path: root/include/configs/yucca.h
2010-09-28Merge branch 'next' of /home/wd/git/u-boot/nextWolfgang Denk
Conflicts: include/ppc4xx.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-09-23ppc4xx: Use common NS16550 driver for PPC4xx UARTStefan Roese
This patch removes the PPC4xx UART driver. Instead the common NS16550 driver is used, since all PPC4xx SoC's use this peripheral device. The file 4xx_uart.c now only implements the UART clock calculation function which also sets the SoC internal UART divisors. All PPC4xx board config headers are changed to use this common NS16550 driver now. Tested on these boards: acadia, canyonlands, katmai, kilauea, sequoia, zeus Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-21POST cleanup.Michael Zaidman
- Revives POST for blackfin arch; - Removes redundant code: arch/blackfin/lib/post.c arch/powerpc/cpu/ppc4xx/commproc.c arch/powerpc/cpu/mpc512x/common.c - fixes up the post_word_{load|store} usage. Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de> List of the maintainers of the affected by patch boards: Cc: Stephan Linz <linz@li-pro.net> Cc: Denis Peter <d.peter@mpl.ch> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Larry Johnson <lrj@acm.org> Cc: Feng Kan <fkan@amcc.com>
2010-04-14ppc4xx: Add option for PPC440SPe ports without old Rev. A supportStefan Roese
The 440SPe Rev. A is quite old and newer 440SPe boards don't need support for this CPU revision. Since removing support for this older version simplifies the creation for newer U-Boot ports, this patch now enables 440SPe > Rev. A support by creating the CONFIG_440SPE_REVA define. By defining this in the board config header, Rev. A will still be supported. Otherwise (default for newer board ports), Rev. A will not be supported. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-09ppc4xx: Consolidate 4xx PCIe board specific configurationStefan Roese
This patch consolidates the PPC4xx board specific PCIe configuration code. This way the duplicated code is removed. Boards can implement a special, non standard behaviour (e.g. number of PCIe slots, etc) by overriding the weak default functions. Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-10rename CFG_ENV_IS_IN_NVRAM in CONFIG_ENV_IS_IN_NVRAMJean-Christophe PLAGNIOL-VILLARD
2008-06-06ppc4xx: Unify AMCC's board config files (part 3/3)Stefan Roese
This patch series unifies the AMCC eval board ports by introducing a common include header for all AMCC eval boards: include/configs/amcc-common.h This header now includes all common configuration options/defines which are removed from the board specific headers. The reason for this is ease of maintenance and unified look and feel of all AMCC boards. Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx: Remove implementations of testdram()Stefan Roese
This patch removes the used testdram() implementations of the board that are maintained by myself. Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-08ppc4xx: Add fdt support to all remaining AMCC PPC4xx eval boardsStefan Roese
This patch adds fdt (flattened device tree) support to all remaining AMCC eval boards. Most newer boards already support device tree. With this patch, all AMCC boards now enable device tree passing from U-Boot to Linux arch/powerpc kernels. Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-06Replace "run load; run update" with conditionalized "run load update".Detlev Zundel
The latter version stops when "run load" fails for whatever reasons rendering the combination *a lot* more secure. Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2007-10-31ppc4xx: Remove cache definition from 4xx board config filesStefan Roese
All 4xx board config files don't need the cache definitions anymore. These are now defined in common headers. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Dynamic configuration of 4xx PCIe mode as root or endpoint modeStefan Roese
This patch adds support for dynamic configuration of PCIe ports for the AMCC PPC4xx boards equipped with PCIe interfaces. These are the PPC440SPe boards Yucca & Katmai and the 405EX board Kilauea. This dynamic configuration is done via the "pcie_mode" environement variable. This variable can be set to "EP" or "RP" for endpoint or rootpoint mode. Multiple values can be joined via the ":" delimiter. Here an example: pcie_mode=RP:EP:EP This way, PCIe port 0 will be configured as rootpoint, PCIe port 1 and 2 as endpoint. Per default Yucca will be configured as: pcie_mode=RP:EP:EP Per default Katmai will be configured as: pcie_mode=RP:RP:REP Per default Kilauea will be configured as: pcie_mode=RP:RP Signed-off-by: Tirumala R Marri <tmarri@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: 4xx_pcie: More general cleanup and 405EX PCIe support addedStefan Roese
