Receive DHCP configuration before running tftp command for fetching
proper dtb. When `run nfsboot` is invoked before DHCP configuration
is received, the booting process is stuck on:
Colibri iMX6 # run nfsboot
Booting via DHCP/TFTP/NFS...
Using FEC device
TFTP from server 192.168.10.1; our IP address is 192.168.10.2
Filename '---.dtb'.
Load address: 0x12100000
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Using FEC device
Filename '---.dtb'.
Using FEC device
Filename '---.dtb'.
Using FEC device
Filename '---.dtb'.
Remove video=tegrafb0:640x480-16@60 aka VESA VGA mode from vidargs in
order for the panel specification in the device tree to be used. This
causes the default to be the 10.1" LVDS display which will be available
in the Toradex webshop shortly.
Commit 2196085dc58e ("colibri_imx7_emmc: add configuration for tezi")
also enabled FDT relocation, however, this is causing the Linux kernel
to freeze if the M4 firmware was previously started from within U-Boot.
Commit 66200a6d2d ("colibri_imx7: add configuration for tezi") also
enabled FDT relocation, however, this is causing the Linux kernel to
Increasing PHY_ANEG_TIMEOUT from the default 4000 to 10000.
Acked-by: Philippe Schenker <philippe.schenker@toradex.com>
The whole thing meanwhile diverged heavily. Fix this.
Currently, the Colibri T20 sdboot variable tries to load the kernel from
the second MMC/SD device instance. However, given the Colibri T20 having
on-module NAND flash the MMC/SD card is actually the primary instance.
Fix this to load the kernel and device tree from the first (typically
FAT) partition of the MMC/SD card as customary on all Toradex modules.
This reverts commit cb4e847cbfe791a4093b0dec7b7467df4406f845.
We had some issues with USB2.0 devices when using OTG,
reverting for now.
Currently Vybrids sdboot variable tries to load the kernel from /boot of
the root partition (typically second partition when using the sdcard
image). However, since we moved to flash the kernel in a separate UBI
volume, we no longer deploy the kernel/device tree to /boot, hence
sdboot does not work in its current state.
Load the kernel and device tree from the first (typically FAT) partition
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Currently $loadaddr and $fdt_addr_r point to the same address. This
might be not ideal for some distro boot scripts which make use of
$loadaddr after loading the device tree.
Make sure the two variables point to two different addresses. Moving
$loadaddr is not entirly trivial since it is defined in mx6_common.h.
Move $fdt_addr_r and $ramdisk_addr_r by 1MiB, which should be enough
for scripts.
Modify configuration for Tezi:
- Use distroboot by default
- Boot from external SD cards by default
- Disable USB PID from config block (otherwise recovery mode download
in U-Boot stage fails)
- Enable SDP in U-Boot
- Enable FDT relocation (in-place is causing issues with FIT images)
Modify configuration for Tezi unified recovery mode:
- Remove video output
- Currently only for recovery (no flash/eMMC support)
- Boot from external SD cards using distroboot first by default
- Enable SDP in SPL and U-Boot
Use the external SD interface for legacy SD update instead of eMMC.
Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
Tested on Colibri iMX7 1GB aka eMMC V1.1A
Change usb_port_owner_info to 3 in defargs to allow for USB 3.0
SuperSpeed functionality on USBO1 in host mode.
The white spaces after the zero string terminator are applied to
the following environment entry. This is not what was intended.
Remove the superfluous white spaces.
Switch to the generic compressed Kernel image type (zImage) instead of
the U-Boot specific uImage format.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
The i.MX 6UL/ULL feature a Cortex-A7 CPU which suppor the ARM
generic timer. This change makes use of the ARM generic timer in
U-Boot.
This is crucial to make the ARM generic timers usable in Linux since
timer_init() initalizes the system counter module, which is necessary
to use the generic timers CP15 registers.
