This patch fixes a problem introdiced with patch
bbeff30c [ppc4xx: Remove superfluous dram_init() call or replace it by
initdram()].
The boards affected are:
- PCI405
- PPChameleonEVB
- quad100hd
- taihu
- zeus
Also set up the port pins for using I2C.
Pantelis Antoniou stated:
AFAIK, it is still used but the products using PPC are long gone.
Nuke it plz (from orbit).
So remove it since it cleans up a usage of env_get_char outside of
the environment code.
Signed-off-by: Andreas Engel <andreas.engel@ericsson.com>
Attempt to bring i386 / sc520 inline with master
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
This patch adds Lime GDC support together with support for the PWM
backlight control through the w83782d chip. The reset pin of the
latter is attached to GPIO, so we need to reset it in
early_board_init_r.
- Update the local bus ranges in the FDT for Linux for the various
devices connected to the local bus via chip-select.
- Set the LCRR_DBYP bit in the LCRR for local bus frequencies
lower than 66 MHz and uses I/O accessor functions consequently.
- UPM data update.
- Update of default environment and configuration. Use I2C multibus
as we do have two I2C buses. Also enable sdram and ext2 commands.
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
Signed-off-by: Detlev Zundel <dzu@denx.de>
The new sys_eeprom.c supports both the old CCID EEPROM format and the new NXID
format, and so it obsoletes board/freescale/common/cds_eeprom.c. Freescale
86xx boards already use sys_eeprom.c, so this patch migrates the remaining
Freescale 85xx boards to use it as well. cds_eeprom.c is deleted.
This patch add FDT support and command line editing capabilities
for CPCI405 and CPCI405AB boards.
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Since this define is only used on one board that was never really in
production, removing this compile time option doesn't hurt and makes
the code more readable.
Some of multi-function USB controllers (e.g. ISP1562) allow root hub
resetting only via EHCI registers. So, this patch adds the
corresponding kind of reset to OHCI's hc_reset() if the newly
introduced CONFIG_PCI_EHCI_DEVNO option is set (e.g. for Socrates
board).
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Acked-by: Markus Klotzbuecher <mk@denx.de>
Signed-off-by: Adam Graham <agraham@amcc.com>
This patch provides an unificated way of handling xilinx v5 ppc440 boards.
It unificates 3 different things:
1) Source code
A new board called ppc440-generic has been created. This board includes
a generic tlb initialization (Maps the whole memory into virtual) and
defines board_pre_init, checkboard, initdram and get_sys_info weakly,
so, they can be replaced by specific functions.
If a new board needs to redefine any of the previous functions
(specific initialization) it can create a new directory with the
specific initializations needed. (see the example ml507 board).
2) Configuration file
Common configurations are located under configs/xilinx-ppc440.h, this
header file interpretes the xparameters file generated by EDK and
configurates u-boot in correspondence. Example: if there is a Temac,
allows CMD_CONFIG_NET
Specific configuration are located under specific configuration file.
3) Makefile
Some work has been done in order to not duplicate work in the Main
Makefile. Please see the attached code.
In order to support new boards they can be implemented in the next way:
a) Simple Generic Board (90% of the time)
Using EDK generates a new xparameters.h file, replace
ppc440-generic/xparameters.h and run make xilinx-ppc440-generic_config
&& make
b) Simple Boards with special u-boot parameters (9 % of the time)
Create a new file under configs for it (use ml507.h as example) and
change your paramaters. Create a new Makefile paragraph and compile
c) Complex boards (1% of the time)
Create a new folder for the board, like the ml507
Finally, it adds support for the Avnet FX30T Evaluation board, following
the new generic structure:
Cheap board by Avnet for evaluating the Virtex5 FX technology.
This patch adds support for:
- UartLite
- 16MB Flash
- 64MB RAM
Prior using U-boot in this board, read carefully the ERRATA by Avnet
to solve some memory initialization issues.
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es>
board/esd/dasa_sim/dasa_sim.c
- remove PCI code
- add command line editing
- minor cleanup
Signed-off-by: Matthias Fuchs <mf@esd.eu>
Wrap long lines etc.
This patch enables the PCI-OHCI controller on PLU405 board.
Also the default CPU frequency is updated to 266 MHz and
command line editing is enabled.
The 8544DS and 8572DS platforms support an optional SGMII riser card to
expose ethernet over an SGMII interface. Once the card is in, it is also
necessary to configure the board such that it uses the card, rather than
the on-board ethernet ports. This can either be done by flipping dip switches
on the motherboard, or by modifying registers in the pixis. Either way
requires a reboot.
This adds a command to allow users to choose which ports are routed through
the SGMII card, and which through the onboard ports. It also allows users
to revert to the current switch settings.
This code does not work on the 8572, as the PIXIS is different.
Signed-off-by: Andy Fleming <afleming@freescale.com>
The 8544DS and 8572DS systems have an optional SGMII riser card which
exposes new ethernet ports which are connected to the eTSECs via an
SGMII interface. The SGMII PHYs for this board are offset from the standard
PHY addresses, so this code modifies the passed in tsec_info structure to
use the SGMII PHYs on the card, instead.
This boards used old type preprocessor.
This patch fix compile error.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
AP325RXA is SH7723's reference board.
This has SCIF, NOR Flash, Ethernet, USB host, LCDC, SD Host, Camera and other.
In this patch, support SCIF, NOR Flash, and Ethernet.
This adds initial support for the RTE RSK+ SH7203 board.
This board has SH7785, 512MB DDR2-SDRAM, NOR Flash,
Graphic, Ethernet, USB, SD, RTC, and I2C controller.
This patch supports the following functions:
- 128MB DDR2-SDRAM (29-bit address mode only)
- NOR Flash
- USB host
- Ethernet
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
Double bootargs setting leads to a duplicated environmant entry.
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
SMDK6400 can only boot U-Boot from NAND-flash. This patch adds a nand_spl
driver for it too. The board can also boot from the NOR flash, but due to
hardware limitations it can only address 64KiB on it, which is not enough
for U-Boot. Based on the original sources by Samsung for U-Boot 1.1.6.
This is needed since now with HUSH enabled (amcc-common.h) the image
read from NAND exceeds the previous limit.
MPC5121 rev 2 silicon has a new register for controlling how long
CS is asserted after deassertion of ALE in multiplexed mode.
The default is to assert CS together with ALE. The alternative
is to assert CS (ALEN+1)*LPC_CLK clocks after deassertion of ALE.
The default is wrong for the NOR flash and CPLD on the ADS5121.
This patch turns on the alternative for CS0 (NOR) and CS2 (CPLD)
it does so conditionally based on silicon rev 2.0 or greater.
Signed-off-by: Martha J Marx <mmarx@silicontkx.com>
Signed-off-by: John Rigby <jrigby@freescale.com>
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
Add FEC pin set and mii reset in __mii_init(). Change
legacy flash vendor from 2 to AMD LEGACY (0xFFF0),
change cfi_offset to 0, and change CFG_FLASH_CFI to
CONFIG_FLASH_CFI_LEGACY. Correct M54451EVB and
M54455EVB env settings in configuration file.
The user manuals recommend 7.
Signed-off-by: Kurt Mahan <kmahan@freescale.com>
Acked-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
M5249EVB, M5271EVB, M5272C3, M5275EVB and M5282EVB platforms
uart baudrate increase from 19200 to 115200 bps
