Now that the other architecture-specific lib directories have been
moved out of the top-level directory there's not much reason to have the
'_generic' suffix on the common lib directory.
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk
This change is intended to clean up the top-level directory structure
and more closely mimic Linux's directory organization.
Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
The MPC8536DS_NAND SPL build was failing due to code size increase
introduced by commit:
commit 33f57bd553edf29dffef5a6c7d76e169c79a6049
Author: Kumar Gala <galak@kernel.crashing.org>
Date: Fri Mar 26 15:14:43 2010 -0500
85xx: Fix enabling of L1 cache parity on secondary cores
We built in some NS16550 functions that we dont need and can get
rid of them via CONFIG_NS16550_MIN_FUNCTIONS.
The Freescale P2020DS board uses a new type of PIXIS FPGA, called the ngPIXIS.
The ngPIXIS has one distinct new feature: the values of the on-board switches
can be selectively overridden with shadow registers. This feature is used to
boot from a different NOR flash bank, instead of having a register dedicated
for this purpose. Because the ngPIXIS is so different from the previous PIXIS,
a new file is introduced: ngpixis.c.
Also update the P2020DS checkboard() function to use the new macros defined
in the header file.
Refactor and document the Freescale PIXIS code, used on most 85xx and 86xx
boards. This makes the code easier to read and more flexible.
Delete pixis.h, because none of the exported functions were actually being
used by any other file. Make all of the functions in pixis.c 'static'.
Remove "#include pixis.h" from every file that has it.
Remove some unnecessary #includes.
Make 'pixis_base' into a macro, so that we don't need to define it in every
function.
Add "while(1);" loops at the end of functions that reset the board, so that
execution doesn't continue while the reset is in progress.
Replace in_8/out_8 calls with clrbits_8, setbits_8, or clrsetbits_8, where
appropriate.
Replace ulong/uint with their spelled-out equivalents. Remove unnecessary
typecasts, changing the types of some variables if necessary.
Add CONFIG_SYS_PIXIS_VCFGEN0_ENABLE and CONFIG_SYS_PIXIS_VBOOT_ENABLE to make
it easier for specific boards to support variations in the PIXIS registers
sets. No current boards appears to need this feature.
Fix the definition of CONFIG_SYS_PIXIS_VBOOT_MASK for the MPC8610 HPCD.
Apparently, "pixis_reset altbank" has never worked on this board.
A low cost 4 port IP-PBX board.
Signed-off-by: Brent Kandetzki <BrentK@teleco.com>
Switch to the SMC911X driver by default now, and fix LDR env settings.
Signed-off-by: Harald Krapfenbauer <Harald.Krapfenbauer@bluetechnix.at>
We tweak the configs a little when doing automated hardware tests.
This patch moves the PPC4xx specific I2C device driver into the I2C
drivers directory. All 4xx config headers are updated to include this
driver.
CONFIG_CMD_AUTOSCRIPT support is deprecated and non-existing
This clean up patch removes the references for esd boards
Signed-off-by: Daniel Gorsulowski <Daniel.Gorsulowski@esd.eu>
Add setup for ethernet on SMDKC100, allowing kernel/ramdisk to be
loaded over tftp.
The preinit function will configure GPIO (GPK0CON) & SROMC to look
for environment in SROM Bank 3.
Signed-off-by: Naveen Krishna Ch <ch.naveen@samsung.com>
CONFIG_SYS_HZ was being calculated (incorrectly) in nios2 configuration
headers. Updated comments to accurately describe timebase macros.
Signed-off-by: Scott McNutt <smcnutt@psyent.com>
The standard Altera UART & JTAG UART as well as the OpenCores
YANU driver are now in individual files in drivers/serial
rather than a single file uner cpu/nios2.
After determining how much DDR is actually in the system, set DBAT0 and
IBAT0 accordingly. This ensures that the CPU won't attempt to access
(via speculation) addresses outside of actual memory.
On 86xx systems, DBAT0 and IBAT0 (the BATs for DDR) are initialized to 2GB
and kept that way. If the system has less than 2GB of memory (typical for
an MPC8610 HPCD), the CPU may attempt to access this memory during
speculation. The zlib code is notorious for generating such memory reads,
and indeed on the MPC8610, uncompressing the Linux kernel causes a machine
check (without this patch).
Currently we are limited to power of two sized DDR since we only use a
single bat. If a non-power of two size is used that is less than
CONFIG_MAX_MEM_MAPPED u-boot will crash.
The ml300 board has a number of issues, but nobody cares about this
long-orphaned board any more. Remove it.