Disabling ASPM fixes incompatibilities with some PCIe cards
It turns out that OpenSSL calls undefined instructions to detect
ARM capabilities at runtime (via SIGILL handler). This leads to
stack traces e.g. when logging in using SSH:
[ 877.464442] sshd (613): undefined instruction: pc=76ee2da8
Disable undefined instruction events since it is used as an
autodetecion mechanism.
Add DFU configuration which allows access to all MTD partitions.
Note that DFU is mostily suited for smaller image uploads e.g.
to update U-Boot but does not work well for large images such as
rootfs since DFU copies the whole image in a memory buffer first.
Let the kernel print some debug messages when a user program
crashes due to an exception.
Set the ver environment variable consistently in all modules.
Move the define form include/configs into the defconfig were
applicable and create a new minimal defconfig.
Add handling for the device tree for the Colibri iMX6ULL 512MB Wi-Fi / BT
Support the V1.2 hardware revision with the following pin muxing
changes:
Ddc_scl_pv4 and ddc_sda_pv5 previously used as Apalis GPIO3 and GPIO4
are now used as DDC pins.
Gen2_i2c_scl_pt5 and gen2_i2c_sda_pt6 previously used as DDC pins are
now used as USB power enable signals.
Usb_vbus_en0_pn4 and usb_vbus_en1_pn5 previously used as USB power
enable signals are now used as GPIO3 and GPIO4.
Additionally a new device tree file tegra124-apalis-v1.2-eval.dtb is
loaded on V1.2 and later modules and resp. USB power enable signals
activated.
Remove m4boot options not available on i.MX 6ULL.
Cleanup U-Boot environment settings.
This undefs CONFIG_ISO_PARTITION.
This removes NAND torture no longer needed after bringup.
Cleanup whitespace and unify order with colibri_imx7.h.
No functional change intended.
Remove/change two NAND releated configs. They are not used in the GPMI
driver and likely confuse readers.
Just like the following commit for distro boot also use the 2nd instance
for legacy sdboot:
colibri_imx7_emmc: distro boot from external SD card
93ef92091832128259ab342a314d0f3e844bb331
Finish the work started by the following commit:
apalis/colibri: fix and synchronize mount options
6ed47e0f143df1c80426edb3b705c87c443c27f7
Currently distro boot is only used for external media. Use mmc 1
which is the external SD card when booting using distro boot.
Store U-Boot environment in eMMC, before config block at the end of 1st
"boot sector".
Use proper emmc specific device tree and boot from eMMC by default
rather than from NAND aka ubi.
Clean-up config header file. Re-order boot commands.
The kernel does not know about rw,noatime. The string rw by itself
is valid, and to pass additional arguments rootflags=noatime can
be used. The kernel mounts ext3/ext4 file systems by default ro,
hence so far the kernel mounted the rootfs read-only. The init
manager systemd then remounts the rootfs after file system checking.
This makes sense and does not add measureable boot time. Let the
kernel explicitly mount ro on block device based rootfs.
The root mount flag noatime is only relevant when re-mounting
read-write, hence it needs to be present in /etc/fstab.
UBIFS used on raw NAND devices has no user space file checking,
hence there is no value to mount it in read-only first. Also mount
time for UBIFS is larger, and mounting first read-only and then
read-write has higher boot time (300ms, likely due to missing block
cache). Let the kernel explicitly mount rw on raw NAND based rootfs.
UBIFS has no atime support, hence no root mount flags needed.
This adds support for Colibri iMX7 Dual 1GB modules which come
with on-board eMMC storage (whereas the other Colibri iMX7
modules use raw NAND). A subselection (variant) for the
Colibri iMX7 target is used to maximize sharing.
The ISO partition support is mainly useful for CD drives which
are not really common in embedded space and in general anymore.
Removing ISO partition support saves 1.5kB and gets rid of the
somewhat confusing message when no partition table is present:
** First descriptor is NOT a primary desc on 0:1 **
