path: root/include/configs/zynq.h
2013-08-07zynq: Enable CONFIG_ZYNQ_SPIJagannadha Sutradharudu Teki
Tested spi on zynq board with sst flash by enabling CONFIG_ZYNQ_SPI. sf probe 1:1 0 0 SF: Detected SST25WF080 with page size 4 KiB, total 1 MiB Signed-off-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com> Acked-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2013-05-06fpga: zynq: Add support for loading bitstreamMichal Simek
Devcfg device requires to load bitstream in binary format. But u-boot also has an option for loading bitstream in bit format. Let's handle both cases by zynqpl driver. Also add suport for loading partial bitstreams. The first driver version was done by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30i2c: zynq: Add support for Xilinx ZynqMichal Simek
Support Xilinx Zynq i2c controller. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Heiko Schocher <hs@denx.de> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30mmc: Add support for Xilinx Zynq sdhci controllerMichal Simek
Add support for SD, MMC and eMMC card on Xilinx Zynq. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30net: gem: Pass phy address to initDavid Andrey
Pass the PHY address to the driver init to allow parallel use of both interfaces Signed-off-by: David Andrey <david.andrey@netmodule.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30zynq: Move macros to hardware.hMichal Simek
Add all fixed addresses to hardware.h and change petalinux configuration to support this. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-04-30zynq: Move scutimer baseaddr to hardware.hMichal Simek
Move baseaddr to hardware.h to be shared between configurations. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-02-07xilinx: zynq: Enable DCC and create new zynq_dcc boardMichal Simek
Enable DCC driver for arm zynq platform to be compiled. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from config filesMarek Vasut
Remove any notion of CONFIG_SERIAL_MULTI from board config files. Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless to specify this config option in the board config files. Therefore remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-04xilinx: Add new Zynq boardMichal Simek
Add support for Xilinx Zynq board. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Marek Vasut <marex@denx.de> CC: Joe Hershberger <joe.hershberger@gmail.com>
