path: root/include/configs/xilinx_zynqmp_zc1751_xm019_dc5.h
2016-06-06ARM64: zynqmp: Add support for standard distro boot commandsMichal Simek
Nand and QSPI are not defined now but this will be extended. Based on selected bootmode boot_targets are rewritten. Patch also contains detection if variables are saved. If yes don't rewrite boot_targets variable. Also move variable setup to the end of file because SCSI needs to be defined before others macros are using it. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Alexander Graf <agraf@suse.de>
2016-04-13ARM64: zynqmp: Use i2c cadence DM driverMichal Simek
Use i2c cadence DM driver for all zynqmp targets except ZCU102 because I2C muxes and PCA953x are not supported in the tree yet. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2016-04-13ARM64: zynqmp: Add support for zc1751 with DC cardsMichal Simek
Support ZynqMP zc1751 with DC cards. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
