This trivially enables Ethernet support in the debug board
by setting up the proper chip select.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Andrea Gallo <andrea.gallo@stnwireless.com>
This driver implements the ECC algorithm described in
the CPU data sheet and uses the OOB layout chosen in
already-released development systems (shipped with a custom-made
u-boot 1.3.1).
The previous merge for cleaning up the I2C driver incorrectly reverted the
CFG_xxx rename for some of the I2C defines.
introduce new macro CONFIG_PXA_MMC to activate it
Fixing the get_timer function to return time in miliseconds instead of
ticks. Also fixed PXA boards to use the conventional value of 1000 for
CONFIG_SYS_HZ.
Signed-off-by: Micha Kalfon <smichak.uv@gmail.com>
- activate CS4 for accessing the FPGA
- activate Rx buf len > 1 on SMC
- pram activated
- MTDPARTS_DEFAULT defined
- update the size of the flashes in the DTS
before booting Linux
- MONITOR_LEN updated to 384k
- added CONFIG_HOSTNAME
- added CONFIG_ENV_BUFFER_PRINT
- Environment size reduced to 16k
- pram activated
- update the size of the flash in the DTS
This patch will create a configuration option for a minimum configuration for
the ns16550 serial driver at drivers/serial/ns16550.c and will apply this new
configuration option to the SIMPC8313.h config file in order to fix the NAND
bootstrap build error. This option will exclude all functions with exception of
NS16550_putc and NS16550_init. This will be used primarily to save space and
remove unused code from builds in which space is limited.
Signed-off-by: Ron Madrid <ron_madrid@sbcglobal.net>
This patch prepares the good old PMC405 board support for
upcoming PMC405V2 patches.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
This patch fixes coding style for PMC405 board support.
Also some unneeded features/code is removed.
1. Changes to the default environment:
- "bootcmd" defined as "run flash_self"
- "saveenv" command removed from "update"
- "uboot" changed to "u-boot" (also in "load")
- "addmtd" variable defined (and added to all boot commands)
2. CONFIG_CMD_JFFS2 defined to enable "mtdparts" command
3. MTDIDS_DEFAULT and MTDPARTS_DEFAULT defined
4. CONFIG_SYS_CBSIZE changed from 256 to 512. That solves the problem
with truncated "bootargs" environment variable.
Signed-off-by: Ilya Yanok <yanok@emcraft.com>
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command
rather than a generic "env" command, or anything else related to the
environment. So, let's make sure the define is named accordingly.
After introducing redundant environment the kernel images was
overlapping with environment.
Signed-off-by: Andy Fleming <afleming@freescale.com>
The TQM8548_AG is a variant of the TQM8548 module with 1 GiB memory,
CAN and without PCI/PCI-X and RTC. U-Boot can be built for this module
with "$ make TQM8548_AG_config".
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
The TQM8548_BE is a variant of the TQM8548 module with NAND and CAN
interface. With NAND support, the image is significantly larger and
TEXT_BASE is adjusted accordingly. U-Boot can be built for this
module with "$ make TQM8548_BE_config".
The TQM8548_AG module does not have the standard PCI/PCI-X interface
connected but just the PCI Express interface . So far it was not
possible to disable it without disabling the complete PCI interface
(CONFIG_PCI) including PCI Express.
Update the 86xx reset sequence to try executing a board-specific reset
function. If the board-specific reset is not implemented or does not
succeed, then assert #HRESET_REQ. Using #HRESET_REQ is a more standard
reset procedure than the previous method and allows all board
peripherals to be reset if needed.
When we introduced the 36-bit config of the MPC8572DS board we had the
wrong PCI MEM bus address map. Additionally, the change to the address
map exposes a small issue in our dummy read on the ULI bus. We need
to use the new mapping functions to handle that read properly in the
36-bit config.
Previously we only allowed power-of-two memory sizes and didnt
handle >2G of memory. Now we will map up to CONFIG_MAX_MEM_MAPPED
and should properly handle any size that we can make in the TLBs
we have available to us
With actual u-boot compiling the mgcoge port fails, because
since commit ba705b5b1a97b47388ed48858bef6bf7b6bfcd56 it is
necessary to define CONFIG_NET_MULTI.
Seems to me the mgcoge port is the only actual existing 8260
port who uses CONFIG_ETHER_ON_SCC, so no other 8260 port needed
to be fixed.
