path: root/include/configs/xilinx_zynqmp.h
2017-05-22Kconfig: Drop CONFIG_CMD_ENVSimon Glass
This option is not used in U-Boot. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_EEPROM et al to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_EEPROM CONFIG_CMD_EEPROM_LAYOUT CONFIG_EEPROM_LAYOUT_HELP_STRING Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Rework Kconfig logic slightly, define EEPROM location on TI eval platforms] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-02-08cmd: move CONFIG_CMD_UNZIP and CONFIG_CMD_ZIP to KconfigMasahiro Yamada
CONFIG_CMD_ZIP is not defined by any board. I am moving CONFIG_CMD_UNZIP to defconfig files except UniPhier SoC family. I am the maintainer of UniPhier platform, so I know "select CMD_UNZIP" is better for this platform. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Michal Simek <michal.simek@xilinx.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Ryan Harkin <ryan.harkin@linaro.org> Tested-by: Ryan Harkin <ryan.harkin@linaro.org>
2017-01-31mmc: zynq: rename CONFIG_ZYNQ_SDHCI to CONFIG_MMC_SDHCI_ZYNQMasahiro Yamada
Make the naming scheme consistent; all SDHCI-base drivers prefixed with CONFIG_MMC_SDHCI_. While we are here, add "depends on ARCH_ZYNQ || ARCH_ZYNQMP". Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-17drivers: usb: Add USB_XHCI_ZYNQMP to KconfigMichal Simek
Move symbol to Kconfig to cleanup configuration file. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-01-14Convert CONFIG_SPL_RAM_DEVICE to defconfigStefan Agner
This converts the following to Kconfig: CONFIG_SPL_RAM_DEVICE Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2017-01-10ARM64: zynqmp: Enable fastboot for first SD/MMC/EMMC deviceSiva Durga Prasad Paladugu
DNL numbers are not changed that's why fastboot needs to be called with -i parameter (Xilinx vendor id). - Show available devices sudo fastboot -i 0x03fd devices xilinx_zynqmp_zcu100 fastboot - Stop fastboot and go back to U-Boot prompt sudo fastboot -i 0x03fd continue - Reboot the board sudo fastboot -i 0x03fd reboot - Get internal variables sudo fastboot -i 0x3fd getvar bootloader-version bootloader-version: U-Boot 2016.07-00026-g19bd53044817 sudo fastboot -i 0x3fd getvar downloadsize downloadsize: 0x06000000 sudo fastboot -i 0x3fd getvar version version: 0.4 (regular variables needs to have fastboot. prefix - there is also serialno variable which should be define as serial#) - Format SD/MMC/EMMC card sudo fastboot -i 0x3fd oem format - Write images to boot and Linux partition sudo fastboot -i 0x3fd flash boot sd.img sudo fastboot -i 0x3fd flash Linux os.img - Creating sd.img or os.img $ dd if=/dev/zero of=sd.img bs=1024 count=1024 $ mkfs.vfat sd.img $ mkdir sd-mount $ mount -o loop sd.img sd-mount $ echo foo > sd-mount/bar $ umount sd-mount partitions setting should be checked by running gpt command. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-01-10ARM64: zynqmp: Add support to save env to FATSiva Durga Prasad Paladugu
Add support to save environment as a file of FAT filesystem on to SD card. The file will be saved with name uEnv.txt. This environment will be retrieved during boot. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-01-10ARM64: zynqmp: Increase environment size to 32KSiva Durga Prasad Paladugu
Increase environment size to 32K as the current default environment itself is greater than 4K. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-12-29mmc: move CONFIG_SDHCI to Kconfig, renaming to CONFIG_MMC_SDHCIMasahiro Yamada
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI. My motivation for the rename is, ultimately, to make all the MMC options prefixed with MMC_ and SDHCI options with MMC_SDHCI_, like Linux. This commit was created as follows: [1] Rename the config option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g' [2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig [3] run "tools/moveconfig.py -y MMC_SDHCI" [4] add "depends on MMC_SDHCI" to existing SDHCI driver entries Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-20block: Move ceva driver to DMMichal Simek
This patch also includes ARM64 zynqmp changes: - Remove platform non DM initialization - Remove hardcoded sata base address Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-12-09Revert "Merge branch 'master' of git://www.denx.de/git/u-boot-microblaze"Tom Rini
This reverts commit 3edc0c252257e4afed163a3a74aba24a5509b198, reversing changes made to bb135a0180c31fbd7456021fb9700b49bba7f533.
