path: root/include/configs
2018-11-14Merge branch 'next'Tom Rini
This brings in the u-boot-net PR from Joe.
2018-11-07arm: zynq: Setup non zero SPL FIT load addressMichal Simek
Default setup is 0 which is incorrect place because it points to OCM which is allocated for SPL only in our case. Use address in DDR. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-11-05configs: net: convert DRIVER_TI_KEYSTONE_NET kconfigGrygorii Strashko
Convert DRIVER_TI_KEYSTONE_NET to Kconfig. Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
2018-11-02Merge tag 'arc-for-2018.11' of git://git.denx.de/u-boot-arcTom Rini
Just 2 non-functinal changes: 1. Rename of EMDK to EMSDP so it matches real marketing name 2. Add essential README for IoTDK
2018-11-01emdk->emsdp: Rename boardAlexey Brodkin
Real marketing name of the board was recently updated so to accommodate that change renaming the board and all related to it. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2018-11-01configs: at91: at91sam9x5ek: fix bootcmd for NAND flashEugen.Hristev@microchip.com
The default bootcommand needs to be accurate w.r.t the nand memory map at http://www.at91.com/linux4sam/bin/view/Linux4SAM/AT91sam9x5ekMainPage#NAND_Flash_demo_Memory_map Updated to load kernel + dtb at right offsets and boot the zImage. Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
2018-10-31arm: socfpga: Fix bootcounter located at the end of internal SRAMStefan Roese
Commit 768f23dc8ae3 ("ARM: socfpga: Put stack at the end of SRAM") broke those socfpga boards that keep the bootcounter at the end of the internal SRAM as the bootcounter needs 8 bytes by default and thus the very first SPL call to board_init_f_alloc_reserve overwrites the bootcounter. This patch allows to move the initial stack pointer down a bit by checking if CONFIG_SYS_BOOTCOUNT_ADDR is located in the internal SRAM area and then using this address as location for the start of the stack pointer. No new macros / defines are added by this approach. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Marek Vasut <marex@denx.de> Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2018-10-28x86: theadorable-x86: Generate and pass root=PARTUUID instead of /dev/sdaXStefan Roese
To enable the root device selection (kernel cmd-line) via PARTUUID, this patch enables CMD_PART on all missing theadorable-x86 boards and changes the default environment to generate the root=PARTUUID string automatically. This fixes problems that have been noticed on systems with multiple SATA/AHCI controller connected via PCIe, where the device name for the root device / partition (/dev/sdaX) was incorrect. Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-10-28x86: theadorable-x86-common: Change pci hotplug cmdline parameters (again)Stefan Roese
This is needed for the PCIe hotplug to work correctly on some boards with the newer Linux kernel versions. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2018-10-25Merge branch 'master' of git://git.denx.de/u-boot-netTom Rini
2018-10-25Merge tag 'u-boot-imx-20181025' of git://git.denx.de/u-boot-imxTom Rini
Merged imx8 architecture, fix build for imx8 + warnings
2018-10-24configs: migrate CONFIG_PHY_AQUANTIA to KconfigJeremy Gebben
The aquantia driver requires both CONFIG_PHY_GIGE and CONFIG_PHYLIB_10G. Signed-off-by: Jeremy Gebben <jgebben@sweptlaser.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2018-10-22ARM: omap3_logic: Add NOR Flash Support for SOM-LVAdam Ford
The DM37 and OMAP35 SOM-LV SOM-LV products both support a NOR flash part connected to CS2 in addition to the NAND part on CS0. This patch setups the GPMC timings for the MT28 NOR Flash and enables the CFI-Flash driver now that the CFI stuff is in Kconfig Signed-off-by: Adam Ford <aford173@gmail.com>
2018-10-22arm: udoo: Convert to distro configMeul, Dirk
Instead of keeping a custom environment, use a more generic approach by switching to distro config. Signed-off-by: Dirk Meul <dirk.meul@rwth-aachen.de> Reviewed-by: Fabio Estevam <festevam@gmail.com>
2018-10-22warp7: include: configs: set skip low level initRui Miguel Silva
If we have defined the OPTEE ram size and not OPTEE means that we are in the case where OPTEE is loaded already (maybe by ARM Trusted Firmware) and that most of the low level initialization is already done and that we may/should skip it doing them here. Signed-off-by: Rui Miguel Silva <rui.silva@linaro.org> Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: u-boot@lists.denx.de
