path: root/include/configs
2009-07-14Miscellaneous fixes for Sequoia board2009.06-sequoia-200907141924Justin Waters
There are a number of issues when building the Sequoia U-Boot with Timesys toolchains. * GCC 4.3.3 builds an image that is too large * 64-bit cross-toolchains run into interesting linking errors * abort is not defined for the toolchain when using GCC 4.3.3 This patch addresses these issues in various ways, allowing builds using the newer toolchains.
2009-06-1285xx: Add PIB support at CS4/CS5 for MPC8569MDSHaiying Wang
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Yu Liu <Yu.Liu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-1285xx: Fix some settings for MPC8569MDS boardHaiying Wang
- Increase the size of malloc to 512KB because MPC8569MDS needs more memory for malloc to support up to eight Ethernet interfaces. - Move Environment address out of uboot thus the saved environment variables will not be erased after u-boot is re-programmed. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-11Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
2009-06-10rmu board: fix error: 'CONFIG_ENV_SECT_SIZE' undeclaredWolfgang Denk
2009-06-09TQM85xx: minor config file cleanupWolfgang Denk
Remove "saveenv" from "update" definition: the environment is outside the U-Boot image on TQM85xx and therefor not affected by updates. Also "beautify" code a bit (vertical alignment). Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-09TQM85xx: adapt for new flash typesWolfgang Denk
Old TQM85xx boards had 'M' type Spansion Flashes from the S29GLxxxM series while new boards have 'N' type Flashes from the S29GLxxxN series, which have bigger sectors: 2 x 128 instead of 2 x 64 KB. We now change the configuration to the new flash types for all boards; this also works on old boards - we just waste two flash sectors for the environment which could be smaller there. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-0985xx: Fix the wrong SYS_CLK_IN for 8569MDSDave Liu
The SYS_CLK_IN of MPC8569MDS is 66.66MHz, The DDR_CLK_IN is same with SYS_CLK_IN in 8569 processor. so, change the SYS_CLK_IN from 66MHz to 66.66MHz. Signed-off-by: Dave Liu <daveliu@freescale.com>
2009-06-08Add config option for disabling DM9000-SROM support.Remy Bohmer
Some boards do not have SROM support for the DM9000 network adapter. Instead of listing these board names in the driver code, make this option configurable from the board config file. It also removes a build warning for the at91sam9261ek board: 'dm9000x.c:545: warning: 'read_srom_word' defined but not used' And it repaires the trizepsiv board build which was broken around the same routines Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-08mpc83xx: don't set SICRH_TSOBI1 to RMII/RTBI operationKim Phillips
In GMII mode (which operates at 3.3V) both SICRH TSEC1/2 output buffer impedance bits should be clear, i.e., SICRH[TSIOB1] = 0 and SICRH[TSIOB2] = 0. SICRH[TSIOB1] was erroneously being set high. U-Boot always operated this PHY interface in GMII mode. It is assumed this was missed in the clean up by the original board porters, and copied along to the TQM and sbc boards. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Ira Snyder <iws@ovro.caltech.edu> Reviewed-by: David Hawkins <dwh@ovro.caltech.edu> Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com> CC: Dave Liu <DaveLiu@freescale.com>
2009-05-25Blackfin: bf518f-ezbrd: setup portmux for async flashGraf Yang
The pins for async memory where parallel flash lives are not enabled by default, so make sure we mux them as needed. Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-05-20TQM834x: remove defines causing gcc4.4 warningsKim Phillips
Configuring for TQM834x board... cpu_init.c: In function 'cpu_init_f': cpu_init.c:262: warning: array subscript is above array bounds cpu_init.c:263: warning: array subscript is above array bounds cpu_init.c:270: warning: array subscript is above array bounds ... Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-05-15Fix OneNAND ipl to read CONFIG_SYS_MONITOR_LENRohit Hagargundgi
Add CONFIG_SYS_MONITOR_LEN macro to apollon board config. CONFIG_SYS_MONITOR_LEN defines the U-Boot image size. and is used by OneNAND ipl when reading U-Boot image. Signed-off-by: Rohit Hagargundgi <h.rohit at samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
2009-05-15powerpc/inka4x0: Remove left-over ide reset code.Detlev Zundel
The pin which was used in preliminary versions of the board for ide reset is really connected to the rtc clock. Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-05-06Blackfin: bf527-ezkit: fix SPI flash env paramsMike Frysinger
The BF527-EZKIT settings for storing the environment in SPI flash wasn't using the correct sector settings for the SPI flash part that is actually on the board. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-04-30OMAP3: Fix timer handling to 1ms and CONFIG_SYS_HZ to 1000Manikandan Pillai
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com> Signed-off-by: Manikandan Pillai <mani.pillai@ti.com>
2009-04-30Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-04-29arm925t: Fix CONFIG_SYS_HZ to 1000Ladislav Michl
Let CONFIG_SYS_HZ to have value of 1000 effectively fixing all users of get_timer. Changes since original version: * Set PTV=2 (divisor 8) for boards using 12MHz timer clock source to improve timer resolution. Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2009-04-29OMAP3: Remove legacy NAND definesDirk Behme
Remove remaining legacy NAND defines for Beagle, EVM, Overo and Pandora. Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-04-29OMAP3: Use functions print_cpuinfo() and checkboard()Sanjeev Premi
Use the functions print_cpuinfo() and checkboard() to display the cpu and board specific information. These functions reuse content from the existing function display_board_info() - which has been removed. Also, updated the existig OMAP3 configurations to define: - CONFIG_DISPLAY_CPUINFO - CONFIG_DISPLAY_BOARDINFO Signed-off-by: Sanjeev Premi <premi@ti.com>