2016-12-08block: Move ceva driver to DMMichal Simek
This patch also includes ARM64 zynqmp changes: - Remove platform non DM initialization - Remove hardcoded sata base address Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org> Series-to: sjg, agraf@suse.de Series-cc: uboot Series-version: 4 Series-changes: 2 - make ceva_init_sata static - Move SATA_CEVA to defconfig - Initalized max_lun and max_id platdata Series-changes: 3 - Extend Kconfig help description - sort dm.h - Remove SPL undefinition from board file - Fix Kconfig dependecies
2016-12-03cmd: move CMD_PXE to KconfigYann E. MORIN
Currently, CMD_PXE is forcibly enabled in config_distro_defaults.h, so that general purpose distributions can rely on it being defined. This header is included, under conditions or not, by various archs or famillies of archs / SoCs. However, it is very possible that boards based on those SoCs will not have a physical ethernet connector at all, even if the have a MAC; for example, the Nanopi Neo AIR (sunxi H3) does not. It is also possible that network booting is absolutely not necessary for a device. However, it is not possible to disable the PXE command, as it is forcibly enabled and is non-configurable. But it turns out we already have a config option to build a distro-ready image, in the name of DISTRO_DEFAULTS. Move CMD_PXE out of the hard-coded config_distro_defaults.h into a Kconfig option, that gets selected by DISTRO_DEFAULTS when it is set. Signed-off-by: "Yann E. MORIN" <yann.morin.1998@free.fr> Cc: Joe Hershberger <joe.hershberger@ni.com> [trini: Make it select MENU, run moveconfig.py] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-03cmd: Convert CMD_BOOTMENUTom Rini
Also convert MENU while we're in here. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-02ARM: zynq(mp): remove unneeded CONFIG_USB_MAX_CONTROLLER_COUNT definesMasahiro Yamada
ARCH_ZYNQ(MP) selects DM_USB, where CONFIG_USB_MAX_CONTROLLER_COUNT is not used. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Moritz Fischer <moritz.fischer@ettus.com> Acked-by: Michal Simek <michal.simek@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-10-14spl: move SPL_OS_BOOT to KconfigHeiko Schocher
Move SPL_OS_BOOT to Kconfig and cleanup existing uses. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-09-27dfu: Migrate to KconfigTom Rini
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for CMD_DFU (as we must have the DFU command enabled to do anything DFU). Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add options for all of the back end choices that DFU can make use of. Cc: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Lukasz Majewski <l.majewski@samsung.com>
2016-09-22ARM64: zynqmp: Use the same name for atf image everywhereMichal Simek
Use atf-uboot.ub image instead of atf.ub. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-09-22ARM64: zynqmp: Enable CONFIG_AHCI via KconfigMichal Simek
Move CONFIG_AHCI to defconfig. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-09-22ARM64: zynqmp: Add support for DFU from SPLMichal Simek
SPL needs to have bigger stack size because of USB. Simple malloc needs to be disabled because dfu code requires different allocation functions. There is no space in OCM that's why random place in DDR is used. BOOTD must be disabled because it is causing compilation error. All variables are disabled and used only variables valid for DFU because they are simple huge. Including automatic variables added by CONFIG_ENV_VARS_UBOOT_CONFIG. Hardcode addresses for u-boot, atf, kernel and dtb just for SPL DFU code. Enable SPL DFU for zcu100. Create new usb_dfu_spl variable just to run Linux kernel loaded in SPL. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-09-22ARM64: zynqmp: Move BSS location to the beginning of ramMichal Simek
With SPL_DFU support memory layout needs to be cleanup that's why move bss to the start of memory. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-09-22ARM64: zynqmp: Wire up both USBs available on ZynqMPMichal Simek
The second USB wasn't enabled. This patch fixes it. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_FAT_SUPPORT to KconfigSimon Glass
2016-08-26ARM: Move SYS_CACHELINE_SIZE over to KconfigTom Rini
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all cases we are mirroring the values used by the Linux Kernel here. Also, so long as (and in this case, it is true) we implement flushes in hunks that are no larger than the smallest implementation (and given that we mirror the Linux Kernel, again we are fine) it is OK to align higher. The biggest changes here are that we always use 64 bytes for CPU_V7 even if for example the underlying core is only 32 bytes (this mirrors Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the Linux Kernel) as we do not need multi-platform support (to this degree) and only the Cavium ThunderX 88xx series has a use for such large alignment. Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Stefan Roese <sr@denx.de> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Vaibhav Hiremath <hvaibhav@ti.com> Acked-by: Lokesh Vutla <lokeshvutla@ti.