Some users might want to modify 'bootcmd' at compile-time by editing
include/configs/uniphier.h, but overwriting it at run-time makes it
impossible.
Instead, set 'bootdev' at run-time, which contains the boot device the
system is booting from, then indirectly reference it from 'bootcmd'.
It is up to users whether to override 'bootcmd'.
Fix typo: neede -> needed
Signed-off-by: Weijie Gao <weijie.gao@mediatek.com>
OMAP3_GPIO_x is needed to enable each GPIO bank on the OMAP3
boards. At one point, the #ifdef's were replaced with
if CONFIG_IS_ENABLED but this won't work for people who need
OMAP3_GPIO_x in SPL since the SPL prefix for this option isn't
used in Kconfig. This patch moves the check to #if defined and
also makes Kconfig select the banks if CMD_GPIO is used which
makes the checks in the code less cumbersome.
Fixes: bd8a9c14c91c ("arm: mach-omap2/omap3/clock.c: Enable
all GPIO with CMD_GPIO")
Reported-by: Liam O'Shaughnessy <liam.o.shaughnessy@gumstix.com>
[trini: Migrate omap3_igep00x0.h]
- Fix breakage in helios4: Change U-Boot offset on SPI Flash
- Enable CONFIG_BLK for db-88f6820-amc
SPI flash support on Helios4 [1] has been merge to u-boot/master on
commit 8cb8c0c6a83bef ("Merge git://git.denx.de/u-boot-marvell")
However, the SPI image build failed after the merge with following
message:
COPY spl/u-boot-spl.bin
MKIMAGE u-boot-spl.kwb
Error: Image header (incl. SPL image) too big!
header=0x20816 CONFIG_SYS_U_BOOT_OFFS=0x20000!
Increase CONFIG_SYS_U_BOOT_OFFS!
Could not create image
Makefile:1162: recipe for target 'u-boot-spl.kwb' failed
make: *** [u-boot-spl.kwb] Error 1
Let's increase the u-boot offset to 0x30000 to accommodate SPL changes
and leave some margin for future changes.
[1] https://patchwork.ozlabs.org/patch/1007762/
Signed-off-by: Aditya Prayoga <aditya@kobol.io>
Add support for the Creator CI20 platform based on the JZ4780 SoC.
Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Signed-off-by: Ezequiel Garcia <ezequiel@collabora.com>
Adding the support for 2 boards sharing common code for Ocelot chip:
PCB120 and PCB123
Signed-off-by: Gregory CLEMENT <gregory.clement@bootlin.com>
Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Improvements and fixes or u-boot-rockchip:
- new board: adds rv1108-elgin-r1 board support
- rk3288-evb: dts: remove 'vmmc' from emmc node
- rk3399-puma: dts: remove obsolete DTS node 'vcc5v0_host'
Add the initial support for Elgin R1 board, which is based on the
RV1108 SoC and has the following features currently supported in
U-Boot:
- UART
- eMMC
- USB
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
DM_USB is now supported in the SPL. Do not undef it
Besides to support DM_USB in SPL, one now has to use SPL_DM_USB
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
The K2G evm uses the generic DWC3 driver. DFU can thus be enabled.
Enabling DFU for easier firmware update.
The keystone platforms can use the generic DC3 driver. Removing the
keystone-spcecific xchi driver and add the configuration options to enable
the generic DWC3 driver on all K2 platforms.
The serial driver in the kernel moved from ttyOx to ttySx a while
ago. This patch updates the console parameter to align with the
kernel change.
Currently on qemu-arm platforms environment is kept in RAM. Instead
use pflash device 1 to provide persistent environment support across
device reset.
Also (optionally) provide support for persistent environment across
qemu machine OFF/ON using following instructions:
- Create envstore.img using qemu-img:
qemu-img create -f raw envstore.img 64M
- Add a pflash drive parameter to the command line:
-drive if=pflash,format=raw,index=1,file=envstore.img
Signed-off-by: Sumit Garg <sumit.garg@linaro.org>
With -device virtio-blk-device,drive=hd0, it could detect distro boot
target.
Reviewed-by: Alexander Graf <agraf@suse.de>
Add TFA boot flow for some Layerscape platforms
Add support for lx2160a SoC
[trini: Add a bunch of missing MAINTAINERS entries]
DM_I2C_COMPAT is a compatibility layer that allows using the non-DM I2C
API when DM_I2C is used. The goal is to eventually remove DM_I2C_COMPAT
when all I2C "clients" have been migrated to use the DM API.
