We really don't want boards defining fixed MAC addresses in their config
so we just remove the option to set it in a fixed way. If you must have
a MAC address that was not provisioned, then use the random MAC address
functionality.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
mxc_serial supports DM so lets use it.
Enable U-Boot Driver Model (DM).
Display what device the SPL will fetch uboot.img from
Bootscripts for some distro's such as Android can benefit from knowing
what boot media its script was loaded from.
Add emmc boot partition commands to be able to select the boot partition.
Signed-off-by: Soeren Moch <smoch@web.de>
Since there is a default CONFIG_SYS_PBSIZE definition in config_fallbacks.h,
this setting is no longer required in board configurations.
Only enable graphical output for stdout/stderr (and a usb keyboard for stdin)
when a hdmi device is detected.
Serial console is always enabled for stdin/stdout/stderr.
Add support for USB OTG host mode. Only high speed devices supported so far
(e.g. usb 2.0 hub required to connect a keyboard).
Hummingboard dual, dual-lite and solo are now supported via SPL mechanism.
Remove the previous hummingboard support, which does not use SPL and supported
only the solo variant.
Starting USB initialization is useful for those who use Cuboxi/Hummingboard
with HDMI and USB keyboard.
However, when booting without a HDMI connection we can skip the usb
initialization, which makes the boot faster.
Signed-off-by: Jon Nettleton <jon.nettleton@gmail.com>
Tested-By: Vagrant Cascadian <vagrant@aikidev.net>
This patch fixes the USB EHCI support on the TQMa6 SoM. Additionally
some filesystems are added, included the generic FS commands (e.g.
ls...).
Cc: Markus Niebel <Markus.Niebel@tq-group.com>
Acked-By: Markus Niebel <Markus.Niebel@tq-group.com>
There are users of Cuboxi and Hummingboard that use these boards without
connecting them to a USB/serial adapter.
Allow such usage by allowing the HDMI port to act as stdout and USB keyboard
as stdin.
The serial console still also works as stdin/stdout.
Signed-off-by: Rabeeh Khoury <rabeeh@solid-run.com>
Tested-by: Vagrant Cascadian <vagrant@aikidev.net>
Enable USB Host1 port.
Add HDMI output using PLL5 as the source for the IPU clocks,
and accurate VESA timings.
These settings are based on the patch from Soeren Moch <smoch@web.de>
submitted for the tbs2910 mx6 based board.
It allows the display to work properly at 1024x768@60.
This should make the hdmi output signal compatible with most if not all
modern displays.
Tested-by: Tom Rini <trini@konsulko.com>
This change enables the configs required to init and setup max77686
regulator driver, using the new driver model pmic and regulator API.
And also changes the old pmic framework calls to the new ones.
This commits enables:
- CONFIG_ERRNO_STR
- CONFIG_DM_PMIC
- CONFIG_DM_PMIC_CMD
- CONFIG_DM_PMIC_MAX77686
- CONFIG_DM_REGULATOR
- CONFIG_DM_REGULATOR_CMD
- CONFIG_DM_REGULATOR_MAX77686
And removes the unused:
- CONFIG_DM_I2C_COMPAT
- CONFIG_POWER
- CONFIG_POWER_I2C
- CONFIG_POWER_MAX77686
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
This config name was never used, because the present pmic command
was precompiled for the CONFIG_POWER.
Move the configs listed below from exynos5-dt-common.h to exynos5-common.h:
- CONFIG_POWER
- CONFIG_POWER_I2C
fixes build break for Arndale and Smdk5250 boards.
Now that the ohci code supports usb interrupt queues we can switch (back)
to using an usb interrupt queue for usb-kbd interrupt polling. This
greatly reduces u-boot's latency when dealing with usb keyboards.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
This commit adds support for the OHCI companion controller, which makes
usb-1 devices directly plugged into to usb root port work.
Note for now this switches usb-keyboard support for sunxi back from int-queue
support to the old interrupt polling method. Adding int-queue support to the
ohci code and switching back to int-queue support is in the works.
The secure world code is relocated to the MB just below the top of 4G, we
reserve it in the FDT (by setting CONFIG_ARMV7_SECURE_RESERVE_SIZE) but it is
not protected in h/w.
