It is not used anywhere.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
For use together with the hdmi console.
Acked-by: Ian Campbell <ian.campbell@citrix.com>
Add simplefb support, note this depends on the kernel having support for
the clocks property which has recently been added to the simplefb devicetree
binding.
Signed-off-by: Luc Verhaegen <libv@skynet.be>
[hdegoede@redhat.com: Use pre-populated simplefb node under /chosen as
disussed on the devicetree list]
Acked-by: Ian Campbell <ijc@hellion.org.uk>.
This adds a fixed mode hdmi driver for the sunxi platform. The fixed
mode is a relatively safe 1024x768, more complete EDID handling is
currently not provided. Only HDMI is supported today.
This code is enabled when HPD detects an attached monitor.
Current config is such that 8MB is shaved off at the top of the RAM.
This avoids several memory handling issues, most significant is the fact
that on linux on ARM you are not allowed to remap known RAM as IO. A
clued in display driver will be able to recycle this reserved RAM in
future though.
cfbconsole was chosen as it provides the most important functionality: a
working u-boot console, allowing for the debugging of certain issues
without the need for a UART.
[hdegoede@redhat.com: Major cleanups and some small bugfixes]
Acked-by: Anatolij Gustschin <agust@denx.de>
drivers/serial/serial-uclass.c
arch/x86/cpu/Makefile
Add arch/arm/cpu/armv7/Kconfig with non-secure and virt options, this is a
preparation patch for adding an env variable to choose between secure /
non-secure boot on non-secure boot capable systems, specifically this
prepares for adding CONFIG_ARMV7_BOOT_SEC_DEFAULT as a proper Kconfig option.
Enable md5sum to obtain the MD5 of the read and written files to check
their contents for validity.
Use map_sysmem() to map buffer in a sandbox environment.
Signed-off-by: Suriyan Ramasami <suriyan.r@gmail.com>
Since commit 0defddc851ed (config: Add a default CONFIG_SYS_PROMPT),
each board header does not need to define CONFIG_SYS_PROMPT
as long as it uses the default prompt "=> ".
Enable i.MX thermal DM driver to mx6sabre_common.h file. Since the
thermal is used in init_sequence_f, so define the CONFIG_SYS_MALLOC_F_LEN
to support DM driver using in pre relocation phase.
Additional, thermal driver depends on ocotp, make sure to enable
CONFIG_MXC_OCOTP when CONFIG_IMX6_THERMAL is selected.
Signed-off-by: Ye.Li <B37916@freescale.com>
Signed-off-by: Nitin Garg <nitin.garg@freescale.com>
The faster functions are not actually available in SPL and the code size
likely isn't worth it. Use the normal memcpy() in SPL.
Convert this at91sam9260-based board to use driver model. This should serve
as an example for other similar boards. Serial and GPIO are supported so
far.
Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
This works correctly, so switch it over before the deadline.
The value should be 0x21f00000. Fix it.
Implement SDRAM init using the Memory Reference Code (mrc.bin) provided in
the board directory and the SDRAM SPD information in the device tree. This
also needs the Intel Management Engine (me.bin) to work. Binary blobs
everywhere: so far we have MRC, ME and microcode.
SDRAM init works by setting up various parameters and calling the MRC. This
in turn does some sort of magic to work out how much memory there is and
the timing parameters to use. It also sets up the DRAM controllers. When
the MRC returns, we use the information it provides to map out the
available memory in U-Boot.
U-Boot normally moves itself to the top of RAM. On x86 the RAM is not
generally contiguous, and anyway some RAM may be above 4GB which doesn't
work in 32-bit mode. So we relocate to the top of the largest block of
RAM we can find below 4GB. Memory above 4GB is accessible with special
functions (see physmem).
It would be possible to build U-Boot in 64-bit mode but this wouldn't
necessarily provide any more memory, since the largest block is often below
4GB. Anyway U-Boot doesn't need huge amounts of memory - even a very large
ramdisk seldom exceeds 100-200MB. U-Boot has support for booting 64-bit
kernels directly so this does not pose a limitation in that area. Also there
are probably parts of U-Boot that will not work correctly in 64-bit mode.
The MRC is one.
There is some work remaining in this area. Since memory init is very slow
(over 500ms) it is possible to save the parameters in SPI flash to speed it
up next time. Suspend/resume support is not fully implemented, or at least
it is not efficient.