2018-10-22Kconfig: Convert CONFIG_IMX_WATCHDOG to KconfigXiaoliang Yang
Move this option to Kconfig and tidy up the config file of eight boards which use it. Signed-off-by: Xiaoliang Yang <xiaoliang.yang_1@nxp.com>
2018-10-22imx: add i.MX8QXP MEK board supportPeng Fan
Add i.MX8QXP MEK board support Enabled pinctrl/clk/power-domain/mmc/i2c/fec driver. Added README file. Signed-off-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Anatolij Gustschin <agust@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com>
2018-10-19work_92105: remove unused CONFIG_SPL_NAND_BOOT configuration optionVladimir Zapolskiy
The option is unused, SPL image gets a wanted boot device by standard spl_boot_device() call. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2018-10-19work_92105: remove unused CONFIG_LPC32XX_SPL configuration optionVladimir Zapolskiy
The CONFIG_LPC32XX_SPL option from board include file has never been used, it is safe to remove it. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2018-10-18ARM: rmobile: Enable cache command on Gen3Hiroyuki Yokoyama
This patch enables the cache command, mostly for convenience of testing. Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2018-10-16arm64: versal: Add support for new Xilinx Versal ACAPsMichal Simek
Xilinx is introducing Versal, an adaptive compute acceleration platform (ACAP), built on 7nm FinFET process technology. Versal ACAPs combine Scalar Processing Engines, Adaptable Hardware Engines, and Intelligent Engines with leading-edge memory and interfacing technologies to deliver powerful heterogeneous acceleration for any application. The Versal AI Core series has five devices, offering 128 to 400 AI Engines. The series includes dual-core Arm Cortex™-A72 application processors, dual-core Arm Cortex-R5 real-time processors, 256KB of on-chip memory with ECC, more than 1,900 DSP engines optimized for high-precision floating point with low latency. The patch is adding necessary infrastructure in place without enabling platform which is done in separate patch. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-10-16arm: mx5: Add M53Menlo boardMarek Vasut
Add Menlosystems M53 board, based on the M53 SoM. This board has Ethernet, USB host, USB gadget, UART and LCD on it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2018-10-12Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
2018-10-10Merge tag 'dm-9oct18' of git://git.denx.de/u-boot-dmTom Rini
Test improvements to tidy up output and drop duplicate tests Sandbox SPL/TPL support Various dm-related improvements
2018-10-10ARM: meson: Add Khadas VIM2 board supportLoic Devulder
This adds platform code for the Khadas VIM2 board based on a Meson GXM (S912) SoC with the Meson GXM configuration. This initial submission supports UART, MMC/SDCard and Ethernet. USB is partially supported. All the code is from Neil Armstrong! I just rebased the code, do some cleanup and tested on my board. Signed-off-by: Neil Armstrong <narmstrong@baylibre.com> Signed-off-by: Loic Devulder <ldevulder@suse.de> Acked-by: Neil Armstrong <narmstrong@baylibre.com>
2018-10-10board: da8xxevm: Add SPL DM for serial, spiJagan Teki
This patch add SPL DM support for da8xxevm boards with SPL serial, SPI drivers supported via platdata. Cc: Adam Ford <aford173@gmail.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Adam Ford <aford173@gmail.com> #da850evm
2018-10-09configs: mx7: Remove CONFIG_DBG_MONITORFabio Estevam
Remove all CONFIG_DBG_MONITOR references as it is not used anywhere. Signed-off-by: Fabio Estevam <festevam@gmail.com>
2018-10-09colibri_imx7: prime get_ram_size() using imx_ddr_size()Fabio Estevam
Rather than passing a hardcoded maxsize to the generic get_ram_size() function use the i.MX 7 specific imx_ddr_size() function, which extracts the memory size at runtime by reading the DDR controller registers. This is a purely cosmetic change as the generic get_ram_size() function already took care of properly automatically detecting 256MB, 512MB or 1GB modules. Signed-off-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2018-10-09pico-imx6ul, pico-imx7d: Enable USB and PXE boot supportOtavio Salvador
