Remove unnecessary board specifc config files for
zynq boards(microzed, picozed, ZC770(all), zed) and point
to zynq common config file.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Enable config CONFIG_SYS_NO_FLASH through defconfig
for all zynq boards.
OF_CONTROL is setup by default and memory reading is done via DT. Remove
all config files with memory references.
Add Arasan SDHCI entry to Kconfig and fix all references.
Clean config file.
Reviewed-by: Jagan Teki <jteki@openedev.com>
There are already Kconfig options for SPI drivers, but we
have not moved them from config.h to defconfig files. This
commit does this in a batch.
Update this driver to use driver model and change all users.
Add xm011 DTS file and related configs and configurations.
This option specifies the default Device Tree used for the run-time
configuration of U-Boot.
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Enabled default dts files on respective pre-board config
files this is way MAKEALL will works. and it's upto user
to build specific dts by specifying at build time.
$ make zynq_zc70x_config
$ make --> with default dts zynq-zc702.dts
or
$ make DEVICE_TREE=zynq-zc702 --> Same configuration with zynq-zc706.dts
Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
ZC770 is a complete development board based on the Xilinx Zynq-7000
All Programmable SoC, similar to ZC70x board but which has four
different daughter cards, like XM010, XM011, XM012 and XM013
ZC770 XM012:
- 1GB DDR3
- 64MiB Numonyx NOR flash
- USB-UART
Cc: Stefan Roese <sr@denx.de>
ZC770 XM013:
- 1GB DDR3
- 128 Mb Quad-SPI Flash(dual parallel)
- USB-UART
ZC770 XM010:
- 1Gb DDR3
- 1Mb SST SPI flash
- 8 Mb SST SI flash
- Full size SD/MMC card cage
- 10/100/1000 Ethernet
- USB-UART
