://nioswiki.com/DasUBoot
A fpga parameter file, which contains base address information
and drivers declaration, is generated from Altera's hardware system
description sopc file using tools.
The example fpga parameter file is compatible with EP1C20, EP1S10
and EP1S40 boards. So these boards can be removed after this commit.
Though epcs controller is removed to cut the dependency of altera_spi
driver.
Signed-off-by: Scott McNutt <smcnutt@psyent.com>
Adds coprocessor communication POST code
PDM360NG is a MPC5121E based board by ifm ecomatic gmbh.
Signed-off-by: Michael Weiss <michael.weiss@ifm.com>
Configure CONFIG_SYS_MAX_RAM_SIZE address range in
DDR Local Access Window and determine the RAM size.
Fix DDR LAW afterwards using detected RAM size.
before, MPC8349ITX boots u-boot in 4.3sec:
column1 is elapsed time since first message
column2 is elapsed time since previous message
column3 is the message
0.000 0.000: U-Boot 2010.03-00126-gfd4e49c (Apr 11 2010 - 17:25:29) MPC83XX
0.000 0.000:
0.000 0.000: Reset Status:
0.000 0.000:
0.032 0.032: CPU: e300c1, MPC8349E, Rev: 1.1 at 533.333 MHz, CSB: 266.667 MHz
0.032 0.000: Board: Freescale MPC8349E-mITX
0.032 0.000: UPMA: Configured for compact flash
0.032 0.000: I2C: ready
0.061 0.028: DRAM: 256 MB (DDR1, 64-bit, ECC off, 266.667 MHz)
1.516 1.456: FLASH: 16 MB
2.641 1.125: PCI: Bus Dev VenId DevId Class Int
2.652 0.011: 00 10 1095 3114 0180 00
2.652 0.000: PCI: Bus Dev VenId DevId Class Int
2.652 0.000: In: serial
2.652 0.000: Out: serial
2.652 0.000: Err: serial
2.682 0.030: Board revision: 1.0 (PCF8475A)
3.080 0.398: Net: TSEC1: No support for PHY id ffffffff; assuming generic
3.080 0.000: TSEC0, TSEC1
4.300 1.219: IDE: Bus 0: .** Timeout **
after, MPC8349ITX boots u-boot in 3.0sec:
0.010 0.010: U-Boot 2010.03-00127-g4b468cc-dirty (Apr 11 2010 - 17:47:29) MPC83XX
0.010 0.000:
0.010 0.000: Reset Status:
0.010 0.000:
0.017 0.007: CPU: e300c1, MPC8349E, Rev: 1.1 at 533.333 MHz, CSB: 266.667 MHz
0.017 0.000: Board: Freescale MPC8349E-mITX
0.038 0.020: UPMA: Configured for compact flash
0.038 0.000: I2C: ready
0.038 0.000: DRAM: 256 MB (DDR1, 64-bit, ECC off, 266.667 MHz)
0.260 0.222: FLASH: 16 MB
1.390 1.130: PCI: Bus Dev VenId DevId Class Int
1.390 0.000: 00 10 1095 3114 0180 00
1.390 0.000: PCI: Bus Dev VenId DevId Class Int
1.400 0.010: In: serial
1.400 0.000: Out: serial
1.400 0.000: Err: serial
1.400 0.000: Board revision: 1.0 (PCF8475A)
1.832 0.432: Net: TSEC1: No support for PHY id ffffffff; assuming generic
1.832 0.000: TSEC0, TSEC1
3.038 1.205: IDE: Bus 0: .** Timeout **
also tested on these boards (albeit with a less accurate
boottime measurement method):
seconds: before after
8349MDS ~2.6 ~2.2
8360MDS ~2.8 ~2.6
8313RDB ~2.5 ~2.3 #nand boot
837xRDB ~3.1 ~2.3
also tested on an 8323ERDB.
v2: also remove the delayed icache enablement assumption in arch ppc's
board.c, and add a CONFIG_MPC83xx define in the ITX config file for
consistency (even though it was already being defined in 83xx'
config.mk).
because it's convenient.
