path: root/include/configs/xtfpga.h
2016-08-15xtensa: add support for the 'xtfpga' evaluation boardChris Zankel
The 'xtfpga' board is actually a set of FPGA evaluation boards that can be configured to run an Xtensa processor. - Avnet Xilinx LX60 - Avnet Xilinx LX110 - Avnet Xilinx LX200 - Xilinx ML605 - Xilinx KC705 These boards share the same components (open-ethernet, ns16550 serial, lcd display, flash, etc.). Signed-off-by: Chris Zankel <chris@zankel.net> Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