2007-10-31ppc4xx: 4xx_pcie: Change CFG_PCIE_MEMSIZE to 128MB on Yucca & KatmaiStefan Roese
128MB seems to be the smallest possible value for the memory size for on PCIe port. With this change now the BAR's of the PCIe cards are accessible under U-Boot. One big note: This only works for PCIe port 0 & 1. For port 2 this currently doesn't work, since the base address is now 0xc0000000 (0xb0000000 + 2 * 0x08000000), and this is already occupied by CFG_PCIE0_CFGBASE. But solving this issue for port 2 would mean to change the base addresses completely and this change would have too much impact right now. This patch adds debug output to the 4xx pcie driver too. Signed-off-by: Stefan Roese <sr@denx.de>
2007-09-07[PPC440SPe] PCIe environment settings for Katmai and YuccaGrzegorz Bernacki
- 'pciconfighost' is set by default in order to be able to scan bridges behind the primary host/PCIe - 'pciscandelay' env variable is recognized to allow for user-controlled delay before the PCIe bus enumeration; some peripheral devices require a significant delay before they can be scanned (e.g. LSI8408E); without the delay they are not detected Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
2007-09-07[PPC440SPe] Improve PCIe configuration space accessGrzegorz Bernacki
- correct configuration space mapping - correct bus numbering - better access to config space Prior to this patch, the 440SPe host/PCIe bridge was able to configure only the first device on the first bus. We now allow to configure up to 16 buses; also, scanning for devices behind the PCIe-PCIe bridge is supported, so peripheral devices farther in hierarchy can be identified. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
2007-08-18lib_ppc: make board_add_ram_info weakKim Phillips
platforms wishing to display RAM diagnostics in addition to size, can do so, on one line, in their own board_add_ram_info() implementation. this consequently eliminates CONFIG_ADD_RAM_INFO. Thanks to Stefan for the hint. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-07-10include/configs/[p-z]* + misc: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various [v-z]* named board config ↵Jon Loeliger
files. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-06-25ppc4xx: Add pci_pre_init() for 405 boardsStefan Roese
This patch removes the CFG_PCI_PRE_INIT option completely, since it's not needed anymore with the patch from Matthias Fuchs with the "weak" pci_pre_init() implementation. Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-31ppc4xx: Change Yucca config file to support ECCStefan Roese
With the updated 44x DDR2 driver the Yucca board now supports ECC generation and checking. Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-08[PATCH] Update AMCC Yucca 440SPe eval board supportStefan Roese
The AMCC Yucca now uses the common 440SP(e) DDR SPD code for DDR inititializition. This includes DDR auto calibration and support for different DIMM modules, instead of the fixed setup used in the earlier version. Signed-off-by: Stefan Roese <sr@denx.de>
2007-02-07[PATCH] Update some AMCC 4xx board config files (set initrd_high)Stefan Roese
Some boards that can have more than 768MBytes of SDRAM need to set "initrd_high", so that the initrd can be accessed by the Linux kernel. Signed-off-by: Stefan Roese <sr@denx.de>
2006-08-17Cleanup debug code for yucca board.Wolfgang Denk
2006-08-13Merge with /home/sr/git/u-boot/denxWolfgang Denk
2006-08-11Fix PCI-Express on PPC440SPe rev. A.Rafal Jaworowski
2006-08-10Add support for PCI-Express on PPC440SPe (Yucca board).Rafal Jaworowski
2006-08-07Add commandline history support to all AMCC eval boardsStefan Roese
Patch by Stefan Roese, 07 Aug 2006
2006-07-06Fix timer problems on AMCC yucca board.Marian Balakowicz
Set Timer Clock Select to use CPU clock as a timer input source.
2006-07-05Bring yucca config more in line with other AMCC boards.Wolfgang Denk
2006-07-04Add system memory to the PCI region list for AMCC PPC44x CPUs.Marian Balakowicz
Enabled it for Yucca board.
2006-07-03Cleanup config file and bootup output for Yucca board.Marian Balakowicz
2006-06-30Add support for AMCC 440SPe CPU based eval board (Yucca).Marian Balakowicz
