CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
CONFIG_LCD
Reviewed-by: Jagan Teki <jteki@openedev.com>
CONFIG_VIDEO
Move these option to Kconfig and tidy up existing uses.
The Power PC boards don't have a suitable common element: the common header
files don't appear to line up with the Kconfig files as far as I can tell.
This results in a lot of defconfig changes.
[trini: Re-migrate, update common/console.c logic]
ARCH_UNIPHIER selects DM_USB, where CONFIG_USB_MAX_CONTROLLER_COUNT
is not used.
Move FDT_FIXUP_PARTITIONS to Kconfig and cleanup existing
uses.
Move SYS_OS_BASE to Kconfig and cleanup existing
uses.
[trini: Also migrate a4m2k]
Move SPL_OS_BOOT to Kconfig and cleanup existing
uses.
T series boards use unified RCW for sd, spi and nand boot.
Now split txxx_rcw.cfg to txxx_sd_rcw.cfg, txxx_spi_rcw.cfg
and txxx_nand_rcw.cfg for SPI/NAND/SD boot.
And modify RCW[PBI_SRC] for them:
PBI_SRC=5 for SPI 24-bit addressing
PBI_SRC=6 for SD boot
PBI_SRC=14 for IFC NAND boot
Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
In AM335x GP EVM, Atheros 8031 phy is used, enable the driver as
AM335x SoC RGMII delay mode has to be enabled in phy as mentioned
in the silicon errata Advisory 1.0.10
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
include/configs/ls1021aqds.h
include/configs/ls1021atwr.h
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Create a Kconfig entry for DISPLAY_CPUINFO and make it be the default
Legacy video driver macros are not needed. Clean them up.
This converts coreboot to use DM framebuffer driver.
At present only chromebook boards are converted to DM video. Other
x86 boards are still using the legacy cfb_console driver. This
switches to use DM version drivers.
Update the common configuration so that it works correctly when
CONFIG_DM_VIDEO is enabled. This involves dropping the legacy CONFIG_VIDEO
option and changing the stdio device from "vga" to "vidconsole".
The Tegra 2 aka T20 is not host PC capable. Therefore gate the define
CONFIG_CI_UDC_HAS_HOSTPC in tegra-common-usb-gadget.h in case of
CONFIG_TEGRA20.
Signed-off-by: Tom Warren <twarren@nvidia.com>
This is an on-board Ethernet device. It has no point if the Micro
Support Card is not available.
NOR flash devices are seldom used on UniPhier platforms these days.
The only use case I see is the Micro Support Card is connected.
Otherwise, define CONFIG_SYS_NO_FLASH to disable NOR FLASH.
Synology DS109 is based on MV88F6281. The code
is based on Dreamplug code with modificatons
from Synologys open source repository.
Signed-off-by: Walter Schweizer <swwa@users.sourceforge.net>
The SPL size for dra7x platform increased beyond 64K,
increasing the size to 256K to cater for future enhancement.
Signed-off-by: Ravi Babu <ravibabu@ti.com>
removing CONFIG_SPL_ENV_SUPPORT defined in header files
due to moved to kconfig option for CONFIG_SPL_ENV_SUPPORT
The KeyStone platform has its own clk_get_rate() but its prototype
is different from that of the common-clk (clk-uclass) framework.
Prefix the KeyStone specific implementation with ks_ in order to
avoid name-space conflict.
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
LS1012AFRDM has 512MB of DDR. So update kernel load address to
0x96000000.
Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Signed-off-by: Pratiyush Mohan Srivastava <pratiyush.srivastava@nxp.com>
[York Sun: Reformatted commit message]
Remove ramdisk_addr, ramdisk_size and update UART baud-rate.
Due to clock source restrictions on i.MX6, certain pixel clock rates can
not be supported. Hence default the resolution/frame rate during boot to a
supported value by passing video bootargs 1024x768@60 for
HDMI (Display Port1) and LVDS (Display Port2) on B850v3.
Signed-off-by: Ken Lin <ken.lin@advantech.com.tw>
Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com>
Now that fastboot options are available in Kconfig, we can migrate them
from DRA7 header to corresponding DRA7 defconfigs.
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Remove legancy I2C config and code in favor of upcomming DM/DT
enable I2C support.
Drop a few that are not used in U-Boot.
Move this option to Kconfig and tidy up existing uses. Also add a function
comment to the header file.
Move DDR3, DDR4 and related config options to Kconfig and clean up
existing uses.
Signed-off-by: York Sun <york.sun@nxp.com>
Move DDR3, DDR4 and realted options to Kconfig and clean up existing
uses.
Move these options to Kconfig and clean up existing uses.
Move these options to Kconfig and create a sub-menu to avoid name
conflict with other architectures.
Following commits 217f92b and 1544698, these two config
CPU_V7_HAS_NONSEC and CPU_V7_HAS_VIRT are moved to Kconfig,
for correctly select ARMV7_PSCI.
Signed-off-by: Hongbo Zhang <hongbo.zhang@nxp.com>
Delete CONFIG_SKIP_LOWLEVEL_INIT define in ls1021atwr.h and
ls1021aqds.h can let it run cpu_init_cp15 to enable i-cache. First
stage of u-boot can run faster after that. There is a description
about skip lowlevel init in board/freescale/ls1021atwr/README.
Signed-off-by: Xiaoliang Yang <xiaoliang.yang@nxp.com>
Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
PCM052 SoMs may be equipped with various sizes of DDR.
Keep default of 256MB; new PCM052-based targets will
specify their actual DDR size.
Linux command line is auto-adjusted to DDR size.
This format can be flashed directly at address 0 of
the NAND FLASH, as it contains all necessary headers.
Merge 'spare' into 'bootloader' partition
Use same partition for ramdisk and rootfs boot scenarios.
Remove 'ramdisk' partition, use 'rootfs' for ramdisk
(ramdisk and nand boot scenarios are mutually exclusive).
Expand last partition to end of actual NAND size.
Adjust UBIFS rootfs boot kernel arguments.