As discussed on the list, move "arch/ppc" to "arch/powerpc" to
better match the Linux directory structure.
Please note that this patch also changes the "ppc" target in
MAKEALL to "powerpc" to match this new infrastructure. But "ppc"
is kept as an alias for now, to not break compatibility with
scripts using this name.
Acked-by: Wolfgang Denk <wd@denx.de>
Acked-by: Detlev Zundel <dzu@denx.de>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
The 440SPe Rev. A is quite old and newer 440SPe boards don't need support
for this CPU revision. Since removing support for this older version
simplifies the creation for newer U-Boot ports, this patch now enables
440SPe > Rev. A support by creating the CONFIG_440SPE_REVA define. By
defining this in the board config header, Rev. A will still be supported.
Otherwise (default for newer board ports), Rev. A will not be supported.
The latest changes increased the size of the alpr image a bit more.
Now it doesn't fit into the 256k reserved for it. This patch now removes
the commands "loads" and "loadb" which are not needed in the production
systems.
Cc: Pieter Voorthuijsen <pieter.voorthuijsen@prodrive.nl>
Now that the other architecture-specific lib directories have been
moved out of the top-level directory there's not much reason to have the
'_generic' suffix on the common lib directory.
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk
This change is intended to clean up the top-level directory structure
and more closely mimic Linux's directory organization.
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
The MPC8536DS_NAND SPL build was failing due to code size increase
introduced by commit:
commit 33f57bd553edf29dffef5a6c7d76e169c79a6049
Author: Kumar Gala <galak@kernel.crashing.org>
Date: Fri Mar 26 15:14:43 2010 -0500
85xx: Fix enabling of L1 cache parity on secondary cores
We built in some NS16550 functions that we dont need and can get
rid of them via CONFIG_NS16550_MIN_FUNCTIONS.
The Freescale P2020DS board uses a new type of PIXIS FPGA, called the ngPIXIS.
The ngPIXIS has one distinct new feature: the values of the on-board switches
can be selectively overridden with shadow registers. This feature is used to
boot from a different NOR flash bank, instead of having a register dedicated
for this purpose. Because the ngPIXIS is so different from the previous PIXIS,
a new file is introduced: ngpixis.c.
Also update the P2020DS checkboard() function to use the new macros defined
in the header file.
Refactor and document the Freescale PIXIS code, used on most 85xx and 86xx
boards. This makes the code easier to read and more flexible.
Delete pixis.h, because none of the exported functions were actually being
used by any other file. Make all of the functions in pixis.c 'static'.
Remove "#include pixis.h" from every file that has it.
Remove some unnecessary #includes.
Make 'pixis_base' into a macro, so that we don't need to define it in every
function.
Add "while(1);" loops at the end of functions that reset the board, so that
execution doesn't continue while the reset is in progress.
Replace in_8/out_8 calls with clrbits_8, setbits_8, or clrsetbits_8, where
appropriate.
Replace ulong/uint with their spelled-out equivalents. Remove unnecessary
typecasts, changing the types of some variables if necessary.
Add CONFIG_SYS_PIXIS_VCFGEN0_ENABLE and CONFIG_SYS_PIXIS_VBOOT_ENABLE to make
it easier for specific boards to support variations in the PIXIS registers
sets. No current boards appears to need this feature.
Fix the definition of CONFIG_SYS_PIXIS_VBOOT_MASK for the MPC8610 HPCD.
Apparently, "pixis_reset altbank" has never worked on this board.
A low cost 4 port IP-PBX board.
Signed-off-by: Brent Kandetzki <BrentK@teleco.com>
Switch to the SMC911X driver by default now, and fix LDR env settings.
Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at>
We tweak the configs a little when doing automated hardware tests.
This patch moves the PPC4xx specific I2C device driver into the I2C
drivers directory. All 4xx config headers are updated to include this
driver.