This a step in that direction for the TI based platforms.
Build tested with buildman:
buildman -dle am33xx ti omap3 omap4 omap5 davinci keystone
boot tested with:
am335x_evm, am335x_boneblack, am335x_boneblack_vboot (DM version),
am57xx_evm, dra7xx_evm, k2g_evm, am437x_evm
Remove the last call to the non-DM I2C API.
Also remove the #undef CONFIG_DM_I2C_COMPAT because it is not defined
in the common header file anymore.
Reviewed-by: Felix Brack <fb@ltec.ch>
Tested-by: Felix Brack <fb@ltec.ch>
Enable SPI flash support under U-Boot and SPL. The ENV size and offset,
ported from U-Boot 2013.01 Marvell version: 2015_T1.0p16
To create U-Boot image for SPI flash, user would need to replace
* CONFIG_MVEBU_SPL_BOOT_DEVICE_MMC with CONFIG_MVEBU_SPL_BOOT_DEVICE_SPI
* CONFIG_ENV_IS_IN_MMC with CONFIG_ENV_IS_IN_SPI_FLASH
Tested-By: Dennis Gilmore <dgilmore@redhat.com>
Reviewed-By: Dennis Gilmore <dgilmore@redhat.com>
Remove unused I2C support in SPL and use simple_malloc functions to
reduce SPL image size.
Since Helios4 does not have any PCIe allocated on SerDes, remove PCI
support. MTD layer on top of SPI flash is not needed, remove it also.
Store the environment before 1M into the block device.
This constant is easier to remember, saves a little space,
and is in line with what SolidRun's 2018.01-based fork does for the
clearfog.
Signed-off-by: Josua Mayer <josua.mayer97@gmail.com>
[ Aditya Prayoga:
* Port forward]
Signed-off-by: Rajat Srivastava <rajat.srivastava@nxp.com>
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
ls1088ardb-pb and ls1088ardb both boards are ls1088a based soc,
board type detection is dynamic at boot time
Signed-off-by: Pramod Kumar <pramod.kumar_1@nxp.com>
TFABOOT support includes:
- ls1012a2g5rdb/ls1012afrdm/ls1012afrwy_tfa_defconfig to be
loaded by trusted firmware
- define BOOTCOMMAND for TFABOOT
Signed-off-by: Pankit Garg <pankit.garg@nxp.com>
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
[YS: remove unnecessary braces]
Includes environment.h file in ls1012aqds.c Also, enables
pfe validation
Signed-off-by: Vinitha V Pillai <vinitha.pillai@nxp.com>
- ls1012ardb_tfa_defconfig to be loaded by trusted firmware
- environment address and size changes for TFABOOT
- enable PFE validation for secure boot
- ls1043aqds_tfa_defconfig to be loaded by trusted firmware
- ls1043ardb_tfa_defconfig to be loaded by trusted firmware
- FMAN and QE address changes for TFABOOT
- ls1046aqds_tfa_defconfig to be loaded by trusted firmware
- FMAN address changes for TFABOOT
- ls1046ardb_tfa_defconfig to be loaded by trusted firmware
Signed-off-by: York Sun <york.sun@nxp.com>
Replaces __ilog2 function call with LOG2 macro, required to
use macros in global variables.
Also, corrects the value passed in LOG2 for some PowerPC
platforms. Minimum value that can be configured is is 64K
for IFC IP.
[YS: fix white space around operator]
Rock960 is a family of boards based on Rockchip RK3399 SoC from Vamrs.
It consists of Rock960 (Consumer Edition) and Ficus (Enterprise Edition)
96Boards.
Below are some of the key differences between both Rock960 and Ficus
boards:
1. Different host enable GPIO for USB
2. Different power and reset GPIO for PCI-E
3. No Ethernet port on Rock960
The common board support will be utilized by both boards. The device
tree has been organized in such a way that only the properties which
differ between both boards are placed in the board specific dts and
the reset of the nodes are placed in common dtsi file.
Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
[Added instructions for SD card boot]
Tested-by: Peter Robinson <pbrobinson@gmail.com>
- Various MTD fixes from Boris
- Zap various unused / legacy paths.
