path: root/include/configs
2013-06-21vybrid: Fix for 1.1 silicon (rev G and later)2011.12-mvf-201306211654Anthony Felice
2013-06-21provide a workaround for GPU in VybridJason Jin
The GPU frequently hang the system during testing. This patch provide a workaroud to reset the soc after the pll system was initialized. Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Jingchang Lu <b35083@freescale.com>
2012-09-07ENGR00219758: Enable the softecc for Vybrid NFC controllerJason Jin
When enable the hardware ecc in kernel, there are crc errors for JFFS2 filesystem after write to the filesystem. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2012-09-07Add NFC support for faraday boardJason Jin
2012-09-07Add Vybrid tower board VF600 initializationJingchang Lu
Signed-off-by: TsiChung Liew <tsicliew@gmail.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2012-03-19Armada100: gplugD: Add FAT & EXT2 command supportAjay Bhargav
This patch adds FAT and ext2 command support for marvell gplugD Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2012-03-19Armada100: gplugD: Add USB command supportAjay Bhargav
This patch adds support for USB commands and USB storage device for Marvell gplugD Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2012-03-19USB:gadget:designware USB device controller (UDC) implementationVipin KUMAR
The earlier usb device controller driver was specific to spear platforms. This patch implements the usb device controller driver as a generic controller which can be reused by other platforms using this peripheral. Signed-off-by: Vipin Kumar <vipin.kumar@st.com> Signed-off-by: Amit Virdi <amit.virdi@st.com> Acked-by: Marek Vasut <marex@denx.de>
2012-03-18CPCI750: Add CPCI-HD/2 supportReinhard Arlt
This patch adds support for the esd CPCI-HD/2 board to u-boot for CPCI-CPU/750. As the primary devices on the CPCI-HD/2 board are connected to device 1 and 3, the device must be swapped. Signed-off-by: Reinhard Arlt <reinhard.arlt@esd.eu>
2012-03-17Merge branch 'master' of git://git.denx.de/u-boot-avr32Wolfgang Denk
* 'master' of git://git.denx.de/u-boot-avr32: atmel_mci.h: remove outdated register macros doc/git-mailrc: add <me> to avr32 alias ATMEL: remove old atmel_mci driver ATMEL: use generic mmc framework
2012-03-17Merge branch 'sandbox' of git://git.denx.de/u-boot-blackfinWolfgang Denk
* 'sandbox' of git://git.denx.de/u-boot-blackfin: sandbox: mark os_exit as noreturn sandbox: add getopt support sandbox: allow processing before main loop sandbox: add concept of sandbox state sandbox: disable fortification sandbox: u-boot.lds: tweak style sandbox: add get_{tbclk,ticks} sandbox: enable GPIO driver sandbox: gpio: add basic driver for simulating GPIOs sandbox: add flags for open() call sandbox: config: enable fdt and snprintf() options sandbox: fdt: add support for CONFIG_OF_CONTROL sandbox: add lseek helper sandbox: add ifdef protection to os.h sandbox: add required header to os.c sandbox: sort header files in os.c
2012-03-13ATMEL: use generic mmc frameworkSven Schnelle
gen_atmel_mci works on AVR32 as well, so no need to use the legacy mmc driver. This also has the nice side effect of being able to use SDHC cards an those boards. Signed-off-by: Sven Schnelle <svens@stackframe.org> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-03-12sandbox: enable GPIO driverSimon Glass
Enable the new GPIO driver for sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-12sandbox: config: enable fdt and snprintf() optionsSimon Glass
Enable fdt code and safe snprintf() options for sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-03-08sh: Fix sh7264 clock speed and related serial settingPhil Edworthy
The generalised calculation of the serial bit rate reg also applies to sh7264, it was just the clock speed that was set incorrectly. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-03-08sh: ecovec: Add support PHY of SMSCNobuhiro Iwamatsu
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2012-02-27tt01: fix hush parser config, add release configHelmut Raiger