This allow the use of a USB storage or PXE network booting as fallback, allowing for example for manufacturing installation of eMMC storage in an easy way. Reviewed-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-10-09pico-imx6ul, pico-imx7d: Use eMMC user partition by defaultOtavio Salvador
After discussing with TechNexion about how its default setting, it is better to install on the eMMC user partition by default, when using DFU, so it works out of box for majority of users. Reviewed-by: Fabio Estevam <festevam@gmail.com> Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
2018-10-09Kconfig: Convert CONFIG_RTC_MC146818 to KconfigSimon Glass
Move this option to Kconfig and tidy up the two boards which use it. Signed-off-by: Simon Glass <sjg@chromium.org>
2018-10-06ARM: LogicPD: omap3logic: Remove Torpedo/SOM-LV autodectionAdam Ford
With there now being four device tree files, and 4 separate defconfig files, the code necessary to determine which board is being used is no longer necessary as the corresponding pin-muxing and board names are determined by the device tree. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-10-06configs: drop CONFIG_SYS_EXTRA_ENV_RELOCSimon Goldschmidt
Instead of manually specifying CONFIG_SYS_EXTRA_ENV_RELOC for every board that needs it, it shouldn't hurt to let initr_reloc_global_data() always relocate gd->env_addr unless we know this pointer is outside the initial binary. To achieve this, the relocation is omitted if CONFIG_ENV_ADDR is defined (and ENV_IS_EMBEDDED is not). Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
2018-10-05Merge branch 'master' of git://git.denx.de/u-boot-shTom Rini
2018-10-05arc: Add support for IoT development kitAlexey Brodkin
The DesignWare ARC IoT Development Kit is a versatile platform that includes the necessary hardware and software to accelerate software development and debugging of sensor fusion, voice recognition and face detection designs. More information is avaialble here [1] and here [2]. The board is based on real silicon with ARC EM9D-based Data Fusion IP Subsystem. It sports a rich set of I/O including * DW USB OTG * DW MobileStorage (used for micro SD-card) * GPIO * multiple serial interface including DW APB UART * ADC, PWM and eFlash, SRAM and SPI Flash memory * Real-Time Clock (RTC) * Bluetooth module with worldwide regulatory compliance (FCC, IC, CE, ETSI, TELEC) * On-board 9-axis sensor (gyro, accelerometer and compass) Extensible with Arduino, Pmod, mikroBUS connectors and a 2x18 extension header. One of the most interesting features for developers is built-in Digilent USB JTAG probe so only micro-USB cable is needed! [1] https://www.synopsys.com/dw/ipdir.php?ds=arc_iot_development_kit [2] https://www.synopsys.com/dw/doc.php/ds/cc/iot_dev_kit.pdf Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
2018-10-03ARM: rmobile: Repair TMU clock on Gen2Marek Vasut
The CPfi/4 is derived from XTAL clock and is not fixed. Undo the previous commit 7984ac8d1635aebd11175c96b07f937a39f0384d. Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
2018-10-03riscv: Add QEMU virt board supportBin Meng
This adds QEMU RISC-V 'virt' board target support, with the hope of helping people easily test U-Boot on RISC-V. The QEMU virt machine models a generic RISC-V virtual machine with support for the VirtIO standard networking and block storage devices. It has CLINT, PLIC, 16550A UART devices in addition to VirtIO and it also uses device-tree to pass configuration information to guest software. It implements RISC-V privileged architecture spec v1.10. Both 32-bit and 64-bit builds are supported. Support is pretty much preliminary, only booting to U-Boot shell with the UART driver on a single core. Booting Linux is not supported yet. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Lukas Auer <lukas.auer@aisec.fraunhofer.de>
2018-10-02Merge branch 'master' of git://git.denx.de/u-boot-spiTom Rini
This is the PR for SPI-NAND changes along with few spi changes. [trini: Re-sync changes for ls1012afrwy_qspi*_defconfig] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-09-29Merge tag 'fsl-qoriq-for-v2018.11-rc1' of git://git.denx.de/u-boot-fsl-qoriqTom Rini
Switch to driver model for eSDHC on Layerscape SoCs including LS1021A, LS1043A, LS1046A, LS1088A, LS2088A. Switch to driver model for SATA on LS1021A and LS1043A. Add support for LS1012AFRWY rev C board. Enable SMMU for LS1043A.