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Reviewed-by: Thierry Reding <treding@nvidia.com>
Tested-by: Thierry Reding <treding@nvidia.com>
Tested-by: Ian Campbell <ijc@hellion.org.uk>
Signed-off-by: Tom Warren <twarren@nvidia.com>
At the very least when USB keyboard support is enabled, we need to enable
CONFIG_SYS_STDIO_DEREGISTER, so the "usb reset" is able to re-scan USB
ports and find new devices. Enable it everywhere per request from Simon
Glass.
As best I can tell, CONFIG_SYS_LOAD_ADDR and CONFIG_LOADADDR/$loadaddr
serve essentially the same purpose. Roughly, if a command takes a load
address, then CONFIG_SYS_LOAD_ADDR or $loadaddr (or both) are the default
if the command-line does not specify the address. Different U-Boot
commands are inconsistent re: which of the two default values they use.
As such, set the two to the same value, and move the logic that does this
into tegra-common-post.h so it's not duplicated. A number of other non-
Tegra boards do this too.
The values chosen for these macros are no longer consistent with anything
in MEM_LAYOUT_ENV_SETTINGS. Regain consistency by setting $kernel_addr_r
to CONFIG_LOADADDR. Older scripts tend to use $loadaddr for the default
kernel load address, whereas newer scripts and features tend to use
$kernel_addr_r, along with other variables for other purposes such as
DTBs and initrds. Hence, it's logical they should share the same value.
I had originally thought to make the $kernel_addr_r and CONFIG_LOADADDR
have different values. This would guarantee no interference if a script
used the two variables for different purposes. However, that scenario is
unlikely given the semantic meaning associated with the two variables.
The lowest available value is 0x90200000; see comments for
MEM_LAYOUT_ENV_SETTINGS in tegra30-common-post.h for details. However,
that value would be problematic for a script that loaded a raw zImage to
$loadaddr, since it's more than 128MB beyond the start of SDRAM, which
would interfere with the kernel's CONFIG_AUTO_ZRELADDR. So, let's not do
that.
The only potential fallout I could foresee from this patch is if someone
has a script that loads the kernel to $loadaddr, but some other file
(DTB, initrd) to a hard-coded address that the new value of $loadaddr
interferes with. This seems unlikely. A user should not do that; they
should either hard-code all load addresses, or use U-Boot-supplied
variables for all load addresses. Equally, any fallout due to this change
is trivial to fix; simply modify the load addresses in that script.
Cc: Paul Walmsley <pwalmsley@nvidia.com>
Reviewed-by: Paul Walmsley <pwalmsley@nvidia.com>
Add the PMIC, LCD settings, PWM and also show the board info at the top of
the LCD when starting up.
Instead of CONFIG_VIDEO_TEGRA, use CONFIG_LCD to determine whether an LCD
is present. Tegra124 uses a different driver.
We should use 'env' to present environment instead of 'evn'
Signed-off-by: Josh Wu <josh.wu@atmel.com>
Remove board support for afeb9260, tny_a9260, and sbc35_a9g20.
They have not been converted into Generic Board yet.
See doc/README.generic-board for details.
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Having this as a Kconfig allows it to be a dependent feature.
As this board seems to be unmaintained for quite some time, and its
not moved to the generic board ingrastructure, lets remove it.
This will also enable us to remove the CONFIG_AUTOBOOT_DELAY_STR2
and CONFIG_AUTOBOOT_STOP_STR2 macros, as this sc3 board is the
only one using one of this macros. A removal patch will follow
soon.
Cc: Juergen Beisert <jbeisert@eurodsn.de>
Acked-by: Heiko Schocher <hs@denx.de>
This patch adds device tree for the ST Micro stv0991 board & enables
device tree control. Progressively device tree support for the drivers
being used will also be added.
Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
If regular NAND booting fails to find a valid uImage in the
kernel partition in NAND, try to boot using a zImage and dtb found
in a UBI volume in the rootfs partition. This is the NAND analog
of mmc zImage booting for device-tree based kernels.