Add PREBOOT, SILENT_CONSOLE and DEVICE_NULLDEV for release build. Fixed bug in CONFIG_SYS_HUSH_PARSER define. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
2012-02-27tt01: add video supportHelmut Raiger
The video setup for the Epson display is provided. Addtionally some extra info is displayed next to the Linux logo. Make get_cpu_rev() publicly available (added to sys_proto.h). Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
2012-02-27tt01: fix environment sizeHelmut Raiger
size of environment must match erasable block size in the flash. Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
2012-02-27i.mx6q: mx6qsabrelite: Update the network configurationTroy Kisky
Define CONFIG_PHY_MICREL, and minimize the tx clock delay. There is an issue with 1000 baseTx mode on early revs of the SabreLite boards. The center tap pin 9 of the mag RJ45 USB combo was connected to the 3.3 filtered supply. Letting this pin float solved the problem. Symptoms of the problem were packets with many extra zeroes tacked on the end, and random bit flips causing a high rate of CRC errors. 10/100 baseTx worked fine on all revs. To disable 1000 baseTx for these boards, simply define the environment variable disable_giga. ie. setenv disable_giga 1 Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com>
2012-02-27integrator: update the Integrator/CP configLinus Walleij
The Integrator/CP config file was very outdated and gives a non functional U-Boot. So: - Set the CONFIG_ARCH_CINTEGRATOR arch flag correctly - Add proper core module configuration options - Skip cluttered command lista and just include <config_cmd_default.h> - Kill off #if 0 network section and insert some example configuration that simply just boots from the network using TFTP if available. - Delete flash control registers that have no business in this config file. These are already moved down to board/armltd/integrator/integrator-sc.h Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-27integrator: rewrite the AP PCI driverLinus Walleij
The PCI support for the Integrator AP has apparently never been finished and I strongly suspect that it has never worked, so let's fix it. This is a list of the more or less un-splittable changes done in this driver rewrite: - Replace the register definitions stashed into the config file (!) with a copy if the register file from the Linux kernels arch/arm/include/asm/hardware/pci_v3.h - Delete the unreadable gigantic macros that perform the config accesses and replace them with copyedited code from Linux arch/arm/mach-integrator/pci_v3.c - Rewrite the rest of the setup code to use the v3_[read|write][lwb]() accessors. - Enable PCI by default in the AP board configuration. - Fix checkpatch warnings and make code more conformant. Tested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-02-27mcx: Enable command line editingDetlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de> CC: Stefano Babic <sbabic@denx.de>
2012-02-27dm6467Tevm: Use a common configuration file for davinci_dm6467evm and ↵prabhakar.csengg@gmail.com
davinci_dm6467Tevm In commit 2d575e46859dd9127a9cec731ace77523e6ea2ab a separate header file was introduced for the DM6467T EVM, include/configs/davinci_dm6467Tevm.h. The substantial difference between the davinci_dm6467evm and the davinci_dm6467Tevm configuration is a single bit in the hardware revision that is passed to the Linux kernel and davinci_dm6467evm has REFCLK_FREQ = 27000000 where as davinci_dm6467Tevm.h has a REFCLK_FREQ = 33000000. This patch removes include/configs/davinci_dm6467Tevm.h. Instead the include/configs/davinci_dm6467evm.h configuration is used for DM6467T EVMs and renamed CFG_REFCLK_FREQ to CONFIG_REFCLK_FREQ and CONFIG_REFCLK_FREQ is defined in boards.cfg. Signed-off-by: Prabhakar Lad <prabhakar.csengg@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-02-27OMAP3: Remove unused CONFIG_SYS_NAND_ECCSTEPS/TOTALThomas Weber
Signed-off-by: Thomas Weber <weber@corscience.de>
2012-02-27Tricorder: Switch env to generic mmc driverThomas Weber
Because the tricorder uses the CONFIG_OMAP_HSMMC the initialization command is mmc rescan and not mmc init. Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-02-27mx6q: mx6qsabrelite: Conditionally define macros for environment in serial flashEric Nelson
