path: root/include/configs/yosemite.h
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-21eeprom: Zap CONFIG_SYS_I2C_MULTI_EEPROMSMarek Vasut
This option only complicates the code unnecessarily, just use CONFIG_SYS_DEF_EEPROM_ADDR as the default address if there are only five arguments to eeprom {read/write} if this is defined. If CONFIG_SYS_DEF_EEPROM_ADDR is not defined, we mandate all six arguments. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Cc: Heiko Schocher <hs@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de>
2014-01-24powerpc: ppc4xx: remove redundant CONFIG_4xx definitionMasahiro Yamada
We do not have to define CONFIG_4xx in board config headers because it is defined in arch/powerpc/cpu/ppc4xx/config.mk. include/configs/JSE.h defines "CONFIG_4x", not "CONFIG_4xx". I believe it is a typo because "CONFIG_4x" is not used at all in other files. So, I also deleted "CONFIG_4x" in include/configs/JSE.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, ppc4xx_i2c: switch to new multibus/multiadapter supportDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2010-09-23ppc4xx: Use common NS16550 driver for PPC4xx UARTStefan Roese
This patch removes the PPC4xx UART driver. Instead the common NS16550 driver is used, since all PPC4xx SoC's use this peripheral device. The file 4xx_uart.c now only implements the UART clock calculation function which also sets the SoC internal UART divisors. All PPC4xx board config headers are changed to use this common NS16550 driver now. Tested on these boards: acadia, canyonlands, katmai, kilauea, sequoia, zeus Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-06-06ppc4xx: Unify AMCC's board config files (part 3/3)Stefan Roese
This patch series unifies the AMCC eval board ports by introducing a common include header for all AMCC eval boards: include/configs/amcc-common.h This header now includes all common configuration options/defines which are removed from the board specific headers. The reason for this is ease of maintenance and unified look and feel of all AMCC boards. Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-08ppc4xx: Add fdt support to all remaining AMCC PPC4xx eval boardsStefan Roese
This patch adds fdt (flattened device tree) support to all remaining AMCC eval boards. Most newer boards already support device tree. With this patch, all AMCC boards now enable device tree passing from U-Boot to Linux arch/powerpc kernels. Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-08ppc4xx: Add device tree support to AMCC YosemiteIra Snyder
Add support for booting with a device tree blob. This is needed to boot ARCH=powerpc kernels. Also add support for setting the eth0 mac address via the ethaddr variable. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Stefan Roese <sr@denx.de>
2008-03-06Replace "run load; run update" with conditionalized "run load update".Detlev Zundel
The latter version stops when "run load" fails for whatever reasons rendering the combination *a lot* more secure. Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2008-02-04ppc4xx: Fix problem with init-ram bigger than 4k on 440 platformsStefan Roese
2007-12-04ppc4xx: Yosemite/Yellowstone: Add DTT AD7414 supportStefan Roese
2007-10-31ppc4xx: Remove cache definition from 4xx board config filesStefan Roese
All 4xx board config files don't need the cache definitions anymore. These are now defined in common headers. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-15ppc4xx: Fix incorrect 33/66MHz PCI clock log-message on Sequoia & YosemiteStefan Roese
The BCSR status bit for the 66MHz PCI operation was correctly addressed (MSB/LSB problem). Now the correct currently setup PCI frequency is displayed upon bootup. This patch also fixes this problem on Rainier & Yellowstone, since these boards use the same souce code as Sequoia & Yosemite do. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-07Merge with git://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2007-07-10include/configs/[p-z]* + misc: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various [v-z]* named board config ↵Jon Loeliger
files. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-06-25Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-06-25ppc4xx: Add pci_pre_init() for 405 boardsStefan Roese
This patch removes the CFG_PCI_PRE_INIT option completely, since it's not needed anymore with the patch from Matthias Fuchs with the "weak" pci_pre_init() implementation. Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-22Coding stylke cleanup; rebuild CHANGELOGWolfgang Denk
2007-06-15ppc4xx: Clean up 440 exceptions handlingGrzegorz Bernacki
- Introduced dedicated switches for building 440 and 405 images required for 440-specific machine instructions like 'rfmci' etc. - Exception vectors moved to the proper location (_start moved away from the critical exception handler space, which it occupied) - CriticalInput now serviced (with default handler) - MachineCheck properly serviced (added a dedicated handler and return subroutine) - Overall cleanup of exceptions declared with STD_EXCEPTION macro (unused, unhandled and those not relevant for 4xx were eliminated) - Eliminated Linux leftovers, removed dead code Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Signed-off-by: Rafal Jaworowski <raj@semihalf.com> Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-06USB: ohci fixes and cleanup for ppc4xx and yosemite board.Markus Klotzbuecher
2007-04-23Merge with git://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2007-03-28Merge some AMCC make targets to keep the top-level Makefile smallerStefan Roese
2007-03-23Merge with git://www.denx.de/git/u-boot.git#testing-USBMarkus Klotzbuecher
2007-01-30[PATCH] Merge Yosemite & Yellowstone board portsStefan Roese
Now the AMCC eval boards Yosemite (440EP) and Yellowstone (440GR) share one config file and all board specific files. This way we don't have to maintain two different sets of files for nearly identical boards. Signed-off-by: Stefan Roese <sr@denx.de>
2007-01-13[PATCH] Update Yosemite (440EP) to display board rev and PCI bus speedStefan Roese
Now the board revision and the current PCI bus speed are printed after the board message. Also the EBC initialising is now done via defines in the board config file. Signed-off-by: Stefan Roese <sr@denx.de>
2006-11-27Merge with /home/mk/git/u-boot-generic_ohci#generic_ohciWolfgang Denk
2006-11-27Introduced the configuration option CONFIG_USB_OHCI_NEW in order to be ableMarkus Klotzbuecher
to choose between the old and the generic OHCI drivers.
2006-11-27Modified the mpc5xxx and the ppc4xx cpu to use the generic OHCI driverMarkus Klotzbuecher
and adapted board configs TQM5200 and yosemite accordingly. This commit also makes the maximum number of root hub ports configurable (CFG_USB_OHCI_MAX_ROOT_PORTS).
2006-10-07Add CONFIG_BOARD_RESET to configure board specific reset functionStefan Roese
Patch by Stefan Roese, 07 Oct 2006
2006-09-07Add support for AMCC Sequoia PPC440EPx eval boardStefan Roese
- Add support for PPC440EPx & PPC440GRx - Add support for PPC440EP(x)/GR(x) NAND controller in cpu/ppc4xx directory - Add NAND boot functionality for Sequoia board, please see doc/README.nand-boot-ppc440 for details - This Sequoia NAND image doesn't support environment in NAND for now. This will be added in a short while. Patch by Stefan Roese, 07 Sep 2006
2006-08-07Add commandline history support to all AMCC eval boardsStefan Roese
Patch by Stefan Roese, 07 Aug 2006