With this patch, link boots to a prompt.
Enable GPIO support and provide the required GPIO setup information to
the driver.
Enable PCI so we can access devices that need to be set up before relocation.
On x86 machines U-Boot needs to be added to a large ROM image which is
then flashed onto the target board. The ROM has a particular format so it
makes sense for U-Boot to build this image automatically. Unfortunately
it relies on binary blobs so we cannot require this for the default
build as yet.
Create a u-boot.rom output file for this purpose.
This board is a 'bare' version of the existing 'link 'board. It does not
require coreboot to run, but is intended to start directly from the reset
vector.
This initial commit has place holders for a wide range of features. These
will be added in follow-on patches and series. So far it cannot be booted
as there is no ROM image produced, but it does build without errors.
Many of the x86 CONFIG options will be common across different boards. Move
them to a common file.
CONFIG_CPU_ARM1136 was introduced into Kconfig by commit 2e07c249a67e
(kconfig: arm: introduce symbol for ARM CPUs).
This commit removes all the defines of CONFIG_ARM1136 and replaces
the only reference in arch/arm/lib/cache.c with CONFIG_CPU_ARM1136.
CONFIG_CPU_ARM926EJS was introduced into Kconfig by commit 2e07c249a67e
This commit removes all the defines of CONFIG_ARM926EJS and replaces
the only reference in arch/arm/lib/cache.c with CONFIG_CPU_ARM926EJS.
CONFIG_CPU_ARM920T was introduced into Kconfig by commit 2e07c249a67e
This commit removes all the defines of CONFIG_ARM920T and replaces the
only reference in drivers/usb/host/ohci-hcd.c with CONFIG_CPU_ARM920T.
CONFIG_ARM1176 is defined for some boards but not referenced at all.
Some (not all) of ARMv7 boards define CONFIG_ARMV7, which is useless.
Besides, it is never referenced.
Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Add the pfuze100 initialization in power_init_board for imx6q/dl
sabreauto board.
Add full support for USDHC2, USDHC3, USDHC4 on mx6sx sabresd board.
The default boot socket is USDHC4, so the MMC environment device and
mmcdev variable are set to this device.
This is nowhere documented and only used
by two other boards. Replace it with
TQMA6_SPI_FLASH_SECTOR_SIZE.
Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
mx6sabreauto boards come with 32 MiB of parallel NOR flash.
Add support for it:
U-Boot 2015.01-rc1-18107-g1543636-dirty (Nov 14 2014 - 11:11:04)
CPU: Freescale i.MX6Q rev1.2 at 792 MHz
Reset cause: POR
Board: MX6Q-Sabreauto revA
I2C: ready
DRAM: 2 GiB
Flash: 32 MiB
NAND: 0 MiB
Due to pin conflict with I2C3, only define configure I2C3 IOMUX when flash is
not used.
Since USDHC1 and USDHC3 added, the dev index for USDHC2 changed to
1. So modify the default mmcdev in environment variables to dev 1.
a3m071 and a4m2k share one config header. So adding the generic board defines
in this one file is enough to convert both boards.
The gdsys hrcon board is based on a Freescale MPC8308 SOC.
It boots from NOR-Flash, kernel and rootfs are stored on
SD-Card.
On board peripherals include:
- 1x GbE (optional)
- Lattice ECP3 FPGA connected via eLBC and PCIe
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
Tune dlvision configuration similar to other gdsys boards to reduce memory
footprint.
The code for this board supports following features:
- Boot media support: NAND flash/SD card/SPI flash
- Support LCD display (optional, disabled by default)
- Support ethernet
- Support USB mass storage
Signed-off-by: Bo Shen <voice.shen@atmel.com>
- Support ethernet
replaces the at91bootstrap code with SPL code.
make the spl image with:
./tools/mkimage -T atmelimage -d spl/u-boot-spl.bin spl/boot.bin
this writes the length of the spl image into the 6th
execption vector. This is needed from the ROM bootloader.
Reviewed-by: Bo Shen <voice.shen@atmel.com>
Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
move CONFIG_SYS_SPI_WRITE_TOUT into drivers/spi/atmel_spi.h
and define a default value. Delete this define in the board
config files, where it is possible (all boards use currently
the same value).
Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com>
Common part of config for lager, koelsch, alt and gose board will be able to
replace rcar-gen2-common.h.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