The default settings store the persistent environment on SD card and not serial flash (SPI NOR). To use SPI NOR to save the environment instead of SD card, edit include/configs/mx6qsabrelite.h and - undefine CONFIG_ENV_IS_IN_MMC - define CONFIG_ENV_IS_IN_SPI_FLASH The SPI driver can take as chip select the controller's chip selects as well as an external GPIO. The LSB byte has the value of the internal chip select, the highest (thought as 16-bit value) contains the GPIO number. The GPIO used on Sabre Lite is GP3:19 == 83. Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Jason Liu <jason.hui@linaro.org> Tested-by: Jason Liu <jason.hui@linaro.org>
2012-02-27mx6q: mx6qsabrelite: Provide default serial flash bus and chip-selectEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com> Acked-by: Dirk Behme <dirk.behme@de.bosch.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Jason Liu <jason.hui@linaro.org> Tested-by: Jason Liu <jason.hui@linaro.org>
2012-02-27mx6q: mx6qsabrelite: Add ECSPI support to the Sabrelite platformEric Nelson
2012-02-27mx28evk: add SPI supportMatthias Fuchs
This patch adds SPI support for the MX28EVK. Support for an optionally installed SPI flash is also added. An example configuration for redundant envrionment from SPI flash is also added but disabled by default. This patch has been tested on a MX28EVK Rev. D with an installed SST25VF032B 32Mbit SPI flash. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-02-27mx28evk: add USB supportMatthias Fuchs
This patch enables USB host support on the MX28EVK board. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-02-27mx28evk: add RTC supportMatthias Fuchs
This patch adds support for the MX28 internal RTC and enables u-boot's date command. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
2012-02-23microblaze: Enable TFTP put commandStephan Linz
Signed-off-by: Stephan Linz <linz@li-pro.net>
2012-02-13Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
* 'master' of git://git.denx.de/u-boot-blackfin: Blackfin: pata_bfin: fix printf warning Blackfin: bfin_nand: mark local func static linkage.h: move from blackfin to common includes Blackfin: br4: new board port Blackfin: add in/out le32 variants post: add blackfin to the post_time_ms list Blackfin: bf537-stamp: drop board reset workaround Blackfin: pr1: new board port
2012-02-12Blackfin: br4: new board portDimitar Penev
This adds support for the BR4 Appliance. It is a quad channel ISDN BRI board based on Blackfin BF537 CPU. Signed-off-by: Dimitar Penev <dpn@switchfin.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-02-12Blackfin: pr1: new board portDimitar Penev
This add support for the PR1 Appliance - Asterisk based ISDN PRI PBX. This board is Blackfin BF537 based. The schematics are not fully opened. Signed-off-by: Dimitar Penev <dpn@switchfin.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-02-12arm, davinci: Add support for the Calimain board from OMICRON electronicsChristian Riesch
This patch adds support for the Calimain board from OMICRON electronics GmbH. The board features a Texas Instruments AM1808 SoC, 128 MB DDR2 memory, and 64 MB NOR flash memory connected to CS2 and CS3. Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
2012-02-12Changes to move hawkboard to the new spl infrastructureSughosh Ganu
This patch moves hawkboard to the new spl infrastructure from the older nand_spl one. Removed the hawkboard_nand_config build option -- The spl code now gets compiled with hawkboard_config, after building the main u-boot image, using the CONFIG_SPL_TEXT_BASE. Modified the README.hawkboard to reflect the same. Signed-off-by: Sughosh Ganu <urwithsughosh@gmail.com> Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com> Cc: Tom Rini <trini@ti.com> Acked-by: Christian Riesch <christian.riesch@omicron.at>
2012-02-12arm, arm926ejs: Add option CONFIG_SYS_EXCEPTION_VECTORS_HIGHChristian Riesch