- pxa3xx NAND update from Miquel
Convert all Renesas R-Car boards to bootm_size of 256 MiB and drop both
fdt_high and initrd_high. This change implies that the FDT and initrd
will always be copied into the first 256 MiB of RAM instead of being
used in place, which can cause various kinds of inobvious problems.
The simpler problems include FDT or initrd being overwritten or being
used from unaligned addresses, especially on ARM64. The overhead of
copying the FDT to aligned location is negligible and these problems
go away, so the benefit is significant.
Regarding alignment problems with fitImage. The alignment of DT properties
is always 32 bits, which implies that the alignment of the "data" property
in fitImage is also 32 bits. The /incbin/ syntax plays no role here. The
kernel expects all elements, including DT and initrd, to be aligned to
64 bits on ARM64, thus using them in place may not be possible. Using the
bootm_size assures correct alignment, again with negligible overhead.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Xilinx changes for v2019.01
microblaze:
- Use default functions for memory decoding
- Showing model from DT
zynq:
- Fix spi flash DTs
- Fix zynq_help_text with CONFIG_SYS_LONGHELP
- Tune cse/mini configurations
- Enabling cse/mini testing with current targets
zynqmp:
- Enable gzip SPL support
- Fix chip detection logic
- Tune mini configurations
- DT fixes(spi-flash, models, clocks, etc)
- Add support for OF_SEPARATE configurations
- Enabling mini testing with current targets
- Add mini mtest configuration
- Some minor config setting
nand:
- arasan: Add subpage configuration
net:
- gem: Add 64bit DMA support
Patch queue for rpi - 2018-12-03
A few Raspberry Pi specific changes this time:
- Allow 2nd MMC device
- Support RPi 3 Model A+
- Allow UUID to find filesystem
This patch moves the RTC M41T62 config define to Kconfig.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Remove CONFIG_PHY_ATHEROS and CONFIG_PHY_SMSC from defconfig
and select them in Kconfig.
Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com>
Also get rid of CONFIG_SYS_NAND_SPL_KERNEL_OFFS as SPL_OS_BOOT
feature won't be used.
Created a new header file for zcu104 RevC board and added below
configurations to use MAC address from EEPROM.
CONFIG_ZYNQ_GEM_EEPROM_ADDR
CONFIG_ZYNQ_EEPROM_BUS
Added CONFIG_ZYNQ_GEM_I2C_MAC_OFFSET=0x20 to
xilinx_zynqmp_zcu104_revC_defconfig
Signed-off-by: T Karthik Reddy <t.karthik.reddy@xilinx.com>
Signed-off-by: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com>
On v2 boards that will hit real stock we'll have 16 Mb of RAM.
Note on v1 boards (if anybody ever get one out of trash bin)
this leads to U-Boot execution freeze in the middle ofthe relocation
so don't be surprised.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
When booting with the rpi-firmware "mmc" overlay that disable
the SDHOST controller and use the SDHCI one for the sd card,
mmc 1 because a viable boot target.
Add it to the list
Signed-off-by: Oleksandr Tymoshenko <gonzo@FreeBSD.org>
Signed-off-by: Emmanuel Vadot <manu@freebsd.org>
Improvements:
- RK3188 USB-UART functionality
- errors triggering a hard-stop in SPL on the RK3399 are reported
- Rockchip RV1108 (SoC) support
- MicroCrystal RV3029 (RTC) DM driver
Fixes:
- RK3188 early UART setup
- limit SD-card frequency to 40MHz on the RK3399-Q7
- MIPI fixes
- RK3399 CPUB clock initialisation
This allow easier integration of RV1108 based boards on generic
distributions and build systems.
To avoid behavior change, we make evb-rv1108 to use the existing
environment as it boots from its SPI NOR.
In order to be able to build the Rockchip eMMC driver on rv1108, the
BOUNCE_BUFFER option needs to be selected. Select it like it is done
on the other Rockchip SoC common files.
Reviewed-by: Andy Yan <andy.yan@rock-chips.com>
Enable CONFIG_DM_SPI=y and CONFIG_DM_SPI_FLASH=y in the defconfig.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
Cleanup and update towards support for Amlogic Meson AXG SoCs :
- mmc: meson-gx: Add AXG compatible
- net: designware: add meson meson compatibles
- Amlogic Meson cleanup for AXG SoC support
No reason to save additional variables to environment for mini
configurations.
