unify arm cache management except for non standard cache as ARM7TDMI
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Currently the mtdparts commands are included in the jffs2 command support.
This doesn't make sense anymore since other commands (e.g. UBI) use this
infrastructure as well now. This patch separates the mtdparts commands from
the jffs2 commands making it possible to only select mtdparts when no JFFS2
support is needed.
introduce new macro CONFIG_PXA_MMC to activate it
Fixing the get_timer function to return time in miliseconds instead of
ticks. Also fixed PXA boards to use the conventional value of 1000 for
CONFIG_SYS_HZ.
Signed-off-by: Micha Kalfon <smichak.uv@gmail.com>
missing migration from "Cleanup of some init functions"
in c837dcb1a316745092567bfe4fb266d0941884ff
Explicitly add in default CONFIG_BOOTP_* options where cmd_confdefs.h
used to be included but CONFIG_BOOTP_MASK was not defined.
Remove lingering references to CFG_CMD_* symbols.
files.
Old, obsolete and duplicated code was cleaned up and replace by the
new partitioning method. There are two possible approaches now:
* define a single, static partition
* use mtdparts command line option and dynamic partitioning
Default is static partitioning.
- remove all references to CONFIG_INIT_CRITICAL for ARM based boards
- introduce two new configuration options instead:
CONFIG_SKIP_LOWLEVEL_INIT and CONFIG_SKIP_RELOCATE_UBOOT
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL
- rename memsetup into lowlevel_init (function name and source files)
Add support for Exys XSEngine board
Some code cleanup.
