Move this option to Kconfig and tidy up existing uses.
This option is not used. Drop it.
CONFIG_SPL_NET_VCI_STRING
There are a few options which use lower case. We should use upper case for
all CONFIG options.
[trini: Add usbtty/nand hunk to include/configs/spear3xx_evb.h]
At present TPL uses the same options as SPL support. In a few cases the board
config enables or disables the SPL options depending on whether
CONFIG_TPL_BUILD is defined.
With the move to Kconfig, options are determined for the whole build and
(without a hack like an #undef in a header file) cannot be controlled in this
way.
Create new TPL options for these and update users. This will allow Kconfig
conversion to proceed for these boards.
This option does not exist in U-Boot. Drop it.
move VERSION_VARIABLE from board config file into a
Kconfig option.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
As bootargs is hard-coded for the default behavior on the
omap3_pandora, only set the bootargs if distro_bootcmd fails to
load. This leaves distro_bootcmd free to use alternate boot arguments.
Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
Add support for using distro_bootcmd to the omap3_pandora target,
falling back to prior behavior.
Move this option to Kconfig and set its default value to 4; this
increases the number of supported CPUs for some boards.
It consumes 1KB memory per CPU for PSCI stack, but it should not
be a big deal, given the amount of memory used for the modern OSes.
Reviewed-by: Alexander Graf <agraf@suse.de>
Add ARCH_SUPPORT_PSCI as a non-configurable option that platforms
can select. Then, move CONFIG_ARMV7_PSCI, which is automatically
enabled if both ARMV7_NONSEC and ARCH_SUPPORT_PSCI are enabled.
CONFIG_CMD_FS_GENERIC is enabled; use it to load the autoboot script,
rather than first attempting with fatload and falling back to
ext2load.
Acked-by: Grazvydas Ignotas <notasas@gmail.com>
fatload/ext2load both require that the device and partition be
specified after specifying the device type. Specify the first
partition on mmc device 0, which is the only mmc device currently
configured on the pandora.
On all TI platforms the ROM defines a "downloaded image" area at or near
the start of SRAM which is followed by a reserved area. As it is at
best bad form and at worst possibly harmful in corner cases to write in
this reserved area, we stop doing that by adding in the define
NON_SECURE_SRAM_IMG_END to say where the end of the downloaded image
area is and make SRAM_SCRATCH_SPACE_ADDR be one kilobyte before this.
At current we define the end of scratch space at 0x228 bytes past the
start of scratch space this this gives us a lot of room to grow. As
these scratch uses are non-optional today, all targets are modified to
respect this boundary.
Tested on OMAP4 Pandaboard, OMAP3 Beagle xM
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Nagendra T S <nagendra@mistralsolutions.com>
Cc: Vaibhav Hiremath <hvaibhav@ti.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Paul Kocialkowski <contact@paulk.fr>
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Cc: Adam Ford <aford173@gmail.com>
Cc: Steve Sakoman <sakoman@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Thomas Weber <weber@corscience.de>
Cc: Hannes Schmelzer <oe5hpm@oevsv.at>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Sam Protsenko <semen.protsenko@linaro.org>
Cc: Samuel Egli <samuel.egli@siemens.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
Cc: Ben Whitten <ben.whitten@gmail.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Mugunthan V N <mugunthanvnm@ti.com>
Cc: "B, Ravi" <ravibabu@ti.com>
Cc: "Matwey V. Kornilov" <matwey.kornilov@gmail.com>
Cc: Ladislav Michl <ladis@linux-mips.org>
Cc: Ash Charles <ashcharles@gmail.com>
Cc: "Kipisz, Steven" <s-kipisz2@ti.com>
Cc: Daniel Allred <d-allred@ti.com>
Tested-by: Lokesh Vutla <lokeshvutla@ti.com>
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
Tested-by: Ladislav Michl <ladis@linux-mips.org>
Sometimes boards may need more time to become stable network connection
due to several reasons:
- phy speed
- link-partner (switch)
Therefore we increase the retry-count to 10 for making sure that network
connection works always.
Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
On the raspberry pi, you can disable the serial port to gain dynamic frequency
scaling which can get handy at times.
However, in such a configuration the serial controller gets its rx queue filled
up with zero bytes which then happily get transmitted on to whoever calls
getc() today.
This patch adds detection logic for that case by checking whether the RX pin is
mapped to GPIO15 and disables the mini uart if it is not mapped properly.
That way we can leave the driver enabled in the tree and can determine during
runtime whether serial is usable or not, having a single binary that allows for
uart and non-uart operation.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
warp7 can run different kernel versions, such as NXP 4.1 or mainline.
Currently the rootfs location is passed via mmcblk number and the
problem with this approach is that the mmcblk number for the eMMC
changes depending on the kernel version.
In order to avoid such issue, use UUID method to specify the rootfs
location.
Succesfully tested booting a NXP 4.1 and also a mainline kernel.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Use imx7s-warp.dts as fdt_file because this is the name that upstream
kernel will deploy.
Signed-off-by: Breno Lima <breno.lima@nxp.com>
Acked-by: Fabio Estevam <fabio.estevam@nxp.com>
Add PMIC support. Tested by command "pmic PFUZE3000 dump".
Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Add support for Advantech DMS-BA16 board. The board is based on Advantech
BA16 module which has a i.MX6D processor. The board supports:
- FEC Ethernet
- USB Ports
- SDHC and MMC boot
- SPI NOR
- LVDS and HDMI display
Basic information about the module:
- Module manufacturer: Advantech
- CPU: Freescale ARM Cortex-A9 i.MX6D
- SPECS:
Up to 2GB Onboard DDR3 Memory;
Up to 16GB Onboard eMMC NAND Flash
Supports OpenGL ES 2.0 and OpenVG 1.1
HDMI, 24-bit LVDS
1x UART, 2x I2C, 8x GPIO,
4x Host USB 2.0 port, 1x USB OTG port,
1x micro SD (SDHC),1x SDIO, 1x SATA II,
1x 10/100/1000 Mbps Ethernet, 1x PCIe X1 Gen2
Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com>
Cc: u-boot@lists.denx.de
Cc: sbabic@denx.de
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
HDMI output must be enabled very early to also enable the pre-console buffer
Signed-off-by: Soeren Moch <smoch@web.de>
'usb start' is much faster now, so always enable usb keyboard
This commit moved the SPL stack into SRAM C, which worked when the SPL
set the AHB1 clock down to 100 MHz to cope with the flaky SRAM C access
from the CPU.
However booting with boot0 (and thus not using SPL at all) we still run
with a 200 MHz AHB1, so any access to SRAM C is prone to fail.
Since this commit does _not_ only affect the SPL code, but also the
U-Boot proper, we fail when booting with boot0.
As the introduction of tiny-printf reduced the size of the SPL, we
can afford to have the SPL stack in SRAM A1.
This reverts commit 1a83fb4a17d959d7b037999ab7ed7e62429abe34
and fixes booting the Pine64 when using boot0.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
The Colorado TK1 SOM is a small form factor board similar to the
Jetson TK1. The main differences lie in the pinmux, and in that the
PCIe controller is set to use in 4lanes+1lane, rather than 2+2.
The pinmux header here was generated from a spreadsheet provided by
Colorado Engineering using the tegra-pinmux scripts. The spreadsheet
was converted from v09 to v11 by me.
Signed-off-by: Peter Chubb <peter.chubb@data61.csiro.au>
Signed-off-by: Tom Warren <twarren@nvidia.com>
