Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Marek Vasut <marek.vasut@gmail.com>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Replace the cache related CONFIG flags with more meaningful
names. Following are the changes:
CONFIG_L2_OFF -> CONFIG_SYS_L2CACHE_OFF
CONFIG_SYS_NO_ICACHE -> CONFIG_SYS_ICACHE_OFF
CONFIG_SYS_NO_DCACHE -> CONFIG_SYS_DCACHE_OFF
Signed-off-by: Aneesh V <aneesh@ti.com>
V2:
* Changed CONFIG_L2_OFF -> CONFIG_SYS_NO_L2CACHE
V4:
* Changed all three flags to the final names suggested as above
and accordingly changed the commit message
For ARM systems, before ELF relocation was introduced,
CONFIG_SKIP_RELOCATE_UBOOT coul be used to prevent *COPYING* the
U-Boot image from whereever it was loaded to it's link address
(CONFIG_SYS_TEXT_BASE). The name was badly chosen, as no relocation
was performed at all, it was just a memcpy().
With ELF relocation, this does not work like that any more, and
related boards need to be fixed anyway. So don't keep this relict any
longer.
Tested-by: Heiko Schocher <hs@denx.de>
Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
There is more and more usage of printing 64bit values,
so enable this feature generally, and delete the
CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL
defines.
All in-tree boards that use this controller have CONFIG_NET_MULTI
added
Also:
- changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111
- cleaned up line lengths
- modified all boards that override weak function in this driver
- modified all eeprom standalone apps to work with new driver
- updated blackfin standalone EEPROM app after testing
Commit 8d2effea added a warning for configurations that use NAND
without defining the (then necessary) CONFIG_SYS_64BIT_VSPRINTF but
failed to fix the affected boards.
This patch covers the non-PPC boards that were missed in the previous
patch (commit 170c1972).
unify arm cache management except for non standard cache as ARM7TDMI
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
introduce new macro CONFIG_PXA_MMC to activate it
Fixing the get_timer function to return time in miliseconds instead of
ticks. Also fixed PXA boards to use the conventional value of 1000 for
CONFIG_SYS_HZ.
Signed-off-by: Micha Kalfon <smichak.uv@gmail.com>
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command
rather than a generic "env" command, or anything else related to the
environment. So, let's make sure the define is named accordingly.
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and
changes the default from 8 to 1 for the legacy and the new MTD
NAND layer. This allows to remove all NAND_MAX_CHIPS definitions
in the board config files because none of the boards use multi
chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440
define
#define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE
but that's bogus and did not work anyhow.
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
Explicitly add in default CONFIG_BOOTP_* options where cmd_confdefs.h
used to be included but CONFIG_BOOTP_MASK was not defined.
Remove lingering references to CFG_CMD_* symbols.
files.
we only see 64MB.
Register Definitions.
It doesn't run yet.
