2 recent sunxi changes have removed the usage of lowlevel_init by moving some
code around and then setting CONFIG_SKIP_LOWLEVEL_INIT.
This is problematic for 2 reasons:
1) It does not just stop s_init from being called, it also stops
cpu_init_cp15 from getting called, which is undesirable.
2) We want u-boot.bin to be usable standalone, without SPL, some people e.g.
use an upstream u-boot.bin together with Allwinner's boot0 loader. So
u-boot.bin must (re)initialize the gpios, timer, etc.
This commit restores the lowlevel_init / s_init usage, while keeping the
changes to no longer use the global-data (gd) struct in the SPL.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Signed-off-by: Sinan Akman <sinan@writeme.com>
Cc: kim.phillips@freescale.com
This does nothing now, so drop it. We have SPL anyway to do our low-level
init.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
All the 74xx_7xx boards are still non-generic boards:
P3G4, ZUMA, ppmc7xx, ELPPC, mpc7448hpc2
Acked-by: York Sun <yorksun@freescale.com>
Cc: Nye Liu <nyet@zumanetworks.com>
Cc: Roy Zang <tie-fei.zang@freescale.com>
It makes sense to specify CONFIG_SYS_CLK_FREQ in "configs/xx_defconfig"
instead of "include/configs/xxx.h" because then header will be reusable
across boards with different CPU clocks.
Also this nice to have an ability for end user to tune this value
himself via "menuconfig".
For now I'm only applying this change to all ARC configs because
otherwise scope of change will be huge.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Tom Rini <trini@ti.com>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Hans de Goede <hdegoede@redhat.com>
cc: Simon Glass <sjg@chromium.org>
Reviewed-by: Tom Rini <trini@ti.com>
Add support for Seagate BlackArmor NAS220
Signed-off-by: Evgeni Dobrev <evgeni@studio-punkt.com>
Some MTD defines are repeated twice; once with UBI and then with MTD.
Remove the duplicate MTD defines from the UBI grouping.
Signed-off-by: Bill Pringlemeir <bpringlemeir@nbsps.com>
Most of the usb-controller init code found in ehci-sunxi.c also is necessary
to init the otg usb controller, so move it to a common place.
While at it also update various #ifdefs / defines for sun8i support.
This allows to always have a complete log on the VGA/HDMI/LCD console.
Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
Acked-by: Hans de Goede <hdegoede@redhat.com>
Before video output support can be enabled on the A13-OLinuXinoM, bootm_size
must first be reduced to take into account that the framebuffer is shaved of
the top of the DRAM. For other boards this is not an issue since bootm was set
to 256M and all boards have at least 512M except for the A13-OLinuXinoM.
Add DDC & EDID support and use it to automatically select the native mode of
the attached monitor. This can be disabled by adding edid=0 as option
to the video-mode env. variable.
Acked-by: Anatolij Gustschin <agust@denx.de>
Add support for the standard video-mode environment variable using the
videomodes.c video_get_ctfb_res_modes() helper function.
This will allow users to specify the resolution e.g. :
setenv video-mode sunxi:video-mode=1280x1024-24@60
saveenv
Also make the reserved fb mem slightly larger to allow 1920x1200 to work.
Switch from fb_videomode to ctfb_res_modes and use the predefined videotimings
from videomodes.c, rather then defining our own.
The CONFIG_UART0_PORT_F option has been supported since
http://git.denx.de/?p=u-boot.git;a=commit;h=ff2b47f6a9cc1025
This option is primarily useful only for low level u-boot debugging
on tablets, where normal UART0 is difficult to access and requires
device disassembly and/or soldering.
This patch now allows it to be selected from menuconfig. A dependency on
SPL_FEL is added because u-boot does not support booting from NAND yet
and also booting from SD card is impossible when a MicroSD breakout board
is plugged into the SD slot.
Additionally a compilation problem is fixed:
common/spl/built-in.o: In function `spl_mmc_load_image':
/tmp/u-boot-sunxi/common/spl/spl_mmc.c:94: undefined reference to `mmc_initialize'
/tmp/u-boot-sunxi/common/spl/spl_mmc.c:96: undefined reference to `find_mmc_device'
/tmp/u-boot-sunxi/common/spl/spl_mmc.c:104: undefined reference to `mmc_init'
scripts/Makefile.spl:206: recipe for target 'spl/u-boot-spl' failed
Based on the register / dram_para headers from the Allwinner u-boot / linux
sources + the init sequences from boot0.
* Add netargs and netboot option.
* This enables tftp and nfs booting
* This puts omap5 devices inline with other devices such as am335x and am437x
Signed-off-by: Franklin S Cooper Jr <fcooper@ti.com>
Signed-off-by: Anthoine Bourgeois <anthoine.bourgeois@gmail.com>
This patch adds boot script support to pcm051
Signed-off-by: Matwey V. Kornilov <matwey.kornilov@gmail.com>
AM43xx Industrial Development Kit is a new board
based on AM437x line of SoCs. Targetted at Industrial
Automation applications, it comes with EtherCAT, motor
control and other goodies.
Thanks to James Doublesin for all the help.
Cc: James Doublesin <doublesin@ti.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
CONFIG_DISPLAY_CPUINFO is already defined in x86-common.h, so remove
it to avoid duplication.
Change SYS_CONFIG_NAME and DEFAULT_DEVICE_TREE to chromebook_link
which is currently the only real board officially supported to run
U-Boot loaded by coreboot.
Note the symbolic link file chromebook_link.dts is deleted and
link.dts is renamed to chromebook_link.dts.
To avoid multiple definition of video_hw_init, the CONFIG_VIDEO_X86
define needs to be moved to arch/x86/cpu/ivybridge/Kconfig.
Since we already swtiched to use the new mechanism for building
U-Boot for coreboot, coreboot.h is no longer needed so remove it.
Move CONFIG_SYS_CAR_ADDR and CONFIG_SYS_CAR_SIZE to Kconfig so that
we don't need them in the board configuration file thus the same
board configuratoin file can be used to build both coreboot version
and bare version.
There are many places in the U-Boot source tree which refer to
CONFIG_SYS_COREBOOT, CONFIG_CBMEM_CONSOLE and CONFIG_VIDEO_COREBOOT
that is currently defined in coreboot.h.
Move them to arch/x86/cpu/coreboot/Kconfig so that we can switch
to board configuration file to build U-Boot later.
Convert CONFIG_X86_RESET_VECTOR and CONFIG_SYS_X86_START16 to Kconfig
options so that we can remove them from board configuration file.
Signed-off-by: Georgi Botev <botev@ronetix.at>
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
- remove some obsolete code
- switch to generic board
only keep CPCI4052