Acked-by: Michal Simek <monstr@monstr.eu>
The flash location is at 0xff800000, not 0
Signed-off-by: TsiChung Liew <tsicliew@gmail.com>
The CF will call cache functions in lib_m68/cache.c and the
cache settings are defined in platform configuration file.
The proper SDRAM size is 32MB not 64MB
Signed-off-by: Jingchang Lu <b22599@freescale.com>
Reside Ethernet buffer descriptors in SRAM instead of DRAM. Add
CONFIG_SYS_TX_ETH_BUFFER in platform configuration file. Update
DRAM control and SRAM control register setting. Update cache
setting where size does not write to proper region.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Provide extra environment Data. Remove default network
address and MAC address.
Fix incorrect default environment for flash erase or protect
range. Change offset from 0 to 0xff80nnnn. Remove default
ethernet setup and MAC address.
This patch adds support for ASTRO board(s) based on MCF5373L.
Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
The soft-i2c code for AT91 defines I2C_SOFT_DECLARATIONS
for direct access by dereferencing a pio pointer.
The OTC570 platform uses the AT91 gpio API so it does not
need the pio variable.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
We do not support a processor that never reached a real customer.
Signed-off-by: Detlev Zundel <dzu@denx.de>
I executed 'find . -name "*.[chS]" -perm 755 -exec chmod 644 {} \;'
Signed-off-by: Thomas Weber <swirl@gmx.li>
Add some more: neither Makefile nor config.mk need execute permissions.
Coding style cleanup, update CHANGELOG.
This code has compile problems and the company does not even exist any
more. So we take the liberty to drop support for it.
CC: Wolfgang Denk <wd@denx.de>
CC: Ben Warren <biggerbadderben@gmail.com>
The 36-bit build exceeds the 512k size we have. Removing FIT type image
support allows us to fit and we dont really use it.
Also enable support for CONFIG_HWCONFIG because we use this for
configuring if this hardware has a FEC or not.
syntax:
hwconfig=fec:on if hardware has an fec
hwconfig=fec:off if hardware has no fec
* convert otc570 board to use c stucture SoC access
* change gpio access to at91_gpio syntax
Add support for the ARM part of the mgcoge2, named suen3.
This board is based on the Marvell Kirkwood (88F6281) SoC.
As there come more board variants, common config options
are collected in include/configs/km_arm.h. Also, this board
use common code for all keymile boards, which is stored in
board/keymile/common/common.c
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
This is an i.MX25 base board with only NAND
so it uses nand_spl to boot.
Signed-off-by: John Rigby <jcrigby@gmail.com>
Tune configuration, add support for (redundant) environment in NAND.
Acked-by: Wolfgang Denk <wd@denx.de>
CC: Fred Fan <fanyefeng@gmail.com>
CC: Tom <Tom.Rix@windriver.com>
The patch adds initial support for the Freescale mx51evk board.
Network (FEC) and SD controller (fsl_esdhc) are supported.
Signed-off-by: Fred Fan <fanyefeng@gmail.com>
Configuration defines should be preceeded with CONFIG_SYS_. Renamed
some at91 specific defines to conform to this naming convention:
AT91_CPU_NAME to CONFIG_SYS_AT91_CPU_NAME
AT91_MAIN_CLOCK to CONFIG_SYS_AT91_MAIN_CLOCK
Signed-off-by: Achim Ehrlich <aehrlich@taskit.de>
Reindent configuration header to limit line lenght to 80 characters by
removing obvious and sometimes misleading comments.
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
Limit line length to 80 characters mostly by removing obvious and sometimes
misleading comments. Fix indentation, too.
Adds support for ethernet networking on the da830evm platform.
This platform uses an SoC EMAC interface and a 3 port ethernet
switch as a PHY with an RMII interface. The PHY also has a i2c
interface for configuring the switch functions.
Signed-off-by: Nick Thompson <nick.thompson@ge.com>
Recent kernels are using generic NAND and NOR drivers. Change
default mtdparts to reflect it.
Correct switching partitions after upgrade and make it more readable.
commit 98d92d8c9f4021629a45261ad5ec3f3595f3a27a "sbc8349: fix incorrect
comment" missed this one.
and avoid e.g., two identical boards from causing random networking
conflicts when hooked up to the same network.
* new board (eb_cpux9k2)
* support for EB+CPUx9K2 board by BuS Elektronik GmbH & Co. KG
* select via make eb_cpux9k2_config
* this also demonstrates, how to use boards with AT91RM9200 cpu
in at91 arch tree
Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