The V bit of the c1 register of CP15 should not be cleared on DA850 SoCs since they have no valid memory at 0x00000000. This patch introduces a configuration option CONFIG_SYS_EXCEPTION_VECTORS_HIGH that allows setting the correct value for the V bit. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Reported-by: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Sughosh Ganu <urwithsughosh@gmail.com> Cc: Heiko Schocher <hs@denx.de>
2012-02-12arm, arm926ejs: Do cpu critical inits only for boards that require itChristian Riesch
This patch reverts commit ca4b55800ed74207c35271bf7335a092d4955416 "arm, arm926ejs: always do cpu critical inits" since it impacts all arm926ejs based configurations and caused problems, e.g., with the hawkboard. Instead the patch removes the CONFIG_SKIP_LOWLEVEL_INIT defines from the board configurations that need low level initialization. Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com> Cc: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de> Tested-by: Heiko Schocher <hs@denx.de>
2012-02-12davinci: add support for printing clock frequencyHadli, Manjunath
add support for printing various clock frequency info found in SOC such as ARM core frequency, DSP core frequency and DDR frequency as part of bdinfo command. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com>
2012-02-12davinci: remove macro CONFIG_DISPLAY_CPUINFOHadli, Manjunath
remove the macro CONFIG_DISPLAY_CPUINFO as it is no longer required. This is because clock info will be printed as part 'bdinfo' command and also remove support print_cpuinfo() as it will no longer be called. Signed-off-by: Manjunath Hadli <manjunath.hadli@ti.com> Cc: Tom Rini <trini@ti.com>
2012-02-12mcx: support for HTKW mcx boardIlya Yanok
This patch adds support for the HTKW mcx AM3517-based board. Serial, Ethernet, NAND, MMC, RTC, EHCI USB host and both NAND and MMC SPLs are supported. Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <tom.rini@gmail.com> Cc: Detlev Zundel <dzu@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-02-12ARM: omap3: Added Teejet mt_ventouxStefano Babic
The mt_ventoux board is a custom board using the Technexion TAM3517 module. The patch fixes also the mtdparts variable in the TAM3517 common configuration file. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Ilya Yanok <yanok@emcraft.com> CC: Igor Grinberg <grinberg@compulab.co.il> CC: Tom Rini <tom.rini@gmail.com> Cc: Detlev Zundel <dzu@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-02-12OMAP3: TAM3517: update ehci interfaceStefano Babic
Changed the EHCI interface using the ulpi framework. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Tom Rini <tom.rini@gmail.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2012-02-12OMAP4: ehci-omap: enable ehci-omap for panda boardsGovindraj.R
For panda initialise the mux pins for ehci usage and enable ehci in omap4_panda config file. Signed-off-by: Govindraj.R <govindraj.raja@ti.com> Tested-by: Stefano Babic <sbabic@denx.de>
2012-02-12ehci-omap: driver for EHCI host on OMAP3Ilya Yanok
Taken from Beagle code. Tested on mcx board (AM3517-based). Signed-off-by: Ilya Yanok <yanok@emcraft.com> Tested-by: Stefano Babic <sbabic@denx.de>
2012-02-12usb: ulpi: Add omap-ulpi-view port supportGovindraj.R
Based on discussion from this thread [1]. Adding omap-view port that helps us in using the generic ulpi framework for any ulpi phy ops using the INSNREG05_ULPI viewport reg available on omap platform. Currently ehci ports are available on omap3/4 platforms so enable the same for beagle and panda, patch is tested on the same boards. Thanks to Igor Grinberg <grinberg@compulab.co.il> for reviewing the omap-ehci patches and suggesting this approach. [1]: http://www.mail-archive.com/u-boot@lists.denx.de/msg76076.html Tested-by: Stefano Babic <sbabic@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Govindraj.R <govindraj.raja@ti.com>
2012-02-12SMDK5250: Add ethernet supportChander Kashyap
This patch enable support for SMC911X based ethernet device. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2012-02-12EXYNOS: SMDK5250: Add MMC SPL supportChander Kashyap
This patch adds support for MMC SPL booting. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