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: Stefan Agner <stefan.agner@toradex.com> Acked-by: Heiko Schocher <hs@denx.de> Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com> Cc: Peter Griffin <peter.griffin@linaro.org> Acked-by: Paul Kocialkowski <contact@paulk.fr> Cc: Anatolij Gustschin <agust@denx.de> Acked-by: "Pali Rohár" <pali.rohar@gmail.com> Cc: Adam Ford <aford173@gmail.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Nishanth Menon <nm@ti.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Robert Baldyga <r.baldyga@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Thomas Weber <weber@corscience.de> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: David Feng <fenghua@phytium.com.cn> Cc: Alison Wang <b18965@freescale.com> Cc: Michal Simek <michal.simek@xilinx.com> Cc: Simon Glass <sjg@chromium.org> Cc: York Sun <york.sun@nxp.com> Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com> Cc: Mingkai Hu <mingkai.hu@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Aneesh Bansal <aneesh.bansal@freescale.com> Cc: Saksham Jain <saksham.jain@nxp.com> Cc: Qianyu Gong <qianyu.gong@nxp.com> Cc: Wang Dongsheng <dongsheng.wang@nxp.com> Cc: Alex Porosanu <alexandru.porosanu@freescale.com> Cc: Hongbo Zhang <hongbo.zhang@nxp.com> Cc: tang yuantian <Yuantian.Tang@freescale.com> Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com> Cc: Josh Wu <josh.wu@atmel.com> Cc: Bo Shen <voice.shen@atmel.com> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Hannes Schmelzer <oe5hpm@oevsv.at> Cc: Thomas Chou <thomas@wytron.com.tw> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Sam Protsenko <semen.protsenko@linaro.org> Cc: Bin Meng <bmeng.cn@gmail.com> Cc: Christophe Ricard <christophe-h.ricard@st.com> Cc: Anand Moon <linux.amoon@gmail.com> Cc: Beniamino Galvani <b.galvani@gmail.com> Cc: Carlo Caione <carlo@endlessm.com> Cc: huang lin <hl@rock-chips.com> Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Cc: Xu Ziyuan <xzy.xu@rock-chips.com> Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com> Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar> Cc: Kever Yang <kever.yang@rock-chips.com> Cc: Samuel Egli <samuel.egli@siemens.com> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Ian Campbell <ijc@hellion.org.uk> Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com> Cc: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Andre Przywara <andre.przywara@arm.com> Cc: Bernhard Nortmann <bernhard.nortmann@web.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Ben Whitten <ben.whitten@gmail.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Alexander Graf <agraf@suse.de> Cc: Sekhar Nori <nsekhar@ti.com> Cc: Vitaly Andrianov <vitalya@ti.com> Cc: "Andrew F. Davis" <afd@ti.com> Cc: Murali Karicheri <m-karicheri2@ti.com> Cc: Carlos Hernandez <ceh@ti.com> Cc: Ladislav Michl <ladis@linux-mips.org> Cc: Ash Charles <ashcharles@gmail.com> Cc: Mugunthan V N <mugunthanvnm@ti.com> Cc: Daniel Allred <d-allred@ti.com> Cc: Gong Qianyu <Qianyu.Gong@freescale.com> Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Chin Liang See <clsee@altera.com> Tested-by: Stephen Warren <swarren@nvidia.com> Acked-by: Paul Kocialkowski <contact@paulk.fr>
2016-08-20cmd: booti: move CONFIG_CMD_BOOTI to KconfigMasahiro Yamada
This command is used to boot ARM64 Linux. I made DISTRO_DEFAULTS select this option for ARM64 to respect include/config_distro_defaults.h. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-02ARM64: zynqmp: Fix stack pointer initializationSoren Brinkmann
This partly reverts commit: "ARM64: zynqmp: Add SPL support support" (sha1: e6a9ed04e78cf87ec97e306fa4e7a1669ef98df6) Stack can rewrite ATF code. Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-08-02ARM64: zynqmp: Define config USB_STORAGE through defconfigMichal Simek
Define config USB_STORAGE through defconfig for all Xilinx ZynqMP boards. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
Modified: configs/ls1012afrdm_qspi_defconfig configs/ls1012aqds_qspi_defconfig configs/ls1012ardb_qspi_defconfig include/configs/ls1012afrdm.h include/configs/ls1012aqds.h include/configs/ls1012ardb.h Signed-off-by: Tom Rini <trini@konsulko.com>
2016-06-06ARM64: zynqmp: Add support for standard distro boot commandsMichal Simek
Nand and QSPI are not defined now but this will be extended. Based on selected bootmode boot_targets are rewritten. Patch also contains detection if variables are saved. If yes don't rewrite boot_targets variable. Also move variable setup to the end of file because SCSI needs to be defined before others macros are using it. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Alexander Graf <agraf@suse.de>
2016-06-06ARM64: zynqmp: Remove CONFIG_BOOTP_SERVERIPAlexander Graf
When the CONFIG_BOOTP_SERVERIP option is set, we ignore all dhcp values for the tftp server and use our own serverip and file name instead. This is usually not what we want and I doubt it's set for a good reason on ZynqMP. It definitely hurts if we want to support uEFI PXE boot on it. So just remove the option for now. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06ARM64: zynqmp: Enable AHCI when CONFIG_SATA_CEVA is definedMichal Simek
Simplify zcu102 board file by moving CONFIG_AHCI enabling to common file. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-06-06ARM64: zynqmp: Enable Vitesse and RealTek ethernet physMichal Simek
Phys are available on zc1751-dc4 that's why enable them. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