Signed-off-by: Ash Charles <ashcharles@gmail.com>
Signed-off-by: Arun Bharadwaj <arun@gumstix.com>
Overo COMs have NAND flash that requires 4-bit ECC or better except for
the first sector which can use 1-bit ECC. The boot ROM expects to load
a payload from NAND written using 1-bit hardware-based ECC. In short,
write SPL to NAND something like this (4 times for redundancy):
#> nandecc hw
#> nand write ${loadaddr} 0x0 ${filesize}
#> nand write ${loadaddr} 0x20000 ${filesize}
#> nand write ${loadaddr} 0x40000 ${filesize}
#> nand write ${loadaddr} 0x60000 ${filesize}
Then, switch back to software-based BCH8 for everything else:
#> nandecc sw bch8
After [1], enlarge the max size of the SPL so the BCH code can fit.
[1] https://www.mail-archive.com/u-boot@lists.denx.de/msg163912.html
Add the stm32F4 board's serial ports support.
User can use it easily.
The user only need to edit the number of the usart.
The patch also fix the serial print out.
Last, this version of patch fix the first patch checkpatch.pl error.
Thanks to Kamil Lulko.
Signed-off-by: kunhuahuang <huangkunhua@gmail.com>
usbupdate in real does allways load some script from usb-storage and execute
it, on all B&R targets.
So we do following 2 things:
- rename it to what it really does
- move it from boards to common environment
Signed-off-by: Hannes Petermaier <oe5hpm@oevsv.at>
Since we display in future the splash screen out of linux-os, we don't need
this support anymore within the common section.
But kwb-target is still using BMP_DISPLAY feature, so we move the related
from the common section into the target-specific.
Also the default environment of tseries will be adapted to this.
Since the used AM3352 SoC doesn't have GPU it isn't allways necessary to build
in complete drm-stuff into linux kernel. In very small applications only we use
the simple-framebuffer.
So we have 2 use-cases:
- device operating on drm-driver (let simplefb node disabled)
- device operating on simplefb-driver (activate simplefb node and reserve mem)
The decision is made by means of "simplefb" environment variable.
simplefb = 0
we don't enable the (maybe) existing simplefb node and all the rest around
display is up to the linux-kernel. We just disable the backlight, beceause we
do not want see the flicker during take over of drm-driver.
simplefb = 1
we enable the (maybe) existing simplefb node and reserve framebuffers size
in memory.
the CONFIG_LCD_NOSTDOUT feature never had become mainline in uboot due to the
fact that the problem of "not writing out whole console to lcd" can be solved
with another way.
So we remove this unnary define.
We take use of the new LCD_ROTATION feature.
The information about how the display is rotated is taken from B&R specific
(/factory-settings/rotation) information in the devicetree.
The information there is stored as string (cw, ud, ccw, none) since starting
support of this devices and cannot be changed, so we have to convert it into
none = 0
cw = 1
ud = 2
ccw = 3
Across several devices network environment variables are duplicated.
Move these variables to a common include file which insures the environment
variables are reused and insures devices across product lines share the same
values.
Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
Replace CONFIG_SOCFPGA with CONFIG_ARCH_SOCFPGA.
Our recent trend is to collect SoC files into arch/arm/mach-(SOC).
For the distro_bootcmds to succeed on the sandbox a bit of setup is
required (e.g. network configured or host image bound), so running them
by default isn't that useful.
Add a -b/--boot command to the sandbox binary, which triggers the
distro_bootcmds to run after the other command-line commands.
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Enable real-time-clock support in sandbox.
This patch adds support for the Marvell DB-88F6820-GP Armada A38x
evaluation board.
Supported peripherals are:
- UART
- Ethernet (mvneta)
- I2C
- SPI (including SPI NOR flash)
Please note that this board support right now only supports the
main U-Boot. Without the bin_hdr integration (DDR training etc). This
will be added in a few days / weeks to complete this board port. But
till then this U-Boot version can be run on the target via the
original Marvell U-Boot via this command:
tftpboot 4000000 db-88f6820-gp/u-boot.bin;go 4000000
Tested-by: Kevin Smith <kevin.smith@elecsyscorp.com>
Tested-by: Dirk Eibach <dirk.eibach@gdsys.cc>