2009-04-28ids8247: Remove legacy NAND definesHeiko Schocher
because legacy NAND support is deprecated converting to current NAND interface. !This just compile, because I have no more the hardware to test it. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-04-28mips/vcth: Use generic 16550 uart driverDetlev Zundel
As the common code also handles baudrate switching, which the board specific vct.c driver did not support, this is one of the rare occassions where deleting code actually adds a feature :) Signed-off-by: Detlev Zundel <dzu@denx.de> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
2009-04-28AmigaOneG3SE: Fix CONFIG_CMD_CONSOLE definitionPeter Tyser
2009-04-27Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
2009-04-26OMAP3: Fix changed mmc init commandDirk Behme
In recent U-Boot mmcinit changed to mmc init. Signed-off-by: Steve Sakoman <steve@sakoman.com> Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
2009-04-24minor DaVinci clock cleanupDavid Brownell
Minor cleanup to clock-related defines for DaVinci DM6446 boards: - CONFIG_SYS_CLK_FREQ is unused; remove it. - CONFIG_SYS_NS16550_CLK must be the same as CONFIG_SYS_HZ_CLOCK On DM6446 both of those peripheral clocks actually come from the same source, the primary oscillator. Having them use the same symbol avoids bugs in the clone'n'modify development cycle. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-04-24Merge branch 'master' of git://git.denx.de/u-boot-at91Wolfgang Denk
2009-04-23mpc83xx: MPC8360ERDK: fix environment offset configuration bugAnatolij Gustschin
The size of U-Boot binary for MPC8360ERDK increased (> 2 flash sectors now), so 'saveenv' will partially overwrite U-Boot in flash and will brick the board. This patch moves environment offset to fourth flash sector and also fixes CONFIG_SYS_MONITOR_LEN. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-04-16fix DaVinci NS16550_REG_SIZE regressionDavid Brownell
Update the DaVinci DM6446 boards to use the new convention for CONFIG_SYS_NS16550_REG_SIZE ... the size hasn't changed from the original 4 bytes, but these chips are little-endian. (Resolves a regression added recently by the include/ns16550.h patch to "Unify structure declaration for registers". The code previously worked just fine because the registers were accessed as host-endian words, not as bytes.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
2009-04-16at91sam9/at91cap: fix CONFIG_SYS_HZ to 1000Jean-Christophe PLAGNIOL-VILLARD
The timer has been rewrote with a precision at ~0,18% Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Tested-by: Sergey Lapin <slapin@ossfans.org> Tested-by: Eric BENARD <ebenard@free.fr>
2009-04-16at91: add support for the PM9263 board of Ronetix GmbHIlko Iliev
The PM9263 board is based on the AT91SAM9263-EK board. Here is the page on Ronetix website: http://www.ronetix.at/starter_kit_9263.html Signed-off-by: Ilko Iliev <iliev@ronetix.at> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-16at91sam9/at91cap: improve clock frameworkJean-Christophe PLAGNIOL-VILLARD
calculate dynamically the clock rate and pllb setting for usb Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-16ppc4xx: Disable POST memory test on NAND-booting KilaueaStefan Roese
Don't run the memory POST on the NAND-booting version. It will overwrite part of the U-Boot image which is already loaded from NAND to SDRAM. We were just lucky that it booted at all with this SDRAM test enabled. Signed-off-by: Stefan Roese <sr@denx.de>
2009-04-16ppc4xx: Disable POST memory test on NAND-booting SequoiaStefan Roese
2009-04-05Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2009-04-05integratorap: fix PCI supportJean-Christophe PLAGNIOL-VILLARD
2009-04-05arm: clean cache managementJean-Christophe PLAGNIOL-VILLARD
unify arm cache management except for non standard cache as ARM7TDMI Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-05ZOOM1 Remove legacy NAND definesTom Rix
Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
2009-04-05Update CHANGELOG, coding style cleanup.Wolfgang Denk
2009-04-04MPC8260ADS: Add nfsboot/ramboot to default environment.Scott Wood
This brings it in line with other Freescale boards. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-04-04at91sam9263ek: enable hush and auto complete supportJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Stelian Pop <stelian@popies.net>
2009-04-04at91: move dataflash spi driver to drivers/spiJean-Christophe PLAGNIOL-VILLARD
2009-04-04at91: move usb driver to drivers/usbJean-Christophe PLAGNIOL-VILLARD
2009-04-04at91rm9200: move serial driver to drivers/serialJean-Christophe PLAGNIOL-VILLARD
add CONFIG_AT91RM9200_USART to activate the driver Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-04Add support for the AT91RM9200EK Board.Ulf Samuelsson
The AT91RM9200-EK Evaluation Board supports the AT91RM9200 ARM9-based 32-bit RISC microcontroller and enables real-time code development and evaluation. Here is the chip page on Atmel website: http://www.atmel.com/dyn/products/tools_card.asp?tool_id=3507 with - NOR (cfi driver) - DataFlash - USB OHCI - Net - I2C (hard) Signed-off-by: Ulf Samuelsson <ulf@atmel.com> Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-04-04MPC8260ADS: Define CONFIG_HAS_ETH0.Scott Wood
This is required so that the MAC address will be updated in the device tree. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-04-04PQ2FADS: Enable PCI.Scott Wood
PCI on PQ2FADS is very similar to PCI on MPC8272ADS. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-04-03Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
2009-04-03Add "source" command; prepare removal of "autoscr" commandWolfgang Denk
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now. This patch prepares this change and starts a 6 month transition period as follows: - The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed resp. removed in a separate patch when the support for the "autoscr" command get's finally dropped. Signed-off-by: Wolfgang Denk <wd@denx.de>