2018-09-29ARM: da850evm_direct_nor_defconfig: Enable DM_SERIALAdam Ford
With DM enabled, this patch enables DM_SERIAL and removes the NS16550 initialization from da850_lowlevel since the driver will take care of that itself. Signed-off-by: Adam Ford <aford173@gmail.com>
2018-09-27drivers: qe: Move CONFIG_U_QE to KconfigRan Wang
Signed-off-by: Ran Wang <ran.wang_1@nxp.com> [York S: revised subject line and removed commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2018-09-27ls2080ardb: remove dhcp function from env as boot sourcePriyanka Jain
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-09-27ls1088a: remove dhcp function from u-boot env as boot sourcePramod Kumar
Signed-off-by: Pramod Kumar <pramod.kumar_1@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2018-09-27ls1012afrwy: Add ls1012afrwy revC board support.Pramod Kumar
LS1012AFRWY supports three board revisions. Revision A and B board are collectively identified as revA/B, Revision C board is identifies as revC. Signed-off-by: Pramod Kumar <pramod.kumar_1@nxp.com> [York S: revised commit message] Reviewed-by: York Sun <york.sun@nxp.com>
2018-09-27Merge tag 'xilinx-for-v2018.11' of git://git.denx.de/u-boot-microblazeTom Rini
Xilinx changes for v2018.11 - Handle BOARD_LATE_INIT via Kconfig SPL: - Enable GZIP for all partitions types(not only for kernel) ZynqMP: - Rearrange pmufw version handling - Support newer PMUFW with improved fpga load sequence Zynq: - Cleanup config file - Simplify zybo config by enabling option via Kconfig net: - Fix gems max-speed property reading - Enable support for fixed-link phys
2018-09-26Merge tag 'signed-efi-next' of git://github.com/agraf/u-bootTom Rini
Patch queue for efi - 2018-09-26 A lot of goodness in this release. We're *very* close to running the UEFI Shell and SCT natively. The only missing piece are HII protocols. - FAT write support (needed for SCT) - improved FAT directory support (needed for SCT) - RTC support with QEMU -M virt - Sandbox support (run UEFI binaries in Linux - yay) - Proper UTF-16 support - EFI_UNICODE_COLLATION_PROTOCOL support (for UEFI Shell) - EFI_SIMPLE_TEXT_INPUT_EX_PROTOCOL support (for UEFI Shell) - Fix window size determination - Fix Tegra by explicitly unmapping RAM - Clean up handle entanglement - Lots of generic code cleanup [trini: Fixup merge conflict in include/configs/qemu-arm.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-09-26arm: zynq: zybo: migrate CONFIG_DISPLAY to defconfigLuis Araneda
Only add CONFIG_DISPLAY to defconfig because CONFIG_I2C_EDID is automatically selected by CONFIG_DISPLAY Signed-off-by: Luis Araneda <luaraneda@gmail.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2018-09-26arm: zynq: Remove useless comments from config fileMichal Simek
Moving options to Kconfig some comments are useless now. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