The criteria of the AMCC SDRAM Controller DDR autocalibration
U-Boot code is to pick the largest passing write/read/compare
window that also has the smallest SDRAM_RDCC.[RDSS] Read Sample
Cycle Select value.
On some Kilauea boards the DDR autocalibration algorithm can
find a large passing write/read/compare window with a small
SDRAM_RDCC.[RDSS] aggressive value of Read Sample Cycle Select
value "T1 Sample".
This SDRAM_RDCC.[RDSS] Read Sample Cycle Select value of
"T1 Sample" proves to be to aggressive when later on U-Boot
relocates into DDR memory and executes.
The memory traces on the Kilauea board are short so on some
Kilauea boards the SDRAM_RDCC.[RDSS] Read Sample Cycle Select
value of "T1 Sample" shows up as a potentially valid value for
the DDR autocalibratiion algorithm.
The fix is to define a weak default function which provides
the minimum SDRAM_RDCC.[RDSS] Read Sample Cycle Select value
to accept for DDR autocalibration. The default will be the
"T2 Sample" value. A board developer who has a well defined
board and chooses to be more aggressive can always provide
their own board specific string function with the more
aggressive "T1 Sample" value or stick with the default
minimum SDRAM_RDCC.[RDSS] value of "T2".
Also put in a autocalibration loop fix for case where current
write/read/compare passing window size is the same as a prior
window size, then in this case choose the write/read/compare
result that has the associated smallest RDCC T-Sample value.
Signed-off-by: Adam Graham <agraham@amcc.com>
CONFIG_SDRAM_PPC4xx_IBM_DDR2 is not set when include/asm-ppc/config.h is
included. So for katmai, CONFIG_MAX_MEM_MAPPED will get set to 256MB.
It makes perfect sense to set CONFIG_MAX_MEM_MAPPED to 2GB for all PPC4xx
boards right now.
At some point an intentional double space at the end of the sentence
got changed into a tab in the GPL header line:
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
This patch fixes the damage.
Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
Added new CONFIG options for the three type of MAC-PHY interconnect and
applied them all relevant board config files
Now that the rest of u-boot can support it, change the PCI bus
address of the PCI MEM regions from 0x80000000 to 0xc0000000,
and use the same bus address for both PCI1 and PCI2. This will
maximize the amount of PCI address space left over to map RAM
on systems with large amounts of memory.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Clean up PCI mapping concepts in the 8641 config - rename _BASE
to _BUS, as it's actually a PCI bus address, separate virtual
and physical addresses into _VIRT and _PHYS, and use each
appopriately.
If the VA and PA of the flash aren't the same, the banks list
should be initialized to hold the physical address. Correct this.
This patch adds support for Dave/DENX QongEVB-LITE i.MX31-based board.
Enable NAND_UNLOCK option for unlocking nand for
erase/write operations
Signed-off-by: Nishanth Menon <nm@ti.com>
Cleanup for M5271EVB:
Added clarification on the use of CONFIG_SYS_CLOCK.
Modified to use u-boot's HUSH parser.
Cleanup on environment settings.
Removed compiler warning by defining CONFIG_SYS_CS0_*
Dependencies:
Added the use of CONFIG_SYS_MCF_SYNCR for clock multiplier.
This depends on a patch to include/asm-m68k/m5271.h
that defines the multiplier and divider ratios.
Removed the definition of CONFIG_SYS_FECI2C.
This depends on a patch that removes the use of it in
cpu/mcf52x2/cpu_init.c
Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
Original patch from Ralph Kondziella
plus clean up by Wolfgang Denk
plus changes by John Rigby
use ips clock not lpc
port forward to current u-boot release
Signed-off-by: Ralph Kondziella <rk@argos-messtechnik.de>
Signed-off-by: John Rigby <jrigby@freescale.com>
IIM (IC Identification Module) is the fusebox for the mpc5121.
Use #define CONFIG_IIM to turn on the clock for this module
use #define CONFIG_CMD_FUSE to add fusebox commands.
Fusebox commands include the ability to read
the status, read the register cache, override the register cache,
program the fuses and sense them.
Signed-off-by: Martha Marx <mmarx@silicontkx.com>
Make inclusion of FSL logo optional and
turn it off by default.
instead the board will have to load it from flash or ram
which will be specified by npe_ucode env var
